Web Configurator
Overview
The Web Configurator is an HTML-based management interface that allows easy Switch setup and management through Internet browser. Use a browser that supports HTML5, such as Microsoft Edge, Mozilla Firefox, or Google Chrome. The recommended minimum screen resolution is 1024 by 768 pixels.
In order to use the Web Configurator, you need to allow:
Web browser pop-up windows
JavaScript (enabled by default)
Java permissions (enabled by default)
Access
1 Make sure your Switch hardware is properly connected. See the Quick Start Guide.
2 Browse to https://192.168.1.1. The Login screen appears.
3 Enter the user name (default: “admin”) and password (default: “1234”).
4 Click Login. The Change Password screen appears the first time you log in using the default password.
Enter the default system password (1234). Enter your new system password using the keyboard characters ("a – z", "A – Z", "0 – 9", ~!@#$%^&*()_+`–={}[]:;<>./\). The allowed string length is 1 to 64. Re-enter your new system password for confirmation. Click Apply.
*If you did not change the default SNMP community values, a warning screen displays each time you log into the Web Configurator.
Change the SNMP access right, and then click Apply to save your changes.
SNMP Access Right
LABEL
Description
SNMP
Use this section to specify the SNMP community and access right values.
Community
Enter a string identifying the community name that this entry should belong to. The allowed string length is 1 to 20, and the allowed content is ASCII characters from 33 to 126.
Access Right
Select the access mode for this entry. The possible values are Read-Only and Read-Write.
Apply
Cancel
Navigating the Web Configurator
The following summarizes how to navigate the Web Configurator from the Getting Started screen. The screens may vary slightly for different models.
The Web Configurator’s main screen is divided into these parts:
Title Bar
Navigation Panel
Main Window
Title Bar
The title bar provides some useful links that always appear over the screens below, regardless of how deep into the Web Configurator you navigate.
The icons provide the following functions.
Title Bar: Web Configurator Icons
Label
Description
Refresh
Click Refresh to reload the page.
Save
Click this to apply your changes to the Switch’s run-time memory. The Switch loses these changes if it is turned off or loses power, so use the Save link on the top navigation panel to save your changes to the non-volatile memory when you are done configuring.
Status
Click this to display basic information about the Switch.
Logout
Click this to log out of the Web Configurator.
Help
Click this to open the help page for the current screen.
Click Logout in a screen to exit the Web Configurator. You have to log in with your password again after you log out. This is recommended after you finish a management session for security reasons.
Navigation Panel
Use the menu items on the navigation panel to open screens to configure Switch features. The following sections introduce the Switch’s navigation panel menus and their screens.
Getting Started
Getting Started displays general device information, system status, system resource usage, and interface status.
Monitor Menu
The monitor menu screens display status and statistics information.
Monitor Menu Screens Summary
Folder or Link
Tab
Function
System
This link takes you to a screen where you can see general identification information for the Switch.
IP
IPv4
This link takes you to a screen where you can see an IPv4 interface and the IPv4 settings on the Switch.
IPv6
This link takes you to a screen where you can see an IPv6 interface and the IPv6 settings on the Switch.
Information
This link takes you to a screen that displays general system information: system name, system location, and system contact.
Port
This link takes you to screens where you can see speed, flow control and priority settings of individual Switch ports.
Port
Status
This link takes you to a screen to view the statistics of individual Switch ports.
Port Counters
This link takes you to a screen to view the interface, port 1 interface mib counters, port 1 etherlike mib counters, port 1 RMON mib counters settings of individual Switch ports.
Bandwidth Utilization
This link takes you to a screen to view the Tx and Rx bandwidth utilization of individual Switch ports.
PoE
This link takes you to a screen to view the current amount of power that PDs are receiving from the Switch.
Bandwidth Management
This link takes you to a screen to view the egress global burst and port rate for individual Switch ports.
Storm Control
This link takes you to a screen that displays broadcast filters.
VLAN
This link takes you to screens where you can see port-based or 802.1Q VLAN (depending on what you configured in the Switch Setup menu). You can also see a protocol based VLAN or a subnet based VLAN in these screens.
VLAN
VLAN
This link takes you to a screen to view the Switch’s VLAN settings.
Port
This link takes you to a screen to view the Switch’s port setting in VLAN.
VLAN Port
This link takes you to a screen to view the Switch’s VLAN port settings.
Guest VLAN
This link takes you to a screen to view the Switch’s guest VLAN settings.
Voice VLAN
This link takes you to a screen to view the Switch’s global and port voice VLAN settings for voice traffic.
MAC Table
This link takes you to a screen where you can view the MAC address and VLAN ID of a device attach to a port. You can also view what kind of MAC address it is.
Link Aggregation
This link takes you to screen where you can view aggregate physical links to form one logical, higher-bandwidth link.
Loop Guard
This link takes you to a screen where you can view protection against network loops that occur on the edge of your network.
Multicast
This link takes you to screen where you can view various multicast features, IGMP snooping and create multicast VLANs.
IGMP
VLAN
This link takes you to a screen to view the Switch’s IGMP VLAN status.
Statistics
This link takes you to a screen to view the Switch’s IGMP statistics.
Group
This link takes you to a screen to view the Switch’s IGMP group information.
Router
This link takes you to a screen to view the Switch’s IGMP router information.
Spanning Tree
This link takes you to screens where you can view CIST, MST, STP preventing network loops.
CIST
This link takes you to a screen to view the Switch’s spanning tree CIST instance.
CIST Port
This link takes you to a screen to view the Switch’s spanning tree CIST port status.
MST
This link takes you to a screen to view the Switch’s spanning tree MST instance status.
MST Port
This link takes you to a screen to view the Switch’s spanning tree MST port status.
STP Statistics
This link takes you to a screen to view the Switch’s spanning tree STP statistics.
LLDP
This link takes you to screens where you can view the LLDP settings.
Statistics
This link takes you to a screen to view the Switch’s LLDP global and port statistics.
Remote Information
This link takes you to a screen to view the Switch’s LLDP remote device information.
Overloading
This link takes you to a screen to view the Switch’s LLDP port overloading status.
Security
This link takes you to screens where you can view the port security and 802.1X settings.
Port Security
This link takes you to a screen to view the Switch’s port security status.
802.1X
Port
This link takes you to a screen to view the Switch’s 802.1X port status.
Authenticated Hosts
This link takes you to a screen to view the Switch’s 802.1X security authenticated host status.
Management
This link takes you to screens where you can view the syslog and error disable status.
Syslog
This link takes you to a screen to view the Switch’s logging filter settings and system logs.
Error Disable
This link takes you to a screen to view the Switch’s global and port error disable status.
Configuration Menu
Use the configuration menu screens to configure the Switch’s features.
Configuration Menu Screens Summary
Folder or Link
Tab
Function
System
This link takes you to a screen where you can configure general identification information and time settings for the Switch.
IP
IPv4
This link takes you to a screen where you can enable an IPv4 interface and configure the IPv4 settings on the Switch.
IPv6
This link takes you to a screen where you can enable an IPv6 interface and configure the IPv6 settings on the Switch.
Time
System Time
This link takes you to a screen to configure the time of the system.
SNTP Server
This link takes you to a screen to configure the SNTP server settings.
Information
This link takes you to a screen that configures general system information: system name, system location, and system contact.
Port
This link takes you to screens where you can configure speed, flow control and priority settings for individual Switch ports.
Port
This link takes you to a screen to view the Switch’s port settings and select individual Switch ports for configuration.
EEE
This link takes you to a screen to view the Switch’s port EEE (Energy-Efficient Ethernet) state and select ports for configuration.
PoE
Global
This link takes you to a screen where you can configure the global settings for the Switch to supply power over Ethernet (PoE).
Port
This link takes you to a screen where you can configure port PoE settings.
This link takes you to a screen where you can view and configure the egress global burst and port rate.
Storm Control
This link takes you to a screen to set up broadcast filters.
VLAN
This link takes you to screens where you can configure VLAN, guest VLAN, and voice VLAN settings.
VLAN
VLAN
This link takes you to a screen where you can view and add/edit the VLAN settings.
Port
This link takes you to a screen where you can view port settings and select VLANs for configuration.
VLAN Port
This link takes you to a screen where you can view and configure the VLAN port settings.
Guest VLAN
Global
This link takes you to a screen where you can configure the global guest VLAN settings.
Port
This link takes you to a screen where you can view the guest VLAN port settings and select VLAN ports for configuration.
Voice VLAN
Global
This link takes you to a screen where you can configure the global voice VLAN settings.
OUI
This link takes you to a screen where you can view and edit/delete the OUI settings.
Port
This link takes you to a screen where you can view the voice VLAN port settings and select a port for configuration.
MAC Table
This link takes you to a screen where you can configure the MAC address and VLAN ID of a device attach to a port. You can also configure what kind of MAC address it is.
Static MAC
This link takes you to screens where you can configure static MAC addresses for a port. These static MAC addresses do not age out.
Filtering MAC
This link takes you to a screen to set up filtering rules.
Dynamic Age
This link takes you to a screen where you can enter the dynamic MAC aging time.
Link Aggregation
This link takes you to a screen where you can logically aggregate physical links to form one logical, higher-bandwidth link.
Global
This link takes you to a screen where you can configure the global link aggregation settings.
LAG Management
This link takes you to a screen where you can configure the LAG management settings.
LAG Port
This link takes you to a screen where you can view or edit the LAG port settings.
LACP Port
This link takes you to a screen where you can view or edit the LACP port settings.
Loop Guard
This link takes you to screens where you can configure protection against network loops that occur on the edge of your network.
Global
This link takes you to a screen where you can configure the global loop guard settings.
Port
This link takes you to a screen where you can view or edit the port’s loop guard settings.
Mirror
This link takes you to a screen where you can copy traffic from one port or ports to another port. This allowing you to examine the traffic from the first port without interference.
Time Range Group
This link takes you to a screen where you can view/define/delete time range (schedule) rules.
Multicast
This link takes you to a screen where you can configure various multicast features, IGMP snooping and create multicast VLANs.
IGMP
Global
This link takes you to a screen where you can configure the IGMP global settings.
VLAN
This link takes you to a screen where you can view or edit the IGMP VLAN settings.
Router Port
This link takes you to a screen where you can add or view the router port settings.
Profile
This link takes you to a screen where you can add or view the IGMP profile settings.
Throttling
This link takes you to a screen where you can view or edit the throttling settings.
Spanning Tree
This link takes you to screens where you can configure the RSTP/MRSTP/MSTP to prevent network loops.
Global
This link takes you to a screen where you can configure the global settings.
STP Port
This link takes you to a screen where you can view or edit the STP port settings.
CIST
This link takes you to a screen where you can configure the CIST settings.
CIST Port
This link takes you to a screen where you can view or edit the CIST port settings.
MST
This link takes you to a screen where you can add/edit/delete the MST instance settings.
MST Port
This link takes you to a screen where you can view or edit the MST port settings.
LLDP
This link takes you to screens where you can configure the global, port, local information, MED network policy, and MED port settings.
Global
This link takes you to a screen where you can configure the global LLDP settings.
Port
This link takes you to a screen where you can view or edit the LLDP port settings.
Local Information
This link takes you to a screen where you can view or edit the LLDP local information settings.
MED Network Policy
This link takes you to a screen where you can add/edit/delete the LLDP MED network policy settings.
MED Port
This link takes you to a screen where you can view or edit the LLDP MED port settings.
QoS
This link takes you to screens where you can configure the general and trust mode settings.
General
Port
This link takes you to a screen where you can view or edit the QoS port settings.
Queue
This link takes you to a screen where you can configure queuing with associated queue weights for each port.
CoS Mapping
This link takes you to a screen where you can configure the CoS to queue mapping and Queue to CoS mapping settings.
DSCP Mapping
This link takes you to a screen where you can configure the DSCP to queue and queue to DSCP mapping settings.
IP Precedence Mapping
This link takes you to a screen where you can configure the IP precedence to queue and queue to IP precedence mapping settings.
Trust Mode
Global
This link takes you to a screen where you can configure the global trust mode setting.
Port
This link takes you to a screen where you can view or edit the QoS port trust mode setting.
Security
This link takes you to screens where you can configure the port security, port isolation, 802.1X and DoS settings.
Port Security
Global
This link takes you to a screen where you can enable the global port security.
Port
This link takes you to a screen where you can view or edit the port’s security settings.
Port Isolation
This link takes you to a screen where you can view the state or enable/disable port isolation.
802.1X
Global
This link takes you to a screen where you can enable the global 802.1X security setting.
Port
This link takes you to a screen where you can view or edit the 802.1X port security settings.
DoS
Global
This link takes you to a screen where you can enable Denial of Service (DoS).
Port
This link takes you to a screen where you can view or edit the Switch’s port DoS state.
AAA
This link takes you to a screen where you can view authentication, authorization and accounting services through external servers. The external servers can be either RADIUS (Remote Authentication Dial-In User Service) or TACACS+ (Terminal Access Controller Access-Control System Plus).
Auth Method
This link takes you to a screen where you can add/edit/delete an authentication method.
RADIUS
This link takes you to a screen where you can add/edit/delete RADIUS server settings.
TACACS+
This link takes you to a screen where you can add/edit/delete TACACS+ server settings.
Management
This link takes you to screens where you can configure the syslog, SNMP, error disable, HTTP/HTTPS, users and remote access control.
Syslog
Global
This link takes you to a screen where you can enable syslog (system logging).
Local
This link takes you to a screen where you can add/edit/delete the local syslog settings.
Remote
This link takes you to a screen where you can add/edit/delete the remote syslog settings.
SNMP
Global
This link takes you to a screen where you can enable SNMP (Simple Network Management Protocol).
Community
This link takes you to a screen where you can add/delete the SNMP community settings.
Group
This link takes you to a screen where you can add/edit/delete the SNMP group settings.
User
This link takes you to a screen where you can add/edit/delete the SNMP users’ settings.
Trap
This link takes you to a screen where you can enable the SNMP traps.
Trap Destination
This link takes you to a screen where you can add/edit/delete the SNMP trap host settings.
Error Disable
This link takes you to a screen where you can configure the error disable settings.
HTTP/HTTPS
HTTP
This link takes you to a screen where you can enable and configure the management HTTP settings.
HTTPS
This link takes you to a screen where you can enable and configure the management HTTPS settings.
TELNET/SSH
TELNET
This link takes you to a screen where you can enable remote Telnet access.
SSH
This link takes you to a screen where you can enable SSH connection.
Users
This link takes you to a screen where you can configure the management users’ settings.
Remote Access Control
This link takes you to a screen where you can enable remote access control and add/edit/delete profile settings.
Maintenance Menu
Use the maintenance menu screens to manage configuration and firmware files, run diagnostics, and reboot or shut down the Switch.
Maintenance Menu Screens Summary
Folder or Link
Tab
Function
Firmware
Upload
This link takes you to a screen where you can manage the firmware upload settings.
Management
This link takes you to a screen where you can view the active/backup firmware image information and activate an image.
Configuration
Backup
This link takes you to a screen where you can backup your current Switch configuration and log files to a server or as a local file to your computer.
Restore
This link takes you to a screen where you can restore a previously saved configuration from a server or your computer.
Management
This link takes you to a screen where you can replace the startup and backup configuration files.
Factory Default
This link takes you to a screen where you can reset the Switch back to factory default settings.
Certificates
This link takes you to a screen where you can import the Switch’s CA-signed certificates.
Diagnostics
This link takes you to screens where you can view system logs and test ports.
Port Test
This link takes you to a screen where you can perform an internal loop-back test on an Ethernet port.
PING
IPv4
This link takes you to a screen where you can ping an IPv4 server.
IPv6
This link takes you to a screen where you can ping an IPv6 server.
Trace Route
This link takes you to a screen where you can print the route that IP packets take to a network host.
Reboot
This link takes you to a screen where you can restart the Switch without turning the power off.
