Label | Description |
Enable Email Daily Report | Select this to send reports by email every day. |
Mail Subject | Type the subject line for outgoing email from the Zyxel Device. Type a string using up to 60 of these characters [a-zA-Z0-9’()+,./:=?;!#@$_%-]. |
Mail To | Type the email address (or addresses) to which the outgoing email is delivered. |
Send Report Now | Click this button to have the Zyxel Device send the daily email report immediately. |
Report Items | Select the information to include in the report. Types of information include System Resource Usage, Wireless Report, Security Service, Interface Traffic Statistics and DHCP Table. Select Reset counters after sending report successfully if you only want to see statistics for a 24 hour period. |
Reset All Counters | Click this to discard all report data and start all of the counters over at zero. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify it. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
# | This field is a sequential value, and it is not associated with a specific log. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
Name | This field displays the type of log setting entry (system log, logs stored on a USB storage device connected to the Zyxel Device, or one of the remote servers). |
Log Format | This field displays the format of the log. Internal - System logs only; VRPT - Syslog-compatible format. CEF/Syslog - Common Event Format, syslog-compatible format. The CEF log format is as follows: Version|Device Vendor|Device Product|Device Version|Signature ID|Name|Severity|Extension Features that use the CEF log format at the time of writing are: • ADP • IDP • Security Policy • Content Filter • URL Threat Filter • Anti-Malware • App Patrol • Email Security • Traffic Log • System Monitoring • User • DHCP • DNS Threat Filter (Your model may not support all features.) |
Summary | This field is a summary of the settings for each log. |
Log Category Settings | Click this button to open the Log Category Settings Edit screen. |
Apply | Click this button to save your changes (activate and deactivate logs) and make them take effect. |
E-Mail Server 1/2 | |
Active | Select this to send log messages and alerts according to the information in this section. You specify what kinds of log messages are included in log information and what kinds of log messages are included in alerts in the Active Log and Alert section. |
Mail Server | Type the name or IP address of the outgoing SMTP server. |
Mail Server Port | Enter the same port number here as is on the mail server for mail traffic. |
Mail Subject | Type the subject line for the outgoing email. |
Send From | Type the email address from which the outgoing email is delivered. This address is used in replies. |
Send Log To | Type the email address to which the outgoing email is delivered. |
Send Alerts To | Type the email address to which alerts are delivered. |
Sending Log | Select how often log information is emailed. Choices are: When Full, Hourly and When Full, Daily and When Full, and Weekly and When Full. |
Day for Sending Log | This field is available if the log is emailed weekly. Select the day of the week the log is emailed. |
Time for Sending Log | This field is available if the log is emailed weekly or daily. Select the time of day (hours and minutes) when the log is emailed. Use 24-hour notation. |
SMTP Authentication | Select this check box if it is necessary to provide a user name and password to the SMTP server. |
User Name | This box is effective when you select the SMTP Authentication check box. Type the user name to provide to the SMTP server when the log is emailed. |
Password | This box is effective when you select the SMTP Authentication check box. Type the password of up to 63 characters to provide to the SMTP server when the log is emailed. |
Retype to Confirm | Type the password again to make sure that you have entered is correctly. |
Active Log and Alert | |
System Log | Use the System Log drop-down list to change the log settings for all of the log categories. disable all logs (red X) - do not log any information for any category for the system log or email any logs to email server 1 or 2. enable normal logs (green check mark) - create log messages and alerts for all categories for the system log. If email server 1 or 2 also has normal logs enabled, the Zyxel Device will email logs to them. enable normal logs and debug logs (yellow check mark) - create log messages, alerts, and debugging information for all categories. The Zyxel Device does not email debugging information, even if this setting is selected. |
E-mail Server 1 | Use the E-Mail Server 1 drop-down list to change the settings for emailing logs to email server 1 for all log categories. Using the System Log drop-down list to disable all logs overrides your email server 1 settings. enable normal logs (green check mark) - email log messages for all categories to email server 1. enable alert logs (red exclamation point) - email alerts for all categories to email server 1. |
E-mail Server 2 | Use the E-Mail Server 2 drop-down list to change the settings for emailing logs to email server 2 for all log categories. Using the System Log drop-down list to disable all logs overrides your email server 2 settings. enable normal logs (green check mark) - email log messages for all categories to email server 2. enable alert logs (red exclamation point) - email alerts for all categories to email server 2. |
Log Category | This field displays each category of messages. It is the same value used in the Display and Category fields in the View Log tab. The Default category includes debugging messages generated by open source software. |
System log | Select which events you want to log by Log Category. There are three choices: disable all logs (red X) - do not log any information from this category enable normal logs (green check mark) - create log messages and alerts from this category enable normal logs and debug logs (yellow check mark) - create log messages, alerts, and debugging information from this category; the Zyxel Device does not email debugging information, however, even if this setting is selected. |
E-mail Server 1 | Select whether each category of events should be included in the log messages when it is emailed (green check mark) and/or in alerts (red exclamation point) for the email settings specified in E-Mail Server 1. The Zyxel Device does not email debugging information, even if it is recorded in the System log. |
E-mail Server 2 | Select whether each category of events should be included in log messages when it is emailed (green check mark) and/or in alerts (red exclamation point) for the email settings specified in E-Mail Server 2. The Zyxel Device does not email debugging information, even if it is recorded in the System log. |
Log Consolidation | |
Active | Select this to activate log consolidation. Log consolidation aggregates multiple log messages that arrive within the specified Log Consolidation Interval. In the View Log tab, the text “[count=x]”, where x is the number of original log messages, is appended at the end of the Message field, when multiple log messages were aggregated. |
Log Consolidation Interval | Type how often, in seconds, to consolidate log information. If the same log message appears multiple times, it is aggregated into one log message with the text “[count=x]”, where x is the number of original log messages, appended at the end of the Message field. |
OK | Click this to save your changes and return to the previous screen. |
Cancel | Click this to return to the previous screen without saving your changes. |
Duplicate logs to USB storage (if ready) | Select this to have the Zyxel Device save a copy of its system logs to a connected USB storage device. Use the Active Log section to specify what kinds of messages to include. |
Enable log keep duration | Select this checkbox to enter a value in the Keep Duration field. |
Keep Duration | Enter a number of days that the Zyxel Device keeps this log. |
Active Log | |
Selection | Use the Selection drop-down list to change the log settings for all of the log categories. disable all logs (red X) - do not send the remote server logs for any log category. enable normal logs (green check mark) - send the remote server log messages and alerts for all log categories. enable normal logs and debug logs (yellow check mark) - send the remote server log messages, alerts, and debugging information for all log categories. |
Log Category | This field displays each category of messages. The Default category includes debugging messages generated by open source software. |
Selection | Select what information you want to log from each Log Category (except All Logs; see below). Choices are: disable all logs (red X) - do not log any information from this category enable normal logs (green check mark) - log regular information and alerts from this category enable normal logs and debug logs (yellow check mark) - log regular information, alerts, and debugging information from this category |
Log Settings for Remote Server | |
Active | Select this check box to send log information according to the information in this section. You specify what kinds of messages are included in log information in the Active Log section. |
Log Format | This field displays the format of the log information. It is read-only. VRPT/Syslog - Zyxel’s Vantage Report, syslog-compatible format. CEF/Syslog - Common Event Format, syslog-compatible format. |
Server Address | Type the server name or the IP address of the syslog server to which to send log information. |
Server Port | Type the service port number used by the remote server. |
Log Facility | Select a log facility. The log facility allows you to log the messages to different files in the syslog server. Please see the documentation for your syslog program for more information. |
Active Log | |
USB Storage | Use the USB Storage drop-down list to change the log settings for saving logs to a connected USB storage device. disable all logs (red X) - do not log any information for any category to a connected USB storage device. enable normal logs (green check mark) - create log messages and alerts for all categories and save them to a connected USB storage device. enable normal logs and debug logs (yellow check mark) - create log messages, alerts, and debugging information for all categories and save them to a connected USB storage device. |
E-mail Server 1 E-mail | Use the E-Mail Server 1 drop-down list to change the settings for emailing logs to email server 1 for all log categories. Using the System Log drop-down list to disable all logs overrides your email server 1 settings. enable normal logs (green check mark) - email log messages for all categories to email server 1. enable alert logs (red exclamation point) - email alerts for all categories to email server 1. |
E-mail Server 2 E-mail | Use the E-Mail Server 2 drop-down list to change the settings for emailing logs to email server 2 for all log categories. Using the System Log drop-down list to disable all logs overrides your email server 2 settings. enable normal logs (green check mark) - email log messages for all categories to email server 2. enable alert logs (red exclamation point) - email alerts for all categories to email server 2. |
Remote Server 1~4 Syslog | For each remote server, use the Selection drop-down list to change the log settings for all of the log categories. disable all logs (red X) - do not send the remote server logs for any log category. enable normal logs (green check mark) - send the remote server log messages and alerts for all log categories. enable normal logs and debug logs (yellow check mark) - send the remote server log messages, alerts, and debugging information for all log categories. |
System Log | Select which events you want to log by Log Category. There are three choices: disable all logs (red X) - do not log any information from this category enable normal logs (green check mark) - create log messages and alerts from this category enable normal logs and debug logs (yellow check mark) - create log messages, alerts, and debugging information from this category; the Zyxel Device does not email debugging information, however, even if this setting is selected. |
USB Storage | Select which event log categories to save to a connected USB storage device. There are three choices: disable all logs (red X) - do not log any information from this category enable normal logs (green check mark) - save log messages and alerts from this category enable normal logs and debug logs (yellow check mark) - save log messages, alerts, and debugging information from this category. |
E-mail Server 1 E-mail | Select whether each category of events should be included in the log messages when it is emailed (green check mark) and/or in alerts (red exclamation point) for the email settings specified in E-Mail Server 1. The Zyxel Device does not email debugging information, even if it is recorded in the System log. |
E-mail Server 2 E-mail | Select whether each category of events should be included in log messages when it is emailed (green check mark) and/or in alerts (red exclamation point) for the email settings specified in E-Mail Server 2. The Zyxel Device does not email debugging information, even if it is recorded in the System log. |
Remote Server 1~4 Syslog | For each remote server, select what information you want to log from each Log Category (except All Logs; see below). Choices are: disable all logs (red X) - do not log any information from this category enable normal logs (green check mark) - log regular information and alerts from this category enable normal logs and debug logs (yellow check mark) - log regular information, alerts, and debugging information from this category |
