Label | Description |
Logging Filter Select | |
Target | Select Buffered or Flash. Buffered: Login saved to temporary memory. Flash: Login saved to permanent memory. |
Severity | This field displays two options: Available and Acting. Severity type: crit, emerg, alert, error, warning, notice, info, and debug. |
Available | Click < to move a severity type from the acting box to the available box. Click > to move a severity type to the acting box from the available box. |
Acting | Click < to move a severity type from the acting box to the available box. Click > to move a severity type to the acting box from the available box. |
< | Click < to move a severity type from the acting box to the available box. |
View | Click View to display results. |
Clear | Click Clear to clear results. |
Show System Log | The syslog protocol allows devices to send event notification messages across an IP network to syslog servers that collect the event messages. A syslog-enabled device can generate a syslog message and send it to a syslog server |
No. | This field displays the number you are viewing. |
Timestamp | This field displays the timestamp. |
Category | This field displays the category. |
Severity | This field displays the severity. |
Message | The syslog protocol allows devices to send event notification messages across an IP network to syslog servers that collect the event messages. A syslog-enabled device can generate a syslog message and send it to a syslog server. |
Error Disable | |
Recovery Interval | View the number of seconds (from 30 to 2592000) for the time interval of the recovery. |
Reason Status | |
Error Disabled Reason | This field displays the supported features that allow the Switch to shut down a port or discard packets on a port according to the feature requirements and what action you configure. |
Timer Status | Select this option to allow the Switch to wait for the specified time interval to activate a port or allow specific packets on a port, after the error was gone. De-select this option to turn off this rule. |
Port Status | |
Port | This field displays the port number. |
Time Left (sec) | This field displays the time left in seconds. |
Action | This field displays the action. |
