Object Type | Object screen | Description |
User Accounts | User Account/ User Group | Configure a user account or user group to which you want to apply this SSL access policy. |
Application | SSL Application | Configure an SSL application object to specify the type of application and the address of the local computer, server, or web site SSL users are to be able to access. |
IP Pool | Address | Configure an address object that defines a range of private IP addresses to assign to user computers so they can access the internal network through a VPN connection. |
Server Addresses | Address | Configure address objects for the IP addresses of the DNS and WINS servers that the Zyxel Device sends to the VPN connection users. |
VPN Network | Address | Configure an address object to specify which network segment users are allowed to access through a VPN connection. |
label | description |
Access Policy Summary | This screen shows a summary of SSL VPN policies created. Click on the VPN icon to go to the Zyxel VPN Client product page at the Zyxel website. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move | To move an entry to a different number in the list, click the Move icon. In the field that appears, specify the number to which you want to move the interface. |
References | Select an entry and click References to open a screen that shows which settings use the entry.Click Refresh to update information on this screen. |
# | This field displays the index number of the entry. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Name | This field displays the descriptive name of the SSL access policy for identification purposes. |
User/Group | This field displays the user account or user group name(s) associated to an SSL access policy. This field displays up to three names. |
Access Policy Summary | This field displays details about the SSL application object this policy uses including its name, type, and address. |
Apply | Click Apply to save the settings. |
Reset | Click Reset to discard all changes. |
Create new Object | Use to configure any new settings objects that you need to use in this screen. |
Configuration | |
Enable Policy | Select this option to activate this SSL access policy. |
Name | Enter a descriptive name to identify this policy. You can enter up to 31 characters (“a-z”, A-Z”, “0-9”) with no spaces allowed. |
Zone | Select the zone to which to add this SSL access policy. You use zones to apply security settings such as security policy and remote management. |
Description | Enter additional information about this SSL access policy. You can enter up to 60 characters ("0-9", "a-z", "A-Z", "-" and "_"). |
User/Group | The Selectable User/Group Objects list displays the name(s) of the user account and/or user group(s) to which you have not applied an SSL access policy yet. To associate a user or user group to this SSL access policy, select a user account or user group and click the right arrow button to add to the Selected User/Group Objects list. You can select more than one name. To remove a user or user group, select the name(s) in the Selected User/Group Objects list and click the left arrow button. |
SSL Application List (Optional) | The Selectable Application Objects list displays the name(s) of the SSL application(s) you can select for this SSL access policy. To associate an SSL application to this SSL access policy, select a name and click the right arrow button to add to the Selected Application Objects list. You can select more than one application. To remove an SSL application, select the name(s) in the Selected Application Objects list and click the left arrow button. |
Network Extension (Optional) | |
Enable Network Extension | Select this option to create a VPN tunnel between the authenticated users and the internal network. This allows the users to access the resources on the network as if they were on the same local network. This includes access to resources not supported by SSL application objects. For example this lets users Telnet to the internal network even though the Zyxel Device does not have SSL application objects for Telnet. Clear this option to disable this feature. Users can only access the applications as defined by the VPN tunnel’s selected SSL application settings and the remote user computers are not made to be a part of the local network. |
Force all client traffic to SSL VPN tunnel | Select this to send all traffic from the SSL VPN clients through the SSL VPN tunnel. This replaces the default gateway of the SSL VPN clients with the SSL VPN gateway. |
NetBIOS broadcast over SSL VPN Tunnel | Select this to search for a remote computer and access its applications as if it was in a Local Area Network. The user can find a computer not only by its IP address but also by computer name. |
Assign IP Pool | Define a separate pool of IP addresses to assign to the SSL users. Select it here. The SSL VPN IP pool should not overlap with IP addresses on the Zyxel Device's local networks (LAN and DMZ for example), the SSL user's network, or the networks you specify in the SSL VPN Network List. |
DNS/WINS Server 1..2 | Select the name of the DNS or WINS server whose information the Zyxel Device sends to the remote users. This allows them to access devices on the local network using domain names instead of IP addresses. |
Network List | To allow user access to local network(s), select a network name in the Selectable Address Objects list and click the right arrow button to add to the Selected Address Objects list. You can select more than one network. To block access to a network, select the network name in the Selected Address Objects list and click the left arrow button. |
OK | Click OK to save the changes and return to the main Access Privilege screen. |
Cancel | Click Cancel to discard all changes and return to the main Access Privilege screen. |
Global Setting | |
Network Extension Local IP | Specify the IP address of the Zyxel Device (or a gateway device) for full tunnel mode SSL VPN access. Leave this field to the default settings unless it conflicts with another interface. |
SSL VPN Login Domain Name | |
SSL VPN Login Domain Name 1/2 | Specify a full domain name for users to use for SSL VPN login. The domain name must be registered to one of the Zyxel Device’s IP addresses or be one of the Zyxel Device’s DDNS entries. You can specify up to two domain names so you could use one domain name for each of two WAN ports. For example, www.zyxel.com is a fully qualified domain name where “www” is the host. The Zyxel Device displays the normal login screen without the button for logging into the Web Configurator. |
Message | |
Login Message | Specify a message to display on the screen when a user logs in and an SSL VPN connection is established successfully. You can enter up to 60 characters (0-9, a-z, A-Z, '()+,/:=?;!*#@$_%-") with spaces allowed. |
Logout Message | Specify a message to display on the screen when a user logs out and the SSL VPN connection is terminated successfully. You can enter up to 60 characters (0-9, a-z, A-Z, '()+,/:=?;!*#@$_%-") with spaces allowed. |
Update Client Virtual Desktop Logo | You can upload a graphic logo to be displayed on the web browser on the remote user computer. The Zyxel company logo is the default logo. Specify the location and file name of the logo graphic or click Browse to locate it. |
Browse | Click Browse to locate the graphic file on your computer. |
Upload | Click Upload to transfer the specified graphic file from your computer to the Zyxel Device. |
Reset Logo to Default | Click Reset Logo to Default to display the Zyxel company logo on the remote user’s web browser. |
Apply | Click Apply to save the changes and/or start the logo file upload process. |
Reset | Click Reset to return the screen to its last-saved settings. |
