Interfaces
Interface Overview
Use the Interface screens to configure the Zyxel Device’s interfaces. You can also create interfaces on top of other interfaces.
• Ports are the physical ports to which you connect cables.
• Interfaces are used within the system operationally. You use them in configuring various features. An interface also describes a network that is directly connected to the Zyxel Device. For example, You connect the LAN network to the LAN interface.
• Zones are groups of interfaces used to ease security policy configuration.
• Use the Port Role screen (Port Role) to create port groups and to assign physical ports and port groups to Ethernet interfaces.
• Use the Port Configuration screen (Port Configuration) to configure Zyxel Device port settings.
• Use the Ethernet screens (Ethernet Summary) to configure the Ethernet interfaces. Ethernet interfaces are the foundation for defining other interfaces and network policies. RIP and OSPF are also configured in these interfaces.
• Use the PPP screens (PPP Interfaces) for PPPoE, PPTP or L2TP Internet connections.
• Use the Cellular screens (Cellular Configuration) to configure settings for interfaces for Internet connections through an installed mobile broadband card.
• Use the Tunnel screens (Tunnel Interfaces) to configure tunnel interfaces to be used in Generic Routing Encapsulation (GRE), IPv6 in IPv4, and 6to4 tunnels.
• Use the VLAN screens (VLAN Interfaces) to divide the physical network into multiple logical networks. VLAN interfaces receive and send tagged frames. The Zyxel Device automatically adds or removes the tags as needed. Each VLAN can only be associated with one Ethernet interface.
• Use the Bridge screens (Bridge Interfaces) to combine two or more network segments into a single network.
• Use the VTI screens (VTI) to encrypt or decrypt IPv4 traffic from or to the interface according to the IP routing table.
• Use the Trunk screens (Trunk Overview) to configure load balancing.
What You Need to Know
Interface Characteristics
Interfaces generally have the following characteristics (although not all characteristics apply to each type of interface).
• An interface is a logical entity through which (layer-3) packets pass.
• An interface is bound to a physical port or another interface.
• Many interfaces can share the same physical port.
• An interface belongs to at most one zone.
• Many interfaces can belong to the same zone.
• Layer-3 virtualization (IP alias, for example) is a kind of interface.
Types of Interfaces
You can create several types of interfaces in the Zyxel Device.
• Setting interfaces to the same port role forms a port group. Port groups creates a hardware connection between physical ports at the layer-2 (data link, MAC address) level. Port groups are created when you use the Interface > Port Roles screen to set multiple physical ports to be part of the same interface.
• Ethernet interfaces are the foundation for defining other interfaces and network policies. RIP and OSPF are also configured in these interfaces.
• Tunnel interfaces send IPv4 or IPv6 packets from one network to a specific network through the Internet or a public network.
• VLAN interfaces receive and send tagged frames. The Zyxel Device automatically adds or removes the tags as needed. Each VLAN can only be associated with one Ethernet interface.
• Bridge interfaces create a software connection between Ethernet or VLAN interfaces at the layer-2 (data link, MAC address) level. Unlike port groups, bridge interfaces can take advantage of some security features in the Zyxel Device. You can also assign an IP address and subnet mask to the bridge.
• PPP interfaces support Point-to-Point Protocols (PPP). ISP accounts are required for PPPoE/PPTP/L2TP interfaces.
• Cellular interfaces are for mobile broadband WAN connections via a connected mobile broadband device.
• Virtual interfaces provide additional routing information in the Zyxel Device. There are three types: virtual Ethernet interfaces, virtual VLAN interfaces, and virtual bridge interfaces.
• Trunk interfaces manage load balancing between interfaces.
Port groups and trunks have a lot of characteristics that are specific to each type of interface. The other types of interfaces--Ethernet, PPP, cellular, VLAN, bridge, and virtual--have a lot of similar characteristics. These characteristics are listed in the following table and discussed in more detail below.
Ethernet, PPP, Cellular, VLAN, Bridge, and Virtual Interface Characteristics
Characteristics
Ethernet
Ethernet
PPP
CELLULAR
VLAN
Bridge
Virtual
Name*
wan1, wan2
lan1, lan2, dmz
pppx
cellularx
vlanx
brx
Configurable Zone
No
No
Yes
Yes
Yes
Yes
No
IP Address Assignment
Static IP address
Yes
Yes
Yes
Yes
Yes
Yes
Yes
DHCP client
Yes
No
Yes
Yes
Yes
Yes
No
Routing metric
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Interface Parameters
Bandwidth restrictions
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Packet size (MTU)
Yes
Yes
Yes
Yes
Yes
Yes
No
DHCP
DHCP server
No
Yes
No
No
Yes
Yes
No
DHCP relay
No
Yes
No
No
Yes
Yes
No
Connectivity Check
Yes
No
Yes
Yes
Yes
Yes
No
Note: - * The format of interface names other than the Ethernet and ppp interface names is strict. Each name consists of 2-4 letters (interface type), followed by a number (x). For most interfaces, x is limited by the maximum number of the type of interface. For VLAN interfaces, x is defined by the number you enter in the VLAN name field. For example, Ethernet interface names are wan1, wan2, lan1, lan2, dmz; VLAN interfaces are vlan0, vlan1, vlan2,...; and so on.
** - The names of virtual interfaces are derived from the interfaces on which they are created. For example, virtual interfaces created on Ethernet interface wan1 are called wan1:1, wan1:2, and so on. Virtual interfaces created on VLAN interface vlan2 are called vlan2:1, vlan2:2, and so on. You cannot specify the number after the colon(:) in the Web Configurator; it is a sequential number. You can specify the number after the colon if you use the CLI to set up a virtual interface.
Relationships Between Interfaces
In the Zyxel Device, interfaces are usually created on top of other interfaces. Only Ethernet interfaces are created directly on top of the physical ports or port groups. The relationships between interfaces are explained in the following table.
Relationships Between Different Types of Interfaces
Interface
Required Port / Interface
Ethernet interface
physical port
VLAN interface
Ethernet interface
bridge interface
Ethernet interface*
VLAN interface*
PPP interface
Ethernet interface*
VLAN interface*
bridge interface
WAN1, WAN2, OPT*
virtual interface
(virtual Ethernet interface)
(virtual VLAN interface)
(virtual bridge interface)
Ethernet interface*
VLAN interface*
bridge interface
trunk
Ethernet interface
Cellular interface
VLAN interface
bridge interface
PPP interface
Note: * You cannot set up a PPP interface, virtual Ethernet interface or virtual VLAN interface if the underlying interface is a member of a bridge. You also cannot add an Ethernet interface or VLAN interface to a bridge if the member interface has a virtual interface or PPP interface on top of it.
IPv6 Overview
IPv6 (Internet Protocol version 6), is designed to enhance IP address size and features. The increase in IPv6 address size to 128 bits (from the 32-bit IPv4 address) allows up to 3.4 x 1038 IP addresses.
IPv6 Addressing
128-bit IPv6 address is written as eight 16-bit hexadecimal blocks separated by colons (:). This is an example IPv6 address 2001:0db8:1a2b:0015:0000:0000:1a2f:0000.
IPv6 addresses can be abbreviated in two ways:
• Leading zeros in a block can be omitted. So 2001:0db8:1a2b:0015:0000:0000:1a2f:0000 can be written as 2001:db8:1a2b:15:0:0:1a2f:0.
• Any number of consecutive blocks of zeros can be replaced by a double colon. A double colon can only appear once in an IPv6 address. So 2001:0db8:0000:0000:1a2f:0000:0000:0015 can be written as 2001:0db8::1a2f:0000:0000:0015, 2001:0db8:0000:0000:1a2f::0015, 2001:db8::1a2f:0:0:15 or 2001:db8:0:0:1a2f::15.
Prefix and Prefix Length
Similar to an IPv4 subnet mask, IPv6 uses an address prefix to represent the network address. An IPv6 prefix length specifies how many most significant bits (start from the left) in the address compose the network address. The prefix length is written as “/x” where x is a number. For example,
2001:db8:1a2b:15::1a2f:0/32
means that the first 32 bits (2001:db8) from the left is the network prefix.
Link-local Address
A link-local address uniquely identifies a device on the local network (the LAN). It is similar to a “private IP address” in IPv4. You can have the same link-local address on multiple interfaces on a device. A link-local unicast address has a predefined prefix of fe80::/10. The link-local unicast address format is as follows.
Link-local Unicast Address Format
1111 1110 10
Interface ID
10 bits
54 bits
64 bits
Subnet Masking
Both an IPv6 address and IPv6 subnet mask compose of 128-bit binary digits, which are divided into eight 16-bit blocks and written in hexadecimal notation. Hexadecimal uses four bits for each character (1 ~ 10, A ~ F). Each block’s 16 bits are then represented by four hexadecimal characters. For example, FFFF:FFFF:FFFF:FFFF:FC00:0000:0000:0000.
Stateless Autoconfiguration
With stateless autoconfiguration in IPv6, addresses can be uniquely and automatically generated. Unlike DHCPv6 (Dynamic Host Configuration Protocol version six) which is used in IPv6 stateful autoconfiguration, the owner and status of addresses don’t need to be maintained by a DHCP server. Every IPv6 device is able to generate its own and unique IP address automatically when IPv6 is initiated on its interface. It combines the prefix and the interface ID (generated from its own Ethernet MAC address) to form a complete IPv6 address.
When IPv6 is enabled on a device, its interface automatically generates a link-local address (beginning with fe80).
When the Zyxel Device’s WAN interface is connected to an ISP with a router and the Zyxel Device is set to automatically obtain an IPv6 network prefix from the router for the interface, it generates another address which combines its interface ID and global and subnet information advertised from the router. (This is a routable global IP address.
Prefix Delegation
Prefix delegation enables an IPv6 router (the Zyxel Device) to use the IPv6 prefix (network address) received from the ISP (or a connected uplink router) for its LAN. The Zyxel Device uses the received IPv6 prefix (for example, 2001:db2::/48) to generate its LAN IP address. Through sending Router Advertisements (RAs) regularly by multicast, the router passes the IPv6 prefix information to its LAN hosts. The hosts then can use the prefix to generate their IPv6 addresses.
IPv6 Router Advertisement
An IPv6 router sends router advertisement messages periodically to advertise its presence and other parameters to the hosts on the same network.
DHCPv6
The Dynamic Host Configuration Protocol for IPv6 (DHCPv6, RFC 3315) is a server-client protocol that allows a DHCP server to assign and pass IPv6 network addresses, prefixes and other configuration information to DHCP clients. DHCPv6 servers and clients exchange DHCP messages using UDP.
Each DHCP client and server has a unique DHCP Unique IDentifier (DUID), which is used for identification when they are exchanging DHCPv6 messages. The DUID is generated from the MAC address, time, vendor assigned ID and/or the vendor's private enterprise number registered with the IANA. It should not change over time even after you reboot the device.
What You Need to Do First
For IPv6 settings, go to the Configuration > System > IPv6 screen to enable IPv6 support on the Zyxel Device first.
Port Role
Use the Port Role screen to set the Zyxel Device’s physical ports to ZONE interfaces. This creates a hardware connection between the physical ports at the layer-2 (data link, MAC address) level. This provides wire-speed throughput but no security.
Note the following if you are configuring from a computer connected to a lan1, lan2, ext-wlan, ext-lan or dmz port and change the port's role:
• A port's IP address varies as its role changes, make sure your computer's IP address is on the same subnet as the Zyxel Device's interface IP address.
• Use the appropriate interface IP address to access the Zyxel Device.
The physical Ethernet ports are shown at the top and the Ethernet interfaces and zones are shown at the bottom of the screen. Use the radio buttons to select for which interface (network) you want to use each physical port. For example, select a port’s LAN radio button to use the port as part of the LAN interface. The port will use the Zyxel Device’s LAN IP address and MAC address.
When you assign more than one physical port to a network, you create a port group. Port groups have the following characteristics:
• There is a layer-2 Ethernet switch between physical ports in the port group. This provides wire-speed throughput but no security.
• It can increase the bandwidth between the port group and other interfaces.
• The port group uses a single MAC address.
Click Apply to save your changes and apply them to the Zyxel Device.
Click Reset to change the port groups to their current configuration (last-saved values).
Port Configuration
Note: Use this screen to configure port settings. You cannot configure the speed and duplex mode of fiber ports.
Each field is described in the following table.
Configuration > Network > Interface > Port Configuration
Label
Description
Edit
Select an entry, and click this button to configure the speed and the duplex mode of the Ethernet connection on this port.
Name
This field displays the name of the port.
Interface
This field displays the interface for the port.
Type
This field displays the cable type that is used on the port.
Settings
Select the speed and the duplex mode of the Ethernet connection on this port. Choices are Auto Negotiate, 1000Mbps-Full Duplex, 100Mbps-Full Duplex, 100Mbps-Half Duplex, 10Mbps-Full Duplex, and 10Mbps-Half Duplex.
Selecting Auto Negotiate allows one port to negotiate with a peer port automatically to obtain the connection speed (of up to 1000M) and duplex mode that both ends support. When auto-negotiation is turned on, a port on the Zyxel Device negotiates with the peer automatically to determine the connection speed and duplex mode. If the peer port does not support auto-negotiation or turns off this feature, the Zyxel Device determines the connection speed by detecting the signal on the cable and using half duplex mode. When the Zyxel Device’s auto-negotiation is turned off, a port uses the pre-configured speed and duplex mode when making a connection, thus requiring you to make sure that the settings of the peer port are the same in order to connect.
Status
This field displays the speed and the duplex mode of the Ethernet connection on the port.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Ethernet Summary
This screen lists every Ethernet interface and virtual interface created on top of Ethernet interfaces. If you enabled IPv6 on the Configuration > System > IPv6 screen, you can also configure Ethernet interfaces used for your IPv6 networks on this screen.
Unlike other types of interfaces, you cannot create new Ethernet interfaces nor can you delete any of them. If an Ethernet interface does not have any physical ports assigned to it, the Ethernet interface is effectively removed from the Zyxel Device, but you can still configure it.
Ethernet interfaces are similar to other types of interfaces in many ways. They have an IP address, subnet mask, and gateway used to make routing decisions. They restrict the amount of bandwidth and packet size. They can provide DHCP services, and they can verify the gateway is available.
Use Ethernet interfaces to control which physical ports exchange routing information with other routers and how much information is exchanged through each one. The more routing information is exchanged, the more efficient the routers should be. However, the routers also generate more network traffic, and some routing protocols require a significant amount of configuration and management. The Zyxel Device supports the following routing protocols: RIP, OSPF and BGP.
Label
Description
Configuration / IPv6 Configuration
Use the Configuration section for IPv4 network settings. Use the IPv6 Configuration section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings.
Remove
To remove a virtual interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
To turn on an interface, select it and click Activate.
Inactivate
To turn off an interface, select it and click Inactivate.
Create Virtual Interface
To open the screen where you can create a virtual Ethernet interface, select an Ethernet interface and click Create Virtual Interface.
References
Select an entry and click References to open a screen that shows which settings use the entry.
This field is a sequential value, and it is not associated with any interface.
Status
This icon is lit when the entry is active and dimmed when the entry is inactive.
Name
This field displays the name of the interface.
Description
This field displays the description of the interface.
IP Address
This field displays the current IP address of the interface. If the IP address is 0.0.0.0 (on the IPv4 network) or :: (on the IPv6 network), the interface does not have an IP address yet.
On the IPv4 network, this screen also shows whether the IP address is a static IP address (STATIC) or dynamically assigned (DHCP). IP addresses are always static in virtual interfaces.
On the IPv6 network, this screen also shows whether the IP address is a static IP address (STATIC), link-local IP address (LINK LOCAL), dynamically assigned (DHCP), or an IPv6 StateLess Address AutoConfiguration IP address (SLAAC).
Mask
This field displays the interface’s subnet mask in dot decimal notation.
Apply
Reset
Ethernet Edit
The Ethernet Edit screen lets you configure IP address assignment, interface parameters, RIP settings, OSPF settings, DHCP settings, connectivity check, and MAC address settings.
Note: If you create IP address objects based on an interface’s IP address, subnet, or gateway, the Zyxel Device automatically updates every rule or setting that uses the object whenever the interface’s IP address settings change. For example, if you change the VLAN's IP address, the Zyxel Device automatically updates the corresponding interface-based, LAN subnet address object.
With RIP, you can use Ethernet interfaces to do the following things.
• Enable and disable RIP in the underlying physical port or port group.
• Select which direction(s) routing information is exchanged - The Zyxel Device can receive routing information, send routing information, or do both.
• Select which version of RIP to support in each direction - The Zyxel Device supports RIP-1, RIP-2, and both versions.
• Select the broadcasting method used by RIP-2 packets - The Zyxel Device can use subnet broadcasting or multicasting.
With OSPF, you can use Ethernet interfaces to do the following things.
• Enable and disable OSPF in the underlying physical port or port group.
• Select the area to which the interface belongs.
• Override the default link cost and authentication method for the selected area.
• Select in which direction(s) routing information is exchanged - The Zyxel Device can receive routing information, send routing information, or do both.
Set the priority used to identify the DR or BDR if one does not exist.
IGMP Proxy
• Internet Group Management Protocol (IGMP) proxy is used for multicast routing. IGMP proxy enables the Zyxel Device to issue IGMP host messages on behalf of hosts that the Zyxel Device discovered on its IGMP-enabled interfaces. The Zyxel Device acts as a proxy for its hosts.
• Enable IGMP Upstream (US) on the Zyxel Device interface that connects to a router (R) running IGMP that is closer to the multicast server (MS).
• Enable IGMP Downstream on the Zyxel Device interface which connects to the multicast hosts.
InternalThese screen’s fields are described in the table below.
Configuration > Network > Interface > Ethernet > Edit
Label
Description
IPv4/IPv6 View / IPv4 View / IPv6 View
Use this button to display both IPv4 and IPv6, IPv4-only, or IPv6-only configuration fields.
Show Advanced Settings / Hide Advanced Settings
Click this button to display a greater or lesser number of configuration fields.
Create New Object
Click this button to create a DHCPv6 lease or DHCPv6 request object that you may use for the DHCPv6 settings in this screen.
General Settings
Enable Interface
Select this to enable this interface. Clear this to disable this interface.
General IPv6 Setting
Enable IPv6
Select this to enable IPv6 on this interface. Otherwise, clear this to disable it.
Interface Properties
Interface Type
This field is configurable for the OPT interface only. Select to which type of network you will connect this interface. When you select internal or external the rest of the screen’s options automatically adjust to correspond. The Zyxel Device automatically adds default route and SNAT settings for traffic it routes from internal interfaces to external interfaces; for example LAN to WAN traffic.
internal is for connecting to a local network. Other corresponding configuration options: DHCP server and DHCP relay. The Zyxel Device automatically adds default SNAT settings for traffic flowing from this interface to an external interface.
external is for connecting to an external network (like the Internet). The Zyxel Device automatically adds this interface to the default WAN trunk.
For general, the rest of the screen’s options do not automatically adjust and you must manually configure a policy route to add routing and SNAT settings for the interface.
Interface Name
Specify a name for the interface. It can use alphanumeric characters, hyphens, and underscores, and it can be up to 11 characters long.
Port
This is the name of the Ethernet interface’s physical port.
Zone
Select the zone to which this interface is to belong. You use zones to apply security settings such as security policy, IDP, remote management, anti-malware, and application patrol. Make sure to select the correct zone as otherwise traffic may be blocked by a security policy.
MAC Address
This field is read-only. This is the MAC address that the Ethernet interface uses.
Description
Enter a description of this interface. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. Spaces are allowed, but the string can’t start with a space.
These IP address fields configure an IPv4 IP address on the interface itself. If you change this IP address on the interface, you may also need to change a related address object for the network connected to the interface. For example, if you use this screen to change the IP address of your LAN interface, you should also change the corresponding LAN subnet address object.
Get Automatically
This option appears when Interface Type is external or general. Select this to make the interface a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server.
You should not select this if the interface is assigned to a VRRP group.
DHCP Option 60
DHCP Option 60 is used by the Zyxel Device for identification to the DHCP server using the VCI (Vendor Class Identifier) on the DHCP server. The Zyxel Device adds it in the initial DHCP discovery message that a DHCP client broadcasts in search of an IP address. The DHCP server can assign different IP addresses or options to clients with the specific VCI or reject the request from clients without the specific VCI.
Type a string using up to 63 of these characters [a-zA-Z0-9!\"#$%&\'()*+,-./:;<=>?@\[\\\]^_`{}] to identify this Zyxel Device to the DHCP server. For example, Zyxel-TW.
Use Fixed IP Address
This option appears when Interface Type is external or general. Select this if you want to specify the IP address, subnet mask, and gateway manually.
IP Address
Enter the IP address for this interface.
Subnet Mask
Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network.
Gateway
This option appears when Interface Type is external or general. Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface.
Metric
This option appears when Interface Type is external or general. Enter the priority of the gateway (if any) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first.
Enable IGMP Support
Select this to allow the Zyxel Device to act as an IGMP proxy for hosts connected on the IGMP downstream interface.
IGMP Upstream
Enable IGMP Upstream on the interface which connects to a router running IGMP that is closer to the multicast server.
IGMP Downstream
Enable IGMP Downstream on the interface which connects to the multicast hosts.
IPv6 Address Assignment
These IP address fields configure an IPv6 IP address on the interface itself.
Enable Stateless Address Auto-configuration (SLAAC)
Select this to enable IPv6 stateless auto-configuration on this interface. The interface will generate an IPv6 IP address itself from a prefix obtained from an IPv6 router on the network.
Link-Local Address
This displays the IPv6 link-local address and the network prefix that the Zyxel Device generates itself for the interface.
IPv6 Address/Prefix Length
Enter the IPv6 address and the prefix length for this interface if you want to use a static IP address. This field is optional.
The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address.
Gateway
Enter the IPv6 address of the default outgoing gateway using colon (:) hexadecimal notation.
Metric
Address from DHCPv6 Prefix Delegation
Use this table to have the Zyxel Device obtain an IPv6 prefix from the ISP or a connected uplink router for an internal network, such as the LAN or DMZ. You have to also enter a suffix address which is appended to the delegated prefix to form an address for this interface.
To use prefix delegation, you must:
• Create at least one DHCPv6 request object before configuring this table.
• The external interface must be a DHCPv6 client. You must configure the DHCPv6 request options using a DHCPv6 request object with the type of prefix-delegation.
• Assign the prefix delegation to an internal interface and enable router advertisement on that interface.
Add
Click this to create an entry.
Edit
Select an entry and click this to change the settings.
Remove
Select an entry and click this to delete it from this table.
References
Select an entry and click References to check which settings use the entry.
This field is a sequential value, and it is not associated with any entry.
Delegated
Prefix
Select the DHCPv6 request object to use from the drop-down list.
Suffix
Address
Enter the ending part of the IPv6 address, a slash (/), and the prefix length. The Zyxel Device will append it to the delegated prefix.
For example, you got a delegated prefix of 2003:1234:5678/48. You want to configure an IP address of 2003:1234:5678:1111::1/128 for this interface, then enter ::1111:0:0:0:1/128 in this field.
Address
This field displays the combined IPv6 IP address for this interface.
*This field displays the combined address after you click OK and reopen this screen.
DHCPv6 Setting
DHCPv6
Select N/A to not use DHCPv6.
Select Client to set this interface to act as a DHCPv6 client.
Select Server to set this interface to act as a DHCPv6 server which assigns IP addresses and provides subnet mask, gateway, and DNS server information to clients.
Select Relay to set this interface to route DHCPv6 requests to the DHCPv6 relay server you specify. The DHCPv6 server(s) may be on another network.
DUID
This field displays the DHCP Unique IDentifier (DUID) of the interface, which is unique and used for identification purposes when the interface is exchanging DHCPv6 messages with others.
DUID as MAC
Select this if you want the DUID is generated from the interface’s default MAC address.
Customized DUID
If you want to use a customized DUID, enter it here for the interface.
Enable Rapid Commit
Select this to shorten the DHCPv6 message exchange process from four to two steps. This function helps reduce heavy network traffic load.
*Make sure you also enable this option in the DHCPv6 clients to make rapid commit work.
Information Refresh Time
Enter the number of seconds a DHCPv6 client should wait before refreshing information retrieved from DHCPv6.
Request Address
This field is available if you set this interface to DHCPv6 Client. Select this to get an IPv6 IP address for this interface from the DHCP server. Clear this to not get any IP address information through DHCPv6.
DHCPv6 Request Options /
DHCPv6 Lease Options
If this interface is a DHCPv6 client, use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server. If the interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what additional information to offer to the DHCPv6 clients.
Add
Click this to create an entry in this table. See Add/Edit DHCPv6 Request/Release Options for more information.
Remove
References
Name
This field displays the name of the DHCPv6 request or lease object.
Type
This field displays the type of the object.
Value
This field displays the IPv6 prefix that the Zyxel Device obtained from an uplink router (Server is selected) or will advertise to its clients (Client is selected).
Interface
When Relay is selected, select this check box and an interface from the drop-down list if you want to use it as the relay server.
Relay Server
When Relay is selected, select this check box and enter the IP address of a DHCPv6 server as the relay server.
IPv6 Router Advertisement Setting
Enable Router Advertisement
Select this to enable this interface to send router advertisement messages periodically.
Advertised Hosts Get Network Configuration From DHCPv6
Select this to have the Zyxel Device indicate to hosts to obtain network settings (such as prefix and DNS settings) through DHCPv6.
Clear this to have the Zyxel Device indicate to hosts that DHCPv6 is not available and they should use the prefix in the router advertisement message.
Advertised Hosts Get Other Configuration From DHCPv6
Select this to have the Zyxel Device indicate to hosts to obtain DNS information through DHCPv6.
Clear this to have the Zyxel Device indicate to hosts that DNS information is not available in this network.
Router Preference
Select the router preference (Low, Medium or High) for the interface. The interface sends this preference in the router advertisements to tell hosts what preference they should use for the Zyxel Device. This helps hosts to choose their default router especially when there are multiple IPv6 router on the network.
*Make sure the hosts also support router preference to make this function work.
MTU
The Maximum Transmission Unit. Type the maximum size of each IPv6 data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device discards the packet and sends an error message to the sender to inform this.
Hop Limit
Enter the maximum number of network segments that a packet can cross before reaching the destination. When forwarding an IPv6 packet, IPv6 routers are required to decrease the Hop Limit by 1 and to discard the IPv6 packet when the Hop Limit is 0.
Advertised Prefix Table
Configure this table only if you want the Zyxel Device to advertise a fixed prefix to the network.
Add
Click this to create an IPv6 prefix address.
Edit
Select an entry in this table and click this to modify it.
Remove
Select an entry in this table and click this to delete it.
IPv6
Address/
Prefix Length
Enter the IPv6 network prefix address and the prefix length.
Advertised Prefix from DHCPv6 Prefix Delegation
This table is available when the Interface Type is internal. Use this table to configure the network prefix if you want to use a delegated prefix as the beginning part of the network prefix.
Add
Edit
Remove
Delegated
Prefix
Select the DHCPv6 request object to use for generating the network prefix for the network.
Suffix
Address
Enter the ending part of the IPv6 network address plus a slash (/) and the prefix length. The Zyxel Device will append it to the selected delegated prefix. The combined address is the network prefix for the network.
For example, you got a delegated prefix of 2003:1234:5678/48. You want to divide it into 2003:1234:5678:1111/64 for this interface and 2003:1234:5678:2222/64 for another interface. You can use ::1111/64 and ::2222/64 for the suffix address respectively. But if you do not want to divide the delegated prefix into subnetworks, enter ::0/48 here, which keeps the same prefix length (/48) as the delegated prefix.
Address
This is the final network prefix combined by the delegated prefix and the suffix.
Egress Bandwidth
Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can send through the interface to the network. Allowed values are 0 - 1048576.
Ingress Bandwidth
This is reserved for future use.
Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can receive from the network through the interface. Allowed values are 0 - 1048576.
MTU
Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1500. Usually, this value is 1500.
Connectivity Check
These fields appear when Interface Properties is External or General.
The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check.
Enable Connectivity Check
Select this to turn on the connection check.
Check Method
Select the method that the gateway allows.
Select icmp to have the Zyxel Device regularly ping the gateway you specify to make sure it is still available.
Select tcp to have the Zyxel Device regularly perform a TCP handshake with the gateway you specify to make sure it is still available.
Check Period
Enter the number of seconds between connection check attempts.
Check Timeout
Enter the number of seconds to wait for a response before the attempt is a failure.
Check Fail Tolerance
Enter the number of consecutive failures before the Zyxel Device stops routing through the gateway.
Check Default Gateway
Select this to use the default gateway for the connectivity check.
Check this address
Select this to specify a domain name or IP address for the connectivity check. Enter that domain name or IP address on the field next to it.
Check Port
This field only displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check.
Check these addresses
Type one or two domain names or IP addresses for the connectivity check.
Probe Succeeds When
This field applies when you specify two domain names or IP addresses for the connectivity check.
Select any one if you want the check to pass if at least one of the domain names or IP addresses responds.
Select all if you want the check to pass only if both domain names or IP addresses respond.
DHCP Setting
This section appears when Interface Type is internal or general.
DHCP
Select what type of DHCP service the Zyxel Device provides to the network. Choices are:
None - the Zyxel Device does not provide any DHCP services. There is already a DHCP server on the network.
DHCP Relay - the Zyxel Device routes DHCP requests to one or more DHCP servers you specify. The DHCP server(s) may be on another network.
DHCP Server - the Zyxel Device assigns IP addresses and provides subnet mask, gateway, and DNS server information to the network. The Zyxel Device is the DHCP server for the network.
These fields appear if the Zyxel Device is a DHCP Relay.
Relay Server 1
Enter the IP address of a DHCP server for the network.
Relay Server 2
This field is optional. Enter the IP address of another DHCP server for the network.
These fields appear if the Zyxel Device is a DHCP Server.
IP Pool Start Address
Enter the IP address from which the Zyxel Device begins allocating IP addresses. If you want to assign a static IP address to a specific computer, use the Static DHCP Table.
If this field is blank, the Pool Size must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address.
Pool Size
Enter the number of IP addresses to allocate. This number must be at least one and is limited by the interface’s Subnet Mask. For example, if the Subnet Mask is 255.255.255.0 and IP Pool Start Address is 10.10.10.10, the Zyxel Device can allocate 10.10.10.10 to 10.10.10.254, or 245 IP addresses.
If this field is blank, the IP Pool Start Address must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address.
First DNS Server, Second DNS Server, Third DNS Server
Specify the IP addresses up to three DNS servers for the DHCP clients to use. Use one of the following ways to specify these IP addresses.
Custom Defined - enter a static IP address.
From ISP - select the DNS server that another interface received from its DHCP server.
Zyxel Device - the DHCP clients use the IP address of this interface and the Zyxel Device works as a DNS relay.
First WINS Server, Second WINS Server
Type the IP address of the WINS (Windows Internet Naming Service) server that you want to send to the DHCP clients. The WINS server keeps a mapping table of the computer names on your network and the IP addresses that they are currently using.
Default Router
If you set this interface to DHCP Server, you can select to use either the interface’s IP address or another IP address as the default router. This default router will become the DHCP clients’ default gateway.
To use another IP address as the default router, select Custom Defined and enter the IP address.
Lease time
Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are:
infinite - select this if IP addresses never expire.
days, hours, and minutes - select this to enter how long IP addresses are valid.
Extended Options
This table is available if you selected DHCP server.
Configure this table if you want to send more information to DHCP clients through DHCP packets.
Add
Click this to create an entry in this table. See Add/Edit DHCP Extended Options.
Edit
Remove
Name
This is the name of the DHCP option.
Code
This is the code number of the DHCP option.
Type
This is the type of the set value for the DHCP option.
Value
This is the value set for the DHCP option.
PXE Server
PXE (Preboot eXecution Environment) allows a client computer to use the network to boot up and install an operating system via a PXE-capable Network Interface Card (NIC).
PXE is available for computers on internal interfaces to allow them to boot up using boot software on a PXE server. The Zyxel Device acts as an intermediary between the PXE server and the computers that need boot software.
The PXE server must have a public IPv4 address. You must enable DHCP Server on the Zyxel Device so that it can receive information from the PXE server.
PXE Boot Loader File
A boot loader is a computer program that loads the operating system for the computer. Type the exact file name of the boot loader software file, including filename extension, that is on the PXE server. If the wrong filename is typed, then the client computers cannot boot.
Enable IP/MAC Binding
Select this option to have this interface enforce links between specific IP addresses and specific MAC addresses. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses.
Enable Logs for IP/MAC Binding Violation
Select this option to have the Zyxel Device generate a log if a device connected to this interface attempts to use an IP address that is bound to another device’s MAC address.
Static DHCP Table
Configure a list of static IP addresses the Zyxel Device assigns to computers connected to the interface. Otherwise, the Zyxel Device assigns an IP address dynamically using the interface’s IP Pool Start Address and Pool Size.
Add
Click this to create a new entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
This field is a sequential value, and it is not associated with a specific entry.
IP Address
Enter the IP address to assign to a device with this entry’s MAC address.
MAC
Enter the MAC address to which to assign this entry’s IP address.
Description
Enter a description to help identify this static DHCP entry. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
RIP Setting
Enable RIP
Select this to enable RIP in this interface.
Direction
This field is effective when RIP is enabled. Select the RIP direction from the drop-down list box.
BiDir - This interface sends and receives routing information.
In-Only - This interface receives routing information.
Out-Only - This interface sends routing information.
Send Version
This field is effective when RIP is enabled. Select the RIP version(s) used for sending RIP packets. Choices are 1, 2, and 1 and 2.
Receive Version
This field is effective when RIP is enabled. Select the RIP version(s) used for receiving RIP packets. Choices are 1, 2, and 1 and 2.
V2-Broadcast
This field is effective when RIP is enabled. Select this to send RIP-2 packets using subnet broadcasting; otherwise, the Zyxel Device uses multicasting.
OSPF Setting
Area
Select the area in which this interface belongs. Select None to disable OSPF in this interface.
Priority
Enter the priority (between 0 and 255) of this interface when the area is looking for a Designated Router (DR) or Backup Designated Router (BDR). The highest-priority interface identifies the DR, and the second-highest-priority interface identifies the BDR. Set the priority to zero if the interface can not be the DR or BDR.
Link Cost
Enter the cost (between 1 and 65,535) to route packets through this interface.
Passive Interface
Select this to stop forwarding OSPF routing information from the selected interface. As a result, this interface only receives routing information.
Authentication
Select an authentication method, or disable authentication. To exchange OSPF routing information with peer border routers, you must use the same authentication method that they use. Choices are:
Same-as-Area - use the default authentication method in the area
None - disable authentication
Text - authenticate OSPF routing information using a plain-text password
MD5 - authenticate OSPF routing information using MD5 encryption
Text Authentication Key
This field is available if the Authentication is Text. Type the password for text authentication. The key can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long.
MD5 Authentication ID
This field is available if the Authentication is MD5. Type the ID for MD5 authentication. The ID can be between 1 and 255.
MD5 Authentication Key
This field is available if the Authentication is MD5. Type the password for MD5 authentication. The password can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long.
MAC Address Setting
This section appears when Interface Properties is External or General. Have the interface use either the factory assigned default MAC address, a manually specified MAC address, or clone the MAC address of another device or computer.
Use Default MAC Address
Select this option to have the interface use the factory assigned default MAC address. By default, the Zyxel Device uses the factory assigned MAC address to identify itself.
Overwrite Default MAC Address
Select this option to have the interface use a different MAC address. Either enter the MAC address in the fields or click Clone by host and enter the IP address of the device or computer whose MAC you are cloning. Once it is successfully configured, the address will be copied to the configuration file. It will not change unless you change the setting or upload a different configuration file.
Proxy ARP
Proxy ARP is available for external or general interfaces on the Zyxel Device. See Proxy ARP for more information on Proxy ARP.
Enable Proxy ARP
Select this to allow the Zyxel Device to answer external interface ARP requests on behalf of a device on its internal interface. Interfaces supported are:
• Ethernet
• VLAN
• Bridge
See Proxy ARP for more information.
Add
Click Add to create an IPv4 Address, an IPv4 CIDR (for example, 192.168.1.1/24) or an IPv4 Range (for example, 192.168.1.2-192.168.1.100) as the target IP address. The Zyxel Device answers external ARP requests only if they match one of these inputted target IP addresses. For example, if the IPv4 Address is 192.168.1.5, then the Zyxel Device will answer ARP requests coming from the WAN only if it contains 192.168.1.5 as the target IP address.
Select an existing entry and click Remove to delete that entry.
Related Setting
Configure PPPoE/PPTP
Click PPPoE/PPTP if this interface’s Internet connection uses PPPoE or PPTP or L2TP.
Configure VLAN
Click VLAN if you want to configure a VLAN interface for this Ethernet interface.
Configure WAN TRUNK
Click WAN TRUNK to go to a screen where you can set this interface to be part of a WAN trunk for load balancing.
Configure Policy Route
Click Policy Route to go to the policy route summary screen where you can manually associate traffic with this interface.
You must manually configure a policy route to add routing and SNAT settings for an interface with the Interface Type set to general. You can also configure a policy route to override the default routing and SNAT behavior for an interface with an Interface Type of internal or external.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving.
Proxy ARP
An Address Resolution Protocol (ARP) is a protocol for mapping an IP address to a MAC address. An ARP broadcast is sent to all devices on the same Ethernet network to request the MAC address of a target IP address.
Enable Proxy ARP (RFC 1027) to allow the Zyxel Device to answer external interface ARP requests on behalf of a device on its internal interface. Interfaces supported are:
• Ethernet
• VLAN
• Bridge
The Zyxel Device sends its external MAC address to the WAN sender as the destination for the target IP address. From then on the sender will send packets containing that target IP address directly to the external interface of the Zyxel Device. The Zyxel Device then forwards the packet to the correct target IP address in its LAN.
To allow the Zyxel Device to answer external interface ARP requests on behalf of a device on a supported interface, select the interface, click Add or Edit, then click Add in the Proxy ARP section of the screen.
The following table describes labels that can appear in this screen.
Interface > Edit > Add Proxy ARP
Label
Description
Interface Name
This identifies the interface for which the configuration settings that use it are displayed.
Address Type
Choose IPv4 Address, or IPv4 CIDR (for example, 192.168.1.1/24) or an IPv4 Range (for example, 192.168.1.2-192.168.1.100) and then enter the target IP address information. The Zyxel Device answers external ARP requests only if they match one of these inputted target IP addresses. For example, if the IPv4 Address is 192.168.1.5, then the Zyxel Device will answer ARP requests coming from the WAN only if it contains 192.168.1.5 as the target IP address.
OK
Cancel
Virtual Interfaces
Virtual interfaces can be created on top of Ethernet interfaces, VLAN interfaces, or bridge interfaces. Virtual VLAN interfaces recognize and use the same VLAN ID. Otherwise, there is no difference between each type of virtual interface. Network policies (for example, security policies) that apply to the underlying interface automatically apply to the virtual interface as well.
Like other interfaces, virtual interfaces have an IP address, subnet mask, and gateway used to make routing decisions. However, you have to manually specify the IP address and subnet mask; virtual interfaces cannot be DHCP clients. The virtual interface uses the same MTU and bandwidth settings that the underlying interface uses. Unlike other interfaces, virtual interfaces do not provide DHCP services, and they do not verify that the gateway is available.
This screen lets you configure IP address assignment and interface parameters for virtual interfaces.
Configuration > Network > Interface > Create Virtual Interface
Label
Description
Interface Name
This field is read-only. It displays the name of the virtual interface, which is automatically derived from the underlying Ethernet interface, VLAN interface, or bridge interface.
Description
Enter a description of this interface. It is not used elsewhere. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
IP Address
Subnet Mask
Gateway
Metric
OK
Cancel
References
This screen displays which configuration settings reference the selected object. The fields shown vary with the type of object.
References
Label
Description
Name
This identifies the object for which the configuration settings that use it are displayed. Click the object’s name to display the object’s configuration screen in the main window.
Service
This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window.
Priority
If it is applicable, this field lists the referencing configuration item’s position in its list, otherwise N/A displays.
Name
This field identifies the configuration item that references the object.
Description
If the referencing configuration item has a description configured, it displays here.
Refresh
Click this to update the information in this screen.
Cancel
Click Cancel to close the screen.
When you configure an interface as a DHCPv6 server or client, you can additionally add DHCPv6 request or lease options which have the Zyxel Device to add more information in the DHCPv6 packets.
Select a DHCPv6 request or lease object in the Select one object field and click OK to save it. Click Cancel to exit without saving the setting.
When you configure an interface as a DHCPv4 server, you can additionally add DHCP extended options which have the Zyxel Device to add more information in the DHCP packets.
Configuration > Network > Interface > Ethernet > Edit > Add/Edit Extended Options
Label
Description
Option
Select which DHCP option that you want to add in the DHCP packets sent through the interface. See the next table for more information.
Name
This field displays the name of the selected DHCP option. If you selected User Defined in the Option field, enter a descriptive name to identify the DHCP option. You can enter up to 16 characters (“a-z”, “A-Z, “0-9”, “-”, and “_”) with no spaces allowed. The first character must be alphabetical (a-z, A-Z).
Code
This field displays the code number of the selected DHCP option. If you selected User Defined in the Option field, enter a number for the option. This field is mandatory.
Type
This is the type of the selected DHCP option. If you selected User Defined in the Option field, select an appropriate type for the value that you will enter in the next field. Only advanced users should configure User Defined. Misconfiguration could result in interface lockout.
Value
Enter the value for the selected DHCP option. For example, if you selected TFTP Server Name (66) and the type is TEXT, enter the DNS domain name of a TFTP server here. This field is mandatory.
First IP Address, Second IP Address, Third IP Address
If you selected Time Server (4), NTP Server (41), SIP Server (120), CAPWAP AC (138), or TFTP Server (150), you have to enter at least one IP address of the corresponding servers in these fields. The servers should be listed in order of your preference.
First Enterprise ID, Second Enterprise ID
If you selected VIVC (124) or VIVS (125), you have to enter at least one vendor’s 32-bit enterprise number in these fields. An enterprise number is a unique number that identifies a company.
First Class, Second Class
If you selected VIVC (124), enter the details of the hardware configuration of the host on which the client is running, or of industry consortium compliance.
First Information, Second Information
If you selected VIVS (125), enter additional information for the corresponding enterprise number in these fields.
OK
Click this to close this screen and update the settings to the previous Edit screen.
Cancel
The following table lists the available DHCP extended options (defined in RFCs) on the Zyxel Device. See RFCs for more information.
Option Name
Code
Description
Time Offset
2
This option specifies the offset of the client's subnet in seconds from Coordinated Universal Time (UTC).
Time Server
4
This option specifies a list of Time servers available to the client.
NTP Server
42
This option specifies a list of the NTP servers available to the client by IP address.
TFTP Server Name
66
This option is used to identify a TFTP server when the “sname” field in the DHCP header has been used for DHCP options. The minimum length of the value is 1.
Bootfile
67
This option is used to identify a bootfile when the “file” field in the DHCP header has been used for DHCP options. The minimum length of the value is 1.
SIP Server
120
This option carries either an IPv4 address or a DNS domain name to be used by the SIP client to locate a SIP server.
VIVC
124
Vendor-Identifying Vendor Class option
A DHCP client may use this option to unambiguously identify the vendor that manufactured the hardware on which the client is running, the software in use, or an industry consortium to which the vendor belongs.
VIVS
125
Vendor-Identifying Vendor-Specific option
DHCP clients and servers may use this option to exchange vendor-specific information.
CAPWAP AC
138
CAPWAP Access Controller addresses option
The Control And Provisioning of Wireless Access Points Protocol allows a Wireless Termination Point (WTP) to use DHCP to discover the Access Controllers to which it is to connect. This option carries a list of IPv4 addresses indicating one or more CAPWAP ACs available to the WTP.
TFTP Server
150
The option contains one or more IPv4 addresses that the client may use. The current use of this option is for downloading configuration from a VoIP server via TFTP; however, the option may be used for purposes other than contacting a VoIP configuration server.
PPP Interfaces
Use PPPoE/PPTP/L2TP interfaces to connect to your ISP. This way, you do not have to install or manage PPPoE/PPTP/L2TP software on each computer on the network.
/L2TPPPPoE/PPTP/L2TP interfaces are similar to other interfaces in some ways. They have an IP address, subnet mask, and gateway used to make routing decisions; they restrict bandwidth and packet size; and they can verify the gateway is available. There are two main differences between PPPoE/PPTP/L2TP interfaces and other interfaces.
• You must also configure an ISP account object for the PPPoE/PPTP/L2TP interface to use.
Each ISP account specifies the protocol (PPPoE or PPTP or L2TP), as well as your ISP account information. If you change ISPs later, you only have to create a new ISP account, not a new PPPoE/PPTP/L2TP interface. You should not have to change any network policies.
• You do not set up the subnet mask or gateway.
PPPoE/PPTP/L2TP interfaces are interfaces between the Zyxel Device and only one computer. Therefore, the subnet mask is always 255.255.255.255. In addition, the Zyxel Device always treats the ISP as a gateway.
PPP Interface Summary
This screen lists every PPPoE/PPTP/L2TP interface.
Configuration > Network > Interface > PPP
Label
Description
User Configuration / System Default
The Zyxel Device comes with the (non-removable) System Default PPP interfaces pre-configured. You can create (and delete) User Configuration PPP interfaces. System Default PPP interfaces vary by model.
Add
Click this to create a new user-configured PPP interface.
Edit
Remove
To remove a user-configured PPP interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Connect
To connect an interface, select it and click Connect. You might use this in testing the interface or to manually establish the connection for a Dial-on-Demand PPPoE/PPTP interface.
Disconnect
To disconnect an interface, select it and click Disconnect. You might use this in testing the interface.
References
Status
The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive.
The connect icon is lit when the interface is connected and dimmed when it is disconnected.
Name
Description
Base Interface
This field displays the interface on the top of which the PPPoE/PPTP/L2TP interface is.
Account Profile
This field displays the ISP account used by this PPPoE/PPTP interface.
Apply
Reset
PPP Interface Add or Edit
Note: You have to set up an ISP account before you create a PPPoE/PPTP/L2TP interface.
This screen lets you configure a PPPoE or PPTP or L2TP interface.If you enabled IPv6 on the Configuration > System > IPv6 screen, you can also configure PPP interfaces used for your IPv6 networks on this screen.
Configuration > Network > Interface > PPP > Add
Label
Description
Create New Object
Click this button to create an ISP Account or a DHCPv6 request object that you may use for the ISP or DHCPv6 settings in this screen.
General Settings
Enable Interface
Enable IPv6
Interface Name
Base Interface
Select the interface upon which this PPP interface is built.
*Multiple PPP interfaces can use the same base interface.
Zone
Select the zone to which this PPP interface belongs. The zone determines the security settings the Zyxel Device uses for the interface.
Description
Connectivity
Nailed-Up
Select this if the PPPoE/PPTP/L2TP connection should always be up. Clear this to have the Zyxel Device establish the PPPoE/PPTP/L2TP connection only when there is traffic. You might use this option if a lot of traffic needs to go through the interface or it does not cost extra to keep the connection up all the time.
Dial-on-Demand
Select this to have the Zyxel Device establish the PPPoE/PPTP/L2TP connection only when there is traffic. You might use this option if there is little traffic through the interface or if it costs money to keep the connection available.
ISP Setting
Account Profile
Select the ISP account that this PPPoE/PPTP/L2TP interface uses. The drop-down box lists ISP accounts by name. Use Create new Object if you need to configure a new ISP account.
Protocol
This field is read-only. It displays the protocol specified in the ISP account.
User Name
This field is read-only. It displays the user name for the ISP account.
Service Name
This field is read-only. It displays the PPPoE service name specified in the ISP account. This field is blank if the ISP account uses PPTP.
Click Show Advanced Settings to display more settings. Click Hide Advanced Settings to display fewer settings.
Get Automatically
Select this if this interface is a DHCP client. In this case, the DHCP server configures the IP address automatically. The subnet mask and gateway are always defined automatically in PPPoE/PPTP/L2TP interfaces.
Select this if you want to specify the IP address manually.
IP Address
This field is enabled if you select Use Fixed IP Address.
Gateway
Metric
Enter the priority of the gateway (the ISP) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first.
Metric
Add
Edit
Remove
References
Delegated
Prefix
Suffix
Address
Address
DHCPv6 Setting
DHCPv6
Select Client to obtain an IP address and DNS information from the service provider for the interface. Otherwise, select N/A to disable the function.
DUID
DUID as MAC
Customized DUID
Enable Rapid Commit
Request Address
Use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server.
Add
Remove
References
Name
This field displays the name of the DHCPv6 request object.
Type
Value
This field displays the IPv6 prefix that the Zyxel Device will advertise to its clients.
Egress Bandwidth
Ingress Bandwidth
MTU
Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1492. Usually, this value is 1492.
Connectivity Check
Check Method
Check Period
Check Timeout
Check this address
Select this to specify a domain name or IP address for the connectivity check. Enter that domain name or IP address in the field next to it.
Check Port
Related Setting
Configure WAN TRUNK
Click WAN TRUNK to go to a screen where you can configure the interface as part of a WAN trunk for load balancing.
Policy Route
Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this interface.
OK
Cancel
Cellular Configuration
Mobile broadband is a digital, packet-switched wireless technology. Bandwidth usage is optimized as multiple users share the same channel and bandwidth is only allocated to users when they send data. It allows fast transfer of voice and non-voice data and provides broadband Internet access to mobile devices.
Note: The actual data rate you obtain varies depending on the mobile broadband device you use, the signal strength to the service provider’s base station, and so on.
You can configure how the Zyxel Device’s mobile broadband device connects to a network:
• You can set the mobile broadband device to connect only to the home network, which is the network to which you are originally subscribed.
Note: You can set the mobile broadband device to connect to other networks if the signal strength of the home network is too low or it is unavailable. The actual data rate you obtain varies depending on your mobile environment. The environmental factors may include the number of mobile devices which are currently connected to the mobile network, the signal strength to the mobile network, and so on.
Note: Install (or connect) a compatible mobile broadband USB device to use a cellular connection.
Note: The WAN IP addresses of a Zyxel Device with multiple WAN interfaces must be on different subnets.
Configuration > Network > Interface > Cellular
Label
Description
Add
Click this to create a new cellular interface.
Edit
Remove
To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
Inactivate
Connect
To connect an interface, select it and click Connect. You might use this in testing the interface or to manually establish the connection.
Disconnect
References
Status
Name
Description
Extension Slot
This field displays where the entry’s cellular card is located.
Connected Device
This field displays the name of the cellular card.
ISP Settings
This field displays the profile of ISP settings that this cellular interface is set to use.
Mobile Broadband Dongle Support
You should have registered your Zyxel Device at myZyxel. myZyxel hosts a list of supported mobile broadband dongle devices. You should have an Internet connection to access this website.
Latest Version
This displays the latest supported mobile broadband dongle list version number.
Current Version
This displays the currently supported (by the Zyxel Device) mobile broadband dongle list version number.
Update Now
If the latest version number is greater than the current version number, then click this button to download the latest list of supported mobile broadband dongle devices to the Zyxel Device.
Apply
Reset
Cellular Choose Slot
In the pop-up window that displays, select the slot that contains the mobile broadband device, then the Add Cellular configuration screen displays.
Add / Edit Cellular Configuration
Configuration > Network > Interface > Cellular > Add / Edit
Label
Description
General Settings
Enable Interface
Select this option to turn on this interface.
Interface Name
Select a name for the interface.
Zone
Select the zone to which you want the cellular interface to belong. The zone determines the security settings the Zyxel Device uses for the interface.
Extension Slot
This is the USB slot that you are configuring for use with a mobile broadband card.
Connected Device
This displays the manufacturer and model name of your mobile broadband card if you inserted one in the Zyxel Device. Otherwise, it displays none.
Description
Connectivity
Nailed-Up
Select this if the connection should always be up. Clear this to have the Zyxel Device to establish the connection only when there is traffic. You might not nail up the connection if there is little traffic through the interface or if it costs money to keep the connection available.
Idle timeout
This value specifies the time in seconds (0~360) that elapses before the Zyxel Device automatically disconnects from the ISP’s server. Zero disables the idle timeout.
ISP Settings
Profile Selection
Select Device to use one of the mobile broadband device’s profiles of device settings. Then select the profile (use Profile 1 unless your ISP instructed you to do otherwise).
Select Custom to configure your device settings yourself.
APN
This field is read-only if you selected Device in the profile selection. Select Custom in the profile selection to be able to manually input the APN (Access Point Name) provided by your service provider. This field applies with a GSM or HSDPA mobile broadband card. Enter the APN from your service provider. Connections with different APNs may provide different services (such as Internet access or MMS (Multi-Media Messaging Service)) and charge method.
You can enter up to 63 ASCII printable characters. Spaces are allowed.
Dial String
Enter the dial string if your ISP provides a string, which would include the APN, to initialize the mobile broadband card.
This field is available only when you insert a GSM mobile broadband card.
Authentication Type
The Zyxel Device supports PAP (Password Authentication Protocol) and CHAP (Challenge Handshake Authentication Protocol). CHAP is more secure than PAP; however, PAP is readily available on more platforms.
Use the drop-down list box to select an authentication protocol for outgoing calls. Options are:
None: No authentication for outgoing calls.
CHAP - Your Zyxel Device accepts CHAP requests only.
PAP - Your Zyxel Device accepts PAP requests only.
User Name
This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection. If this field is configurable, enter the user name for this mobile broadband card exactly as the service provider gave it to you.
You can use 1 ~ 64 alphanumeric and #:%-_@$./ characters. The first character must be alphanumeric or -_@$./. Spaces are not allowed.
Password
This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection and the password is included in the mobile broadband card’s profile. If this field is configurable, enter the password for this SIM card exactly as the service provider gave it to you.
You can use 0 ~ 63 alphanumeric and `~!@#$%^&*()_-+={}|;:'<,>./ characters. Spaces are not allowed.
Retype to Confirm
This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection and the password is included in the mobile broadband card’s profile. If this field is configurable, re-enter the password for this SIM card exactly as the service provider gave it to you.
SIM Card Setting
PIN Code
This field displays with a GSM or HSDPA mobile broadband card. A PIN (Personal Identification Number) code is a key to a mobile broadband card. Without the PIN code, you cannot use the mobile broadband card.
Enter the 4-digit PIN code (0000 for example) provided by your ISP. If you enter the PIN code incorrectly, the mobile broadband card may be blocked by your ISP and you cannot use the account to access the Internet.
If your ISP disabled PIN code authentication, enter an arbitrary number.
Retype to Confirm
Type the PIN code again to confirm it.
Interface Parameters
Egress Bandwidth
Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can send through the interface to the network. Allowed values are 0 - 1048576. This setting is used in WAN load balancing and bandwidth management.
Ingress Bandwidth
MTU
Connectivity Check
Check Method
Check Period
Check Timeout
Check this address
Check Port
Related Setting
Configure WAN TRUNK
Click Policy Route to go to the policy route summary screen where you can configure a policy route to override the default routing and SNAT behavior for the interface.
IP Address Assignment
Get Automatically
Select this option If your ISP did not assign you a fixed IP address. This is the default selection.
Select this option If the ISP assigned a fixed IP address.
Enter the cellular interface’s WAN IP address in this field if you selected Use Fixed IP Address.
Metric
Device Settings
Band Selection
This field appears if you selected a mobile broadband device that allows you to select the type of network to use. Select the type of mobile broadband service for your mobile broadband connection. If you are unsure what to select, check with your mobile broadband service provider to find the mobile broadband service available to you in your region.
Select auto to have the card connect to an available network. Choose this option if you do not know what networks are available.
You may want to manually specify the type of network to use if you are charged differently for different types of network or you only have one type of network available to you.
Select GPRS / EDGE (GSM) only to have this interface only use a 2.5G or 2.75G network (respectively). If you only have a GSM network available to you, you may want to select this so the Zyxel Device does not spend time looking for a WCDMA network.
Select UMTS / HSDPA (WCDMA) only to have this interface only use a 3G or 3.5G network (respectively). You may want to do this if you want to make sure the interface does not use the GSM network.
Select LTE only to have this interface only use a 4G LTE network. This option only appears when a USG dongle for 4G technology is inserted.
Network Selection
Home network is the network to which you are originally subscribed.
Select Home to have the mobile broadband device connect only to the home network. If the home network is down, the Zyxel Device’s mobile broadband Internet connection is also unavailable.
Select Auto (Default) to allow the mobile broadband device to connect to a network to which you are not subscribed when necessary, for example when the home network is down or another mobile broadband base station's signal is stronger. This is recommended if you need continuous Internet connectivity. If you select this, you may be charged using the rate of a different network.
Budget Setup
Enable Budget Control
Select this to set a monthly limit for the user account of the installed mobile broadband card. You can set a limit on the total traffic and/or call time. The Zyxel Device takes the actions you specified when a limit is exceeded during the month.
Time Budget
Select this and specify the amount of time (in hours) that the mobile broadband connection can be used within one month. If you change the value after you configure and enable budget control, the Zyxel Device resets the statistics.
Data Budget
Select this and specify how much downstream and/or upstream data (in Mega bytes) can be transmitted via the mobile broadband connection within one month.
Select Download to set a limit on the downstream traffic (from the ISP to the Zyxel Device).
Select Upload to set a limit on the upstream traffic (from the Zyxel Device to the ISP).
Select Download/Upload to set a limit on the total traffic in both directions.
Reset time and data budget counters on
Select the date on which the Zyxel Device resets the budget every month. If the date you selected is not available in a month, such as 30th or 31st, the Zyxel Device resets the budget on the last day of the month.
This button is available only when you enable budget control in this screen.
Click this button to reset the time and data budgets immediately. The count starts over with the mobile broadband connection’s full configured monthly time and data budgets. This does not affect the normal monthly budget restart; so if you configured the time and data budget counters to reset on the second day of the month and you use this button on the first, the time and data budget counters will still reset on the second.
Actions when over budget
Specify the actions the Zyxel Device takes when the time or data limit is exceeded.
Log
Select None to not create a log, Log to create a log, or Log-alert to create an alert log. If you select Log or Log-alert you can also select recurring every to have the Zyxel Device send a log or alert for this event periodically. Specify how often (from 1 to 65535 minutes) to send the log or alert.
New connection
Select Allow to permit new mobile broadband connections or Disallow to drop/block new mobile broadband connections.
Current connection
Select Keep to maintain an existing mobile broadband connection or Drop to disconnect it. You cannot set New connection to Allow and Current connection to Drop at the same time.
If you set New connection to Disallow and Current connection to Keep, the Zyxel Device allows you to transmit data using the current connection, but you cannot build a new connection if the existing connection is disconnected.
Actions when over % of time budget or % of data budget
Specify the actions the Zyxel Device takes when the specified percentage of time budget or data limit is exceeded. Enter a number from 1 to 99 in the percentage fields. If you change the value after you configure and enable budget control, the Zyxel Device resets the statistics.
Log
Select None to not create a log when the Zyxel Device takes this action, Log to create a log, or Log-alert to create an alert log. If you select Log or Log-alert you can also select recurring every to have the Zyxel Device send a log or alert for this event periodically. Specify how often (from 1 to 65535 minutes) to send the log or alert.
OK
Cancel
Tunnel Interfaces
The Zyxel Device uses tunnel interfaces in Generic Routing Encapsulation (GRE), IPv6 in IPv4, and 6to4 tunnels.
GRE Tunneling
GRE tunnels encapsulate a wide variety of network layer protocol packet types inside IP tunnels. A GRE tunnel serves as a virtual point-to-point link between the Zyxel Device and another router over an IPv4 network. At the time of writing, the Zyxel Device only supports GRE tunneling in IPv4 networks.
IPv6 Over IPv4 Tunnels
To route traffic between two IPv6 networks over an IPv4 network, an IPv6 over IPv4 tunnel has to be used.
On the Zyxel Device, you can either set up a manual IPv6-in-IPv4 tunnel or an automatic 6to4 tunnel. The following describes each method:
IPv6-in-IPv4 Tunneling
Use this mode on the WAN of the Zyxel Device if
• your Zyxel Device has a public IPv4 IP address given from your ISP,
and
• you want to transmit your IPv6 packets to one and only one remote site whose LAN network is also an IPv6 network.
With this mode, the Zyxel Device encapsulates IPv6 packets within IPv4 packets across the Internet. You must know the WAN IP address of the remote gateway device. This mode is normally used for a site-to-site application such as two branch offices.
In the Zyxel Device, you must also manually configure a policy route for an IPv6-in-IPv4 tunnel to make the tunnel work.
6to4 Tunneling
This mode also enables IPv6 packets to cross IPv4 networks. Unlike IPv6-in-IPv4 tunneling, you do not need to configure a policy route for a 6to4 tunnel. Through your properly pre-configuring the destination router’s IP address in the IP address assignments to hosts, the Zyxel Device can automatically forward 6to4 packets to the destination they want to go. A 6to4 relay router is required to route 6to4 packets to a native IPv6 network if the packet’s destination do not match your specified criteria.
In this mode, the Zyxel Device should get a public IPv4 address for the WAN. The Zyxel Device adds an IPv4 IP header to an IPv6 packet when transmitting the packet to the Internet. In reverse, the Zyxel Device removes the IPv4 header from an IPv6 packet when receiving it from the Internet.
An IPv6 address using the 6to4 mode consists of an IPv4 address, the format is as the following:
2002:[a public IPv4 address in hexadecimal]::/48
For example, a public IPv4 address is 202.156.30.41. The converted hexadecimal IP string is ca.9c.1E.29. The IPv6 address prefix becomes 2002:ca9c:1e29::/48.
Configuring a Tunnel
This screen lists the Zyxel Device’s configured tunnel interfaces.
Network > Interface > Tunnel
Label
Description
Add
Click this to create a new GRE tunnel interface.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings.
Remove
Activate
Inactivate
References
Select an entry and click References to open a screen that shows which settings use the entry.
This field is a sequential value, and it is not associated with any interface.
Status
Name
This field displays the name of the interface.
IP Address
This is the IP address of the interface. If the interface is active (and connected), the Zyxel Device tunnels local traffic sent to this IP address to the Remote Gateway Address.
Tunnel Mode
This is the tunnel mode of the interface (GRE, IPv6-in-IPv4 or 6to4). This field also displays the interface’s IPv4 IP address and subnet mask if it is a GRE tunnel. Otherwise, it displays the interface’s IPv6 IP address and prefix length.
My Address
This is the interface or IP address uses to identify itself to the remote gateway. The Zyxel Device uses this as the source for the packets it tunnels to the remote gateway.
This is the IP address or domain name of the remote gateway to which this interface tunnels traffic.
Apply
Reset
Click Reset to begin configuring this screen afresh.
Tunnel Add or Edit
This screen lets you configure a tunnel interface.
Network > Interface > Tunnel > Add/Edit
Label
Description
General Settings
Enable
Interface Name
This field is read-only if you are editing an existing tunnel interface. Enter the name of the tunnel interface. The format is tunnelx, where x is 0 - 3. For example, tunnel0.
Zone
Use this field to select the zone to which this interface belongs. This controls what security settings the Zyxel Device applies to this interface.
Tunnel Mode
Select the tunneling protocol of the interface (GRE, IPv6-in-IPv4 or 6to4).
This section is available if you are configuring a GRE tunnel.
IP Address
Subnet Mask
Metric
This section is available if you are configuring an IPv6-in-IPv4 or a 6to4 tunnel.
Metric
6to4 Tunnel Parameter
This section is available if you are configuring a 6to4 tunnel which encapsulates IPv6 to IPv4 packets.
6to4 Prefix
Enter the IPv6 prefix of a destination network. The Zyxel Device forwards IPv6 packets to the hosts on the matched network.
If you enter a prefix starting with 2002, the Zyxel Device will forward the matched packets to the IPv4 IP address converted from the packets’ destination address. The IPv4 IP address can be converted from the next 32 bits after the prefix you specified in this field. The Zyxel Device forwards the unmatched packets to the specified Relay Router.
Relay Router
Enter the IPv4 address of a 6to4 relay router which helps forward packets between 6to4 networks and native IPv6 networks.
Remote Gateway Prefix
Enter the IPv4 network address and network bits of a remote 6to4 gateway, for example, 14.15.0.0/16.
This field works if you enter a 6to4 Prefix not starting with 2002 (2003 for example). The Zyxel Device forwards the matched packets to a remote gateway with the network address you specify here, and the bits converted after the 6to4 Prefix in the packets.
For example, you configure the 6to4 prefix to 2003:A0B::/32 and the remote gateway prefix to 14.15.0.0/16. If a packet’s destination is 2003:A0B:1011:5::8, the Zyxel Device forwards the packet to 14.15.16.17, where the network address is 14.15.0.0 and the host address is the remain bits converted from 1011 after the packet’s 6to4 prefix (2003:A0B).
Gateway Settings
My Address
Specify the interface or IP address to use as the source address for the packets this interface tunnels to the remote gateway. The remote gateway sends traffic to this interface or IP address.
Enter the IP address or domain name of the remote gateway to which this interface tunnels traffic.
Automatic displays in this field if you are configuring a 6to4 tunnel. It means the 6to4 tunnel will help forward packets to the corresponding remote gateway automatically by looking at the packet’s destination address.
Egress Bandwidth
Ingress Bandwidth
MTU
Connectivity Check
Check Method
Check Period
Check Timeout
Check this address
Check Port
This field displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check.
Related Setting
WAN TRUNK
Click this link to go to a screen where you can configure WAN trunk load balancing.
Policy Route
Click this link to go to the screen where you can manually configure a policy route to associate traffic with this interface.
OK
Cancel
VLAN Interfaces
A Virtual Local Area Network (VLAN) divides a physical network into multiple logical networks. The standard is defined in IEEE 802.1q.
Each VLAN is a separate network with separate IP addresses, subnet masks, and gateways. Each VLAN also has a unique identification number (ID). The ID is a 12-bit value that is stored in the MAC header. The VLANs are connected to switches, and the switches are connected to the router. (If one switch has enough connections for the entire network, the network does not need switches A and B.)
• Traffic inside each VLAN is layer-2 communication (data link layer, MAC addresses). It is handled by the switches. As a result, the new switch is required to handle traffic inside VLAN 2. Traffic is only broadcast inside each VLAN, not each physical network.
• Traffic between VLANs (or between a VLAN and another type of network) is layer-3 communication (network layer, IP addresses). It is handled by the router.
This approach provides a few advantages.
• Increased performance - In VLAN 2, the extra switch should route traffic inside the sales department faster than the router does. In addition, broadcasts are limited to smaller, more logical groups of users.
• Higher security - If each computer has a separate physical connection to the switch, then broadcast traffic in each VLAN is never sent to computers in another VLAN.
• Better manageability - You can align network policies more appropriately for users. For example, you can set different bandwidth limits for each VLAN. These rules are also independent of the physical network, so you can change the physical network without changing policies.
VLAN Interfaces Overview
In the Zyxel Device, each VLAN is called a VLAN interface. As a router, the Zyxel Device routes traffic between VLAN interfaces, but it does not route traffic within a VLAN interface. All traffic for each VLAN interface can go through only one Ethernet interface, though each Ethernet interface can have one or more VLAN interfaces.
Note: Each VLAN interface is created on top of only one Ethernet interface.
Otherwise, VLAN interfaces are similar to other interfaces in many ways. They have an IP address, subnet mask, and gateway used to make routing decisions. They restrict bandwidth and packet size. They can provide DHCP services, and they can verify the gateway is available.
VLAN Summary
This screen lists every VLAN interface and virtual interface created on top of VLAN interfaces. If you enabled IPv6 on the Configuration > System > IPv6 screen, you can also configure VLAN interfaces used for your IPv6 networks on this screen.
Configuration > Network > Interface > VLAN
Label
Description
Configuration / IPv6 Configuration
Use the Configuration section for IPv4 network settings. Use the IPv6 Configuration section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below.
Edit
Remove
Activate
Inactivate
To open the screen where you can create a virtual interface, select an interface and click Create Virtual Interface.
References
Status
This icon is lit when the entry is active and dimmed when the entry is inactive.
Name
Description
This field displays the description of the interface.
Port/VID
For VLAN interfaces, this field displays
• the Ethernet interface on which the VLAN interface is created
• the VLAN ID
For virtual interfaces, this field is blank.
IP Address
This field displays the current IP address of the interface. If the IP address is 0.0.0.0, the interface does not have an IP address yet.
This screen also shows whether the IP address is a static IP address (STATIC) or dynamically assigned (DHCP). IP addresses are always static in virtual interfaces.
Mask
This field displays the interface’s subnet mask in dot decimal notation.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
VLAN Add/Edit
Configuration > Network > Interface > VLAN > Add / Edit
Label
Description
IPv4/IPv6 View / IPv4 View / IPv6 View
Use this button to display both IPv4 and IPv6, IPv4-only, or IPv6-only configuration fields.
Show Advanced Settings / Hide Advanced Settings
Click this button to display a greater or lesser number of configuration fields.
Create New Object
Click this button to create a DHCPv6 lease or DHCPv6 request object that you may use for the DHCPv6 settings in this screen.
General Settings
Enable Interface
Select this to turn this interface on. Clear this to disable this interface.
General IPv6 Setting
Enable IPv6
Select this to enable IPv6 on this interface. Otherwise, clear this to disable it.
Interface Type
Select one of the following option depending on the type of network to which the Zyxel Device is connected or if you want to additionally manually configure some related settings.
internal is for connecting to a local network. Other corresponding configuration options: DHCP server and DHCP relay. The Zyxel Device automatically adds default SNAT settings for traffic flowing from this interface to an external interface.
external is for connecting to an external network (like the Internet). The Zyxel Device automatically adds this interface to the default WAN trunk.
For general, the rest of the screen’s options do not automatically adjust and you must manually configure a policy route to add routing and SNAT settings for the interface.
Interface Name
This field is read-only if you are editing an existing VLAN interface. Enter the number of the VLAN interface. You can use a number from 0~4094. For example, use vlan0, vlan8, and so on. The total number of VLANs you can configure on the Zyxel Device depends on the model.
Zone
Select the zone to which the VLAN interface belongs.
Base Port
Select the Ethernet interface on which the VLAN interface runs.
VLAN ID
Enter the VLAN ID. This 12-bit number uniquely identifies each VLAN. Allowed values are 1 - 4094. (0 and 4095 are reserved.)
Priority Code
This is a 3-bit field within a 802.1Q VLAN tag that’s used to prioritize associated outgoing VLAN traffic. . The setting configured in Configuration > BWM overwrites the priority setting here.
Description
Enter a description of this interface. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. Spaces are allowed, but the string can’t start with a space.
Get Automatically
Select this if this interface is a DHCP client. In this case, the DHCP server configures the IP address, subnet mask, and gateway automatically.
You should not select this if the interface is assigned to a VRRP group.
DHCP Option 60
DHCP Option 60 is used by the Zyxel Device for identification to the DHCP server using the VCI (Vendor Class Identifier) on the DHCP server. The Zyxel Device adds it in the initial DHCP discovery message that a DHCP client broadcasts in search of an IP address. The DHCP server can assign different IP addresses or options to clients with the specific VCI or reject the request from clients without the specific VCI.
Type a string using up to 63 of these characters [a-zA-Z0-9!\"#$%&\'()*+,-./:;<=>?@\[\\\]^_`{}] to identify this Zyxel Device to the DHCP server. For example, Zyxel-TW.
Select this if you want to specify the IP address, subnet mask, and gateway manually.
IP Address
Enter the IP address for this interface.
Subnet Mask
Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network.
Gateway
Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface.
Metric
Enter the priority of the gateway (if any) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first.
Enable IGMP Support
Select this to allow the Zyxel Device to act as an IGMP proxy for hosts connected on the IGMP downstream interface.
IGMP Upstream
Enable IGMP Upstream on the interface which connects to a router running IGMP that is closer to the multicast server.
IGMP Downstream
Enable IGMP Downstream on the interface which connects to the multicast hosts.
IPv6 Address Assignment
These IP address fields configure an IPv6 IP address on the interface itself.
Enable Stateless Address Auto-configuration (SLAAC)
Select this to enable IPv6 stateless auto-configuration on this interface. The interface will generate an IPv6 IP address itself from a prefix obtained from an IPv6 router on the network.
Link-Local address
This displays the IPv6 link-local address and the network prefix that the Zyxel Device generates itself for the interface.
IPv6 Address/Prefix Length
Enter the IPv6 address and the prefix length for this interface if you want to configure a static IP address for this interface. This field is optional.
The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address.
Gateway
Enter the IPv6 address of the default outgoing gateway using colon (:) hexadecimal notation.
Metric
Address from DHCPv6 Prefix Delegation
Use this table to have the Zyxel Device obtain an IPv6 prefix from the ISP or a connected uplink router for an internal network, such as the LAN or DMZ. You have to also enter a suffix address which is appended to the delegated prefix to form an address for this interface.
To use prefix delegation, you must:
• Create at least one DHCPv6 request object before configuring this table.
• The external interface must be a DHCPv6 client. You must configure the DHCPv6 request options using a DHCPv6 request object with the type of prefix-delegation.
• Assign the prefix delegation to an internal interface and enable router advertisement on that interface.
Add
Click this to create an entry.
Edit
Select an entry and click this to change the settings.
Remove
Select an entry and click this to delete it from this table.
References
This field is a sequential value, and it is not associated with any entry.
Delegated
Prefix
Select the DHCPv6 request object to use from the drop-down list.
Suffix
Address
Enter the ending part of the IPv6 address, a slash (/), and the prefix length. The Zyxel Device will append it to the delegated prefix.
For example, you got a delegated prefix of 2003:1234:5678/48. You want to configure an IP address of 2003:1234:5678:1111::1/128 for this interface, then enter ::1111:0:0:0:1/128 in this field.
Address
This field displays the combined IPv6 IP address for this interface.
*This field displays the combined address after you click OK and reopen this screen.
DHCPv6 Setting
DHCPv6
Select N/A to not use DHCPv6.
Select Client to set this interface to act as a DHCPv6 client.
Select Server to set this interface to act as a DHCPv6 server which assigns IP addresses and provides subnet mask, gateway, and DNS server information to clients.
Select Relay to set this interface to route DHCPv6 requests to the DHCPv6 relay server you specify. The DHCPv6 server(s) may be on another network.
DUID
This field displays the DHCP Unique IDentifier (DUID) of the interface, which is unique and used for identification purposes when the interface is exchanging DHCPv6 messages with others.
DUID as MAC
Select this to have the DUID generated from the interface’s default MAC address.
Customized DUID
If you want to use a customized DUID, enter it here for the interface.
Enable Rapid Commit
Select this to shorten the DHCPv6 message exchange process from four to two steps. This function helps reduce heavy network traffic load.
*Make sure you also enable this option in the DHCPv6 clients to make rapid commit work.
Information Refresh Time
Enter the number of seconds a DHCPv6 client should wait before refreshing information retrieved from DHCPv6.
Request Address
This field is available if you set this interface to DHCPv6 Client. Select this to get an IPv6 IP address for this interface from the DHCP server. Clear this to not get any IP address information through DHCPv6.
DHCPv6 Request Options /
DHCPv6 Lease Options
If this interface is a DHCPv6 client, use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server.
If this interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what to offer to the DHCPv6 clients.
Add
Remove
References
Name
This field displays the name of the DHCPv6 request or lease object.
Type
This field displays the type of the object.
Value
This field displays the IPv6 prefix that the Zyxel Device obtained from an uplink router (Server is selected) or will advertise to its clients (Client is selected).
Interface
When Relay is selected, select this check box and an interface from the drop-down list if you want to use it as the relay server.
Relay Server
When Relay is selected, select this check box and enter the IP address of a DHCPv6 server as the relay server.
IPv6 Router Advertisement Setting
Enable Router Advertisement
Select this to enable this interface to send router advertisement messages periodically.
Advertised Hosts Get Network Configuration From DHCPv6
Select this to have the Zyxel Device indicate to hosts to obtain network settings (such as prefix and DNS settings) through DHCPv6.
Clear this to have the Zyxel Device indicate to hosts that DHCPv6 is not available and they should use the prefix in the router advertisement message.
Advertised Hosts Get Other Configuration From DHCPv6
Select this to have the Zyxel Device indicate to hosts to obtain DNS information through DHCPv6.
Clear this to have the Zyxel Device indicate to hosts that DNS information is not available in this network.
Router Preference
Select the router preference (Low, Medium or High) for the interface. The interface sends this preference in the router advertisements to tell hosts what preference they should use for the Zyxel Device. This helps hosts to choose their default router especially when there are multiple IPv6 router on the network.
*Make sure the hosts also support router preference to make this function work.
MTU
The Maximum Transmission Unit. Type the maximum size of each IPv6 data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments.
Hop Limit
Enter the maximum number of network segments that a packet can cross before reaching the destination. When forwarding an IPv6 packet, IPv6 routers are required to decrease the Hop Limit by 1 and to discard the IPv6 packet when the Hop Limit is 0.
Advertised Prefix Table
Configure this table only if you want the Zyxel Device to advertise a fixed prefix to the network.
Add
Click this to create an IPv6 prefix address.
Edit
Select an entry in this table and click this to modify it.
Remove
Select an entry in this table and click this to delete it.
IPv6
Address/
Prefix Length
Enter the IPv6 network prefix address and the prefix length.
Advertised Prefix from DHCPv6 Prefix Delegation
Use this table to configure the network prefix if you want to use a delegated prefix as the beginning part of the network prefix.
Add
Edit
Remove
References
Delegated
Prefix
Select the DHCPv6 request object to use for generating the network prefix for the network.
Suffix
Address
Enter the ending part of the IPv6 network address plus a slash (/) and the prefix length. The Zyxel Device will append it to the selected delegated prefix. The combined address is the network prefix for the network.
For example, you got a delegated prefix of 2003:1234:5678/48. You want to divide it into 2003:1234:5678:1111/64 for this interface and 2003:1234:5678:2222/64 for another interface. You can use ::1111/64 and ::2222/64 for the suffix address respectively. But if you do not want to divide the delegated prefix into subnetworks, enter ::0/48 here, which keeps the same prefix length (/48) as the delegated prefix.
Address
This is the final network prefix combined by the delegated prefix and the suffix.
Egress Bandwidth
Ingress Bandwidth
This is reserved for future use.
Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can receive from the network through the interface. Allowed values are 0 - 1048576.
MTU
Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1500. Usually, this value is 1500.
Connectivity Check
The Zyxel Device can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often to check the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check.
Enable Connectivity Check
Select this to turn on the connection check.
Check Method
Select the method that the gateway allows.
Select icmp to have the Zyxel Device regularly ping the gateway you specify to make sure it is still available.
Select tcp to have the Zyxel Device regularly perform a TCP handshake with the gateway you specify to make sure it is still available.
Check Period
Enter the number of seconds between connection check attempts.
Check Timeout
Enter the number of seconds to wait for a response before the attempt is a failure.
Check Fail Tolerance
Enter the number of consecutive failures before the Zyxel Device stops routing through the gateway.
Check Default Gateway
Select this to use the default gateway for the connectivity check.
Check this address
Check Port
This field only displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check.
Check these addresses
Type one or two domain names or IP addresses for the connectivity check.
Probe Succeeds When
This field applies when you specify two domain names or IP addresses for the connectivity check.
Select any one if you want the check to pass if at least one of the domain names or IP addresses responds.
Select all if you want the check to pass only if both domain names or IP addresses respond.
DHCP Setting
The DHCP settings are available for the OPT, LAN and DMZ interfaces.
DHCP
Select what type of DHCP service the Zyxel Device provides to the network. Choices are:
None - the Zyxel Device does not provide any DHCP services. There is already a DHCP server on the network.
DHCP Relay - the Zyxel Device routes DHCP requests to one or more DHCP servers you specify. The DHCP server(s) may be on another network.
DHCP Server - the Zyxel Device assigns IP addresses and provides subnet mask, gateway, and DNS server information to the network. The Zyxel Device is the DHCP server for the network.
These fields appear if the Zyxel Device is a DHCP Relay.
Relay Server 1
Enter the IP address of a DHCP server for the network.
Relay Server 2
This field is optional. Enter the IP address of another DHCP server for the network.
These fields appear if the Zyxel Device is a DHCP Server.
IP Pool Start Address
Enter the IP address from which the Zyxel Device begins allocating IP addresses. If you want to assign a static IP address to a specific computer, click Add Static DHCP.
If this field is blank, the Pool Size must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address.
Pool Size
Enter the number of IP addresses to allocate. This number must be at least one and is limited by the interface’s Subnet Mask. For example, if the Subnet Mask is 255.255.255.0 and IP Pool Start Address is 10.10.10.10, the Zyxel Device can allocate 10.10.10.10 to 10.10.10.254, or 245 IP addresses.
If this field is blank, the IP Pool Start Address must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address.
First DNS Server
Second DNS Server
Third DNS Server
Specify the IP addresses up to three DNS servers for the DHCP clients to use. Use one of the following ways to specify these IP addresses.
Custom Defined - enter a static IP address.
From ISP - select the DNS server that another interface received from its DHCP server.
Zyxel Device - the DHCP clients use the IP address of this interface and the Zyxel Device works as a DNS relay.
First WINS Server, Second WINS Server
Type the IP address of the WINS (Windows Internet Naming Service) server that you want to send to the DHCP clients. The WINS server keeps a mapping table of the computer names on your network and the IP addresses that they are currently using.
Default Router
If you set this interface to DHCP Server, you can select to use either the interface’s IP address or another IP address as the default router. This default router will become the DHCP clients’ default gateway.
To use another IP address as the default router, select Custom Defined and enter the IP address.
Lease time
Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are:
infinite - select this if IP addresses never expire
days, hours, and minutes - select this to enter how long IP addresses are valid. The default is 2 days.
Extended Options
This table is available if you selected DHCP server.
Configure this table if you want to send more information to DHCP clients through DHCP packets.
Add
Click this to create an entry in this table. See Add/Edit DHCP Extended Options.
Edit
Remove
Name
This is the option’s name.
Code
This is the option’s code number.
Type
This is the option’s type.
Value
This is the option’s value.
Enable IP/MAC Binding
Select this option to have the Zyxel Device enforce links between specific IP addresses and specific MAC addresses for this VLAN. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses.
Enable Logs for IP/MAC Binding Violation
Select this option to have the Zyxel Device generate a log if a device connected to this VLAN attempts to use an IP address that is bound to another device’s MAC address.
Static DHCP Table
Configure a list of static IP addresses the Zyxel Device assigns to computers connected to the interface. Otherwise, the Zyxel Device assigns an IP address dynamically using the interface’s IP Pool Start Address and Pool Size.
Add
Click this to create a new entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
This field is a sequential value, and it is not associated with a specific entry.
IP Address
Enter the IP address to assign to a device with this entry’s MAC address.
MAC Address
Enter the MAC address to which to assign this entry’s IP address.
Description
Enter a description to help identify this static DHCP entry. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
RIP Setting
Enable RIP
Select this to enable RIP on this interface.
Direction
This field is effective when RIP is enabled. Select the RIP direction from the drop-down list box.
BiDir - This interface sends and receives routing information.
In-Only - This interface receives routing information.
Out-Only - This interface sends routing information.
Send Version
This field is effective when RIP is enabled. Select the RIP version(s) used for sending RIP packets. Choices are 1, 2, and 1 and 2.
Receive Version
This field is effective when RIP is enabled. Select the RIP version(s) used for receiving RIP packets. Choices are 1, 2, and 1 and 2.
V2-Broadcast
This field is effective when RIP is enabled. Select this to send RIP-2 packets using subnet broadcasting; otherwise, the Zyxel Device uses multicasting.
OSPF Setting
Area
Select the area in which this interface belongs. Select None to disable OSPF in this interface.
Priority
Enter the priority (between 0 and 255) of this interface when the area is looking for a Designated Router (DR) or Backup Designated Router (BDR). The highest-priority interface identifies the DR, and the second-highest-priority interface identifies the BDR. Set the priority to zero if the interface can not be the DR or BDR.
Link Cost
Enter the cost (between 1 and 65,535) to route packets through this interface.
Passive Interface
Select this to stop forwarding OSPF routing information from the selected interface. As a result, this interface only receives routing information.
Authentication
Select an authentication method, or disable authentication. To exchange OSPF routing information with peer border routers, you must use the same authentication method that they use. Choices are:
Same-as-Area - use the default authentication method in the area
None - disable authentication
Text - authenticate OSPF routing information using a plain-text password
MD5 - authenticate OSPF routing information using MD5 encryption
Text Authentication Key
This field is available if the Authentication is Text. Type the password for text authentication. The key can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long.
MD5 Authentication ID
This field is available if the Authentication is MD5. Type the ID for MD5 authentication. The ID can be between 1 and 255.
MD5 Authentication Key
This field is available if the Authentication is MD5. Type the password for MD5 authentication. The password can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long.
MAC Address Setting
This section appears when Interface Properties is External or General. Have the interface use either the factory assigned default MAC address, a manually specified MAC address, or clone the MAC address of another device or computer.
Use Default MAC Address
Select this option to have the interface use the factory assigned default MAC address. By default, the Zyxel Device uses the factory assigned MAC address to identify itself.
Overwrite Default MAC Address
Select this option to have the interface use a different MAC address. Either the MAC address in the field. Once it is successfully configured, the address will be copied to the configuration file. It will not change unless you change the setting or upload a different configuration file.
Proxy ARP
Proxy ARP is available for external or general interfaces on the Zyxel Device. See InternalThese screen’s fields are described in the table below. for more information on Proxy ARP.
Enable Proxy ARP
Select this to allow the to answer external interface ARP requests on behalf of a device on its internal interface. Interfaces supported are:
• Ethernet
• VLAN
• Bridge
See Proxy ARP for more information.
Add
Click Add to create an IPv4 Address, an IPv4 CIDR (for example, 192.168.1.1/24) or an IPv4 Range (for example, 192.168.1.2-192.168.1.100) as the target IP address. The Zyxel Device answers external ARP requests only if they match one of these inputted target IP addresses. For example, if the IPv4 Address is 192.168.1.5, then the Zyxel Device will answer ARP requests coming from the WAN only if it contains 192.168.1.5 as the target IP address.
Select an existing entry and click Remove to delete that entry.
Related Setting
Configure WAN TRUNK
Click WAN TRUNK to go to a screen where you can set this VLAN to be part of a WAN trunk for load balancing.
Configure Policy Route
Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this VLAN.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving.
Bridge Interfaces
A bridge creates a connection between two or more network segments at the layer-2 (MAC address) level.
When the bridge receives a packet, the bridge records the source MAC address and the port on which it was received in a table. It also looks up the destination MAC address in the table. If the bridge knows on which port the destination MAC address is located, it sends the packet to that port. If the destination MAC address is not in the table, the bridge broadcasts the packet on every port (except the one on which it was received).
A bridge interface creates a software bridge between the members of the bridge interface. It also becomes the Zyxel Device’s interface for the resulting network.
Unlike the device-wide bridge mode in ZyNOS-based Zyxel Devices, this Zyxel Device can bridge traffic between some interfaces while it routes traffic for other interfaces. The bridge interfaces also support more functions, like interface bandwidth parameters, DHCP settings, and connectivity check. To use the whole Zyxel Device as a transparent bridge, add all of the Zyxel Device’s interfaces to a bridge interface.
A bridge interface may consist of the following members:
• Zero or one VLAN interfaces (and any associated virtual VLAN interfaces)
• Any number of Ethernet interfaces (and any associated virtual Ethernet interfaces)
When you create a bridge interface, the Zyxel Device removes the members’ entries from the routing table and adds the bridge interface’s entries to the routing table.For example, this table shows the routing table before and after you create bridge interface br0 (250.250.250.0/23) between lan1 and vlan1.
Bridge Summary
This screen lists every bridge interface and virtual interface created on top of bridge interfaces.If you enabled IPv6 on the Configuration > System > IPv6 screen, you can also configure bridge interfaces used for your IPv6 network on this screen.
Configuration > Network > Interface > Bridge
Label
Description
Add
Edit
Remove
Activate
Inactivate
References
Status
Name
Description
IP Address
Member
This field displays the Ethernet interfaces and VLAN interfaces in the bridge interface. It is blank for virtual interfaces.
Apply
Reset
Bridge Add/Edit
This screen lets you configure IP address assignment, interface bandwidth parameters, DHCP settings, and connectivity check for each bridge interface.
Configuration > Network > Interface > Bridge > Add / Edit
Label
Description
Create New Object
General Settings
Enable Interface
Select this to enable this interface. Clear this to disable this interface.
Enable IPv6
Interface Type
Interface Name
This field is read-only if you are editing the interface. Enter the name of the bridge interface. The format is brx, where x is 0 - 11. For example, br0, br3, and so on.
Zone
Select the zone to which the interface is to belong. You use zones to apply security settings such as security policy, IDP, remote management, anti-malware, and application patrol.
Description
Member Configuration
Available
This field displays Ethernet interfaces and VLAN interfaces that can become part of the bridge interface. An interface is not available in the following situations:
• There is a virtual interface on top of it
• It is already used in a different bridge interface
Select one, and click the >> arrow to add it to the bridge interface. Each bridge interface can only have one VLAN interface.
Member
This field displays the interfaces that are part of the bridge interface. Select one, and click the << arrow to remove it from the bridge interface.
Get Automatically
DHCP Option 60
IP Address
Subnet Mask
Gateway
Metric
Enable IGMP Support
IGMP Upstream
IGMP Downstream
Link-Local address
Enter the IPv6 address and the prefix length for this interface if you want to use a static IP address. This field is optional.
Gateway
Metric
Add
Edit
Remove
References
Delegated
Prefix
Suffix
Address
For example, you got a delegated prefix of 2003:1234:5678/48. You want to configure an IP address of 2003:1234:5678:1111:1/128 for this interface, then enter ::1111:0:0:0:1/128 in this field.
Address
DHCPv6 Setting
DHCPv6
DUID
This field displays the DHCP Unique IDentifier (DUID) of the interface, which is unique and used for identification purposes when the interface is exchanging DHCPv6 messages with others. See DHCPv6 for more information.
DUID as MAC
Select this if you want the DUID is generated from the interface’s default MAC address.
Customized DUID
Enable Rapid Commit
Request Address
If the interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what to offer to the DHCPv6 clients.
Add
Click this to create an entry in this table. See Add/Edit DHCPv6 Request/Release Options for more information.
Edit
Remove
References
Name
Type
Value
Interface
Relay Server
Router Preference
MTU
Hop Limit
Add
Edit
Remove
IPv6
Address/
Prefix Length
Add
Edit
Remove
References
Delegated
Prefix
Suffix
Address
Address
This is the final network prefix combined by the selected delegated prefix and the suffix.
Egress Bandwidth
Ingress Bandwidth
MTU
DHCP Setting
DHCP
Relay Server 1
Relay Server 2
Pool Size
First DNS Server
Second DNS Server
Third DNS Server
Default Router
Lease time
Extended Options
Add
Edit
Remove
Name
Code
Type
Value
PXE Server
PXE (Preboot eXecution Environment) allows a client computer to use the network to boot up and install an operating system via a PXE-capable Network Interface Card (NIC).
PXE is available for computers on internal interfaces to allow them to boot up using boot software on a PXE server. The Zyxel Device acts as an intermediary between the PXE server and the computers that need boot software.
The PXE server must have a public IPv4 address. You must enable DHCP Server on the Zyxel Device so that it can receive information from the PXE server.
PXE Boot Loader File
A boot loader is a computer program that loads the operating system for the computer. Type the exact file name of the boot loader software file, including filename extension, that is on the PXE server. If the wrong filename is typed, then the client computers cannot boot.
Select this option to have this interface enforce links between specific IP addresses and specific MAC addresses. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses.
Select this option to have the Zyxel Device generate a log if a device connected to this interface attempts to use an IP address that is bound to another device’s MAC address.
Static DHCP Table
Add
Edit
Remove
IP Address
MAC Address
Description
Connectivity Check
The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check.
Check Method
Check Period
Check Timeout
Check this address
Check Port
Probe Succeeds When
Proxy ARP
Enable Proxy ARP
• Ethernet
• VLAN
• Bridge
Add
Related Setting
Configure WAN TRUNK
Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this bridge interface.
OK
Cancel
VTI
IPSec VPN Tunnel Interface (VTI) encrypts or decrypts IPv4 traffic from or to the interface according to the IP routing table.
VTI allows static routes to send traffic over the VPN. The IPSec tunnel endpoint is associated with an actual (virtual) interface. Therefore many interface capabilities such as Policy Route, Static Route, Trunk, and BWM can be applied to the IPSec tunnel as soon as the tunnel is active
IPSec VTI simplifies network management and load balancing. Create a trunk using VPN tunnel interfaces for load balancing.
Restrictions for IPSec Virtual Tunnel Interface
• IPv4 traffic only
• IPSec tunnel mode only. A shared keyword must not be configured when using tunnel mode.
• With a VTI VPN you do not add local or remote LANs to your VPN configuration.
• For a VTI VPN you should only have one local and one remote WAN.
• A dynamic peer is not supported
• The IPSec VTI is limited to IP unicast and multicast traffic only.
VTI Screen
The following table describes the fields in this screen.
Configuration > Network > Interface > VTI
Label
Description
Configuration
Add
Edit
Remove
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
References
Status
Name
This field displays the name of the VTI interface.
IP Address
This field displays the current IP address of the virtual interface and subnet mask in bits. If the IP address is 0.0.0.0, the interface does not have an IP address yet.
vpn-rule
This shows the name of the associated IPSec VPN rule with VPN Tunnel Interface application scenario.
Apply
Reset
VTI Add/Edit
This screen lets you configure IP address assignment and interface parameters for VTI.
Note: You should have created a VPN tunnel for a VPN Tunnel Interface scenario first.
Configuration > Network > Interface > VTI > Add
Label
Description
General Settings
Enable
Select this to enable VTI. Clear this to disable it.
Interface Name
This field is read-only if you are editing an existing VPN tunnel interface. For a new VPN tunnel interface, enter the name of the VPN tunnel interface in vtix format, where x is a number from 0 to the maximum number of VPN connections allowed for this model. For example, enter vti10.
Zone
Select a zone. Make sure that the zone you select does not have traffic blocked by a security feature such as a security policy.
vpn-rule
You should have created a VPN tunnel first for a VPN Tunnel Interface scenario. Select one of the VPN Tunnel Interface scenario rules that you created.
IP Address
Subnet Mask
Metric
Enable IGMP Support
IGMP Upstream
IGMP Downstream
Egress Bandwidth
Ingress Bandwidth
Connectivity Check
These fields appear when you select a vpn-rule.
Check Method
Check Period
Check Timeout
Check this address
Check Port
RIP Setting
Enable RIP
Select this to enable RIP in this interface.
Direction
Send Version
Receive Version
V2-Broadcast
OSPF Setting
Area
Priority
Link Cost
Passive Interface
Authentication
Related Setting
Configure WAN TRUNK
OK
Cancel
Trunk Overview
Use trunks for WAN traffic load balancing to increase overall network throughput and reliability. Load balancing divides traffic loads between multiple interfaces. This allows you to improve quality of service and maximize bandwidth utilization for multiple ISP links.
Maybe you have two Internet connections with different bandwidths. You could set up a trunk that uses spillover or weighted round robin load balancing so time-sensitive traffic (like video) usually goes through the higher-bandwidth interface. For other traffic, you might want to use least load first load balancing to even out the distribution of the traffic load.
Suppose ISP A has better connections to Europe while ISP B has better connections to Australia. You could use policy routes and trunks to have traffic for your European branch office primarily use ISP A and traffic for your Australian branch office primarily use ISP B.
Or maybe one of the Zyxel Device's interfaces is connected to an ISP that is also your Voice over IP (VoIP) service provider. You can use policy routing to send the VoIP traffic through a trunk with the interface connected to the VoIP service provider set to active and another interface (connected to another ISP) set to passive. This way VoIP traffic goes through the interface connected to the VoIP service provider whenever the interface’s connection is up.
• Add WAN interfaces to trunks to have multiple connections share the traffic load.
• If one WAN interface’s connection goes down, the Zyxel Device sends traffic through another member of the trunk.
• For example, you connect one WAN interface to one ISP and connect a second WAN interface to a second ISP. The Zyxel Device balances the WAN traffic load between the connections. If one interface's connection goes down, the Zyxel Device can automatically send its traffic through another interface.
You can also use trunks with policy routing to send specific traffic types through the best WAN interface for that type of traffic.
• If that interface’s connection goes down, the Zyxel Device can still send its traffic through another interface.
• You can define multiple trunks for the same physical interfaces.
Load Balancing Algorithms
The following sections describe the load balancing algorithms the Zyxel Device can use to decide which interface the traffic (from the LAN) should use for a session. The available bandwidth you configure on the Zyxel Device refers to the actual bandwidth provided by the ISP and the measured bandwidth refers to the bandwidth an interface is currently using.
Least Load First
The least load first algorithm uses the current (or recent) outbound bandwidth utilization of each trunk member interface as the load balancing index(es) when making decisions about to which interface a new session is to be distributed. The outbound bandwidth utilization is defined as the measured outbound throughput over the available outbound bandwidth.
Weighted Round Robin
The Weighted Round Robin (WRR) algorithm is best suited for situations when the bandwidths set for the two WAN interfaces are different. Weighted Round Robin (WRR) algorithm sets the Zyxel Device to send traffic through each WAN interface in turn. In addition, the WAN interfaces are assigned weights. An interface with a larger weight gets more chances to transmit traffic than an interface with a smaller weight.
Spillover
The spillover load balancing algorithm sends network traffic to the first interface in the trunk member list until the interface’s maximum allowable load is reached, then sends the excess network traffic of new sessions to the next interface in the trunk member list. This continues as long as there are more member interfaces and traffic to be sent through them.
Suppose the first trunk member interface uses an unlimited access Internet connection and the second is billed by usage. Spillover load balancing only uses the second interface when the traffic load exceeds the threshold on the first interface. This fully utilizes the bandwidth of the first interface to reduce Internet usage fees and avoid overloading the interface.
The Trunk Summary screen lists the configured trunks and the load balancing algorithm that each is configured to use.
Configuration > Network > Interface > Trunk
label
description
Configuration
Configure what to do with existing passive mode interface connections when an interface set to active mode in the same trunk comes back up.
Disconnect Connections Before Falling Back
Select this to terminate existing connections on an interface which is set to passive mode when any interface set to active mode in the same trunk comes back up.
Enable Default SNAT
Select this to have the Zyxel Device use the IP address of the outgoing interface as the source IP address of the packets it sends out through its WAN trunks. The Zyxel Device automatically adds SNAT settings for traffic it routes from internal interfaces to external interfaces.
Default Trunk Selection
Select whether the Zyxel Device is to use the default system WAN trunk or one of the user configured WAN trunks as the default trunk for routing traffic from internal interfaces to external interfaces.
User Configuration / System Default
The Zyxel Device automatically adds all external interfaces into the pre-configured system default SYSTEM_DEFAULT_WAN_TRUNK. You cannot delete it. You can create your own User Configuration trunks and customize the algorithm, member interfaces and the active/passive mode.
Add
Click this to create a new user-configured trunk.
Edit
Remove
To remove a user-configured trunk, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
References
Name
This field displays the label that you specified to identify the trunk.
Algorithm
This field displays the load balancing method the trunk is set to use.
Apply
Click this button to save your changes to the Zyxel Device.
Reset
Click this button to return the screen to its last-saved settings.
Configuring a User-Defined Trunk
Use this screen to create or edit a WAN trunk entry.
Configuration > Network > Interface > Trunk > Add (or Edit)
Label
Description
Name
This is read-only if you are editing an existing trunk. When adding a new trunk, enter a descriptive name for this trunk. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
Select a load balancing method to use from the drop-down list box.
Select Weighted Round Robin to balance the traffic load between interfaces based on their respective weights. An interface with a larger weight gets more chances to transmit traffic than an interface with a smaller weight. For example, if the weight ratio of wan1 and wan2 interfaces is 2:1, the Zyxel Device chooses wan1 for 2 sessions’ traffic and wan2 for 1 session’s traffic in each round of 3 new sessions.
Select Least Load First to send new session traffic through the least utilized trunk member.
Select Spillover to send network traffic through the first interface in the group member list until there is enough traffic that the second interface needs to be used (and so on).
Load Balancing Index(es)
This field is available if you selected to use the Least Load First or Spillover method.
Select Outbound, Inbound, or Outbound + Inbound to set the traffic to which the Zyxel Device applies the load balancing method. Outbound means the traffic traveling from an internal interface (ex. LAN) to an external interface (ex. WAN). Inbound means the opposite.
The table lists the trunk’s member interfaces. You can add, edit, remove, or move entries for user configured trunks.
Add
Click this to add a member interface to the trunk. Select an interface and click Add to add a new member interface after the selected member interface.
Edit
Select an entry and click Edit to modify the entry’s settings.
Remove
To remove a member interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Move
To move an interface to a different number in the list, click the Move icon. In the field that appears, specify the number to which you want to move the interface.
This column displays the priorities of the group’s interfaces. The order of the interfaces in the list is important since they are used in the order they are listed.
Member
Click this table cell and select an interface to be a group member.
If you select an interface that is part of another Ethernet interface, the Zyxel Device does not send traffic through the interface as part of the trunk. For example, if you have physical port 5 in the ge2 representative interface, you must select interface ge2 in order to send traffic through port 5 as part of the trunk. If you select interface ge5 as a member here, the Zyxel Device will not send traffic through port 5 as part of the trunk.
Mode
Click this table cell and select Active to have the Zyxel Device always attempt to use this connection.
Select Passive to have the Zyxel Device only use this connection when all of the connections set to active are down. You can only set one of a group’s interfaces to passive mode.
Weight
This field displays with the weighted round robin load balancing algorithm. Specify the weight (1~10) for the interface. The weights of the different member interfaces form a ratio. This ratio determines how much traffic the Zyxel Device assigns to each member interface. The higher an interface’s weight is (relative to the weights of the interfaces), the more sessions that interface should handle.
Ingress Bandwidth
This field displays with the least load first load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to allow to come in through the interface per second.
*You can configure the bandwidth of an interface on the corresponding interface edit screen.
Egress Bandwidth
This field displays with the least load first or spillover load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to send out through the interface per second.
Spillover
This field displays with the spillover load balancing algorithm. Specify the maximum bandwidth of traffic in kilobits per second (1~1048576) to send out through the interface before using another interface. When this spillover bandwidth limit is exceeded, the Zyxel Device sends new session traffic through the next interface. The traffic of existing sessions still goes through the interface on which they started.
The Zyxel Device uses the group member interfaces in the order that they are listed.
OK
Cancel
Configuring the System Default Trunk
Use this screen to change the load balancing algorithm and view the bandwidth allocations for each member interface.
Note: The available bandwidth is allocated to each member interface equally and is not allowed to be changed for the default trunk.
Configuration > Network > Interface > Trunk > Edit (System Default)
Label
Description
Name
This field displays the name of the selected system default trunk.
Select the load balancing method to use for the trunk.
The table lists the trunk’s member interfaces. This table is read-only.
Member
This column displays the name of the member interfaces.
Mode
This field displays Active if the Zyxel Device always attempt to use this connection.
This field displays Passive if the Zyxel Device only use this connection when all of the connections set to active are down. Only one of a group’s interfaces can be set to passive mode.
Weight
This field displays with the weighted round robin load balancing algorithm. Specify the weight (1~10) for the interface. The weights of the different member interfaces form a ratio. s
Ingress Bandwidth
Egress Bandwidth
Spillover
OK
Cancel
