Hardware, Interfaces and Zones
Hardware Overview
This section describes the front and rear panels for each model.
Front Panels
The following table describes the front panel LEDs.
LED Descriptions
LED
Color
status
description
PWR
Off
The Zyxel Device is turned off.
Green
On
The Zyxel Device is turned on.
Red
On
There is a hardware component failure. Shut down the device, wait for a few minutes and then restart the device. If the LED turns red again, then please contact your vendor.
SYS
Green
Off
The Zyxel Device is not ready or has failed.
On
The Zyxel Device is ready and running.
Blinking
The Zyxel Device is booting.
Red
On
The Zyxel Device has an error or has failed.
USB
Green
Off
No device is connected to the Zyxel Device’s USB port or the connected device is not supported by the Zyxel Device.
On
A mobile broadband USB card or USB storage device is connected to the USB port.
Orange
On
Connected to a mobile broadband network through the connected mobile broadband USB card.
P1, P2...
Green
Off
There is no traffic on this port.
Blinking
The Zyxel Device is sending or receiving packets on this port.
Orange
Off
There is no connection on this port.
On
This port has a successful link.
Blinking
The following table describes the USG2200-VPN/USG2200 LEDs.
USG2200-VPN/USG2200 LED Descriptions
LED
Color
status
description
PWR1, 2
Off
Green
On
Red
On
SYS
Green
Off
On
Blinking
Red
On
P1-P4 (SFP) Link
Green
Off
On
This port has a successful 100Mbps link.
Orange
Off
On
This port has a successful 1000Mbps link.
P1-P4 (SFP) ACT
Green
Off
On
P5-P16 (WAN/LAN))
Green
Off
On
This port has a successful 10/100Mbps link.
Blinking
Orange
Off
On
Blinking
P17-P18 (SFP+) Link
Blue
Off
On
This port has a successful 10Gbps link.
P17-P18 (SFP+) ACT
Green
Off
Blinking
P17-P18 (10GE) Link
Blue
Off
On
P17-P18 (10GE) ACT
Green
Off
Blinking
The following table describes the ports on the front panel.The following table describes the ports on the USG2200-VPN/USG2200 front panel.
Front Panel Ports
Label
Description
RESET
Press the button in for about 5 seconds (or until the SYS LED starts to blink), then release it to return the Zyxel Device to the factory defaults (password is 1234, LAN IP address 192.168.1.1 etc.)
CONSOLE
You can use the console port to manage the Zyxel Device using CLI commands. You will be prompted to enter your user name and password. See the Command Reference Guide for more information about the CLI.
When configuring using the console port, you need a computer equipped with communications software configured to the following parameters:
• Speed 115200 bps
• Data Bits 8
• Parity None
• Stop Bit 1
• Flow Control Off
USB
Connect a storage device for system logs (see Maintenance > Diagnostics > System Log) and storage (see Configuration > System > USB Storage).
P1 ~ P6
These are 1G RJ-45 Ethernet ports.
USG2200-VPN/USG2200 Front Panel Ports
Label
Description
RESET
BUZZER RESET
The buzzer alarms when a power module fails. Use this to mute the buzzer alarm.
CONSOLE
• Speed 115200 bps
• Data Bits 8
• Parity None
• Stop Bit 1
• Flow Control Off
USB
P1 ~ P4
These are SFP (1G) ports. These are compatible 1G transceiver modules (at the time of writing):
• SFP-1000T
• SFP-SX-D
• SFP-LX-10-D
• SFP-BX1310-10-D
• SFP-BX1490-10-D
• SFP-LHX1310-40-D
• SFP-ZX-80-D
P5 ~ P16
P17 ~ P18
These are 10G combo (SFP+ & RJ-45) ports. These are compatible 10G transceiver modules (at the time of writing:)
• SFP10G-SR
• SFP10G-LR
Rear Panels
The following table describes the items on the rear panel.
Rear Panel Items
Label
Description
Console
• Speed 115200 bps
• Data Bits 8
• Parity None
• Stop Bit 1
• Flow Control Off
Power
Use the included power cord to connect the power socket to a power outlet. Turn the power switch on if your Zyxel Device has a power switch.
Lock
Attach a lock-and-cable from the Kensington lock (the small, metal-reinforced, oval hole) to a permanent object, such as a pole, to secure the Zyxel Device in place.
Fan
The fans are for cooling the Zyxel Device. Make sure they are not obstructed to allow maximum ventilation.
Note: Use an 8-wire Ethernet cable to run your Gigabit Ethernet connection at 1000 Mbps. Using a 4-wire Ethernet cable limits your connection to 100 Mbps. Note that the connection speed also depends on what the Ethernet device at the other end can support.
Default Zones, Interfaces, and Ports
The default configurations for zones, interfaces, and ports are as follows. References to interfaces may be generic rather than the specific name used in your model. For example, this guide may use “the WAN interface” rather than “wan1” or “wan2”, “ge2” or” ge3” (USG2200-VPN/USG2200 is “ge5” or “ge6”).
An OPT (optional) Ethernet port can be configured as an additional WAN port, LAN, WLAN, or DMZ port.
The following table shows the default physical port and interface mapping for each model at the time of writing.
Default Physical Port - Interface Mapping
port / interface
p1
p2
p3
p4
p5
p6
p7
p8
• USG20-VPN
sfp
wan
lan1
lan1
lan1
lan1
• USG20W-VPN
sfp
wan
lan1
lan1
lan1
lan1
• USG40
wan1
lan1
lan1
lan1
opt
• USG40W
wan1
lan1
lan1
lan1
opt
• USG60
wan1
wan2
lan1
lan1
lan1
lan1
• USG60W
wan1
wan2
lan1
lan1
lan1
lan1
• ZyWALL 110
• USG110
• USG210
wan1
wan2
opt
lan1
lan1
lan1
dmz
• VPN50
sfp
wan
lan1
lan1
lan1
lan1
• VPN100
sfp
wan
wan
lan1
lan1
lan1
lan1
• ZyWALL 310
• ZyWALL 1100
• USG310
• USG1100
• USG1900
• VPN300
ge1
ge2
ge3
ge4
ge5
ge6
ge7
ge8
Default Physical Port - Interface Mapping - VPN1000
Port / Interface
P1
P2
P3
P4
P5
P6
P7
P8
P9
P10
P11
P12
P13
P14
VPN1000
ge1
ge2
ge3
ge4
ge5
ge6
ge7
ge8
ge9
ge10
ge11
ge12
ge13
ge14
Default Physical Port - Interface Mapping - USG2200-VPN/USG2200
Port / Interface
P1
P2
P3
P4
P5
P6
P7
P8
P9
P10
P11
P12
P13
P14
P15
P16
P17
P18
USG2200-VPN
USG2200
ge1
ge2
ge3
ge4
ge5
ge6
ge7
ge8
ge9
ge10
ge11
ge12
ge13
ge14
ge15
ge16
te1
te2
The following table shows the default interface and zone mapping for each model at the time of writing.
Default Zone - Interface Mapping
Zone / interface
wan
lan1
lan2
dmz
opt
no default zone
• USG20-VPN
• USG20W-VPN
• VPN50
WAN
WAN_PPP
LAN1
LAN2
DMZ
OPT
OPT_PPP
• USG40
WAN1
WAN1_PPP
LAN1
LAN2
DMZ
OPT
OPT_PPP
• USG40W
WAN1
WAN1_PPP
LAN1
LAN2
DMZ
OPT
OPT_PPP
• USG60
WAN1
WAN1_PPP
WAN2
WAN2_PPP
LAN1
LAN2
DMZ
• USG60W
WAN1
WAN1_PPP
WAN2
WAN2_PPP
LAN1
LAN2
DMZ
• ZyWALL 110
• USG110
• USG210
WAN1
WAN1_PPP
WAN2
WAN2_PPP
LAN1
LAN2
DMZ
OPT
OPT_PPP
• ZyWALL 310
• ZyWALL 1100
• USG310
• USG1100
• USG1900
GE1
GE1_PPP
GE2
GE2_PPP
GE3
GE4
GE5
GE3_PPP
GE4_PPP
GE5_PPP
GE6
GE7
GE8
• VPN100
WAN1
WAN1_PPP
WAN2
WAN2_PPP
LAN1
LAN2
DMZ
SFP
SFP_PPP
GE7
GE7_PPP
GE8
GE8_PPP
• VPN300
GE2
GE2_PPP
GE3
GE3_PPP
GE4
GE5
GE6
GE1
GE1_PPP
GE7
GE7_PPP
GE8
GE8_PPP
• VPN1000
GE1
GE1_PPP
GE2
GE2_PPP
GE3
GE4
GE5
GE13
GE13_PPP
GE14
GE14_PPP
GE6~GE12
GE6_PPP~GE12_PPP
GE1
GE1_PPP
GE2
GE2_PPP
Default Zone - Interface Mapping USG2200-VPN/USG2200
Zone / interface
wan
lan1
lan2
dmz
10G
no default zone
• USG2200-VPN
• USG2200
GE5, GE5_PPP
GE7
GE8
GE9, GE10
TE1, TE1_PPP
TE2, TE2_PPP
GE1, GE1_PPP
GE2, GE2_PPP
GE3, GE3_PPP
GE4, GE4_PPP
GE7_PPP
GE8_PPP
GE9_PPP
GE10_PPP
GE11, GE11_PPP
GE12, GE12_PPP
GE13, GE13_PPP
GE14, GE14_PPP
GE15, GE15_PPP
GE16, GE16_PPP
Stopping the Zyxel Device
Always use Maintenance > Shutdown > Shutdown or the shutdown command before you turn off the Zyxel Device or remove the power. Not doing so can cause the firmware to become corrupt.
