LABEL | Description |
IPv4/IPv6 Exception List Settings | |
Add | Click this to create a new entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
# | This is the entry’s index number in the list. |
Name | This field displays the descriptive name of this entry. |
IPv4/IPv6 Source | This field displays the source IP address (or address object) of incoming traffic. It displays any if there is no restriction on the source IP address. |
IPv4/IPv6 Destination | This field displays the destination IP address (or address object) of incoming traffic. It displays any if there is no restriction on the destination IP address. |
Service to Bypass | This field displays which services will not inspect matched packets. |
Log | This field displays if the Zyxel Device will generate a log when the incoming traffic is in the exception list. |
Create New Object | Use this to configure any new settings objects that you need to use in this screen. |
Name | Enter a descriptive name of this entry. |
Description | Enter the description for this entry. You can use up to 60 printable ASCII characters. |
Source | Select any or an address object of the source IP address for this entry. Select any so there’s no restriction on the source IP address. |
Destination | Select any or an address object of the destination IP address for this entry. Select any so there’s no restriction on the destination IP address. |
Log | Select Yes to have the Zyxel Device generate a log when the incoming traffic is in the exception list. Otherwise, select No. |
Service to Bypass | Selected services do not inspect packets that match source/destination criteria above. Non-selected services do inspect packets that match source/destination criteria above. |
OK | Click OK to save your customized settings and exit this screen. |
Cancel | Click Cancel to exit this screen without saving. |
