Port | TCP/UDP | Description |
1 | TCP | TCP Port Service Multiplexer (TCPMUX) |
20 | TCP | FTP - Data |
21 | TCP | FTP - Control |
22 | TCP | SSH Remote Login Protocol |
23 | TCP | Telnet |
25 | TCP | Simple Mail Transfer Protocol (SMTP) |
42 | UDP | Host Name Server (Nameserv) |
43 | TCP | WhoIs |
53 | TCP/UDP | Domain Name System (DNS) |
67 | UDP | BOOTP/DHCP server |
68 | UDP | BOOTP/DHCP client |
69 | UDP | Trivial File Transfer Protocol (TFTP) |
79 | TCP | Finger |
80 | TCP | HTTP |
110 | TCP | POP3 |
119 | TCP | Newsgroup (NNTP) |
123 | UDP | Network Time Protocol (NTP) |
135 | TCP/UDP | RPC Locator service |
137 | TCP/UDP | NetBIOS Name Service |
138 | UDP | NetBIOS Datagram Service |
139 | TCP | NetBIOS Datagram Service |
143 | TCP | Interim Mail Access Protocol (IMAP) |
161 | UDP | SNMP |
179 | TCP | Border Gateway Protocol (BGP) |
389 | TCP/UDP | Lightweight Directory Access Protocol (LDAP) |
443 | TCP | HTTPS |
445 | TCP | Microsoft - DS |
636 | TCP | LDAP over TLS/SSL (LDAPS) |
953 | TCP | BIND DNS |
990 | TCP | FTP over TLS/SSL (FTPS) |
995 | TCP | POP3 over TLS/SSL (POP3S) |
Label | Description |
Use Static-Dynamic Route to Control 1-1 NAT Route | If you are using SiteToSite VPN and 1-1 SNAT, it’s recommended that you select this checkbox. Otherwise, you’ll need to create policy route rules for VPN and destination NAT traffic. Note that the selection of this checkbox will change the priority of the routing flow (SiteToSite VPN, Static-Dynamic Route, and 1-1 SNAT). See Packet Flow Explore for more information about the packet flow. |
Add | Click this to create a new entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move | To change an entry’s position in a numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed. For example, if you type 6, the entry you are moving becomes number 6 and the previous entry 6 (if there is one) gets pushed up (or down) one. |
# | This field is a sequential value, and it is not associated with a specific entry. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Priority | This field displays the priority level of the entry. |
Name | This field displays the name of the entry. |
Mapping Type | This field displays what kind of NAT this entry performs: Virtual Server, 1:1 NAT, or Many 1:1 NAT. |
Interface | This field displays the interface on which packets for the NAT entry are received. |
Source IP | This field displays the source IP address (or address object) of traffic that matches this NAT entry. It displays any if there is no restriction on the source IP address. |
External IP | This field displays the external destination IP address (or address object) of traffic that matches this NAT entry. It displays any if there is no restriction on the external destination IP address. |
Internal IP | This field displays the new destination IP address for the packet. |
Protocol | This field displays the service used by the packets for this NAT entry. It displays any if there is no restriction on the services. |
External Port | This field displays the external destination port(s) of packets for the NAT entry. This field is blank if there is no restriction on the external destination port. |
Internal Port | This field displays the new destination port(s) for the packet. This field is blank if there is no restriction on the external destination port. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Create new Object | Use to configure any new settings objects that you need to use in this screen. |
Enable Rule | Use this option to turn the NAT rule on or off. |
Rule Name | Type in the name of the NAT rule. The name is used to refer to the NAT rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Classification | Select what kind of NAT this rule is to perform. Virtual Server - This makes computers on a private network behind the Zyxel Device available to a public network outside the Zyxel Device (like the Internet). 1:1 NAT - If the private network server will initiate sessions to the outside clients, select this to have the Zyxel Device translate the source IP address of the server’s outgoing traffic to the same public IP address that the outside clients use to access the server. Many 1:1 NAT - If you have a range of private network servers that will initiate sessions to the outside clients and a range of public IP addresses, select this to have the Zyxel Device translate the source IP address of each server’s outgoing traffic to the same one of the public IP addresses that the outside clients use to access the server. The private and public ranges must have the same number of IP addresses. One many 1:1 NAT rule works like multiple 1:1 NAT rules, but it eases configuration effort since you only create one rule. |
Incoming Interface | Select the interface on which packets for the NAT rule must be received. It can be an Ethernet, VLAN, bridge, or PPPoE/PPTP interface. |
Source IP | Specify the source IP address of the packets received by this NAT rule’s specified incoming interface. any - Select this to use all of the incoming interface’s IP addresses including dynamic addresses or those of any virtual interfaces built upon the selected incoming interface. User Defined - Select this to manually enter an IP address in the User Defined field. For example, you could enter a static IP address. Host address - select a address object to use the IP address it specifies. |
External IP | Specify the destination IP address of the packets received by this NAT rule’s specified incoming interface. The specified IP address will be translated to the Internal IP address. any - Select this to use all of the incoming interface’s IP addresses including dynamic addresses or those of any virtual interfaces built upon the selected incoming interface. User Defined - Select this to manually enter an IP address in the User Defined field. For example, you could enter a static public IP assigned by the ISP without having to create a virtual interface for it. Host address - select a host address object to use the IP address it specifies. The list also includes address objects based on interface IPs. So for example you could select an address object based on a WAN interface even if it has a dynamic IP address. |
User Defined External IP | This field is available if External IP is User Defined. Type the destination IP address that this NAT rule supports. |
External IP Subnet/Range | This field displays for Many 1:1 NAT. Select the destination IP address subnet or IP address range that this NAT rule supports. The external and internal IP address subnets or ranges must have the same number of IP addresses. |
Internal IP | Select to which translated destination IP address this NAT rule forwards packets. User Defined - this NAT rule supports a specific IP address, specified in the User Defined field. HOST address - the drop-down box lists all the HOST address objects in the Zyxel Device. If you select one of them, this NAT rule supports the IP address specified by the address object. |
User Defined Internal IP | This field is available if Internal IP is User Defined. Type the translated destination IP address that this NAT rule supports. |
Internal IP Subnet/Range | This field displays for Many 1:1 NAT. Select to which translated destination IP address subnet or IP address range this NAT rule forwards packets. The external and Internal IP address subnets or ranges must have the same number of IP addresses. |
Port Mapping Type | Use the drop-down list box to select how many external destination ports this NAT rule supports for the selected destination IP address (External IP). Choices are: Any - this NAT rule supports all the destination ports. Port - this NAT rule supports one destination port. Ports - this NAT rule supports a range of destination ports. You might use a range of destination ports for unknown services or when one server supports more than one service. Service - this NAT rule supports a service such as FTP (see Object > Service > Service) Service-Group - this NAT rule supports a group of services such as all service objects related to DNS (see Object > Service > Service Group) |
Protocol Type | This field is available if Mapping Type is Port or Ports. Select the protocol (TCP, UDP, or Any) used by the service requesting the connection. |
External Port | This field is available if Mapping Type is Port. Enter the external destination port this NAT rule supports. |
Internal Port | This field is available if Mapping Type is Port. Enter the translated destination port if this NAT rule forwards the packet. |
External Start Port | This field is available if Mapping Type is Ports. Enter the beginning of the range of external destination ports this NAT rule supports. |
External End Port | This field is available if Mapping Type is Ports. Enter the end of the range of external destination ports this NAT rule supports. |
Internal Start Port | This field is available if Mapping Type is Ports. Enter the beginning of the range of translated destination ports if this NAT rule forwards the packet. |
Internal End Port | This field is available if Mapping Type is Ports. Enter the end of the range of translated destination ports if this NAT rule forwards the packet. The external port range and the internal port range must be the same size. |
Enable NAT Loopback | Enable NAT loopback to allow users connected to any interface (instead of just the specified Incoming Interface) to use the NAT rule’s specified External IP address to access the Internal IP device. For users connected to the same interface as the Internal IP device, the Zyxel Device uses that interface’s IP address as the source address for the traffic it sends from the users to the Internal IP device. For example, if you configure a NAT rule to forward traffic from the WAN to a LAN server, enabling NAT loopback allows users connected to other interfaces to also access the server. For LAN users, the Zyxel Device uses the LAN interface’s IP address as the source address for the traffic it sends to the LAN server. If you do not enable NAT loopback, this NAT rule only applies to packets received on the rule’s specified incoming interface. |
Security Policy | By default the security policy blocks incoming connections from external addresses. After you configure your NAT rule settings, click the Security Policy link to configure a security policy to allow the NAT rule’s traffic to come in. The Zyxel Device checks NAT rules before it applies To-Zyxel Device security policies, so To-Zyxel Device security policies, do not apply to traffic that is forwarded by NAT rules. The Zyxel Device still checks other security policies, according to the source IP address and internal IP address. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to return to the NAT summary screen without creating the NAT rule (if it is new) or saving any changes (if it already exists). |
