Monitor: Security
Overview
This section provides information for Security in Monitor.
This link takes you to a screen where you can view the settings or traffic statistics which contain detailed information about specific activities.
Port Security
Port security allows only packets with dynamically learned MAC addresses and/or configured static MAC addresses to pass through a port on the Switch. The Switch can learn up to 8K MAC addresses in total with no limit on individual ports; system total MAC address entry is 8K. Use this screen to view Switch port security settings. Click Monitor > Security > Port Security.
Each field is described in the following table.
Label
Description
Port Security
Status
This field displays the status of global control information.
Port
Port
This field displays a port number.
Status
This field displays the status of port based control information.
Max MAC Entry Number
Displays the designated maximum number of allowed MAC entries. The maximum MAC entry number can be learned for individual ports.
Current Addr Number
This field displays the number of the current addr.
Action
This field displays the actions the Switch takes on the associated classified traffic flow.
802.1X Security Settings
Use this screen to view Switch 802.1x security settings.
Port Settings
Use this screen to view the Switch’s 802.1x port status. Click Monitor > Security > 802.1X > Port.
Label
Description
Port Status
Port
This label shows the port you are viewing.
Status
This field displays status of the port.
Authenticated Hosts
Use this screen to view the Switch’s 802.1x security authenticated host status. Click Monitor > Security > 802.1X > Authenticated Hosts.
Label
Description
Authenticated Hosts
User Name
This field displays the name of a user.
Port
Session Time
This label shows the session time.
Authentication Method
This label shows the authentication method.
MAC Address
This field displays the source MAC address in the binding.
