Printer Manager
Printer Manager Overview
You can create dynamic guest accounts and print guest account information by pressing the button on an external statement printer, such as SP350E.
Make sure that the printer is connected to the appropriate power and the Zyxel Device, and that there is printing paper in the printer. Refer to the printer’s documentation for details.
Printer Manager > General
Use this screen to configure a printer list and allow the Zyxel Device to monitor the printer status.
Configuration > Hotspot > Printer Manager > General
Label
Description
General Setting
Enable Printer Manager
Select the check box to allow the Zyxel Device to manage and monitor the printer status.
Printer Settings
Encryption
Select the check box to turn on data encryption. Data transmitted between the Zyxel Device and the printer will be encrypted with a secret key
Secret Key
Enter four alphanumeric characters (A-Z, a-z, 0-9) to specify a key for data encryption.
Printer List
Use this section to add the printer(s) that can be managed by the Zyxel Device.
Add
Click this to create a new entry.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings.
Remove
To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Discover Printer
Click this to discover the printer(s) that is connected to the Zyxel Device and display the printer information in a pop-up window. IPnP is enabled while discovering the printer and disabled when the discovering process has finished.
*You need a Hotspot license to use this feature.
Use Printer Manager > General > Add to manually configure a printer’s IP address and add it to the managed printer list when the printer is not detected or connected to the Zyxel Device.
Refresh
Click this to update the printer list table.
This field is a sequential value, and it is not associated with any entry.
Status
This icon is lit when the entry is active and dimmed when the entry is inactive. Click the Connection icon for the Zyxel Device connect to the printer.
IPv4 Address
This field displays the IP address of the printer.
Update Time
This field displays the date and time the Zyxel Device last synchronized with the printer.
This shows n/a when the printer is not in the managed printer list or the printer status is sync fail or sync progressing.
Status
This field is hidden by default. It displays whether the Zyxel Device can connect to the printer and update the printer information.
This shows n/a when the printer is not in the managed printer list.
Nickname
This shows an optional friendly name for the printer that you configured.
Firmware Version
This field displays the model number and firmware version of the printer.
This shows n/a when the printer is not in the managed printer list or the printer status is sync fail.
MAC
This shows the hardware MAC address of the printer.
Description
This field displays the descriptive name for the printer that you configured.
Printer Firmware Information
Current Version
This is the version of the printer firmware currently uploaded to the Zyxel Device. The Zyxel Device automatically installs it in the connected printers to make sure the printers are upgraded to the same version.
Hotspot Service Status
The hotspot license must be registered in order to be activated.
Service Status
This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service.
If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license.
Then, click Activate to connect with the myZyxel server to activate the new license.
Service Type
This shows whether you have a trial or standard license or none (Trial, Standard, None).
Expiration Date
This shows when your hotspot license will expire.
Apply
Click this button to save your changes to the Zyxel Device.
Reset
Click this button to return the screen to its last-saved settings.
Add Printer Rule
Use this screen to add a new printer.
Configuration > Hotspot > Printer Manager > General: Add
Label
Description
Select this option to turn on this entry in order to allow the Zyxel Device to manage this printer.
IPv4 Address
Enter an IPv4 address for the printer.
Description
Enter a description of this printer. You can use alphanumeric and ()+,/:=?!*#@$_%-” characters, and it can be up to 60 characters long.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving.
Edit Printer Rule
Use this screen to modify the printer’s settings. You can't click the Edit icon when the printer status is sync fail or sync progressing.
Configuration > Hotspot > Printer Manager > General: Edit
Label
Description
Nickname
Type an optional friendly name for the printer. A nickname must begin with a letter and cannot exceed 15 characters. Valid characters are [a-zA-Z0-9_-].
Description
IP Address Assignment
Get Automatically
Select this to make the printer a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server.
Use Fixed IP Address
Select this if you want to specify the IP address, subnet mask, and gateway manually.
IP Address
This field is enabled if you select Use Fixed IP Address.
Enter the IP address for the printer.
Subnet Mask
Enter the subnet mask of the printer in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers in the network.
Gateway
Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the printer.
OK
Cancel
Discover Printer
Use this screen to find connected printers or edit a connected printer’s settings. Use Printer Manager > General > Add to manually configure a printer’s IP address and add it to the managed printer list when the printer is not detected or connected to the Zyxel Device.
Configuration > Hotspot > Printer Manager > General > Discover Printer
Label
Description
Un-Mgnt Printer List / Mgnt Printer List
The tables displays according to whether the printer is in the unmanaged printer list (Un-Mgnt Printer List) or the managed printer list (Mgnt Printer List).
Edit
*You cannot edit an entry’s settings when the printer status is sync fail or sync progressing.
Add to Mgnt Printer List
Click this to add the selected printer to the managed printer list.
This is the index number of the printer in the list.
Registration
This field displays whether the printer is added to the managed printer list (Mgnt Printer) or not (Un-Mgnt Printer).
IPv4 Address
Update Time
Status
This field displays whether the Zyxel Device can connect to the printer and update the printer information.
Nickname
This field displays the optional friendly name of the printer that you configured.
Firmware Version
MAC
This field displays the MAC address of the printer.
Edit Printer Manager (Discover Printer)
Use this screen to modify the printer’s nickname and IP address.
Configuration > Hotspot > Printer Manager > General > Discover Printer: Edit
Label
Description
General Settings
Nickname
Get Automatically
IP Address
Subnet Mask
Gateway
OK
Cancel
Printout Configuration Screen
Use this screen to customize the account printout.
Configuration > Hotspot > Printer Manager > Printout Configuration
Label
Description
Use Default Printout Configuration
Select this to use the default account printout format built into the device. If you later create a custom account printout format, you can still return to the Zyxel Device’s default format as it is saved indefinitely.
Use Customized Printout Configuration
Select this to use a custom account printout format instead of the default one built into the Zyxel Device. Once this option is selected, the custom format controls below become active.
Preview
Click the button to display a preview of account printout format you uploaded to the Zyxel Device.
File Name
This shows the file name of account printout format file in the Zyxel Device.
Click Download to download the account printout format file from the Zyxel Device to your computer.
File Path / Browse / Upload
Browse for the account printout format file or enter the file path in the available input box, then click the Upload button to put it on the Zyxel Device.
Restore Customized File to Default
Click Restore to set the Zyxel Device back to use the default built-in account printout format.
Download
Click this to download an example account printout format file from the Zyxel Device for your reference.
Printout
Number of Copies
Select how many copies of subscriber statements you want to print (1 is the default).
Apply
Reset
Printer Reports Overview
The SP350E allows you to print status reports about the guest accounts and general Zyxel Device system information. Simply press a key combination on the SP350E to print a report instantly without accessing the web configurator.
The following lists the reports that you can print using the SP300E.
• Daily account summary
• Monthly account summary
• Last month account summary
• System status
Key Combinations
The following table lists the key combination to print each report.
Note: You must press the key combination on the SP350E within five seconds to print.
Report Printing Key Combinations
Report Type
Key Combination
Daily Account Summary
A B C A A
Monthly Account Summary
A B C B A
Last Month Account Summary
A B C B B
System Status
A B C C A
The following sections describe each report printout in detail.
The daily account report lists the accounts printed during the current day, the current day’s total number of accounts and the total charge. It covers the accounts that have been printed during the current day starting from midnight (not the past 24 hours). For example, if you press the daily account key combination on 2013/05/10 at 20:00:00, the daily account report includes the accounts created on 2013/05/10 between 00:00:01 and 19:59:59.
The monthly account report lists the accounts printed during the current month, the current month’s total number of accounts and the total charge. It covers the accounts that have been printed during the current month starting from midnight of the first day of the current month (not the past one month period). For example, if you press the monthly account key combination on 2013/05/17 at 20:00:00, the monthly account report includes the accounts created from 2013/05/01 at 00:00:01 to 2013/05/17 at 19:59:59.
Account Report Notes
The daily, monthly or last month account report holds up to 2000 entries. If there are more than 2000 accounts created in the same month or same day, the account report’s calculations only include the latest 2000.
For example, if 2030 accounts (each priced at $1) have been created from 2013/05/01 00:00:00 to 2013/05/31 19:59:59, the monthly account report includes the latest 2000 accounts, so the total would be $2,000 instead of $2,030.
Use the Monitor > System Status > Dynamic Guest screen to see the accounts generated on another day or month (up to 2000 entries total).
System Status
This report shows the current system information such as the host name and WAN IP address.
System Status
label
description
SYST
This field displays the time since the system was last restarted.
WAST
This field displays the WAN connection status.
WLST
This field displays the status of the Zyxel Device’s wireless LAN.
FWVR
This field displays the version of the firmware on the Zyxel Device.
BTVR
This field displays the version of the bootrom.
WAMA
This field displays the MAC address of the Zyxel Device on the WAN.
LAMA
This field displays the MAC address of the Zyxel Device on the LAN.
WAIP
This field displays the IP address of the WAN port on the Zyxel Device.
LAIP
This field displays the IP address of the LAN port on the Zyxel Device.
WLIP
This field displays the IP address of the wireless LAN interface on the Zyxel Device.
DHSP
This field displays the first of the continuous addresses in the IP address pool.
DHEP
This field displays the end of the continuous addresses in the IP address pool.
CPUS
This field displays the Zyxel Device’s recent CPU usage.
MEMS
This field displays the Zyxel Device’s recent memory usage.
DKST
This field displays what percentage of the Zyxel Device’s on-board flash memory is currently being used.
