Label | Description |
Registration Type | Select Manual to add each AP to the Zyxel Device for management, or Always Accept to automatically add APs to the Zyxel Device for management. If you select Manual, then go to Monitor > Wireless > AP Information > AP List, select an AP to be managed and then click Add to Mgnt AP List. That AP will then appear in Configuration > Wireless > Controller > Mgnt. AP List. APs must be connected to the Zyxel Device by a wired connection or network. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Hide/ Show Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
AP List | Select the type of APs you want to display. Select All to show all kinds of APs that are currently or used to be connected to the ZyWALL. Select NebulaFlexPRO to show the APs that can work in Nebula cloud management mode. |
Status | Select the status of APs you want to display. |
Keyword | Enter a keyword to display the APs that include it in their AP information, such as model number, firmware version, MAC address and so on. This field is case-sensitive. |
Search | Click this to update the list of APs based on the search criteria. Your search criteria is retained when navigating between screens. |
Reset | Click this to return the search criteria to the factory defaults and display all currently or previously connected APs without a filter. |
Enable Column Freeze | Select the check box to freeze the first column (#) so it will be always visible when you scroll through the list. Clear the check box to unfreeze the column. |
Edit Selected Rule | Select an AP and click this button to edit its properties. |
Add to Mgnt | Select an AP and click this to add the selected AP to the managed AP list. |
Reboot device | Select an AP and click this button to force it to restart. |
Remove Rule | Select an AP and click this button to remove it from the list. |
DCS Now | Select one or multiple APs and click this button to use DCS (Dynamic Channel Selection) to allow the AP to automatically find a less-used channel in an environment where there are many APs and there may be interference. |
More Information | Select an AP and click this to view a daily station count about the selected AP. The count records station activity on the AP over a consecutive 24 hour period. |
Radio Info | Select an online AP and click this button to go to the Monitor > Wireless > AP Information > Radio List screen to view detailed information about the AP’s radios. |
Query Controller Log | Select an AP and click this button to go to the Monitor > Log > View AP Log screen to view the selected AP’s current log messages. |
Nebula | Select an AP and click this to open a screen where you can set whether the AP’s IP address and VLAN settings will be changed when it goes into Nebula cloud management mode. |
Upgrade FW | Select one or more APs and click this button to update the APs’ firmware version. |
Suppression On | Select an AP and click this button to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Suppression Off | Select an AP and click this button to disable the AP’s LED suppression mode. The AP LEDs stay lit after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Locator On | Select an AP and click this button to run the locator feature. The AP’s Locator LED will start to blink for 10 minutes by default. It will show the actual location of the AP between several devices in the network. |
# | This field is a sequential value, and it is not associated with any entry. |
Status | This visually displays the AP’s connection status with icons. |
Description | This field displays the AP’s description, which you can configure by selecting the AP’s entry and clicking the Edit button. |
CPU Usage | This displays what percentage of the AP’s processing capability is currently being used. |
IP Address | This field displays the IP address of the AP. |
MAC Address | This field displays the MAC address of the AP. |
Station 2.4G | This displays the number of stations (aka wireless clients) associated with the AP’s 2.4 GHz WiFi network. |
Station 5G | This displays the number of stations (aka wireless clients) associated with the AP’s 5 GHz WiFi network. |
Recent On-line Time | |
Power | This displays the AP’s power status. Full power - the AP receives optimal power from the power sourcing equipment. Force Full Power- the power sourcing equipment provides full power to the AP even in cases where a PoE injector that does not support PoE negotiation is used. Limited power - the AP receives less than optimal power from the power sourcing equipment. This may be due to the PoE switch/injector using an earlier PoE standard. This may impact wireless transmission throughput or disable a radio transmitter, depending on the AP’s power requirements. Off-Line - the AP is not receiving power. |
Type | This indicates whether the AP is on the managed AP list (Mgmt) or not (Un-Mgmt). This displays Limited when the AP is configured by conflicted or unsupported setting(s). |
Model | This field displays the AP’s hardware model information. It displays N/A (not applicable) only when the AP disconnects from the NXC and the information is unavailable as a result. |
R1 Mode/ Profile/ ZyMesh Profile | This field displays the operating mode (AP, MON, root, or repeater), AP radio profile name and ZyMesh profile name for Radio 1. It displays n/a for the AP profile for a radio not using an AP profile or - for the ZyMesh profile for a radio not using a ZyMesh profile. |
R2 Mode/ Profile/ ZyMesh Profile | This field displays the operating mode (AP, MON, root, or repeater), AP radio profile name and ZyMesh profile name for Radio 2. It displays n/a for the AP profile for a radio not using an AP profile or - for the ZyMesh profile for a radio not using a ZyMesh profile. |
Version | This displays the AP’s current firmware version. |
Group | This field displays the name of the AP group to which the AP belongs. The group becomes editable immediately upon clicking. |
Mgnt. VLAN ID(AC/AP) | This displays the Access Controller (the NXC) management VLAN ID setting for the AP and the runtime management VLAN ID setting on the AP. VLAN Conflict displays if the AP’s management VLAN ID does not match the NXC’s management VLAN ID setting for the AP. This field displays n/a if the NXC cannot get VLAN information from the AP. |
Last Off-line Time | This displays the most recent time the AP went off-line. N/A displays if the AP has either not come on-line or gone off-line since the NXC last started up. |
LED status | This displays the AP LED status. N/A displays if the AP does not support LED suppression mode and/or have a locator LED to show the actual location of the AP. A gray LED icon signifies that the AP LED suppression mode is enabled. All the LEDs of the AP will turn off after the AP is ready. A green LED icon signifies that the AP LED suppression mode is disabled and the AP LEDs stay lit after the AP is ready. A sun icon signifies that the AP’s locator LED is blinking. A circle signifies that the AP’s locator LED is extinguished. |
Ethernet Uplink | This field displays the AP’s uplink port speed and duplex mode (Full or Half). |
Bluetooth | This field displays the AP’s Bluetooth Low Energy (BLE) capability. Bluetooth Low Energy, which is also known as Bluetooth Smart, transmits less data over a shorter distance and consumes less power than classic Bluetooth. APs communicate with other BLE enabled devices using advertisements. N/A displays if the AP does not support BLE. Unavailable displays if the AP supports Bluetooth, but there is no BLE USB dongle connected to the USB port of the AP. Available displays if the AP supports Bluetooth, detects a BLE device and advertising is inactive. Some APs, such as the WAC5302D-S. need to have a supported BLE USB dongle attached to act as a beacon to broadcast packets. Advertising displays if the AP supports Bluetooth, detects a BLE device and advertising is activated, which means the BLE device can broadcasts packets to every device around it. |
Location | This field displays the AP’s location you configured. |
Roaming Group | This field displays the name of roaming group to which the AP belongs. |
Load Balancing Group | This field displays the load balancing group(s) to which the AP belongs. |
S/N | This field displays the serial number of the AP. |
System Name | This field displays the system name to identify the AP on a network. |
Refresh | Click Refresh to update the information in this screen. |
Create new Object | Use this menu to create a new Radio Profile object to associate with this AP. |
MAC | This displays the MAC address of the selected AP. |
Model | This field displays the AP’s hardware model information. It displays N/A (not applicable) only when the AP disconnects from the Zyxel Device and the information is unavailable as a result. |
S/N | This displays the serial number of the selected AP. |
Description | Enter a description for this AP. You can use up to 31 characters, spaces and underscores allowed. |
Group Setting | Select an AP group to which you want this AP to belong. |
System Name | Enter a name to identify the AP on a network. This is usually the AP’s fully qualified domain name. |
Location | Specify the name of the place where the AP is located. |
Roaming Group | Specify the name of the roaming group to which the AP belongs. You can use up to 31 alphanumeric and @# characters. Dashes and underscores are also allowed. The name should start with a letter or digit. The 802.11k neighbor list a client requests from the AP is generated according to the roaming group and RCPI (Received Channel Power Indicator) value of its neighbor APs. When a client wants to roam from the current AP to another, other APs in the same roaming group or not in a roaming group will be candidates for roaming. Neighbor APs in a different roaming group will be excluded from the 802.11k neighbor lists even when the neighbor AP has the best signal strength. If the AP’s roaming group is not configured, any neighbor APs can be candidates for roaming. |
Load Balancing Group 1/2 | Load balancing is only applied to APs within the same group. If a load balancing group is not assigned to an AP, it will belong to a default group. Each AP can belong to up to two groups. |
Radio 1/2 Setting | |
Override Group Radio Setting | Select this option to overwrite the AP radio settings with the settings you configure here. |
OP Mode | Select the operating mode for radio 1 or radio 2. AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). MON Mode means the AP monitors the broadcast area for other APs, then passes their information on to the Zyxel Device where it can be determined if those APs are friendly or rogue. If an AP is set to this mode it cannot receive connections from wireless clients. Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a ZyMesh to extend its wireless network. Repeater AP means the radio can establish a wireless connection with other APs (in either root AP or repeater mode). |
Radio 1/2 AP Profile | Select an AP profile from the list. If no profile exists, you can create a new one through the Create new Object menu. |
Radio 1/2 Profile | Select a monitor profile from the list. If no profile exists, you can create a new one through the Create new Object menu. |
Radio 1/2 ZyMesh Profile | This field is available only when the radio is in Root AP or Repeater AP mode. Select the ZyMesh profile the radio uses to connect to a root AP or repeater. |
Enable Wireless Bridging | This field is available only when the radio is in Repeater AP mode. Select this option to enable wireless bridging on the radio. The managed AP must support LAN provision and the radio should be in repeater mode. VLAN and bridge interfaces are created automatically according to the LAN port’s VLAN settings. When wireless bridging is enabled, the managed repeater AP can still transmit data through its Ethernet port(s) after the ZyMesh link is up. Be careful to avoid bridge loops. The managed APs in the same ZyMesh must use the same static VLAN ID. |
Override Group Output Power Setting | Select this option to overwrite the AP output power setting with the setting you configure here. |
Output Power | Set the output power of the AP. |
Override Group SSID Setting | Select this option to overwrite the AP SSID profile setting with the setting you configure here. This section allows you to associate an SSID profile with the radio. |
IP Setting | |
Force Overwrite IP Setting | Select this to have the Zyxel Device change the AP’s IP address setting to match the configuration in this screen. |
Get Automatically | Select this to have the AP act as a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server. |
Use Fixed IP Address | Select this if you want to specify the IP address, subnet mask, gateway and DNS server address manually. |
IP Address | Enter the IP address for the AP. |
Subnet Mask | Enter the subnet mask of the AP in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all devices in the network. |
Gateway | Enter the IP address of the gateway. The AP sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the AP. |
DNS Server IP Address | Enter the IP address of the DNS server. |
VLAN Settings | |
Override Group VLAN Setting | Select this option to overwrite the AP VLAN setting with the setting you configure here. |
Force Overwrite VLAN Config | Select this to have the Zyxel Device change the AP’s management VLAN to match the configuration in this screen. |
Management VLAN ID | Enter a VLAN ID for this AP. |
As Native VLAN | Select this option to treat this VLAN ID as a VLAN created on the NXC and not one assigned to it from outside the network. |
Storm Control Setting | |
Broadcast Storm Control | Enabling this will drop ingress broadcast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide). |
Multicast Storm Control | Enabling this will drop ingress multicast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide) |
Rogue AP Detection Setting | |
Override Group Rogue AP Detection Setting | Select this option to overwrite the AP Rogue Detection Settings with the settings you configure here |
Enable Rogue AP Detection | Select this option to detect Rogue APs in the network. |
Antenna Setting | This section is available only when the AP has an antenna switch. The screen varies depending on whether the AP has a physical antenna switch or allows you to change antenna orientation settings on a per-radio basis or on a per-AP basis. |
Wall/ Ceiling | This allows you to adjust coverage depending on the antenna orientation of the AP’s radios for better coverage. Select Wall if you mount the AP to a wall. Select Ceiling if the AP is mounted on a ceiling. You can switch from Wall to Ceiling if there are still wireless dead zones, and vice versa. |
LED Suppression Mode Configuration | This section is available only when the AP supports LED suppression mode. |
Suppression On | Select this option to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. If the check box is unchecked, it means the LEDs will stay lit after the AP is ready. |
Power Setting | Enable Force override the power mode to full power if you are using a PoE injector that does not support PoE negotiation. Otherwise, the AP cannot draw full power from the power sourcing equipment. Enable this power mode to improve the AP’s performance in this situation. |
Locator LED Configuration | This section is available only when the AP has a locator LED. |
Turn On/ Turn Off | When the locator LED is off, click the Turn On button to activate the locator function. It will show the actual location of the AP between several devices in the network. If the locator LED is blinking, click the Turn Off button to stop the locator LED from blinking immediately. |
Automatically Extinguish After | Enter a time interval between 1 and 60 minutes to stop the locator LED from blinking. The locator LED will start to blink for the number of minutes set here. If you make changes to the time default setting, it will be stored as the default when the AP restarts. |
Reset AP Configuration | This section is available only when the AP is online. |
Apply Factory Default | Click the button to reset all of the AP settings to the factory defaults. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to close the window with changes unsaved. |
Force Override AC IP Config on AP | Select this to have the Zyxel Device change the AP controller’s IP address on the managed AP(s) to match the configuration in this screen. |
Override Type | Select Auto to have the managed AP(s) automatically send broadcast packets to find any other available AP controllers. Select Manual to replace the AP controller’s IP address configured on the managed AP(s) with the one(s) you specified below. |
Primary Controller | Specify the IP address of the primary AP controller if you set Override Type to Manual. |
Secondary Controller | Specify the IP address of the secondary AP controller if you set Override Type to Manual. |
Fall back to Primary Controller when possible | Select this option to have the managed AP(s) change back to associate with the primary AP controller as soon as the primary AP controller is available. |
Fall Back Check Interval | Set how often the managed AP(s) check whether the primary AP controller is available. |
Firmware Updating | |
Updating Type | Specify how you want the Zyxel Device to upgrade AP firmware. Select CAPWAP to have the Zyxel Device use CAPWAP (Control and Provisioning of Wireless Access Points protocol) to automatically update firmware on the managed APs. Select FTP to allow the managed APs to download the latest firmware from the Zyxel Device using FTP. |
Updating Mode | Select Auto so the Zyxel Device checks the AP’s firmware version and updates it automatically to the Zyxel Device’s latest supported version. Select Manual so you update the AP firmware manually. |
Group Setting | |
Default Group | Select a group that is used as the default group. Any AP that is not configured to associate with a specific AP group belongs to the default group automatically. |
Group Summary | |
Add | Click this button to create a new AP group. |
Edit | Select an entry and click this button to edit its properties. |
Remove | Select an entry and click this button to remove it from the list. |
Reboot | Select an AP group and click this button to force the AP(s) in this group to restart. |
DCS Now | Select one or multiple groups and click this button to use DCS (Dynamic Channel Selection) to allow the APs in the group(s) to automatically find a less-used channel in an environment where there are many APs and there may be interference. |
Upgrade Now | Select an AP group and click this button to upgrade the firmware of the APs to the Zyxel Device’s latest supported version. |
# | This is the index number of the group in the list. |
Group Name | This is the name of the group. |
Member Count | This is the total number of APs which belong to this group. |
General Settings | |
Group Name | Enter a name for this group. You can use up to 31 alphanumeric characters. Dashes and underscores are also allowed. The name should start with a letter. |
Description | Enter a description for this group. You can use up to 31 characters, spaces and underscores allowed. |
Location | Specify the name of the place where the AP group is located. |
Radio 1/2 ZyMesh Profile | This field is available only when the radio is in Root AP or Repeater AP mode. |
Enable Wireless Bridging | Select the ZyMesh profile the radio uses to connect to a root AP or repeater. This field is available only when the radio is in Repeater AP mode. Select this option to enable wireless bridging on the radio. The managed AP must support LAN provision and the radio should be in repeater mode. VLAN and bridge interfaces are created automatically according to the LAN port’s VLAN settings. When wireless bridging is enabled, the managed repeater AP can still transmit data through its Ethernet port(s) after the ZyMesh link is up. Be careful to avoid bridge loops. The managed APs in the same ZyMesh must use the same static VLAN ID. |
Output Power | Set the maximum output power of the AP. If there is a high density of APs in an area, decrease the output power of the managed AP to reduce interference with other APs. |
Edit | Select an SSID and click this button to reassign it. The selected SSID becomes editable immediately upon clicking. |
# | This is the index number of the SSID profile. You can associate up to eight SSID profiles with an AP radio. |
SSID Profile | Indicates which SSID profile is associated with this radio profile. |
VLAN Settings | |
As Native VLAN | Select this option to treat this VLAN ID as a VLAN created on the Zyxel Device and not one assigned to it from outside the network. |
Port Settings | |
Model Specific Setting | Select the model of the managed AP to display the model-specific port and VLAN settings in the tables below. |
Port Setting | You can activate or deactivate a non-uplink port. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Activate/Inactivate | To turn on an entry, select it and click Activate. To turn off an entry, select it and click Inactivate. |
# | This is the port’s index number in this list. |
Status | This displays whether or not the port is activated. |
Port | This shows the name of the physical Ethernet port on the managed AP. |
PVID | This shows the port’s PVID. A PVID (Port VLAN ID) is a tag that adds to incoming untagged frames received on a port so that the frames are forwarded to the VLAN group that the tag defines. |
VLAN Configuration | |
Add | Click this to create a new entry. |
Remove | To remove an entry, select it and click Remove. The NXC confirms you want to remove it before doing so. |
Activate/ Inactivate | To turn on an entry, select it and click Activate. To turn off an entry, select it and click Inactivate. |
# | This is the VLAN’s index number in this list. |
Status | This displays whether or not the VLAN is activated. |
Name | This shows the name of the VLAN. |
VID | This shows the VLAN ID number. |
Member | This field displays the Ethernet port(s) that is a member of this VLAN. |
Load Balancing Setting | |
Enable Load Balancing | Select this to enable load balancing on the Zyxel Device. Use this section to configure wireless network traffic load balancing between the managed APs in this group. |
Mode | Select a mode by which load balancing is carried out. Select By Station Number to balance network traffic based on the number of specified stations connected to an AP. Select By Traffic Level to balance network traffic based on the volume generated by the stations connected to an AP. Select By Smart Classroom to balance network traffic based on the number of specified stations connected to an AP. The AP ignores association request and authentication request packets from any new station when the maximum number of stations is reached. If you select By Station Number or By Traffic Level, once the threshold is crossed (either the maximum station numbers or with network traffic), the AP delays association request and authentication request packets from any new station that attempts to make a connection. This allows the station to automatically attempt to connect to another, less burdened AP if one is available. |
Radio 1/2 Max Station Number | Enter the threshold number of stations at which an AP begins load balancing its connections. |
Disassociate station when overloaded | This function is enabled by default and the disassociation priority is always Signal Strength when you set Mode to By Station Number. Select this option to disassociate wireless clients connected to the AP when it becomes overloaded. If you do not enable this option, then the AP simply delays the connection until it can afford the bandwidth it requires, or it transfers the connection to another AP within its broadcast radius. The disassociation priority is determined automatically by the Zyxel Device and is as follows: • Idle Timeout - Devices that have been idle the longest will be disassociated first. If none of the connected devices are idle, then the priority shifts to Signal Strength. • Signal Strength - Devices with the weakest signal strength will be disassociated first. |
Radio 1/2 Traffic Level | Select the threshold traffic level of the radio slot at which the AP begins load balancing its connections (Low, Medium, High). The maximum bandwidth allowed for each level is: • Low - 11 Mbps • Medium - 23 Mbps • High - 35 Mbps |
AP List | |
Available | This lists the APs that do not belong to this group. Select the APs that you want to add to the group you are editing, and click the right arrow button to add them. |
Member | This lists the APs that belong to this group. Select any APs that you want to remove from the group, and click the left arrow button to remove them. |
Override Member AP Setting | Click this button to overwrite the settings of all managed APs in this group with the settings you configure here. All Override Group check boxes on the AP Management > Mgnt. AP List > Edit AP List screen for the APs in this group will be deselected. |
AP Firmware | |
Runtime Firmware | This displays the current AP firmware version on the Zyxel Device. The Zyxel Device must have the latest AP firmware to manage all supported APs. |
Available Firmware | This field displays if there is a later AP firmware version available on the firmware server. It displays N/A if the Zyxel Device cannot connect with the firmware server. Check that the Zyxel Device has Internet access if N/A displays and then click the Check button below. |
Check | Click this button to have the Zyxel Device display the latest AP firmware version available on the firmware server. |
Last Check Success | This displays the date and time the last check for new firmware was made and whether the check is in progress (checking), was successful (success), or has failed (fail). |
Apply AP Firmware | Due to space limitations, the Zyxel Device only downloads and keeps AP firmware for APs it is currently managing. If you connect a new AP to the Zyxel Device, the Zyxel Device may need to download a new AP firmware. Please wait while downloading new firmware as the speed depends on your Internet connection speed. Make sure to maintain the Internet connection while downloading new firmware. |
Apply | Click this to download newer Available Firmware from the firmware server and update the Runtime Firmware version. |
# | This is an index number of a managed AP. |
Model | This displays the name of all manageable AP models. |
Runtime Firmware | This displays the firmware version that the managed AP must have in order to be managed by the Zyxel Device. Firmware for APs that the Zyxel Device already has displays in bold; firmware that the Zyxel Device doesn’t have or is still downloading is grayed out. Firmware that is in the download queue will show To be downloaded. |
Refresh | Click this to update the model firmware table. |
Suspected Rogue AP Classification Rule | Click the check boxes (Weak Security (Open, WEP, WPA-PSK), Un-managed AP, Hidden SSID, SSID Keyword) of the characteristics an AP should have for the Zyxel Device to rule it as a rogue AP. |
Add | Click this to add an SSID Keyword. |
Edit | Select an SSID Keyword and click this button to modify it. |
Remove | Select an existing SSID keyword and click this button to delete it. |
# | This is the SSID Keyword’s index number in this list. |
SSID Keyword | This field displays the SSID Keyword. |
Rogue/Friendly AP List | |
Add | Click this button to add an AP to the list and assign it either friendly or rogue status. |
Edit | Select an AP in the list to edit and reassign its status. |
Remove | Select an AP in the list to remove. |
Containment | Click this button to quarantine the selected AP. A quarantined AP cannot grant access to any network services. Any stations that attempt to connect to a quarantined AP are disconnected automatically. |
Dis-Containment | Click this button to take the selected AP out of quarantine. An unquarantined AP has normal access to the network. |
# | This field is a sequential value, and it is not associated with any interface. |
Containment | This field indicates the selected AP’s containment status. |
Role | This field indicates whether the selected AP is a rogue-ap or a friendly-ap. To change the AP’s role, click the Edit button. |
MAC Address | This field indicates the AP’s radio MAC address. |
Description | This field displays the AP’s description. You can modify this by clicking the Edit button. |
Rogue/Friendly AP List Importing/Exporting | These controls allow you to export the current list of rogue and friendly APs or import existing lists. |
File Path / Browse / Importing | Enter the file name and path of the list you want to import or click the Browse button to locate it. Once the File Path field has been populated, click Importing to bring the list into the Zyxel Device. |
Exporting | Click this button to export the current list of either rogue APs or friendly APS. |
Monitor Mode Settings | |
Enable Rogue AP Containment | Select this to enable rogue AP containment. |
MAC | Enter the MAC address of the AP you want to add to the list. A MAC address is a unique hardware identifier in the following hexadecimal format: xx:xx:xx:xx:xx:xx where xx is a hexadecimal number separated by colons. |
Description | Enter up to 60 characters for the AP’s description. Spaces and underscores are allowed. |
Role | Select either Rogue AP or Friendly AP for the AP’s role. |
Enable Auto Healing | Select this option to turn on the auto healing feature. |
Save Current State | Click this button to have all manged APs immediately scan their neighborhoods three times in a row and update their neighbor lists to the AP controller (Zyxel Device). |
Auto Healing Interval | Set the time interval (in minutes) at which the managed APs scan their neighborhoods and report the status of neighbor APs to the AP controller (Zyxel Device). An AP is considered “failed” if the AP controller obtains the same scan result that the AP is missing from the neighbor list of other APs three times. |
Power Threshold | Set the power level (in dBm) to which the neighbor APs of the failed AP increase their output power in order to extend their wireless service coverage areas. When the failed AP is working again, its neighbor APs return their output power to the original level. |
Port Number | Type | Description |
8548 | TCP | Ekahau T201 location update. |
8549 | UDP | Ekahau T201 location update. |
8550 | TCP | Ekahau T201 tag maintenance protocol and Ekahau RTLS Controller user interface. |
8552 | UDP | Ekahau Location Protocol |
8553 | UDP | Ekahau Maintenance Protocol |
8554 | UDP | Ekahau T301 firmware update. |
8560 | TCP | Ekahau Vision web interface |
8562 | UDP | Ekahau T301W firmware update. |
8569 | UDP | Ekahau TZSP Listener Port |
Enable | Select this to use Wi-Fi to track the location of Ekahau Wi-Fi tags. |
IP Address | Specify the IP address of the Ekahau RTLS Controller. |
Server Port | Specify the server port number of the Ekahau RTLS Controller. |
