IP Exception
Overview
IP Exception allows incoming IP packets to bypass specific security services based on the packet’s source or destination address. Bypassing a security service means the security service does not intercept nor inspect the packet. IP Exception supports bypassing the following security services:
• Anti-Malware (including sandboxing)
• URL Threat Filter
• IDP (Intrusion Detection and Prevention)
• IP Reputation.
The IP Exception Screen
Use this screen to view the IP exception list for the specified services. The Zyxel Device will not inspect incoming packets that match the listed source and destination IP address(es) wit h the specified services.
Use Add to put a new entry in the list or Edit to change an existing one or Remove to delete an existing entry.
The following table describes the fields in this screen.
Configuration > Security Service > IP Exception
LABEL
Description
IPv4/IPv6 Exception List Settings
Add
Click this to create a new entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
This is the entry’s index number in the list.
Name
This field displays the descriptive name of this entry.
IPv4/IPv6 Source
This field displays the source IP address (or address object) of incoming traffic. It displays any if there is no restriction on the source IP address.
IPv4/IPv6 Destination
This field displays the destination IP address (or address object) of incoming traffic. It displays any if there is no restriction on the destination IP address.
Service to Bypass
This field displays which services will not inspect matched packets.
Log
This field displays if the Zyxel Device will generate a log when the incoming traffic is in the exception list.
The IP Exception Add/Edit Screen
Use this screen to add or edit entries of IPv4 or IPv6 address in the IP exception list.
Configuration > Security Service > IP Exception > Add/Edit
LABEL
Description
Create New Object
Use this to configure any new settings objects that you need to use in this screen.
Name
Enter a descriptive name of this entry.
Description
Enter the description for this entry. You can use up to 60 printable ASCII characters.
Source
Select any or an address object of the source IP address for this entry. Select any so there’s no restriction on the source IP address.
Destination
Select any or an address object of the destination IP address for this entry. Select any so there’s no restriction on the destination IP address.
Log
Select Yes to have the Zyxel Device generate a log when the incoming traffic is in the exception list. Otherwise, select No.
Service to Bypass
Selected services do not inspect packets that match source/destination criteria above. Non-selected services do inspect packets that match source/destination criteria above.
OK
Click OK to save your customized settings and exit this screen.
Cancel
Click Cancel to exit this screen without saving.
