Label | Description |
Add | Click this to add a new profile. |
Edit | Click this to edit the selected profile. |
Remove | Click this to remove the selected profile. |
# | This field is a sequential value, and it is not associated with a specific profile. |
Profile Name | This field indicates the name assigned to the profile. |
WDS SSID | This field shows the SSID specified in this WDS profile. |
Profile Name | Enter up to 31 alphanumeric characters for the profile name. |
WDS SSID | Enter the SSID with which you want the Zyxel Device to connect to a root AP or repeater to form a WDS. |
Pre-Shared Key | Enter a pre-shared key of between 8 and 63 case-sensitive ASCII characters (including spaces and symbols) or 64 hexadecimal characters. The key is used to encrypt the traffic between the APs. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
