Introduction
Introduction
Overview
Zyxel Device refers to these models as outlined below.
• ZyWALL
• ZyWALL USG (Unified Security Gateway)
• ZyWALL 110
• USG40W
• USG210
• USG2200
• ZyWALL 310
• USG60
• USG310
• USG20-VPN
• ZyWALL 1100
• USG60W
• USG1100
• USG20W-VPN
• USG40
• USG110
• USG1900
• USG2200-VPN
Besides performance variance, the following are the key feature differences between the models:
• UTM (Unified Threat Management) features include the following:
• Application Patrol (AP)
• Intrusion Detection & Prevention (IDP)
• Anomaly Detection & Prevention (ADP)
• Content Filtering (CF)
• Anti-Virus (AV)
• Anti-Spam (AS)
• Secure Socket Layer (SSL) encrypted traffic Inspection
• ZyWALL models need a license for UTM functionality. USG models need a UTM license after one yearThe following UTM features work without a UTM license:
• Configuration > Content Filter > Trusted Web Sites
• Configuration > IDP > Custom Signatures
• Configuration > Anti-Virus > Black/White List
• Configuration > Anti-Spam > Black/White List
• The following models support SSL Inspection. You must enable SSL Inspection if you want to use Content Filtering 2.0 Safe Search.
• ZyWALL 110
• ZyWALL 310
• ZyWALL 1100
• USG110
• USG210
• USG310
• USG1100
• USG1900
• USG2200-VPN
• USG2200
• USG40 / USG40W / USG60 / USG60W support UTM but not SSL Inspection
• USG20-VPN and USG20W-VPN support UTM consisting of Content Filter and Anti-Spam
• USG2200-VPN support UTM consisting of Content Filter, Anti-Spam and SSL Inspection
• The following models support Hotspot management:
• ZyWALL 110
• ZyWALL 310
• ZyWALL 1100
• USG110
• USG210
• USG310
• USG1100
• USG1900
• USG2200-VPN
• USG2200
• USG20W-VPN, USG40W, USG60W have built-in Wi-Fi functionality.
• USG20W-VPN do not support the AP controller function.
• Models that came with firmware versions 4.10 to 4.25 support both Device HA and Device HA Pro even after upgrading to versions 4.30 and later:
• ZyWALL 110
• ZyWALL 310
• ZyWALL 1100
• USG110
• USG210
• USG310
• USG1100
• USG1900
• USG2200-VPN
• USG2200
• The following table shows the models that support port role.
• ZyWALL 110
• USG60W
• USG40
• USG110
• USG40W
• USG210
• USG60
• The following table shows the models that support port group.
• USG2200-VPN
• USG2200
• The following models support Link Aggregation Group (LAG):
• ZyWALL 310
• ZyWALL 1100
• USG310
• USG1100
• USG1900
• The following models have Easy Mode wizards. Initial setup wizards for these models have a different style to the other models.You can use the web configurator to configure Amazon VPC on ZyWALL USG20-VPN/USG20W-VPN/USG2200-VPN. You must use the Command Line Interface to configure Amazon VPC on the other Zyxel Devices.
• USG20-VPN
• USG20W-VPN
• USG40
• USG40W
• USG60
• USG60W
• Some interface names vary by model.
See the product’s datasheet for detailed information on a specific model.
Registration at myZyxel
myZyxel is Zyxel’s online services center where you can register your Zyxel Device and manage subscription services available for your Zyxel Device (see Configuration > Licensing > Registration > Service for services available for your Zyxel Device).
• For Zyxel Devices that already have firmware version 4.25 or later, you have to register your Zyxel Device and activate the corresponding service at myZyxel (through your Zyxel Device).
• For Zyxel Devices upgrading to firmware version 4.25 or later, you may skip registering your Zyxel Device and activating the corresponding service at myZyxel (through your Zyxel Device). However, it is highly recommended to at least register your Zyxel Device. At the time of writing, the Firmware Upgrade license providing Cloud Helper new firmware notifications, is free when you register your Zyxel Device.
Note: You need to create a myZyxel account at http://portal.myZyxel.com before you can register your device and activate the services at myZyxel.
You may need your Zyxel Device’s serial number and LAN MAC address to register it at myZyxel. See the label at the back of the Zyxel Device’s for details.
Grace Period
UTM licenses have a 15-day grace period after a license expires. Services will continue to work in this period during which you will receive notifications to renew your license(s). New license(s) are valid for 1 year from the date of purchase.
Applications
These are some Zyxel Device application scenarios.
Security Router
Security includes a Stateful Packet Inspection (SPI) firewall, and UTM (Unified Threat Management). All models need a license to use UTM (Unified Threat Management) features.
IPv6 Routing
The Zyxel Device supports IPv6 Ethernet, PPP, VLAN, and bridge routing. You may also create IPv6 policy routes and IPv6 objects. The Zyxel Device can also route IPv6 packets through IPv4 networks using different tunneling methods.
VPN Connectivity
Set up VPN tunnels with other companies, branch offices, telecommuters, and business travelers to provide secure access to your network. AS is an Authentication Server in the below figure.
SSL VPN Network Access
SSL VPN lets remote users use their web browsers for a very easy-to-use VPN solution. A user just browses to the Zyxel Device’s web address and enters his user name and password to securely connect to the Zyxel Device’s network. Here full tunnel mode creates a virtual connection for a remote user and gives him a private IP address in the same subnet as the local network so he can access network resources in the same way as if he were part of the internal network.
User-Aware Access Control
Set up security policies to restrict access to sensitive information and shared resources based on the user who is trying to access it. In the following figure user A can access both the Internet and an internal file server. User B has a lower level of access and can only access the Internet. User C is not even logged in, so and cannot access either the Internet or the file server.
Load Balancing
Set up multiple connections to the Internet on the same port, or different ports, including cellular interfaces. In either case, you can balance the traffic loads between them.
Management Overview
Web Configurator
The Web Configurator allows easy Zyxel Device setup and management using an Internet browser.
Command-Line Interface (CLI)
The CLI allows you to use text-based commands to configure the Zyxel Device. Access it using remote management (for example, SSH or Telnet) or via the physical or Web Configurator console port. See the Command Reference Guide for CLI details. The default settings for the console port are:
Console Port Default Settings
Setting
Value
Speed
115200 bps
Data Bits
8
Parity
None
Stop Bit
Flow Control
Off
Web Configurator
In order to use the Web Configurator, you must:
• Use one of the following web browser versions or later: Internet Explorer 10.x, 11.x
• Chrome latest version (45 or above)
• Firefox latest version (45 or above)
• Safari latest version (9.0 or above)
• Allow pop-up windows (blocked by default in some browsers)
• Enable JavaScripts, Java permissions, and cookies
The recommended screen resolution is 1024 x 768 pixels.
Web Configurator Access
1 Make sure your Zyxel Device hardware is properly connected. See the Quick Start Guide.
2 In your browser go to http://192.168.1.1. By default, the Zyxel Device automatically routes this request to its HTTPS server, and it is recommended to keep this setting. The Login screen appears.Type the user name (default: “admin”) and password (default: “1234”).
If you have a OTP (One-Time Password) token generate a number and enter it in the One-Time Password field. The number is only good for one login. You must use the token to generate a new number the next time you log in.
3 Click Login. After you log in for the first time using the default user name and password, you must change the default admin password in the Update Admin Info screen. Enter a new password of from 1 to 64 characters.
In Configuration > Object > User/Group > Setting, you can enable Password Complexity to require a new password to consist of at least 8 characters and at most 64, where at least 1 character must be a number, at least 1 a lower case letter, at least 1 an upper case letter and at least 1 a special character from the keyboard, such as !@#$%^&*()_+. You can also require periodic changing of the password in that screen by configuring Password must changed every (days).
Make a note of your new password, enter it in the following screen, then click Apply.
4 A Terms of Use screen displays. Read the statement, select the checkbox, and then click Acknowledge to proceed.
5 The Network Risk Warning screen displays any unregistered or disabled security services. If your Zyxel Device is not registered, you will see a prompt to register it. Select how often to display the screen and click OK.
6 Follow the directions in the Update Admin Info screen. If you change the default password, the Login screen appears after you click Apply. If you click Ignore, the Installation Setup Wizard opens if the ZyWALL is using its default configuration; otherwise the dashboard appears.
Web Configurator Screens Overview
The Web Configurator screen is divided into these parts:
• A - title bar
• B - navigation panel
• C - main window
Title Bar
The title bar icons in the upper right corner provide the following functions.
Title Bar: Web Configurator Icons
Label
Description
Logout
Click this to log out of the Web Configurator.
Help
Click this to open the help page for the current screen.
Forum
Go to https://businessforum.zyxel.com for product discussions.
About
Click this to display basic information about the Zyxel Device.
Site Map
Click this to see an overview of links to the Web Configurator screens.
Reference
Click this to check which configuration items reference an object.
Console
Click this to open a Java-based console window from which you can run command line interface (CLI) commands. You will be prompted to enter your user name and password. See the Command Reference Guide for information about the commands.
CLI
Click this to open a popup window that displays the CLI commands sent by the Web Configurator to the Zyxel Device.
Easy Mode
Click this to
About
Click About to display basic information about the Zyxel Device.
About
Label
Description
Current Version
This shows the firmware version of the Zyxel Device.
Released Date
This shows the date (yyyy-mm-dd) and time (hh:mm:ss) when the firmware is released.
OK
Click this to close the screen.
Site Map
Click Site MAP to see an overview of links to the Web Configurator screens.
Reference
Select the type of object and the individual object and click Refresh to show which configuration settings reference the object.
The fields vary with the type of object. This table describes labels that can appear in this screen.
References
Label
Description
Type
Select the type of reference from the drop-down list box.
Name
Select the specific reference for the type selected. The settings then display in the table below.
This field is a sequential value, and it is not associated with any entry.
Service
This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window.
Priority
If it is applicable, this field lists the referencing configuration item’s position in its list, otherwise N/A displays.
Name
This field identifies the configuration item that references the object.
Description
If the referencing configuration item has a description configured, it displays here.
Refresh
Click this to update the information in this screen.
Cancel
Click Cancel to close the screen.
Console
Click Console to open a Java-based console window from which you can run CLI commands. You will be prompted to enter your user name and password. See the Command Reference Guide for information about the commands.
CLI Messages
Click CLI to look at the CLI commands sent by the Web Configurator. Open the pop-up window and then click some menus in the web configurator to display the corresponding commands.
Navigation Panel
Use the navigation panel menu items to open status and configuration screens. Click the arrow in the middle of the right edge of the navigation panel to hide the panel or drag to resize it. The following sections introduce the Zyxel Device’s navigation panel menus and their screens.
Dashboard
The dashboard displays general device information, system status, system resource usage, licensed service status, and interface status in widgets that you can re-arrange to suit your needs.
Monitor Menu
The monitor menu screens display status and statistics information.
Monitor Menu Screens Summary
Folder or Link
Tab
Function
System Status
Port Statistics
Port Statistics
Displays packet statistics for each physical port.
Interface Status
Interface Summary
Displays general interface information and packet statistics.
Traffic Statistics
Traffic Statistics
Collect and display traffic statistics.
Session Monitor
Session Monitor
Displays the status of all current sessions.
IGMP Statistics
IGMP Statistics
Collect and display IGMP statistics.
DDNS Status
DDNS Status
Displays the status of the Zyxel Device’s DDNS domain names.
IP/MAC Binding
IP/MAC Binding
Lists the devices that have received an IP address from Zyxel Device interfaces using IP/MAC binding.
Login Users
Login Users
Lists the users currently logged into the Zyxel Device.
Dynamic Guest
Dynamic Guest
List the dynamic guest accounts in the Zyxel Device’s local database.
Cellular Status
Cellular Status
Displays details about the Zyxel Device’s mobile broadband connection status.
UPnP Port Status
Port Statistics
Displays details about UPnP connections going through the Zyxel Device.
USB Storage
Storage Information
Displays details about USB device connected to the Zyxel Device.
Ethernet Neighbor
Ethernet Neighbor
View and manage the Zyxel Device’s neighboring devices via Smart Connect (Layer Link Discovery Protocol (LLDP)). Use the Zyxel One Network (ZON) utility to view and manage the Zyxel Device’s neighboring devices via the Zyxel Discovery Protocol (ZDP).
FQDN Object
FQDN Object
Displays FQDN (Fully Qualified Domain Name) object cache lists used in DNS queries.
Wireless
AP Information
AP List
Lists APs managed by the Zyxel Device.
Radio List
Lists wireless details of APs managed by the Zyxel Device.
Top N APs
Lists managed APs with the most wireless traffic usage and most associated wireless stations.
Single AP
Lists APs wireless traffic usage and associated wireless stations for a managed AP.
ZyMesh
ZyMesh Link Info
Display statistics about ZyMesh wireless connections between managed APs.
SSID Info
SSID Info
Display information about the SSID’s wireless clients.
Station Info
Station List
Lists wireless clients associated with the APs managed by the Zyxel Device.
Top N Stations
Lists wireless stations with the most wireless traffic usage.
Single Station
Lists wireless traffic usage for an associated wireless station.
Detected Device
Detected Device
Display information about suspected rogue APs.
Printer Status
Printer Status
Display information about the connected statement printers.
VPN Monitor
IPSec
IPSec
Displays and manages the active IPSec SAs.
SSL
SSL
Lists users currently logged into the VPN SSL client portal. You can also log out individual users and delete related session information.
L2TP over IPSec
L2TP over IPSec
Displays details about current L2TP sessions.
UTM Statistics
App Patrol
AppPatrol Statistics
Displays application patrol statistics.
Content Filter
Report
Collect and display content filter statistics
IDP
IDP
Collect and display statistics on the intrusions that the Zyxel Device has detected.
Anti-Virus
Anti-Virus
Collect and display statistics on the viruses that the Zyxel Device has detected.
Anti-Spam
Report
Collect and display spam statistics.
Status
Displays how many mail sessions the ZyWALL is currently checking and DNSBL (Domain Name Service-based spam Black List) statistics.
SSL Inspection
Report
Collect and display SSL Inspection statistics.
Certificate Cache List
Displays traffic to destination servers using certificates.
Log
View Log
Lists log entries.
View AP Log
Lists AP log entries.
Dynamic Users Log
Display the Zyxel Device’s dynamic guest account log messages.
Configuration Menu
Use the configuration menu screens to configure the Zyxel Device’s features.
Configuration Menu Screens Summary
Folder or Link
Tab
Function
Quick Setup
Quickly configure WAN interfaces or VPN connections.
Licensing
Registration
Registration
Register the device and activate trial services.
Service
View the licensed service status and upgrade licensed services.
Signature Update
Anti-Virus
Update anti-virus signatures immediately or by a schedule.
IDP/AppPatrol
Update IDP signatures immediately or by a schedule.
Signature
Update signatures immediately or by a schedule.
Wireless
Controller
Configuration
Configure manual or automatic controller registration.
AP Management
Mgnt AP List
Edit or remove entries in the lists of APs managed by the Zyxel Device.
AP Policy
Configure the AP controller’s IP address on the managed APs and determine the action the managed APs take if the current AP controller fails.
AP Group
Create groups of APs, define their radio, VLAN, port and load balancing settings.
Firmware
Update the firmware on APs connected to your Zyxel Device.
MON Profile
Rogue/Friendly AP List
Configure how the Zyxel Device monitors rogue APs.
Load Balancing
Load Balancing
Configure load balancing for traffic moving to and from wireless clients.
DCS
DCS
Configure dynamic wireless channel selection.
Auto Healing
Auto Healing
Enable auto healing to extend the wireless service coverage area of the managed APs when one of the APs fails.
RTLS
Real Time Location System
Use the managed APs as part of an Ekahau RTLS to track the location of Ekahau Wi-Fi tags.
Network
Interface
Port Role
Use this screen to set the Zyxel Device’s flexible ports such as LAN, OPT, WLAN, or DMZ.
Ethernet
Manage Ethernet interfaces and virtual Ethernet interfaces.
PPP
Create and manage PPPoE and PPTP interfaces.
Cellular
Configure a cellular Internet connection for an installed mobile broadband card.
Tunnel
Configure tunneling between IPv4 and IPv6 networks.
VLAN
Create and manage VLAN interfaces and virtual VLAN interfaces.
Bridge
Create and manage bridges and virtual bridge interfaces.
LAG
Use this screen to combine multiple physical Ethernet interfaces into a single logical interface.
VTI
Configure IP address assignment and interface parameters for VTI (Virtual Tunnel Interface).
Trunk
Create and manage trunks (groups of interfaces) for load balancing.
Routing
Policy Route
Create and manage routing policies.
Static Route
Create and manage IP static routing information.
RIP
Configure device-level RIP settings.
OSPF
Configure device-level OSPF settings, including areas and virtual links.
BGP
Configure exchange of Border Gateway Protocol (BGP) information over an IPSec tunnel.
DDNS
DDNS
Define and manage the Zyxel Device’s DDNS domain names.
NAT
NAT
Set up and manage port forwarding rules.
Redirect Service
Redirect Service
Set up and manage HTTP and SMTP redirection rules.
ALG
ALG
Configure SIP, H.323, and FTP pass-through settings.
UPnP
UPnP
Configure interfaces that allow UPnP and NAT-PMP connections.
IP/MAC Binding
Summary
Configure IP to MAC address bindings for devices connected to each supported interface.
Exempt List
Configure ranges of IP addresses to which the Zyxel Device does not apply IP/MAC binding.
Layer 2 Isolation
General
Enable layer-2 isolation on the Zyxel Device and the internal interface(s).
White List
Enable and configure the white list.
DNS Inbound LB
DNS Load Balancing
Configure DNS Load Balancing.
Web Authentication
Web Authentication
General/Authentication Type/Custom Web Portal File/Custom User Agreement File/Facebook Wi-Fi
Define a web portal and exempt services from authentication.
SSO
Configure the Zyxel Device to work with a Single Sign On agent.
Hotspot
Billing
General
Configure the general billing settings, such as the accounting method.
Billing Profile
Configure the billing profiles for the web-based account generator and each button on the connected statement printer.
Discount
Configure discount price plans.
Payment Service
Enable online payment service and configure the service pages.
Printer Manager
General Setting
Configure the printer list, enable printer management and customize the account printout.
Printer Manager
Detect the connected statement printers, change their IP addresses and/or add them to the managed printer list.
Free Time
Free Time
Allow users to get a free account for Internet surfing during the specified time period.
IPnP
IPnP
Enable IPnP on the Zyxel Device and the internal interface(s).
Walled Garden
Walled Garden
Create walled garden links that display in the login screen.
Advertisement
Advertisement
Enable and set advertisement links.
Security Policy
Policy Control
Policy
Create and manage level-3 traffic rules and apply UTM profiles.
ADP
General
Display and manage ADP bindings.
Profile
Create and manage ADP profiles.
Session Control
Session Control
Limit the number of concurrent client NAT/security policy sessions.
Cloud CNM
SecuManager
Enable and configure management of the Zyxel Device by a Central Network Management system.
SecuReporter
Enable SecuReporter logging and access the SecuReporter security analytics portal that collects and analyzes logs from your Zyxel Device in order to identify anomalies, alert on potential internal / external threats, and report on network usage.
VPN
IPSec VPN
VPN Connection
Configure IPSec tunnels.
VPN Gateway
Configure IKE tunnels.
Concentrator
Combine IPSec VPN connections into a single secure network
Configuration Provisioning
Set who can retrieve VPN rule settings from the Zyxel Device using the Zyxel Device IPSec VPN Client.
SSL VPN
Access Privilege
Configure SSL VPN access rights for users and groups.
Global Setting
Configure the Zyxel Device’s SSL VPN settings that apply to all connections.
L2TP VPN
L2TP VPN
Configure L2TP over IPSec tunnels.
BWM
BWM
Enable and configure bandwidth management rules.
App Patrol
General
Enable or disable traffic management by application and see registration and signature information.
UTM Profile
AppPatrol
Profile
Manage different types of traffic in this screen. Create App Patrol template(s) of settings to apply to a traffic flow using a security policy.
Content Filter
Profile
Create and manage the detailed filtering rules for content filtering profiles and then apply to a traffic flow using a security policy.
Trusted Web Sites
Create a list of allowed web sites that bypass content filtering policies.
Forbidden Web Sites
Create a list of web sites to block regardless of content filtering policies.
IDP
Profile
Create IDP template(s) of settings to apply to a traffic flow using a security policy.
Custom Signatures
Create, import, or export custom signatures.
Anti-Virus
Profile
Create anti-virus template(s) of settings to apply to a traffic flow using a security policy.
Black/White List
Set up a black list to identify files with virus file patterns and a white list to identify files that should not be checked for AV.
Signature
Search for signatures by signature name or attributes and configure how the Zyxel Device uses them.
Anti-Spam
Profile
Turn anti-spam on or off and manage anti-spam policies. Create anti-spam template(s) of settings to apply to a traffic flow using a security policy.
Mail Scan
Configure e-mail scanning details.
Black/White List
Set up a black list to identify spam and a white list to identify legitimate e-mail.
DNSBL
Have the ZyWALL check e-mail against DNS Black Lists.
SSL Inspection
Profile
Decrypt HTTPS traffic for UTM inspection. Create SSL Inspection template(s) of settings to apply to a traffic flow using a security policy.
Exclude List
Configure services to be excluded from SSL Inspection.
Certificate Update
Use this screen to update the latest certificates of servers using SSL connections to the Zyxel Device network.
Device HA
General
Device HA Status
Configure Device HA global settings, and see the status of each interface monitored by Device HA.
View Device HA Pro license information.
Device HA Pro
Configure Device HA Pro global, monitored interfaces and synchronization settings.
Device HA
View Log
Configure active-passive mode Device HA.
See Device HA Pro logs.
Object
Zone
Zone
Configure zone template(s) used to define various policies.
User/Group
User
Create and manage users.
Group
Create and manage groups of users.
Setting
Manage default settings for all users, general settings for user sessions, and rules to force user authentication.
MAC Address
Configure the MAC addresses of wireless clients for MAC authentication using the local user database.
AP Profile
Radio
Create template(s) of radio settings to apply to policies as an object.
SSID
Create template(s) of wireless settings to apply to radio profiles or policies as an object.
MON Profile
MON Profile
Create and manage rogue AP monitoring files that can be associated with different APs.
ZyMesh Profile
ZyMesh Profile
Create and manage ZyMesh files that can be associated with different APs.
Application
Application
Create template(s) of services to apply to policies as an object.
Application Group
Create and manage groups of applications to apply to policies as a single object.
Address/Geo IP
Address
Create and manage host, range, and network (subnet) addresses.
Address Group
Create and manage groups of addresses to apply to policies as a single objects.
Geo IP
Service
Service
Create and manage TCP and UDP services.
Service Group
Create and manage groups of services to apply to policies as a single object.
Schedule
Schedule
Create one-time and recurring schedules.
Schedule Group
Create and manage groups of schedules to apply to policies as a single object.
AAA Server
Active Directory
Configure the Active Directory settings.
LDAP
Configure the LDAP settings.
RADIUS
Configure the RADIUS settings.
Auth. Method
Authentication Method
Create and manage ways of authenticating users.
Two-factor Authentication
Configure SMS/email authentication to access a secured network behind the Zyxel Device via a VPN tunnel.
Certificate
My Certificates
Create and manage the Zyxel Device’s certificates.
Trusted Certificates
Import and manage certificates from trusted sources.
ISP Account
ISP Account
Create and manage ISP account information for PPPoE/PPTP interfaces.
SSL Application
SSL Application
Create SSL web application or file sharing objects to apply to policies.
DHCPv6
Request
Configure IPv6 DHCP request type and interface information.
Lease
Configure IPv6 DHCP lease type and interface information.
System
Host Name
Host Name
Configure the system and domain name for the Zyxel Device.
USB Storage
Settings
Configure the settings for the connected USB devices.
Date/Time
Date/Time
Configure the current date, time, and time zone in the Zyxel Device.
Console Speed
Console Speed
Set the console speed.
DNS
DNS
Configure the DNS server and address records for the Zyxel Device.
WWW
Service Control
Configure HTTP, HTTPS, and general authentication.
Login Page
Configure how the login and access user screens look.
SSH
SSH
Configure SSH server and SSH service settings.
TELNET
TELNET
Configure telnet server settings for the Zyxel Device.
FTP
FTP
Configure FTP server settings.
SNMP
SNMP
Configure SNMP communities and services.
Auth. Server
Auth. Server
Configure the Zyxel Device to act as a RADIUS server.
Notification
Mail Server
Configure a mail server with authentication to send reports and password expiration notification emails.
SMS
Enable the SMS service to send dynamic guest account information in text messages and authorization for VPN tunnel access to a secured network.
Language
Language
Select the Web Configurator language.
IPv6
IPv6
Enable IPv6 globally on the Zyxel Device here.
ZON
ZON
Log & Report
Email Daily Report
Email Daily Report
Configure where and how to send daily reports and what reports to send.
Log Settings
Log Settings
Configure the system log, e-mail logs, and remote syslog servers.
Maintenance Menu
Use the maintenance menu screens to manage configuration and firmware files, run diagnostics, and reboot or shut down the Zyxel Device.
Maintenance Menu Screens Summary
Folder or Link
Tab
Function
File Manager
Configuration File
Manage and upload configuration files for the Zyxel Device.
Firmware Management
View the current firmware version and upload firmware. Reboot with your choice of firmware.
Shell Script
Manage and run shell script files for the Zyxel Device.
Diagnostics
Diagnostics
Collect
Collect on AP
Files
Collect diagnostic information.
Packet Capture
Capture packets for analysis.
CPU/Memory Status
View CPU and memory usage statistics.
System Log
Connect a USB device to the Zyxel Device and archive the Zyxel Device system logs to it here.
Remote Assistance
Configure and schedule external access to the Zyxel Device for troubleshooting.
Network Tool
Identify problems with the connections. You can use Ping or Traceroute to help you identify problems.
Routing Traces
Configure traceroute to identify where packets are dropped for troubleshooting.
Wireless Frame Capture
Capture wireless frames from APs for analysis.
Packet Flow Explore
Routing Status
Check how the Zyxel Device determines where to route a packet.
SNAT Status
View a clear picture on how the Zyxel Device converts a packet’s source IP address and check the related settings.
Shutdown
Shutdown
Turn off the Zyxel Device.
Tables and Lists
Web Configurator tables and lists are flexible with several options for how to display their entries.
Click a column heading to sort the table’s entries according to that column’s criteria.
Click the down arrow next to a column heading for more options about how to display the entries. The options available vary depending on the type of fields in the column. Here are some examples of what you can do:
• Sort in ascending or descending (reverse) alphabetical order
• Select which columns to display
• Group entries by field
• Show entries in groups
• Filter by mathematical operators (<, >, or =) or searching for text
Select a column heading cell’s right border and drag to re-size the column.
Select a column heading and drag and drop it to change the column order. A green check mark displays next to the column’s title when you drag the column to a valid new location.
Use the icons and fields at the bottom of the table to navigate to different pages of entries and control how many entries display at a time.
The tables have icons for working with table entries. You can often use the [Shift] or [Ctrl] key to select multiple entries to remove, activate, or deactivate.
Here are descriptions for the most common table icons.
Common Table Icons
Label
Description
Add
Click this to create a new entry. For features where the entry’s position in the numbered list is important (features where the Zyxel Device applies the table’s entries in order like the security policy for example), you can select an entry and click Add to create a new entry after the selected entry.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied.
Remove
To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Connect
To connect an entry, select it and click Connect.
Disconnect
To disconnect an entry, select it and click Disconnect.
References
Select an entry and click References to check which settings use the entry.
Move
To change an entry’s position in a numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed. For example, if you type 6, the entry you are moving becomes number 6 and the previous entry 6 (if there is one) gets pushed up (or down) one.
Working with Lists
When a list of available entries displays next to a list of selected entries, you can often just double-click an entry to move it from one list to the other. In some lists you can also use the [Shift] or [Ctrl] key to select multiple entries, and then use the arrow button to move them to the other list.
