label | description |
IP Address Information | |
IPv4 Address | This displays the IP address of the Switch for it to be managed over the network. |
Subnet Mask | This displays the subnet mask that specifies the network number portion of an IP address. |
Default Gateway | This displays the IP address of the default outgoing gateway in dotted decimal notation. |
IP Setup | This link takes you to a screen where you can configure the IP address and subnet mask (necessary for Switch management) and set up to 64 IP routing domains. |
Quick Links | |
Auto Camera Recovery | This link takes you to a screen where you can enable and configure Auto PD Recovery on the Switch. |
PoE Setup | This link takes you to a screen where you can set priorities, PoE power-up settings and schedule so that the Switch is able to reserve and allocate power to certain PDs. |
Extended Range & Port Setup | This link takes you to a screen where you can configure settings for individual Switch ports. |
ONVIF | This link takes you to a screen where you can configure a specific VLAN to run ONVIF (Open Network Video Interface Forum) protocol. |
