Hardware Installation and Connection
Front Panel Connections
The following table describes the ports. To see the port details, please refer to the XGS1935 Series Comparison Table.
Panel Connections
CONNECTOR
description
10M, 100M, and 1G RJ-45 Ethernet Ports
These are 10/100/1000Base-T auto-negotiating and auto-crossover Ethernet ports.
Connect these ports to a computer, a hub, a router, or an Ethernet switch.
10M, 100M, and 1G PoE+ Ports
10G SFP+ Slots
Use SFP+ transceivers in these ports for high-bandwidth backbone connections. You can also insert an SFP+ Direct Attach Copper (DAC) in the SFP+ slot.
RESET
Press the RESET button to reboot the Switch without turning the power off.
RESTORE
Standalone Mode:
Press the RESTORE button for 3 to 7 seconds to have the Switch automatically reboot and restore the last-saved custom default file.
Press the RESTORE button for more than 7 seconds to have the Switch automatically reboot and restore the factory default file.
Cloud Mode:
Press the RESTORE button for more than 3 seconds to have the Switch automatically reboot and restore the factory default file.
LEDs
After you connect the power to the Switch, view the LEDs to ensure proper functioning of the Switch and as an aid in troubleshooting.
LED Descriptions
LED
Color
Status
Description
PWR
Green
On
The Switch is on and functioning properly.
Blinking
The Switch is returning to the custom default configuration settings.
Amber
On
The Switch is returning to its factory default configuration settings.
Off
The Switch is not receiving power from the power module in the power slot.
SYS
Green
On
Blinking
The Switch is rebooting and performing self-diagnostic tests.
Red
On
The Switch is functioning abnormally.
Off
The power is off or the Switch is not ready or malfunctioning.
CLOUD
Green
On
The Switch has successfully connected to the NCC (Nebula Control Center).
Blinking
The Switch cannot connect to the NCC because it is not registered. Please register the Switch with NCC.
Amber
On
The Switch is registered with NCC but cannot connect to the NCC. Please check the Internet connection of the Switch.
Blinking
The Switch is not registered with NCC and cannot connect to the NCC. Please check the Internet connection of the Switch and register the Switch with NCC.
Off
The Switch is operating in standalone mode. Nebula Control Center (NCC) Discovery is disabled in SYSTEM > Cloud Management in the Switch Web Configurator.
LOCATOR
Blue
On
The Switch is uploading firmware. While the Switch is doing this, do not turn off the power.
Blinking
Shows the actual location of the Switch between several devices in a rack. The default timer is 30 minutes when you are configuring the Switch.
Off
The locator is not functioning or malfunctioning.
PoE MAX
(XGS1935-28HP and XGS1935-52HP)
Red
On
PoE power usage is more than 95 percent of the power supplied budget.
Amber
On
PoE power usage is below 95 percent of the power supplied budget, but over 80 percent of the power supplied budget.
Off
PoE power usage is below 80 percent of the power supplied budget.
