Policy | Configured RAte | Max. b. u. | priority | Actual rate |
A | 300 kbps | No | 1 | 300 kbps |
B | 200 kbps | No | 1 | 200 kbps |
A | 800 kbps | Yes | 1 | 800 kbps |
B | 1000 kbps | Yes | 2 | 200 kbps |
A | 300 kbps | Yes | 1 | 550 kbps |
B | 200 kbps | Yes | 2 | 450 kbps |
A | 1000 kbps | Yes | 1 | 999 kbps |
B | 1000 kbps | Yes | 2 | 1 kbps |
Label | Description |
Enable BWM | Select this check box to activate management bandwidth. |
Enable Highest Bandwidth Priority for SIP Traffic | Select this to maximize the throughput of SIP traffic to improve SIP-based VoIP call sound quality. This has the Zyxel Device immediately send SIP traffic upon identifying it. When this option is enabled the Zyxel Device ignores any other application patrol rules for SIP traffic (so there is no bandwidth control for SIP traffic) and does not record SIP traffic bandwidth usage statistics. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move | To change an entry’s position in the numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. The status icon is not available for the default bandwidth management policy. |
Priority | This field displays a sequential value for each bandwidth management policy and it is not associated with a specific setting. This field displays default for the default bandwidth management policy. |
Description | This field displays additional information about this policy. |
BWM Type | This field displays the below types of BWM: • Shared, when the policy is set for all matched traffic • Per User, when the policy is set for an individual user or a user group • Per-Source-IP, when the policy is set for a source IP |
User | This is the type of user account to which the policy applies. If any displays, the policy applies to all user accounts. |
Schedule | This is the schedule that defines when the policy applies. none means the policy always applies. |
Incoming Interface | This is the source interface of the traffic to which this policy applies. |
Outgoing Interface | This is the destination interface of the traffic to which this policy applies. |
Source | This is the source address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. If any displays, the policy is effective for every source. |
Destination | This is the destination address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. If any displays, the policy is effective for every destination. |
DSCP Code | These are the DSCP code point values of incoming and outgoing packets to which this policy applies. The lower the number the higher the priority with the exception of 0 which is usually given only best-effort treatment. any means all DSCP value or no DSCP marker. default means traffic with a DSCP value of 0. This is usually best effort traffic The “af” options stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. |
Service | App and the service name displays if you selected Application Object for the service type. An Application Object is a pre-defined service. Obj and the service name displays if you selected Service Object for the service type. A Service Object is a customized pre-defined service or another service. Mouse over the service object name to view the corresponding IP protocol number. |
BWM In/Pri/Out/Pri | This field shows the amount of bandwidth the traffic can use. In - This is how much inbound bandwidth, in kilobits per second, this policy allows the matching traffic to use. Inbound refers to the traffic the Zyxel Device sends to a connection’s initiator. If no displays here, this policy does not apply bandwidth management for the inbound traffic. Out - This is how much outgoing bandwidth, in kilobits per second, this policy allows the matching traffic to use. Outbound refers to the traffic the Zyxel Device sends out from a connection’s initiator. If no displays here, this policy does not apply bandwidth management for the outbound traffic. Pri - This is the priority for the incoming (the first Pri value) or outgoing (the second Pri value) traffic that matches this policy. The smaller the number, the higher the priority. Traffic with a higher priority is given bandwidth before traffic with a lower priority. The Zyxel Device ignores this number if the incoming and outgoing limits are both set to 0. In this case the traffic is automatically treated as being set to the lowest priority (7) regardless of this field’s configuration. |
DSCP Marking | This is how the Zyxel Device handles the DSCP value of the incoming and outgoing packets that match this policy. In - Inbound, the traffic the Zyxel Device sends to a connection’s initiator. Out - Outbound, the traffic the Zyxel Device sends out from a connection’s initiator. If this field displays a DSCP value, the Zyxel Device applies that DSCP value to the route’s outgoing packets. preserve means the Zyxel Device does not modify the DSCP value of the route’s outgoing packets. default means the Zyxel Device sets the DSCP value of the route’s outgoing packets to 0. The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
DA | SA | TPID | Priority | VID | Len/Etype | Data | FCS | IEEE 802.1Q customer tagged frame |
DA | Destination Address | Priority | 802.1p Priority |
SA | Source Address | Len/Etype | Length and type of Ethernet frame |
TPID | Tag Protocol IDentifier | Data | Frame data |
VID | VLAN ID | FCS | Frame Check Sequence |
Priority | Traffic Types |
0 (lowest) | Background |
1 | Best Effort |
2 | Excellent Effort |
3 | Critical Applications |
4 | Video, less than 100 ms latency and jitter |
5 | Voice, less than 10 ms latency and jitter |
6 | Internetwork Control |
7 (highest) | Network Control |
Create new Object | Use to configure any new settings objects that you need to use in this screen. |
Configuration | |
Enable | Select this check box to turn on this policy. |
Description | Enter a description for this user object. It is not used elsewhere. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
Criteria | Use this section to configure the conditions of traffic to which this policy applies. |
BWM Type | This field displays the below types of BWM rule: • Shared, when the policy is set for all users • Per User, when the policy is set for an individual user or a user group • Per Source IP, when the policy is set for a source IP |
User | Select a user name or user group to which to apply the policy. Use Create new Object if you need to configure a new user account. Select any to apply the policy for every user. |
Schedule | Select a schedule that defines when the policy applies or select Create Object to configure a new one. Otherwise, select none to make the policy always effective. |
Incoming Interface | Select the source interface of the traffic to which this policy applies. |
Outgoing Interface | Select the destination interface of the traffic to which this policy applies. |
Source | Select a source address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Use Create new Object if you need to configure a new one. Select any if the policy is effective for every source. |
Destination | Select a destination address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Use Create new Object if you need to configure a new one. Select any if the policy is effective for every destination. |
DSCP Code | Select a DSCP code point value of incoming packets to which this policy route applies or select User Defined to specify another DSCP code point. The lower the number the higher the priority with the exception of 0 which is usually given only best-effort treatment. any means all DSCP value or no DSCP marker. default means traffic with a DSCP value of 0. This is usually best effort traffic The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. |
User-Defined DSCP Code | Use this field to specify a custom DSCP code point. |
Service Type | Select Service Object or Application Object if you want a specific service (defined in a service object) or application patrol service to which the policy applies. |
Service Object | This field is available if you selected Service Object as the service type. Select a service or service group to identify the type of traffic to which this policy applies. any means all services. |
Application Object | This field is available if you selected Application Object as the service type. Select application patrol services to identify the specific traffic to which this policy applies. |
DSCP Marking | Set how the Zyxel Device handles the DSCP value of the incoming and outgoing packets that match this policy. Inbound refers to the traffic the Zyxel Device sends to a connection’s initiator. Outbound refers to the traffic the Zyxel Device sends out from a connection’s initiator. Select one of the pre-defined DSCP values to apply or select User Defined to specify another DSCP value. The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. Select preserve to have the Zyxel Device keep the packets’ original DSCP value. Select default to have the Zyxel Device set the DSCP value of the packets to 0. |
Bandwidth Shaping | Configure these fields to set the amount of bandwidth the matching traffic can use. |
Inbound kbps | Type how much inbound bandwidth, in kilobits per second, this policy allows the traffic to use. Inbound refers to the traffic the Zyxel Device sends to a connection’s initiator. If you enter 0 here, this policy does not apply bandwidth management for the matching traffic that the Zyxel Device sends to the initiator. Traffic with bandwidth management disabled (inbound and outbound are both set to 0) is automatically treated as the lowest priority (7). If the sum of the bandwidths for routes using the same next hop is higher than the actual transmission speed, lower priority traffic may not be sent if higher priority traffic uses all of the actual bandwidth. |
Outbound kbps | Type how much outbound bandwidth, in kilobits per second, this policy allows the traffic to use. Outbound refers to the traffic the Zyxel Device sends out from a connection’s initiator. If you enter 0 here, this policy does not apply bandwidth management for the matching traffic that the Zyxel Device sends out from the initiator. Traffic with bandwidth management disabled (inbound and outbound are both set to 0) is automatically treated as the lowest priority (7). If the sum of the bandwidths for routes using the same next hop is higher than the actual transmission speed, lower priority traffic may not be sent if higher priority traffic uses all of the actual bandwidth. |
Priority | This field displays when the inbound or outbound bandwidth management is not set to 0. Enter a number between 1 and 7 to set the priority for traffic that matches this policy. The smaller the number, the higher the priority. Traffic with a higher priority is given bandwidth before traffic with a lower priority. The Zyxel Device uses a fairness-based (round-robin) scheduler to divide bandwidth between traffic flows with the same priority. The number in this field is ignored if the incoming and outgoing limits are both set to 0. In this case the traffic is automatically treated as being set to the lowest priority (7) regardless of this field’s configuration. |
Maximize Bandwidth Usage | This field displays when the inbound or outbound bandwidth management is not set to 0 and the BWM Type is set to Shared. Enable maximize bandwidth usage to let the traffic matching this policy “borrow” all unused bandwidth on the out-going interface. After each application or type of traffic gets its configured bandwidth rate, the Zyxel Device uses the fairness-based scheduler to divide any unused bandwidth on the out-going interface among applications and traffic types that need more bandwidth and have maximize bandwidth usage enabled. |
Maximum | If you did not enable Maximize Bandwidth Usage, then type the maximum unused bandwidth that traffic matching this policy is allowed to “borrow” on the out-going interface (in Kbps), here. |
802.1P Marking | Use 802.1P to prioritize outgoing traffic from a VLAN interface. |
Priority Code | This is a 3-bit field within a 802.1Q VLAN tag that’s used to prioritize associated outgoing VLAN traffic. "0" is the lowest priority level and "7" is the highest. The setting configured here overwrites existing priority settings. |
Interface | Choose a VLAN interface to which to apply the priority level for matching frames. |
Related Setting | |
Log | Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) when any traffic matches this policy. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
label | description |
User Name | Type a user or user group object name of the rule. |
User Type | Select a user type from the drop down menu. The user types are Admin, Limited admin, User, Guest, Ext-user, Ext-group-user. |
Password | Type a password for the user object. The password can consist of alphanumeric characters, the underscore, and some punctuation marks (+-/*= :; .! @$&%#~ ‘ \ () ), and it can be up to eight characters long. |
Retype | Retype the password to confirm. |
Authentication Timeout Settings | Choose either Use Default setting option, which shows the default Lease Time of 1,440 minutes and Reauthentication Time of 1,440 minutes or you can enter them manually by choosing Use Manual Settings option. |
Lease Time | This shows the Lease Time setting for the user, by default it is 1,440 minutes. |
Reauthentication Time | This shows the Reauthentication Time for the user, by default it is 1,440 minutes. |
OK | Click OK to save the setting. |
Cancel | Click Cancel to abandon this screen. |
Name | Enter a name for the schedule object of the rule. |
Type | Select an option from the drop down menu for the schedule object. It will show One Time or Recurring. |
Start Date | Click the icon menu on the right to choose a Start Date for the schedule object. |
Start Time | Click the icon menu on the right to choose a Start Time for the schedule object. |
Stop Date | Click the icon menu on the right to choose a Stop Date for schedule object. |
Stop Time | Click the icon menu on the right to choose a Stop Time for the schedule object. |
Name | Enter a name for the Address object of the rule. |
Address Type | Select an Address Type from the drop down menu on the right. The Address Types are Host, Range, Subnet, Interface IP, Interface Subnet, and Interface Gateway. |
IP Address | Enter an IP address for the Address object. |
Cancel | Click Cancel to abandon the setting. |
