label | description |
General | |
Enable Sandbox | Select this option to turn on sandbox if you have a license and have activated it on the Zyxel Device. Otherwise, deselect it. |
Collect Statistics | Enable to have the Zyxel Device collect sandbox statistics, such as the time, type and name of the files scanned. The statistics collected will display in Security Statistics > Sandbox. All of the statistics are erased if you restart the Zyxel Device or click Flush Data in Security Statistics > Sandbox. |
Action For Malicious File | Specify whether the Zyxel Device deletes (destroy) or forwards (allow) malicious files. Malicious files are files given a high score for malware characteristics by the cloud. You can check the medium score for malware characteristics given by the cloud in the logs. |
Log For Malicious File | These are the log options for malicious files: • no: Do not create a log when a malicious file is detected. • log: Create a log on the Zyxel Device when a malicious file is detected. • log alert: An alert is an emailed log. Select this option to have the Zyxel Device send an alert when a malicious file is detected. |
Action For Suspicious File | Specify whether the Zyxel Device deletes (destroy) or forwards (allow) suspicious files. Suspicious files are files given a medium score for malware characteristics by the cloud. You can check the medium score for malware characteristics given by the cloud in the logs. |
Log For Suspicious File | These are the log options for suspicious files: no: Do not create a log when a suspicious file is detected. log: Create a log on the Zyxel Device when a suspicious file is detected. log alert: An alert is an emailed log for more serious events that may need more immediate attention. Select this option to have the Zyxel Device send an alert when a suspicious file is detected. |
File Types to Scan | Specify the type of files to be sent for sandbox inspection. • Executables (exe): An executable file is a file that contains a program or application which your computer can run • MS Office Document (doc...): This category includes Microsoft Word files, Microsoft Excel files and Microsoft PowerPoint files. MS Office Document are files that are created using software developed by Microsoft. • Macromedia Flash Data (swf): A flash file (.swf) is a file that contains animations, multimedia elements or games. A flash file is often embedded into a web page. • PDF Document (pdf): A Portable Document Format (PDF) file is a file that maintains the presentation and formatting of documents across different platform and devices. • RTF Document (rtf): A Rich Text Format (RTF) file is a file that allows you to create text with different formats, such as bold or italics. • ZIP Archive (zip): A zip file is a file used to compress multiple files together into a single file. A zip file can reduce the overall size of a collection of files. |
Search | Type an item in the search box, then click this to display all file types in the table below according to the item you typed. |
Select All | Select this to select all file types in the table. |
Apply | Click Apply to save your changes. |
Cancel | Click Cancel to return the screen to its last-saved settings. |
