Label | Description |
DHCP State | This field displays the state of Dynamic Host Configuration Protocol RFC 2131 and RFC 2132 (DHCP). |
IP Address | This field displays IP address of the Switch in the IP domain. |
Subnet Mask | This field displays the subnet mask of the Switch in the IP domain. |
Gateway | This field displays the IP address of the default outgoing gateway in dotted decimal notation, for example 192.168.1.254. |
DNS Server 1 | DNS (Domain Name System) is for mapping a domain name to its corresponding IP address and vice versa. This field displays a domain name server IP address, enabling the use of a domain. |
DNS Server 2 | DNS (Domain Name System) is for mapping a domain name to its corresponding IP address and vice versa. This field displays a domain name server IP address, enabling the use of a domain. |
Management VLAN | This field displays the management VLAN. |
Auto Configuration | This field displays auto configuration. |
IPv6 Address | This field displays IP address of the Switch in the IP domain. |
IPv6 Gateway | This field displays the IP address of the default outgoing gateway. |
DHCPv6 Client | This field displays the Switch’s DHCP settings when it is acting as a DHCPv6 client. |
System Name | This field displays the descriptive name of the Switch for identification purposes. |
System Location | This field displays the geographic location of the Switch for identification purposes. |
System Contact | This field displays the person in charge of the Switch for identification purposes. |
