Shutdown/Reboot
Overview
Use this to shutdown the device in preparation for disconnecting the power.
Always use the Maintenance > Shutdown > Shutdown screen or the “shutdown” command before you turn off the Zyxel Device or remove the power. Not doing so can cause the firmware to become corrupt.
Shutdown writes all cached data to the local storage and stops the system processes.
Maintenance> Shutdown/ Reboot
label | description |
Shutdown | Click the Shutdown button to shut down the Zyxel Device. Wait for the device to shut down before you manually turn off or remove the power. It does not turn off the power. |
Reboot | Click Reboot to reboot the Zyxel Device immediately without turning the power off. |
Schedule Reboot | Select this check box to schedule a periodic reboot of the Zyxel Device. You should select a time when your network is not busy for minimal interruption.  You cannot enable Auto Update in File Manager> Firmware Management and Schedule Reboot in Maintenance> Shutdown-Reboot at the same time. |
Daily | Set the Zyxel Device to reboot every day at the specified time. The time format is the 24 hour clock, so ‘0’ means midnight for example. |
Weekly | Set the Zyxel Device to reboot once a week on the day and at the time specified. |
Monthly | Set the Zyxel Device to reboot once a month on the specified day, at the specified hour and minute.  If the date you select is greater than the number of days in a month, the Zyxel Device automatically backs up its configuration on the last day of the month. For example, if you select 31 and the month is February, the Zyxel Device backs up its configuration file on day 28 or 29. |
Apply | Click Apply to save you change back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
You can also use the CLI command shutdown to close down the Zyxel Device.
