Monitor: LLDP
Overview
This section provides information for LLDP in Monitor.
Link Layer Discovery Protocol (LLDP), defined as IEEE 802.1ab, enables LAN devices that support LLDP to exchange their configured settings. This helps eliminate configuration mismatch issues.
LLDP Settings
This link takes you to a screen where you can view LLDP on the Switch. LLDP allows a network device to advertise its identity and capabilities on the local network. It also allows the device to maintain and store information from adjacent devices which are directly connected to the network device.
Statistics Settings
Use this screen to view the Switch’s LLDP global and port statistics. Click Monitor > LLDP > Statistics.
Each field is described in the following table.
Label
Description
Statistics
Insertions
This field displays the number of insertions.
Deletions
This field displays the number of deletions.
Drops
This field displays the number of drops.
Age Outs
This field displays the number of age outs.
Clear
Click Clear to clear statistics.
Refresh
Click Refresh to reload the page.
LLDP Port Statistics
Port
This field displays the port number.
TX Frames Total
This field displays the total number of TX LLDP frames.
RX Frames Total
This field displays the total number of RX LLDP frames.
RX Frames Discarded
This field displays the number of discarded RX LLDP frames.
RX Frames Errors
This field displays the number of RX LLDP frames errors.
RX TLVs Discarded
This field displays the number of discarded RX LLDP TLVs.
RX TLVs Unrecognized
This field displays the number of unrecognized RX LLDP TLVs.
RX Ageouts Total
This field displays the total number of RX LLDP ageouts.
Remote Information
Use this screen to view the Switch’s LLDP remote device information. Click Monitor > LLDP > Remote Information.
Label
Description
Remote Device
Local Port
This field displays the local port.
Chassis ID Subtype
This field displays the chassis ID subtype.
Chassis ID
This field displays the chassis ID.
Port ID Subtype
This field displays the port ID subtype.
Port ID
This field displays the port ID.
System Name
This field displays the descriptive name of the Switch for identification purposes.
Time to Live
This field displays the live time of this entry.
Action
Detail
Click Detail to show more information about this entry.
Delete
Click Delete to remove the entry.
Overloading
Use this screen to view the Switch’s LLDP port overloading. Click Monitor > LLDP > Overloading.
Label
Description
Port Overloading
Port
This label shows the port you are viewing.
Total (Bytes)
This field displays the total in bytes.
Left to Send (Bytes)
This field displays what is left to send in bytes.
Status
This field displays whether the Switch is overloading or not.
Bytes Detail
This field displays how many bytes used by TLVs
Mandatory TLVs
This field displays how many bytes used by mandatory TLVs.
MED Capabilities
This field displays how many bytes used by MED capabilities.
MED Location
This field displays how many bytes used by MED location.
MED Network Policy
This field displays how many bytes used by MED network policy.
MED Extended Power via MDI
This field displays how many bytes used by MED extended power through MDI.
802.3 TLVs
This field displays how many bytes used by 802.3 TLVs.
Optional TLVs
This field displays how many bytes used by optional TLVs.
MED Inventory
This field displays how many bytes used by MED inventory.
802.1 TLVs
This field displays how many bytes used by 802.1 TLVs.
