Label | Description |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
# | This field is a sequential value, and it is not associated with a specific entry. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Interface | This is the name of an interface that supports IP/MAC binding. |
Number of Binding | This field displays the interface’s total number of IP/MAC bindings and IP addresses that the interface has assigned by DHCP. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
IP/MAC Binding Settings | |
Interface Name | This field displays the name of the interface within the Zyxel Device and the interface’s IP address and subnet mask. |
Enable IP/MAC Binding | Select this option to have this interface enforce links between specific IP addresses and specific MAC addresses. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses. |
Enable Logs for IP/MAC Binding Violation | Select this option to have the Zyxel Device generate a log if a device connected to this interface attempts to use an IP address not assigned by the Zyxel Device. |
Static DHCP Bindings | This table lists the bound IP and MAC addresses. The Zyxel Device checks this table when it assigns IP addresses. If the computer’s MAC address is in the table, the Zyxel Device assigns the corresponding IP address. You can also access this table from the interface’s edit screen. |
Add | Click this to create a new entry. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
# | This is the index number of the static DHCP entry. |
IP Address | This is the IP address that the Zyxel Device assigns to a device with the entry’s MAC address. |
MAC Address | This is the MAC address of the device to which the Zyxel Device assigns the entry’s IP address. |
Description | This helps identify the entry. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
IP Address | Enter the IP address that the Zyxel Device is to assign to a device with the entry’s MAC address. |
MAC Address | Enter the MAC address of the device to which the Zyxel Device assigns the entry’s IP address. |
Description | Enter up to 64 printable ASCII characters to help identify the entry. For example, you may want to list the computer’s owner. |
Edit | Click an entry or select it and click Edit to modify the entry’s settings. |
# | This is the index number of the IP/MAC binding list entry. |
Name | Enter a name to help identify this entry. |
Start IP | Enter the first IP address in a range of IP addresses for which the Zyxel Device does not apply IP/MAC binding. |
End IP | Enter the last IP address in a range of IP addresses for which the Zyxel Device does not apply IP/MAC binding. |
Add icon | Click the Add icon to add a new entry. Click the Remove icon to delete an entry. A window displays asking you to confirm that you want to delete it. |
