TPID 16 Bits | User Priority 3 Bits | CFI 1 Bit | VLAN ID 12 Bits |
VLAN Parameter | Term | Description |
VLAN Type | Permanent VLAN | This is a static VLAN created manually. |
Dynamic VLAN | This is a VLAN configured by a GVRP registration or de-registration process. | |
VLAN Administrative Control | Registration Fixed | Fixed registration ports are permanent VLAN members. |
Registration Forbidden | Ports with registration forbidden are forbidden to join the specified VLAN. | |
Normal Registration | Ports dynamically join a VLAN using GVRP. | |
VLAN Tag Control | Tagged | Ports belonging to the specified VLAN tag all outgoing frames transmitted. |
Untagged | Ports belonging to the specified VLAN do not tag all outgoing frames transmitted. | |
VLAN Port | Port VID | This is the VLAN ID assigned to untagged frames that this port received. |
Acceptable Frame Type | You may choose to accept both tagged and untagged incoming frames, just tagged incoming frames or just untagged incoming frames on a port. | |
Ingress filtering | If set, the Switch discards incoming frames for VLANs that do not have this port as a member. |
label | description |
VLAN Search by VID | Enter (an) existing VLAN ID numbers (use a comma (,) to separate individual VLANs or a hyphen (-) to indicate a range of VLANs. For example, “3,4” or “3-9”) and click Search to display only the specified VLANs in the list below. Leave this field blank and click Search to display all VLANs configured on the Switch. |
The Number of VLAN | This is the number of VLANs configured on the Switch. |
The Number of Search Results | This is the number of VLANs that match the searching criteria and display in the list below. This field displays only when you use the Search button to look for certain VLANs. |
Index | This is the VLAN index number. Click an index number to view more VLAN details. |
VID | This is the VLAN identification number that was configured in the corresponding VLAN configuration screen. |
Name | This fields shows the descriptive name of the VLAN. |
Tagged Port | This field shows the tagged ports that are participating in the VLAN. |
Untagged Port | This field shows the untagged ports that are participating in the VLAN. |
Elapsed Time | This field shows how long it has been since a normal VLAN was registered or a static VLAN was set up. |
Status | This field shows how this VLAN was added to the Switch. Static: added as a permanent entry. |
Status | This field shows how this VLAN was added to the Switch. • Dynamic: using GVRP • Static: added as a permanent entry • Voice: manually added as a Voice VLAN • MVR: added through multicast VLAN registration • MAC-based: manually added as MAC-based VLAN |
Port Number | This section displays the ports that are participating in a VLAN. A tagged port is marked as T, an untagged port is marked as U and ports not participating in a VLAN are marked as “–“. |
label | Description |
VID | This field displays the ID number of the VLAN group. |
Active | This field indicates whether the VLAN settings are enabled or disabled. |
Name | This field displays the descriptive name for this VLAN group. |
Select an entry’s checkbox to select a specific entry. Otherwise, select the checkbox in the table heading row to select all entries. | |
Add/Edit | Click Add/Edit to add a new static VLAN or edit a selected one. |
Delete | Click Delete to remove the selected static VLAN. |
Active | Enable the switch button to activate the VLAN settings. |
Name | Enter a descriptive name for the VLAN group for identification purposes. This name consists of up to 64 printable ASCII characters. The string should not contain [ ? ], [ | ], [ ' ], [ " ], or [ , ]. |
VLAN Group ID | Enter the VLAN ID for this static entry; the valid range is between 1 and 4094. |
Port | The port number identifies the port you are configuring. |
* | Settings in this row apply to all ports. Use this row only if you want to make some settings the same for all ports. Use this row first to set the common settings and then make adjustments on a port-by-port basis. |
Control | Select Normal for the port to dynamically join this VLAN group using GVRP. This is the default selection. Select Fixed for the port to be a permanent member of this VLAN group. Select Forbidden if you want to prohibit the port from joining this VLAN group. |
Tagging | Select Tx Tagging if you want the port to tag all outgoing frames transmitted with this VLAN Group ID. |
Apply | Click Apply to save your changes to the Switch’s run-time memory. The Switch loses these changes if it is turned off or loses power, so use the Save link on the top navigation panel to save your changes to the non-volatile memory when you are done configuring. |
Clear | Click Clear to clear the fields to the factory defaults. |
Cancel | Click Cancel to not save the configuration you make and return to the last screen. |
Port | This field displays the port number. |
Ingress Check | If this checkbox is selected, the Switch discards incoming frames on a port for VLANs that do not include this port in its member set. Clear this checkbox to disable ingress filtering. |
PVID | A PVID (Port VLAN ID) is a tag that adds to incoming untagged frames received on a port so that the frames are forwarded to the VLAN group that the tag defines. Enter a number between 1and 4094 as the port VLAN ID. |
Acceptable Frame Type | Specify the type of frames allowed on a port. Choices are All, Tag Only and Untag Only. Select All from the drop-down list box to accept all untagged or tagged frames on this port. This is the default setting. Select Tag Only to accept only tagged frames on this port. All untagged frames will be dropped. Select Untag Only to accept only untagged frames on this port. All tagged frames will be dropped. |
VLAN Trunking | Enable VLAN Trunking on ports connected to other switches or routers (but not ports directly connected to end users) to allow frames belonging to unknown VLAN groups to pass through the Switch. |
Isolation | Select this to allows this port to communicate only with the CPU management port and the ports on which the isolation feature is NOT enabled. |
Cancel | Click Cancel to begin configuring this screen afresh. |
GVRP | GVRP (GARP VLAN Registration Protocol) is a registration protocol that defines a way for switches to register necessary VLAN members on ports across the network. Enable the switch button to permit VLAN groups beyond the local Switch. |
GVRP | Select this checkbox to allow GVRP on this port. |
Active | Enable the switch button to activate this subnet based VLANs on the Switch. |
DHCP-VLAN Override | When DHCP snooping is enabled DHCP clients can renew their IP address through the DHCP VLAN or through another DHCP server on the subnet based VLAN. Enable the switch button to force the DHCP clients in this IP subnet to obtain their IP addresses through the DHCP VLAN. |
Index | This is the index number identifying this subnet based VLAN. |
Active | This field shows whether the subnet based VLAN is active or not. |
Name | This field shows the name the subnet based VLAN. |
IP | This field shows the IP address of the subnet for this subnet based VLAN. |
Mask-Bits | This field shows the subnet mask in bit number format for this subnet based VLAN. |
VID | This field shows the VLAN ID of the frames which belong to this subnet based VLAN. |
Priority | This field shows the priority which is assigned to frames belonging to this subnet based VLAN. |
Add/Edit | Click Add/Edit to add a new entry or edit a selected one. |
Delete | Click Delete to remove the selected entry. |
Active | Enable the switch button to activate the IP subnet VLAN you are creating or editing. |
Name | Enter up to 32 alphanumeric characters to identify this subnet based VLAN. The string should not contain [ ? ], [ | ], [ ' ], [ " ], or [ , ]. |
IP | Enter the IP address of the subnet for which you want to configure this subnet based VLAN. |
Mask-Bits | Enter the bit number of the subnet mask. To find the bit number, convert the subnet mask to binary format and add all the 1’s together. Take “255.255.255.0” for example. 255 converts to eight 1s in binary. There are three 255s, so add three eights together and you get the bit number (24). |
VLAN | Enter the ID of a VLAN with which the untagged frames from the IP subnet specified in this subnet based VLAN are tagged. This must be an existing VLAN which you defined in the SWITCHING > VLAN > VLAN Setup > Static VLAN screen. |
Priority | Select the priority level that the Switch assigns to frames belonging to this VLAN. |
Index | This is the index number identifying this protocol based VLAN. Click any of these numbers to edit an existing protocol based VLAN. |
Active | This field shows whether the protocol based VLAN is active or not. |
Port | This field shows which port belongs to this protocol based VLAN. |
Name | This field shows the name of the protocol based VLAN. |
Ethernet-type | This field shows which Ethernet protocol is part of this protocol based VLAN. |
VID | This field shows the VLAN ID of the port. |
Priority | This field shows the priority which is assigned to frames belonging to this protocol based VLAN. |
Active | Enable the switch button to activate this protocol based VLAN. |
Port | Type a port to be included in this protocol based VLAN. This port must belong to a static VLAN in order to participate in a protocol based VLAN. |
Name | Enter up to 32 alphanumeric characters to identify this protocol based VLAN. The string should not contain [ ? ], [ | ], [ ' ], [ " ], or [ , ]. |
Ethernet-type | Use the drop down list box to select a predefined protocol to be included in this protocol based VLAN or select Other and type the protocol number in hexadecimal notation. For example the IP protocol in hexadecimal notation is 0800, and Novell IPX protocol is 8137. |
VLAN | Enter the ID of a VLAN to which the port belongs. This must be an existing VLAN which you defined in the SWITCHING > VLAN > VLAN Setup > Static VLAN screen. |
Priority | Select the priority level that the Switch will assign to frames belonging to this VLAN. |
Voice VLAN Global Setup | |
Voice VLAN | Click the second radio button if you want to enable the Voice VLAN feature. Enter a VLAN ID number that is associated with the Voice VLAN. Click the Disable radio button if you do not want to enable the Voice VLAN feature. |
Priority | Select the priority level of the voice traffic from 0 to 7. Default setting is 5. The higher the numeric value you assign, the higher the priority for this voice traffic. |
Cancel | Click Cancel to begin configuring this section afresh. |
Voice VLAN OUI Setup | |
Index | This field displays the index number of the Voice VLAN. |
OUI Address | This field displays the OUI address of the Voice VLAN. |
OUI Mask | This field displays the OUI mask address of the Voice VLAN. |
Description | This field displays the description of the Voice VLAN with OUI address. |
OUI Address | Enter the IP phone manufacturer’s OUI MAC address. The first 3 bytes is the manufacturer identifier, the last 3 bytes is a unique station ID. |
OUI Mask | Enter the mask for the specified IP phone manufacturer’s OUI MAC address to determine which bits a packet’s MAC address should match. Enter “f” for each bit of the specified MAC address that the traffic’s MAC address should match. Enter “0” for the bits of the matched traffic’s MAC address, which can be of any hexadecimal characters. For example, if you set the MAC address to 00:13:49:00:00:00 and the mask to ff:ff:ff:00:00:00, a packet with a MAC address of 00:13:49:12:34:56 matches this criteria. |
Description | Enter a description up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], or [ " ] for the Voice VLAN device. For example: Siemens. |
Index | This field displays the index number of the MAC-based VLAN entry. |
Name | This field displays the name of the MAC-based VLAN entry. |
MAC Address | This field displays the source MAC address that is bind to the MAC-based VLAN entry. |
VID | This field displays the VLAN ID of the MAC-based VLAN entry. |
Priority | This field displays the priority level which is assigned to frames belonging to this MAC-based VLAN entity. |
Name | Enter a name up to 32 alphanumeric characters except [ ? ], [ | ], [ ' ], [ " ], or [ , ] for the MAC-based VLAN entry. |
MAC Address | Enter a MAC address that is bind to the MAC-based VLAN entry. This is the source MAC address of the data packet that is looked up when untagged packets arrive at the Switch. |
VID | Enter an ID (from 1 to 4094) for the VLAN that is associated with the MAC-based VLAN entry. |
Priority | Enter a priority (0 to 7) that the Switch assigns to frames belonging to this VLAN. The higher the numeric value you assign, the higher the priority for this MAC-based VLAN entry. |
Index | This field displays the index number of the vendor ID based VLAN entry. |
Name | This field displays the name of the vendor ID based VLAN entry. |
MAC Address | This field displays the source MAC address that is bind to the vendor ID based VLAN entry. |
Mask | This field displays the mask for the source MAC address that is bind to the vendor ID based VLAN entry. |
VID | This field displays the VLAN ID of the vendor ID based VLAN entry. |
Priority | This field displays the priority level which is assigned to frames belonging to this vendor ID based VLAN. |
Weight | This field displays the weight of the vendor ID based VLAN entry. |
Name | Enter a name up to 32 alphanumeric characters except [ ? ], [ | ], [ ' ], or [ " ] for the vendor ID based VLAN entry. |
MAC Address | Enter a MAC address that is bind to the vendor ID-based VLAN entry. This is the source MAC address of the data packet that is looked up when untagged packets arrive at the Switch. |
Mask | Enter the mask for the specified source MAC address to determine which bits a packet’s MAC address should match. Enter “f” for each bit of the specified MAC address that the traffic’s MAC address should match. Enter “0” for the bits of the matched traffic’s MAC address, which can be of any hexadecimal characters. For example, if you set the MAC address to 00:13:49:00:00:00 and the mask to ff:ff:ff:00:00:00, a packet with a MAC address of 00:13:49:12:34:56 matches this criteria. |
VID | Enter an ID (from 1 to 4094) for the VLAN that is associated with the vendor ID based VLAN entry. |
Priority | Select the priority level that the Switch assigns to frames belonging to this VLAN. The higher the numeric value you assign, the higher the priority for this vendor ID based VLAN entry. |
Weight | Enter a number between 0 and 255 to specify the rule’s weight. This is to decide the priority in which the rule is applied. The higher the number, the higher the rule’s priority. |
Setting Wizard | Choose Current configuration to display the Switch’s current port-based VLAN configuration. Choose All connected or Port isolation wizard to quickly set up a port-based VLAN according to the below descriptions. All connected means all ports can communicate with each other, that is, there are no virtual LANs. All incoming and outgoing ports are selected. This option is the most flexible but also the least secure. Port isolation means that each port can only communicate with the CPU management port and cannot communicate with each other. All incoming ports are selected while only the CPU outgoing port is selected. This option is the most limiting but also the most secure. After selecting the setting wizard, you can customize the port settings. Click on the ports to add or delete incoming or outgoing ports. The configuration will be saved only after you click Apply at the bottom of the screen. |
Incoming | These are the ingress ports; an ingress port is an incoming port, that is, a port through which a data packet enters. If you wish to allow two subscriber ports to talk to each other, you must define the ingress port for both ports. The numbers in the top row denote the incoming port for the corresponding port listed on the left (its outgoing port). CPU refers to the Switch management port. By default it forms a VLAN with all Ethernet ports. If it does not form a VLAN with a particular port then the Switch cannot be managed from that port. |
Outgoing | These are the egress ports; an egress port is an outgoing port, that is, a port through which a data packet leaves. If you wish to allow two subscriber ports to talk to each other, you must define the egress port for both ports. CPU refers to the Switch management port. By default it forms a VLAN with all Ethernet ports. If it does not form a VLAN with a particular port then the Switch cannot be managed from that port. |
Index | This is the index number of the rule. |
Active | This shows whether this rule is activated or not. |
Name | This is the descriptive name for this rule. |
VLAN ID | This is the VLAN to which this rule is applied. |
Promiscuous Ports | This shows the ports that can communicate with any ports in the same VLAN. |
Delete | Click Delete to remove the selected entries. |
Active | Enable the switch button to enable VLAN Isolation in a VLAN. |
Name | Enter a descriptive name (up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ], or [ , ]) for identification purposes. |
VLAN ID | Enter a VLAN ID from 1 to 4094. This is the VLAN to which this rule applies. |
Promiscuous Ports | Enter the number of the ports that can communicate with any ports in the same VLAN. Other ports belonging to this VLAN will be added to the isolation list and can only send and receive traffic from the ports you specify here. |
