Label | Description |
Enable Layer2 Isolation | Select this option to turn on the layer-2 isolation feature on the Zyxel Device. |
Member List | The Available list displays the name(s) of the internal interface(s) on which you can enable layer-2 isolation. To enable layer-2 isolation on an interface, you can double-click a single entry to move it or use the [Shift] or [Ctrl] key to select multiple entries and click the right arrow button to add to the Member list. To remove an interface, select the name(s) in the Member list and click the left arrow button. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Enable White List | Select this option to turn on the white list on the Zyxel Device. |
Add | Click this to add a new rule. |
Edit | Click this to edit the selected rule. |
Remove | Click this to remove the selected rule. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
# | This field is a sequential value, and it is not associated with a specific rule. |
Status | This icon is lit when the rule is active and dimmed when the rule is inactive. |
IP Address | This field displays the IP address of device that can be accessed by the devices connected to an internal interface on which layer-2 isolation is enabled. |
Description | This field displays the description for the IP address in this rule. |
Enable | Select this option to turn on the rule. |
Host IP Address | Enter an IPv4 address associated with this rule. |
Description | Specify a description for the IP address associated with this rule. Enter up to 60 characters, spaces and underscores allowed. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
