Label | Description |
Routing Flow | This section shows you the flow of how the Zyxel Device determines where to route a packet. Click a function box to display the related settings in the Routing Table section. |
Routing Table | This section shows the corresponding settings according to the function box you click in the Routing Flow section. |
The following fields are available if you click Direct Route, Static-Dynamic Route, or Main Route in the Routing Flow section. | |
# | This field is a sequential value, and it is not associated with any entry. |
Destination | This is the destination IP address of a route. |
Gateway | This is the IP address of the next-hop gateway or the interface through which the traffic is routed. |
Interface | This is the name of an interface associated with the route. |
Metric | This is the route’s priority among the displayed routes. |
Flags | This indicates additional information for the route. The possible flags are: • A - this route is currently activated. • S - this is a static route. • C - this is a direct connected route. • O - this is a dynamic route learned through OSPF. • R - this is a dynamic route learned through RIP. • B - this is a dynamic route learned through BGP. • G - the route is to a gateway (router) in the same network. • ! - this is a route which forces a route lookup to fail. • B - this is a route which discards packets. • L - this is a recursive route. |
Persist | This is the remaining time of a dynamically learned route. The Zyxel Device removes the route after this time period is counted down to zero. |
The following fields are available if you click Policy Route in the Routing Flow section. | |
Incoming | This is the interface on which the packets are received. |
Source | This is the source IP address(es) from which the packets are sent. |
Destination | This is the destination IP address(es) to which the packets are transmitted. |
Service | This is the name of the service object. any means all services. |
Source Port | This is the source port(s) from which the packets are sent. |
DSCP Code | This is the DSCP value of incoming packets to which this policy route applies. |
Next Hop Type | This is the type of the next hop to which packets are directed. |
Next Hop Info | • This is the main route if the next hop type is Auto. • This is the interface name and gateway IP address if the next hop type is Interface /GW. • This is the tunnel name if the next hop type is VPN Tunnel. • This is the trunk name if the next hop type is Trunk. |
The following fields are available if you click 1-1 SNAT in the Routing Flow section. | |
NAT Rule | This is the name of an activated 1:1 or Many 1:1 NAT rule in the NAT table. |
Source | This is the external source IP address(es). |
Protocol | This is the transport layer protocol. |
Source Port | This is the source port number. |
Destination | This is the external destination IP address(es). |
Outgoing | This is the outgoing interface that the SNAT rule uses to transmit packets. |
Gateway | This is the IP address of the gateway in the same network of the outgoing interface. |
The following fields are available if you click Dynamic VPN or SiteToSite VPN in the Routing Flow section. | |
Source | This is the IP address(es) of the local VPN network. |
Destination | This is the IP address(es) for the remote VPN network. |
VPN Tunnel | This is the name of the VPN tunnel. |
The following fields are available if you click Default WAN Trunk in the Routing Flow section. | |
Source | This is the source IP address(es) from which the packets are sent. any means any IP address. |
Destination | This is the destination IP address(es) to which the packets are transmitted. any means any IP address. |
Trunk | This is the name of the WAN trunk through which the matched packets are transmitted. |
SNAT Flow | This section shows you the flow of how the Zyxel Device changes the source IP address for a packet according to the rules you have configured in the Zyxel Device. Click a function box to display the related settings in the SNAT Table section. |
SNAT Table | The table fields in this section vary depending on the function box you select in the SNAT Flow section. |
The following fields are available if you click Policy Route SNAT in the SNAT Flow section. | |
Outgoing | This is the outgoing interface that the route uses to transmit packets. |
SNAT | This is the source IP address(es) that the SNAT rule uses finally. |
The following fields are available if you click 1-1 SNAT in the SNAT Flow section. | |
NAT Rule | This is the name of an activated NAT rule which uses SNAT. |
The following fields are available if you click Loopback SNAT in the SNAT Flow section. | |
NAT Rule | This is the name of an activated NAT rule which uses SNAT and enables NAT loopback. |
Source | This is the original source IP address(es). any means any IP address. |
Destination | This is the original destination IP address(es). any means any IP address. |
SNAT | This indicates which source IP address the SNAT rule uses finally. For example, Outgoing Interface IP means that the Zyxel Device uses the IP address of the outgoing interface as the source IP address for the matched packets it sends out through this rule. |
The following fields are available if you click Default SNAT in the SNAT Flow section. | |
Incoming | This indicates internal interface(s) on which the packets are received. |
Outgoing | This indicates external interface(s) from which the packets are transmitted. |
