Label | Description |
General Setting | |
Enable Printer Manager | Select the check box to allow the Zyxel Device to manage and monitor the printer status. |
Printer Settings | |
Encryption | Select the check box to turn on data encryption. Data transmitted between the Zyxel Device and the printer will be encrypted with a secret key |
Secret Key | Enter four alphanumeric characters (A-Z, a-z, 0-9) to specify a key for data encryption. |
Printer List | Use this section to add the printer(s) that can be managed by the Zyxel Device. |
Add | Click this to create a new entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Discover Printer | Click this to discover the printer(s) that is connected to the Zyxel Device and display the printer information in a pop-up window. IPnP is enabled while discovering the printer and disabled when the discovering process has finished. Use Printer Manager > General > Add to manually configure a printer’s IP address and add it to the managed printer list when the printer is not detected or connected to the Zyxel Device. |
Refresh | Click this to update the printer list table. |
# | This field is a sequential value, and it is not associated with any entry. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. Click the Connection icon for the Zyxel Device connect to the printer. |
IPv4 Address | This field displays the IP address of the printer. |
Update Time | This field displays the date and time the Zyxel Device last synchronized with the printer. This shows n/a when the printer is not in the managed printer list or the printer status is sync fail or sync progressing. |
Status | This field is hidden by default. It displays whether the Zyxel Device can connect to the printer and update the printer information. This shows n/a when the printer is not in the managed printer list. |
Nickname | This shows an optional friendly name for the printer that you configured. |
Firmware Version | This field displays the model number and firmware version of the printer. This shows n/a when the printer is not in the managed printer list or the printer status is sync fail. |
MAC | This shows the hardware MAC address of the printer. |
Description | This field displays the descriptive name for the printer that you configured. |
Printer Firmware Information | |
Current Version | This is the version of the printer firmware currently uploaded to the Zyxel Device. The Zyxel Device automatically installs it in the connected printers to make sure the printers are upgraded to the same version. |
Hotspot Service Status | The hotspot license must be registered in order to be activated. |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. |
Service Type | This shows whether you have a trial or standard license or none (Trial, Standard, None). |
Expiration Date | This shows when your hotspot license will expire. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Enable Printer Manager | Select this option to turn on this entry in order to allow the Zyxel Device to manage this printer. |
IPv4 Address | Enter an IPv4 address for the printer. |
Description | Enter a description of this printer. You can use alphanumeric and ()+,/:=?!*#@$_%-” characters, and it can be up to 60 characters long. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
Nickname | Type an optional friendly name for the printer. A nickname must begin with a letter and cannot exceed 15 characters. Valid characters are [a-zA-Z0-9_-]. |
IP Address Assignment | |
Get Automatically | Select this to make the printer a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server. |
Use Fixed IP Address | Select this if you want to specify the IP address, subnet mask, and gateway manually. |
IP Address | This field is enabled if you select Use Fixed IP Address. Enter the IP address for the printer. |
Subnet Mask | This field is enabled if you select Use Fixed IP Address. Enter the subnet mask of the printer in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network. |
Gateway | This field is enabled if you select Use Fixed IP Address. Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the printer. |
Un-Mgnt Printer List / Mgnt Printer List | The tables displays according to whether the printer is in the unmanaged printer list (Un-Mgnt Printer List) or the managed printer list (Mgnt Printer List). |
Add to Mgnt Printer List | Click this to add the selected printer to the managed printer list. |
# | This is the index number of the printer in the list. |
Registration | This field displays whether the printer is added to the managed printer list (Mgnt Printer) or not (Un-Mgnt Printer). |
Status | This field displays whether the Zyxel Device can connect to the printer and update the printer information. This shows n/a when the printer is not in the managed printer list. |
Nickname | This field displays the optional friendly name of the printer that you configured. |
MAC | This field displays the MAC address of the printer. |
General Settings | |
Use Default Printout Configuration | Select this to use the default account printout format built into the device. If you later create a custom account printout format, you can still return to the Zyxel Device’s default format as it is saved indefinitely. |
Use Customized Printout Configuration | Select this to use a custom account printout format instead of the default one built into the Zyxel Device. Once this option is selected, the custom format controls below become active. |
Preview | Click the button to display a preview of account printout format you uploaded to the Zyxel Device. |
File Name | This shows the file name of account printout format file in the Zyxel Device. Click Download to download the account printout format file from the Zyxel Device to your computer. |
File Path / Browse / Upload | Browse for the account printout format file or enter the file path in the available input box, then click the Upload button to put it on the Zyxel Device. |
Restore Customized File to Default | Click Restore to set the Zyxel Device back to use the default built-in account printout format. |
Download | Click this to download an example account printout format file from the Zyxel Device for your reference. |
Printout | |
Number of Copies | Select how many copies of subscriber statements you want to print (1 is the default). |
Report Type | Key Combination |
Daily Account Summary | A B C A A |
Monthly Account Summary | A B C B A |
Last Month Account Summary | A B C B B |
System Status | A B C C A |
label | description |
SYST | This field displays the time since the system was last restarted. |
WAST | This field displays the WAN connection status. |
WLST | This field displays the status of the Zyxel Device’s wireless LAN. |
FWVR | This field displays the version of the firmware on the Zyxel Device. |
BTVR | This field displays the version of the bootrom. |
WAMA | This field displays the MAC address of the Zyxel Device on the WAN. |
LAMA | This field displays the MAC address of the Zyxel Device on the LAN. |
WAIP | This field displays the IP address of the WAN port on the Zyxel Device. |
LAIP | This field displays the IP address of the LAN port on the Zyxel Device. |
WLIP | This field displays the IP address of the wireless LAN interface on the Zyxel Device. |
DHSP | This field displays the first of the continuous addresses in the IP address pool. |
DHEP | This field displays the end of the continuous addresses in the IP address pool. |
CPUS | This field displays the Zyxel Device’s recent CPU usage. |
MEMS | This field displays the Zyxel Device’s recent memory usage. |
DKST | This field displays what percentage of the Zyxel Device’s on-board flash memory is currently being used. |
