Color | status | description | |
![]() | Amber | Blinks amber for 1 second and green for 1 second alternatively. | The Zyxel Device is booting up or is connecting with NCC. |
Green | |||
![]() | Amber | Blinks amber and green alternatively 3 times and then turns solid green for 3 seconds. | The Zyxel Device is discovering the NCC or an AC. |
Green | |||
![]() | Amber | Blinks amber and green alternatively 2 times and then turns solid green for 3 seconds. | The Zyxel Device is managed by an AC but the uplink is disconnected. |
Green | |||
![]() | Green | Slow Blinking (On for 1 second, Off for 1 second) | The wireless module of the Zyxel Device is disabled or fails, the Zyxel Device is using default wireless settings, or the Zyxel Device is configured to be managed by NCC but is not yet registered with the NCC. |
![]() | Green | Steady On | The Zyxel Device is ready for use, the Zyxel Device’s wireless interface is activated, and/or wireless clients are connected to the Zyxel Device. |
![]() | Bright Blue | Steady On | The Zyxel Device’s wireless interface is activated, but there are no wireless clients connected. |
![]() | Blue | Slow Blinking (Blink for 1 time, Off for 1 second) | The Zyxel Device is performing a Channel Availability Check (CAC) with Dynamic Frequency Selection (DFS) to monitor a channel for radar signals. |
![]() | Red | On | The Zyxel Device failed to boot up or is experiencing system failure. |
![]() | Fast Blinking (On for 50 milliseconds, Off for 50 milliseconds) | The Zyxel Device is undergoing firmware upgrade. | |
![]() | Slow Blinking (Blink for 3 times, Off for 3 seconds) | The Uplink port of the Zyxel Device in standalone mode is disconnected. |
