Layer 2 Isolation
Layer-2 isolation is used to prevent connected devices from communicating with each other in the Zyxel Device’s local network(s), except for the devices in the white list, when layer-2 isolation is enabled on the Zyxel Device and the local interface(s).
Note: The security policy control must be enabled before you can use layer-2 isolation.
Layer-2 Isolation General Screen
This screen allows you to enable Layer-2 isolation on the Zyxel Device and specific internal interface(s).
Configuration > Network > Layer 2 Isolation
Label
Description
Enable Layer2 Isolation
Select this option to turn on the layer-2 isolation feature on the Zyxel Device.
*You can enable this feature only when the security policy is enabled.
Member List
The Available list displays the name(s) of the internal interface(s) on which you can enable layer-2 isolation.
To enable layer-2 isolation on an interface, you can double-click a single entry to move it or use the [Shift] or [Ctrl] key to select multiple entries and click the right arrow button to add to the Member list. To remove an interface, select the name(s) in the Member list and click the left arrow button.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Allow List Screen
IP addresses that are not listed in the allow list are blocked from communicating with other devices in the layer-2-isolation-enabled internal interface(s) except for broadcast packets.
Configuration > Network > Layer 2 Isolation > Allow List
Label
Description
Enable Allow List
Select this option to turn on the white list on the Zyxel Device.
Add
Click this to add a new rule.
Edit
Click this to edit the selected rule.
Remove
Click this to remove the selected rule.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
This field is a sequential value, and it is not associated with a specific rule.
Status
This icon is lit when the rule is active and dimmed when the rule is inactive.
IP Address
This field displays the IP address of device that can be accessed by the devices connected to an internal interface on which layer-2 isolation is enabled.
Description
This field displays the description for the IP address in this rule.
Apply
Reset
Add/Edit Allow List Rule
This screen allows you to create a new rule in the allow list or edit an existing one.
Note: You can configure up to 100 allow list rules on the Zyxel Device.
Note: You need to know the IP address of each connected device that you want to allow to be accessed by other devices when layer-2 isolation is enabled.
Configuration > Network > Layer 2 Isolation > allow List > Add/Edit
Label
Description
Enable
Select this option to turn on the rule.
Host IP Address
Enter an IPv4 address associated with this rule.
Description
Specify a description for the IP address associated with this rule. Enter up to 60 characters, spaces and underscores allowed.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving your changes.
