Monitor: Port
Overview
This section provides information for Port in Monitor. Use the Port screens to view general Switch port settings.
Port Settings
Use this screen to view Switch port settings.
Status
Use this screen to view the Switch’s port statistics. Click Monitor > Port > Port > Status.
Each field is described in the following table.
Label
Description
Port
This is the port index number.
Port Name
A descriptive name that identifies this port.
State
This is port admin setting state.
Link Status
This field displays Up, Down. It displays Up when the port is linked up or Down when it is not.
Speed
View the speed of the Ethernet connection on this port.
Duplex
View the duplex mode of the Ethernet connection on this port.
FlowCtrl Status
A concentration of traffic on a port decreases port bandwidth and overflows buffer memory causing packet discards and frame losses. Flow Control is used to regulate transmission of signals to match the bandwidth of the receiving port.
TxPkts
View the number of transmitted frames on this port.
RxPkts
View the number of received frames on this port.
Tx kB/s
View the number of kilobytes per second transmitted on this port.
Rx kB/s
View the number of kilobytes per second received on this port.
Errors
View the number of received errors on this port.
Port Counters
Use this screen to view the Switch’s port counters settings. Click Monitor > Port > Port > Port Counters.
Label
Description
Port Counters
Port
This field displays the port.
Mode
This field displays the mode.
Port 1 Interface mib Counters
iflnOctets
This field displays the iflnOctets.
iflnUcastPkts
This field displays the iflnUcastPkts.
iflnNUcastPkts
This field displays the iflnNUcastPkts.
ifInDiscards
This field displays the ifInDiscards.
ifOutOctets
This field displays the ifOutOctets.
ifOutUcastPkts
This field displays the ifOutUcastPkts.
ifOutNUcastPkts
This field displays the ifOutNUcastPkts.
ifOutDiscards
This field displays the ifOutDiscards.
ifInMulticastPkts
This field displays the ifInMulticastPkts.
ifInBroadcastPkts
This field displays the ifInBroadcastPkts.
ifOutMulticastPkts
This field displays the ifOutMulticastPkts.
ifOutBroadcastPkts
This field displays the ifOutBroadcastPkts.
Port 1 Etherlike mib Counters
dot3StatsAlignmentErrors
This field displays the dot3StatsAlignmentErrors.
dot3StatsFCSErrors
This field displays the dot3StatsFCSErrors.
dot3StatsSingleCollisionFrames
This field displays the dot3StatsSingleCollisionFrames.
dot3StatsMultipleCollisionFrames
This field displays the dot3StatsMultipleCollisionFrames.
dot3StatsDeferredTransmissions
This field displays the dot3StatsDeferredTransmissions.
dot3StatsLateCollisions
This field displays the dot3StatsLateCollisions.
dot3StatsExcessiveCollisions
This field displays the dot3StatsExcessiveCollisions.
dot3StatsFrameTooLongs
This field displays the dot3StatsFrameTooLongs.
dot3StatsSymbolErrors
This field displays the dot3StatsSymbolErrors.
dot3ControlInUnkownOpcodes
This field displays the dot3ControlInUnkownOpcodes.
dot3lInPauseFrames
This field displays the dot3lInPauseFrames.
dot3lOutPauseFrames
This field displays the dot3lOutPauseFrames.
Port 1 RMON mib Counters
etherStatsDropEvents
This field displays the etherStatsDropEvents.
etherStatsOctets
This field displays the etherStatsOctets.
etherStatsPkts
This field displays the etherStatsPkts.
etherStatsBroadcastPkts
This field displays the etherStatsBroadcastPkts.
etherStatsMulticastPkts
This field displays the etherStatsMulticastPkts.
etherStatsCRCAlignErrors
This field displays the etherStatsCRCAlignErrors.
etherStatsUnderSizePkts
This field displays the etherStatsUnderSizePkts.
etherStatsOverSizePkts
This field displays the etherStatsOverSizePkts.
etherStatsFragments
This field displays the etherStatsFragments.
etherStatsJabbers
This field displays the etherStatsJabbers.
etherStatsCollisions
This field displays the etherStatsCollisions.
etherStatsPkts64Octets
This field displays the etherStatsPkts64Octets.
etherStatsPkts65to127Octets
This field displays the etherStatsPkts65to127Octets.
etherStatsPkts128to255Octets
This field displays the etherStatsPkts128to255Octets.
etherStatsPkts256to511Octets
This field displays the etherStatsPkts256to511Octets.
etherStatsPkts512to1023Octets
This field displays the etherStatsPkts512to1023Octets.
etherStatsPkts1024to1518Octets
This field displays the etherStatsPkts1024to1518Octets.
Bandwidth Utilization
Utilization is the percentage of a network's bandwidth that is currently being consumed by network traffic. Each vertical bar represents the highest utilization on a port, and can be either transmitted (Tx) traffic or received (Rx) traffic during the last time interval in seconds.
Use this screen to view the Switch’s bandwidth utilization settings. Click Monitor > Port > Port > Bandwidth Utilization.
Label
Description
1Gbps
This field displays the 1 Gbps.
100Mbps
This field displays the 100 Mbps.
10Mbps
This field displays the 10 Mbps.
Link down
This field displays the link down.
Refresh period
This field displays the refresh period.
IFG
This field displays the IFG.
Tx
Transmitted (Tx) traffic during the last time interval in seconds.
Rx
Received (Rx) traffic during the time interval in seconds.
PoE Settings
The Switch supports both the IEEE 802.3af Power over Ethernet (PoE) and IEEE 802.3at High Power over Ethernet (PoE) standards. The Switch is Power Sourcing Equipment (PSE) because it provides a source of power through its Ethernet ports, and each device that receives power through an Ethernet port is a Powered Device (PD).
*The PoE function and the following screens are available for models ending in “HP” and “EP” only.
*Make sure your PoE Switch is using the latest firmware.
You can also set priorities so that the Switch is able to reserve and allocate power to certain PDs.
*The PoE devices that supply or receive power and their connected Ethernet cables must all be completely indoors.
PoE Standards and PoE Features
PoE standards vary primarily based on the power budget they provide. PoE standards are:
IEEE 802.3at Power over Ethernet (PoE+)
The following table describes the differences among the PoE standards.
PoE Standards
PoE FEATURES
PoE
PoE+
IEEE Standard
IEEE 802.3af
IEEE 802.3at
PoE Type
Type 1
Type 2
Switch Port Power
IEEE Power Classification
Class 0, 1, 2, 3
Class 4
Maximum Power Per Port
15.4 W
30 W
Port Voltage Range
44 - 57 V
50 - 57 V
Cables
Twisted Pairs Used
2-pair
2-pair
Supported Cables
Cat3 or better
Cat5 or better
To view the current amount of power that PDs are receiving from the Switch, click Monitor > Port > PoE.
Label
Description
PoE Mode
This field displays the power management mode used by the Switch, whether it is in Classification or Consumption mode.
Total Power(W)
This field displays the total power the Switch can provide to the connected PoE-enabled devices on the PoE ports.
Consuming Power(W)
This field displays the total amount of power the Switch is currently supplying to the connected PoE-enabled devices.
Allocated Power(W)
This field displays the total amount of power the Switch (in Classification mode) has reserved for PoE after negotiating with the connected PoE devices. It shows NA when the Switch is in Consumption mode.
Consuming Power (W) can be less than or equal but not more than the Allocated Power (W).
Remaining Power(W)
This field displays the amount of power the Switch can still provide for PoE.
Note: The Switch must have at least 16 W of remaining power in order to supply power to a PoE device, even if the PoE device needs less than 16 W.
Bandwidth Management
This section shows you the maximum bandwidth using the Bandwidth Management screen. Bandwidth management shows the maximum allowable bandwidth for incoming and/or out-going traffic flows on a port.
Bandwidth Control
Use this screen to view the Switch’s bandwidth control in egress global burst and port rate.
An egress port is an outgoing port, that is, a port through which a data packet leaves for both ports. An ingress port is an incoming port, that is, a port through which a data packet enters.
Click Monitor > Port > Bandwidth Management > Bandwidth Control.
Label
Description
Bandwidth Control
Egress Global Burst
This field specifies the current egress burst size in bytes all ports.
Port Rate
View the maximum bandwidth allowed in kilobits per second (Kbps) for the traffic flow on a port.
Port
This field displays the port number.
Ingress RateLimit (Kbps)
View the maximum bandwidth allowed in kilobits per second (Kbps) for the incoming traffic flow on a port.
Egress RateLimit (Kbps)
View the maximum bandwidth allowed in kilobits per second (Kbps) for the out-going traffic flow on a port.
Storm Control
This section shows you the storm control feature.
Storm control limits the number of broadcast, multicast and unicast packets the Switch receives per second on the ports. When the maximum number of allowable broadcast, multicast and/or unicast packets is reached per second, the subsequent packets are discarded. Enabling this feature reduces broadcast, multicast and/or unicast packets in your network. You can specify limits for each packet type on each port.
Click Monitor > Port > Storm Control.
Label
Description
Storm Control
Port
State
This field displays the state.
Broadcast (pps)
Displays how many broadcast packets the port receives (in pps).
Unknown Multicast (pps)
Displays how many unknown multicast packets the port receives (in pps).
Unknown Unicast (pps)
Displays how many unknown unicast packets the port receives (in pps).
Action
Displays the action the device takes when a limit is reached. The following options are available:
Drop – drop the packet.
Shutdown – shutdown the connection.
