Client | Single Sign-on | Google Authenticator | User authentication steps |
802.1X | No | No | 1. 802.1X - Username/password 2. Web Authentication Portal - Username/password |
No | Yes | 1. 802.1X - Username/password 2. Web Authentication Portal - Username/password 3. Web Authentication Portal - Google Authenticator code | |
Yes (802.1X SSO) | No | 1. 802.1X - Username/password | |
Yes (802.1X SSO) | Yes | 1. 802.1X - Username/password 2. Web Authentication Portal - Google Authenticator code | |
Non-802.1X | No | No | 1. Web Authentication Portal - Username/password |
No | Yes | 1. Web Authentication Portal - Username/password 2. Web Authentication Portal - Google Authenticator code | |
Yes (Active Directory SSO) | No | None needed (if user is using Windows) | |
Yes (Active Directory SSO) | Yes | None needed (if user is using Windows) |
label | Description |
Global Setting | |
Enable Web Authentication | Select the check box to turn on the web authentication feature. Otherwise, clear the check box to turn it off. Once enabled, all network traffic is blocked until a client authenticates with the Zyxel Device through the specifically designated web portal or user agreement page. |
Web Portal General Setting | |
Enable Session Page | Select this to display a page showing information on the user session after s/he logs in. It displays remaining time with an option to renew or log out immediately. |
Logout IP | Specify an IP address that users can use to terminate their sessions manually by entering the IP address in the address bar of the web browser. |
User Agreement General Setting | |
Enforce data collection | Select this to require users to fill in their registration information (name, telephone number, address and email address) on the User Agreement (PC or mobile) page. |
Google Authentication Setting | Web authentication supports two-factor authentication using Google Authenticator. When enabled, the web authentication page first prompts the user to enter their username and password (factor 1), and then prompts them to enter a time-limited code from the Google Authenticator app (factor 2). It is also possible to configure two-factor authentication for VPN and admin users. The admin two-factor authentication settings override the web authentication two-factor authentication settings if both are configured. |
Valid Time | Enter the time limit (1-5 minutes) for the code from the Google Authenticator app to be used for login. |
Exceptional Services | Use this table to list services that users can access without logging in. Click Add to change the list’s membership. A screen appears. Available services appear on the left. Select any services you want users to be able to access without logging in and click the right arrow button to add them. The member services are on the right. Select any service that you want to remove from the member list, and click the left arrow button to remove them. Keeping DNS as a member allows users’ computers to resolve domain names into IP addresses. In the table, select one or more entries and click Remove to delete it or them. |
Web Authentication Policy Summary | Use this table to manage the Zyxel Device’s list of web authentication policies. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move | To move an entry to a different number in the list, click the Move icon. In the field that appears, specify the number to which you want to move the interface. |
# | This field is a sequential value showing the number of the profile. The profile order is not important. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Priority | This is the position of the authentication policy in the list. The priority is important as the policies are applied in order of priority. Default displays for the default authentication policy that the Zyxel Device uses on traffic that does not match any exceptional service or other authentication policy. You can edit the default rule but not delete it. |
Incoming Interface | This field displays the interface on which packets for this policy are received. |
Source | This displays the source address object, including geographic address and FQDN (group) objects, to which this policy applies. |
Destination | This displays the destination address object, including geographic address and FQDN (group) objects, to which this policy applies. |
Schedule | This field displays the schedule object that dictates when the policy applies. none means the policy is active at all times if enabled. |
Authentication | This field displays the authentication requirement for users when their traffic matches this policy. unnecessary - Users do not need to be authenticated. required - Users need to be authenticated. They must manually go to the login screen or user agreement page. The Zyxel Device will not redirect them to the login screen. force - Users need to be authenticated. The Zyxel Device automatically displays the login screen or user agreement page whenever it routes HTTP traffic for users who have not logged in yet. |
Authentication Type | This field displays the name of the authentication type profile used in this policy to define how users authenticate their sessions. It shows n/a if Authentication is set to unnecessary. |
Description | If the entry has a description configured, it displays here. This is n/a for the default policy. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Create new Object | Use to configure any new settings objects that you need to use in this screen. Select Address or Schedule. |
Enable Policy | Select this check box to activate the authentication policy. This field is available for user-configured policies. |
Description | Enter a descriptive name of up to 60 printable ASCII characters for the policy. Spaces are allowed. This field is available for user-configured policies. |
User Authentication Policy | Use this section of the screen to determine which traffic requires (or does not require) the senders to be authenticated in order to be routed. |
Incoming Interface | Select the interface on which packets for this policy are received. |
Source Address | Select a source address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Select any if the policy is effective for every source. This is any and not configurable for the default policy. |
Destination Address | Select a destination address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Select any if the policy is effective for every destination. This is any and not configurable for the default policy. |
Schedule | Select a schedule that defines when the policy applies. Otherwise, select none and the rule is always effective. This is none and not configurable for the default policy. |
Authentication | Select the authentication requirement for users when their traffic matches this policy. unnecessary - Users do not need to be authenticated. required - Users need to be authenticated. If Force User Authentication is selected, all HTTP traffic from unauthenticated users is redirected to a default or user-defined login page. Otherwise, they must manually go to the login screen. The Zyxel Device will not redirect them to the login screen. |
Single Sign-on | This field is available for user-configured policies that require Single Sign-On (SSO). Select this to have the Zyxel Device enable the SSO feature. You can set up this feature in the SSO screen. |
Force User Authentication | This field is available for user-configured policies that require authentication. Select this to have the Zyxel Device automatically display the login screen when users who have not logged in yet try to send HTTP traffic. |
Authentication Type | Select an authentication method. default-web-portal: the default login page built into the Zyxel Device. default-user-agreement: the default user agreement page built into the Zyxel Device. |
Single Sign-On using 802.1X | 802.1X Single Sign-On allows the Zyxel Device to use the same username and password for 802.1X WiFi authentication and web authentication. When enabled, a user logs into a WiFi network on the Zyxel Device that has 802.1X (WPA Enterprise) enabled. The Zyxel Device then reuses the 802.1X username and password for web authentication, preventing the user from having to log in twice. Active Directory Single Sign-On takes priority over 802.1X Single Sign-On, if both are enabled. |
Google Authenticator | Select Google Authenticator to first prompt a user to enter their username and password (factor 1), and then prompt the user to enter a time-limited code from the Google Authenticator app (factor 2). |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
Label | Description |
# | This field is a sequential value, and it is not associated with a specific entry. |
Name | This field displays the name of the profile. default-web-portal: the default login page built into the Zyxel Device. default-user-agreement: the default user agreement page built into the Zyxel Device. |
Type | This field displays the type of the web authentication page used by this profile. |
Web Page | This field displays whether this profile uses the default web authentication page built into the Zyxel Device (System Default Page) or custom web authentication pages from an external web server (External Page). |
Reset | Click Reset to return the screen to its last-saved settings. |
Type | Select the type of the web authentication page through which users authenticate their connections. If you select User Agreement, by agreeing to the policy of user agreement, users can access the Internet without a guest account. |
Profile Name | Enter a name for the profile. You can use up to 31 alphanumeric characters (A-Z, a-z, 0-9) and underscores (_). Spaces are not allowed. The first character must be a letter. |
The following fields are available if you set Type to Web Portal. | |
Internal Web Portal | Select this to use the web portal pages uploaded to the Zyxel Device. The login page appears whenever the web portal intercepts network traffic, preventing unauthorized users from gaining access to the network. |
Preview | Select to display the page you uploaded to the Zyxel Device in a new frame. |
Customize file | Select the file name of the web portal file in the Zyxel Device. |
External Web Portal | Select this to use a custom login page from an external web portal instead of the one uploaded to the Zyxel Device. You can configure the look and feel of the web portal page. |
Login URL | Specify the login page’s URL; for example, http://IIS server IP Address/login.html. The Internet Information Server (IIS) is the web server on which the web portal files are installed. |
Logout URL | Specify the logout page’s URL; for example, http://IIS server IP Address/logout.html. The Internet Information Server (IIS) is the web server on which the web portal files are installed. |
Welcome URL | Specify the welcome page’s URL; for example, http://IIS server IP Address/welcome.html. Users will be redirected to the welcome page after authentication. This field is optional. The Internet Information Server (IIS) is the web server on which the web portal files are installed. |
Session URL | Specify the session page’s URL; for example, http://IIS server IP Address/session.html. The Internet Information Server (IIS) is the web server on which the web portal files are installed. |
Error URL | Specify the error page’s URL; for example, http://IIS server IP Address/error.html. The Internet Information Server (IIS) is the web server on which the web portal files are installed. |
Download | Click this to download an example external web portal file for your reference. |
The following fields are available if you set Type to User Agreement. | |
Enable Idle Detection | This is applicable for access users. Select this check box if you want the Zyxel Device to monitor how long each access user is logged in and idle (in other words, there is no traffic for this access user). The Zyxel Device automatically logs out the access user once the Idle timeout has been reached. |
Idle timeout | This is applicable for access users. This field is effective when Enable Idle Detection is checked. Type the number of minutes each access user can be logged in and idle before the Zyxel Device automatically logs out the access user. |
Reauthentication Time | Enter the number of minutes the user can be logged into the Zyxel Device in one session before having to log in again. |
Internal User Agreement | Select this to use the user agreement pages in the Zyxel Device. The user agreement page appears whenever the Zyxel Device intercepts network traffic, preventing unauthorized users from gaining access to the network. |
Customize file | Select the file name of the user agreement file in the Zyxel Device. |
External User Agreement | Select this to use custom user agreement pages from an external web server instead of the default one built into the Zyxel Device. You can configure the look and feel of the user agreement page. |
Agreement URL | Specify the user agreement page’s URL; for example, http://IIS server IP Address/logout.html. The Internet Information Server (IIS) is the web server on which the user agreement files are installed. |
Welcome URL | Specify the welcome page’s URL; for example, http://IIS server IP Address/welcome.html. The Internet Information Server (IIS) is the web server on which the user agreement files are installed. If you leave this field blank, the Zyxel Device will use the welcome page of internal user agreement file. |
Download | Click this to download an example external user agreement file for your reference. |
Remove | Click a file’s row to select it and click Remove to delete it from the Zyxel Device. |
Download | Click a file’s row to select it and click Download to save the zipped file to your computer. |
# | This column displays the index number for each file entry. This field is a sequential value, and it is not associated with a specific entry. |
File Name | This column displays the label that identifies a web portal or user agreement file. |
Size | This column displays the size (in KB) of a file. |
Last Modified | This column displays the date and time that the individual files were last changed or saved. |
Browse / Upload | Click Browse... to find the zipped file you want to upload, then click the Upload button to put it on the Zyxel Device. |
Download | Click this to download an example external web portal or user agreement file for your reference. |
Zyxel Device | SSO | ||
Screen | field | Screen | field |
Web Authentication > SSO | Listen Port | Agent Configuration Page > Gateway Setting | Gateway Port |
Web Authentication > SSO | Primary Agent Port | Agent Configuration Page | Agent Listening Port |
Object > User/Group > User > Add | Group Identifier | Agent Configuration Page > Configure LDAP/AD Server | Group Membership |
Object > AAA Server > Active Directory > Add | Base DN | Agent Configuration Page > Configure LDAP/AD Server | Base DN |
Object > AAA Server > Active Directory > Add | Bind DN | Agent Configuration Page > Configure LDAP/AD Server | Bind DN |
Object > User/Group > User > Add | User Name | Agent Configuration Page > Configure LDAP/AD Server | Login Name Attribute |
Object > AAA Server > Active Directory > Add | Server Address | Agent Configuration Page > Configure LDAP/AD Server | Server Address |
Network > Interface > Ethernet > wan (IPv4) | IP address | Agent Configuration Page > Gateway Setting | Gateway IP |
LABEL | DESCRIPTION |
Listen Port | The default agent listening port is 2158. If you change it on the Zyxel Device, then change it to the same number in the Gateway Port field on the SSO agent too. Type a number ranging from 1025 to 65535. |
Agent PreShareKey | Type 8-32 printable ASCII characters or exactly 32 hex characters (0-9; a-f). The Agent PreShareKey is used to encrypt communications between the Zyxel Device and the SSO agent. |
Primary Agent | Type the IPv4 address of the SSO agent. The Zyxel Device and the SSO agent must be in the same domain and be able to communicate with each other. |
Primary Agent Port | Type the same port number here as in the Agent Listening Port field on the SSO agent. Type a number ranging from 1025 to 65535. |
Secondary Agent Address (Optional) | Type the IPv4 address of the backup SSO agent if there is one. The Zyxel Device and the backup SSO agent must be in the same domain and be able to communicate with each other. |
Secondary Agent Port (Optional) | Type the same port number here as in the Agent Listening Port field on the backup SSO agent if there is one. Type a number ranging from 1025 to 65535. |
Reset | Click this button to return the screen to its last-saved settings |
