Label | Description |
MAC Table | |
MAC Address | This is the MAC address of the device from which this incoming frame came. |
VLAN | Displays a type for the VLAN for identification purposes. |
Port | This is the port from which the above MAC address was learned. |
View | This link takes you to a screen where you can view the MAC address and VLAN ID of a device attach to a port. You can also view what kind of MAC address it is. |
Clear | Click Clear to return the fields to the factory defaults. |
Type | This shows whether the MAC address is dynamic (learned by the Switch) or static (manually entered in the Static MAC Forwarding screen). |
Total Entries | Displays the number of total entries. |
