Dashboard
Use the Dashboard screens to check status information about the Zyxel Device.
The General Screen
The dashboard displays general device information, system status, system resource usage, licensed service status, and interface status in widgets that you can re-arrange to suit your needs. You can also collapse, refresh, and close individual widgets.
Dashboard
Label
Description
Refresh Now
Click this to update the widget’s information immediately.
Virtual Device
Rear Panel
Click this to view details about the Zyxel Device’s rear panel. Hover your cursor over a connected interface or slot to display status details.
Front Panel
Click this to view details about the status of the Zyxel Device’s front panel LEDs and connections. An unconnected interface or slot appears grayed out.
The following front and rear panel labels display when you hover your cursor over a connected interface or slot.
Name
This field displays the name of each interface.
Status
This field displays the current status of each interface or device installed in a slot. The possible values depend on what type of interface it is.
Inactive - The Ethernet interface is disabled.
Down - The Ethernet interface does not have any physical ports associated with it or the Ethernet interface is enabled but not connected.
Speed / Duplex - The Ethernet interface is enabled and connected. This field displays the port speed and duplex setting (Full or Half).
The status for a WLAN card is none.
For the auxiliary interface:
Inactive - The auxiliary interface is disabled.
Connected - The auxiliary interface is enabled and connected.
Disconnected - The auxiliary interface is not connected.
Zone
This field displays the zone to which the interface is currently assigned.
IP Address/Mask
This field displays the current IP address and subnet mask assigned to the interface. If the interface is a member of an active virtual router, this field displays the IP address it is currently using. This is either the static IP address of the interface (if it is the master) or the management IP address (if it is a backup).
Device Information Screen
The Device Information screen displays Zyxel Device’s system and model name, serial number, MAC address and firmware version shown in the below screen.
The table describes the fields in this screen.
Dashboard > Device Information
LABEL
DESCRIPTION
System Name
This field displays the name used to identify the Zyxel Device on any network. Click the link and open the Host Name screen where you can edit and make changes to the system and domain name.
Serial Number
This field displays the serial number of this Zyxel Device. The serial number is used for device tracking and control.
MAC Address Range
This field displays the MAC addresses used by the Zyxel Device. Each physical port has one MAC address. The first MAC address is assigned to physical port 1, the second MAC address is assigned to physical port 2, and so on.
Firmware Version
This field displays the version number and date of the firmware the Zyxel Device is currently running. Click the link to open the Firmware Package screen where you can upload firmware.
System Status Screen
The table describes the fields in the screen.
Dashboard > System Status
LABEL
DESCRIPTION
Boot Status
This field displays details about the Zyxel Device’s startup state.
OK - The Zyxel Device started up successfully.
Firmware update OK - A firmware update was successful.
Problematic configuration after firmware update - The application of the configuration failed after a firmware upgrade.
System default configuration - The Zyxel Device successfully applied the system default configuration. This occurs when the Zyxel Device starts for the first time or you intentionally reset the Zyxel Device to the system default settings.
Fallback to lastgood configuration - The Zyxel Device was unable to apply the startup-config.conf configuration file and fell back to the lastgood.conf configuration file.
Fallback to system default configuration - The Zyxel Device was unable to apply the lastgood.conf configuration file and fell back to the system default configuration file (system-default.conf).
Booting in progress - The Zyxel Device is still applying the system configuration.
System Uptime
This field displays how long the Zyxel Device has been running since it last restarted or was turned on.
Current Date/Time
This field displays the current date and time in the Zyxel Device. The format is yyyy-mm-dd hh:mm:ss. Click on the link to see the Date/Time screen where you can make edits and changes to the date, time and time zone information.
Tx/Rx Statistics
This screen displays a line graph of packet statistics for each physical port.
Dashboard > The Lastest Logs
LABEL
DESCRIPTION
Mbps
The y-axis represents the speed of transmission or reception.
Time
The x-axis shows the time period over which the transmission or reception occurred.
The Latest Logs Screen
LABEL
DESCRIPTION
This is the entry’s rank in the list of alert logs.
Time
This field displays the date and time the log was created.
Priority
This field displays the severity of the log.
Category
This field displays the type of log generated.
Message
This field displays the actual log message.
Source
This field displays the source address (if any) in the packet that generated the log.
Destination
This field displays the destination address (if any) in the packet that generated the log.
System Resources Screen
Dashboard > System Resources
LABEL
DESCRIPTION
CPU Usage
This field displays what percentage of the Zyxel Device’s processing capability is currently being used. Hover your cursor over this field to display the Show CPU Usage icon that takes you to a chart of the Zyxel Device’s recent CPU usage.
Memory Usage
This field displays what percentage of the Zyxel Device’s RAM is currently being used. Hover your cursor over this field to display the Show Memory Usage icon that takes you to a chart of the Zyxel Device’s recent memory usage.
Flash Usage
This field displays what percentage of the Zyxel Device’s onboard flash memory is currently being used.
USB Storage Usage
This field shows how much storage in the USB device connected to the Zyxel Device is in use.
Active Sessions
This field shows how many sessions, established and non-established, that pass through/from/to/within the ZyWALL. Hover your cursor over this field to display icons. Click the Detail icon to go to the Session Monitor screen to see details about the active sessions. Click the Show Active Sessions icon to display a chart of Zyxel Device’s recent session usage.
DHCP Table Screen
Click on the number to look at the IP addresses currently assigned to DHCP clients and the IP addresses reserved for specific MAC addresses.
Dashboard > DHCP Table
LABEL
DESCRIPTION
Refresh Interval
Select how often you want this window to be updated automatically.
Refresh Now
Click this to update the information in the window right away.
This field is a sequential value, and it is not associated with a specific entry.
Interface
This field identifies the interface that assigned an IP address to a DHCP client.
IP Address
This field displays the IP address currently assigned to a DHCP client or reserved for a specific MAC address. Click the column’s heading cell to sort the table entries by IP address. Click the heading cell again to reverse the sort order.
Host Name
This field displays the name used to identify this device on the network (the computer name). The Zyxel Device learns these from the DHCP client requests. “None” shows here for a static DHCP entry.
MAC Address
This field displays the MAC address to which the IP address is currently assigned or for which the IP address is reserved. Click the column’s heading cell to sort the table entries by MAC address. Click the heading cell again to reverse the sort order.
Expiration Time
This is the period of time DHCP-assigned addresses is used.
Description
For a static DHCP entry, the host name or the description you configured shows here. This field is blank for dynamic DHCP entries.
Reserve
If this field is selected, this entry is a static DHCP entry. The IP address is reserved for the MAC address.
If this field is clear, this entry is a dynamic DHCP entry. The IP address is assigned to a DHCP client.
To create a static DHCP entry using an existing dynamic DHCP entry, select this field, and then click Apply.
To remove a static DHCP entry, clear this field, and then click Apply.
Number of Login Users Screen
Dashboard > Number of Login Users
LABEL
DESCRIPTION
This field is a sequential value and is not associated with any entry.
User ID
This field displays the user name of each user who is currently logged in to the Zyxel Device.
Reauth/Lease Time
This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each user.
Session Timeout
This field displays the total account of time the account (authenticated by an external server) can use to log into the UAG or access the Internet through the Zyxel Device.
This shows unlimited for an administrator account.
Type
This field displays the way the user logged in to the Zyxel Device.
IP address
This field displays the IP address of the computer used to log in to the Zyxel Device.
User Info
This field displays the types of user accounts the Zyxel Device uses. If the user type is ext-user (external user), this field will show its external-group information when you move your mouse over it.
If the external user matches two external-group objects, both external-group object names will be shown.
Force Logout
Click this icon to end a user’s session.
Current Login User
his field displays the user name used to log in to the current session, the amount of reauthentication time remaining, and the amount of lease time remaining.
VPN Status
Click on the link to look at the VPN tunnels that are currently established.
Dashboard > VPN Status
LABEL
DESCRIPTION
Name
This field displays the name of the VPN tunnel.
Encapsulation
This field displays the type of encapsulation the VPN tunnel uses.
Algorithm
This field displays the hash algorithm that the VPN tunnel uses to authenticate packet data.
Refresh Interval
Refresh Now
SSL VPN Status
The first number is the actual number of VPN tunnels up and the second number is the maximum number of SSL VPN tunnels allowed.
The Advanced Threat Protection Screen
Use the Advanced Threat Protection screen to check security status information about the Zyxel Device.
This screen gives the following information:
The amount of scanned traffic
The number of scanned connections for URL Threat filtering
The number of scanned files for sandboxing
The number of scanned files for anti-malware
The number of scanned connections for IDP
The number of scanned emails for email security
The number of the scanned sites for content filtering
Top 5 applications that are used the most
Top 5 URLs that are detected the most
Reputation filter reports
URL Threat filter reports
Sandboxing reports
Threat statistics
Click the Refresh icon to update the information in the window right away.
