Content Filter
Overview
Use the content filtering feature to control access to specific web sites or web content.
Use the Filter Profile screens (Content Filter Profile) to set up content filtering profiles.
Use the Trusted Web Sites screens (Content Filter Trusted Web Sites) to create a common list of good (allowed) web site addresses.
Use the Forbidden Web Sites screens (Content Filter Forbidden Web Sites) to create a common list of bad (blocked) web site addresses.
Content Filtering
Content filtering allows you to block certain web features, such as cookies, and/or block access to specific web sites. It can also block access to specific categories of web site content. You can create different content filter policies for different addresses, schedules, users or groups and content filter profiles. For example, you can configure one policy that blocks John Doe’s access to arts and entertainment web pages during the workday and another policy that lets him access them after work.
Content Filtering Policies
A content filtering policy allows you to do the following.
Use schedule objects to define when to apply a content filter profile.
Use address and/or user/group objects to define to whose web access to apply the content filter profile.
Apply a content filter profile that you have custom-tailored.
Content Filtering Profiles
A content filtering profile conveniently stores your custom settings for the following features.
Category-based Blocking
The Zyxel Device can block access to particular categories of web site content, such as pornography or racial intolerance.
Restrict Web Features
The Zyxel Device can disable web proxies and block web features such as ActiveX controls, Java applets and cookies.
Customize Web Site Access
You can specify URLs to which the Zyxel Device blocks access. You can alternatively block access to all URLs except ones that you specify. You can also have the Zyxel Device block access to URLs that contain particular keywords.
Content Filtering Configuration Guidelines
When the Zyxel Device receives an HTTP request, the content filter searches for a policy that matches the source address and time (schedule). The content filter checks the policies in order (based on the policy numbers). When a matching policy is found, the content filter allows or blocks the request depending on the settings of the filtering profile specified by the policy. Some requests may not match any policy. The Zyxel Device allows the request if the default policy is not set to block. The Zyxel Device blocks the request if the default policy is set to block.
External Web Filtering Service
When you register for and enable the external web filtering service, your Zyxel Device accesses an external database that has millions of web sites categorized based on content. You can have the Zyxel Device block, block and/or log access to web sites based on these categories.
HTTPS Domain Filter
HTTPS Domain Filter works with the Content Filter category feature to identify HTTPS traffic and take appropriate action. SSL Inspection identifies HTTPS traffic for all Security Service traffic and has higher priority than HTTPS Domain Filter. HTTPS Domain Filter only identifies keywords in the domain name of an URL and matches it to a category. For example, if the keyword is 'picture' and the URL is http://www.google.com/picture/index.htm, then HTTPS Domain Filter cannot identify 'picture' because that keyword in not in the domain name 'www.google.com'. However, SSL Inspection can identify 'picture' in the URL http://www.google.com/picture/index.htm.
Keyword Blocking URL Checking
The Zyxel Device checks the URL’s domain name (or IP address) and file path separately when performing keyword blocking.
The URL’s domain name or IP address is the characters that come before the first slash in the URL. For example, with the URL www.zyxel.com.tw/news/pressroom.php, the domain name is www.zyxel.com.tw.
The file path is the characters that come after the first slash in the URL. For example, with the URL www.zyxel.com.tw/news/pressroom.php, the file path is news/pressroom.php.
Since the Zyxel Device checks the URL’s domain name (or IP address) and file path separately, it will not find items that go across the two. For example, with the URL www.zyxel.com.tw/news/pressroom.php, the Zyxel Device would find “tw” in the domain name (www.zyxel.com.tw). It would also find “news” in the file path (news/pressroom.php) but it would not find “tw/news”.
Before You Begin
You must configure an address object, a schedule object and a filtering profile before you can set up a content security policy.
You must have Content Filtering license in order to use the function.subscribe to use the external database content filtering (see the Licensing > Registration screens).
Use this screen to enable content filtering, view and order your list of content filter policies, create a denial of access message or specify a redirect URL and check your external web filtering service registration status.
Click the Content Filter icon for more information on the Zyxel Device’s security features.
Apply to a Security Policy
Configuration > Security Service > Content Filter > Profile
Label
Description
General Settings
Enable HTTPS Domain Filter for HTTPS traffic
Select this check box to have the Zyxel Device block HTTPS web pages using the cloud category service.
In an HTTPS connection, the Zyxel Device can extract the Server Name Indication (SNI) from a client request, check if it matches a category in the cloud content filter and then take appropriate action. The keyword match is for the domain name only.
Enable Content Filter HTTPS Domain Filter Block/Warn Page
Use this field to have the Zyxel Device display a warning page instead of a blank page when an HTPPS connection is redirected.
Block/Warn Page Port
Use the default port number as displayed for the warning page. If you change it, the new port number should be unique.
Drop connection when HTTPS connection with SSL V3 or previous version
Select this check box to have the Zyxel Device block HTTPS web pages using SSL V3 or a previous version.
Content Filter Category Service Timeout
Specify the allowable time period in seconds for accessing the external web filtering service’s server.
Denied Access Message
Enter a message to be displayed when content filter blocks access to a web page. Use up to 127 characters (0-9a-zA-Z;/?:@&=+$\.-_!~*'()%,”). For example, “Access to this web page is not allowed. Please contact the network administrator”.
It is also possible to leave this field blank if you have a URL specified in the Redirect URL field. In this case if the content filter blocks access to a web page, the Zyxel Device just opens the web page you specified without showing a denied access message.
Redirect URL
Enter the URL of the web page to which you want to send users when their web access is blocked by content filter. The web page you specify here opens in a new frame below the denied access message.
Use “http://” or “https://” followed by up to 262 characters (0-9a-zA-Z;/?:@&=+$\.-_!~*'()%). For example, http://192.168.1.17/blocked access.
Profile Management
Add
Click Add to create a new content filter rule.
Edit
Click Edit to make changes to a content filter rule.
Remove
Click Remove the delete a content filter rule.
References
Select an entry and click References to open a screen that shows which settings use the entryClick Refresh to update information on this screen.
This column lists the index numbers of the content filter profile.
Name
This column lists the names of the content filter profile rule.
Description
This column lists the description of the content filter profile rule.
Reference
This displays the number of times an Object Reference is used in a rule.
Action
Click this icon to apply the content filter profile with a security policy.
Go to the Configuration > Security Policy > Policy Control screen to check the result.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Click the icon in the Action field to apply the entry to a security policy.
ServiceContent Filter > Action
Label
Description
Show Filter/Hide Filter
Click Show Filter to display IPv4 and IPv6 (if enabled) security policy search filters.
IPv4 / IPv6 Configuration
Use IPv4 / IPv6 search filters to find specific IPv4 and IPv6 (if enabled) security policies based on direction, application, user, source, destination and/or schedule.
From / To
Select a zone to view all security policies from a particular zone and/or to a particular zone. any means all zones.
IPv4 / IPv6 Source
Type an IPv4 or IPv6 IP address to view all security policies based on the IPv4 / IPv6 source address object used.
An IPv4 IP address is written as four integer blocks separated by periods. This is an example IPv4 address: 172.16.6.7.
An 128-bit IPv6 address is written as eight 16-bit hexadecimal blocks separated by colons (:). This is an example IPv6 address: 2001:0db8:1a2b:0015:0000:0000:1a2f:0000.
IPv4 / IPv6 Destination
Type an IPv4 or IPv6 IP address to view all security policies based on the IPv4 / IPv6 destination address object used.
Service
View all security policies based the service object used.
User
View all security policies based on user or user group object used.
Schedule
View all security policies based on the schedule object used.
Priority
This is the position of your Security Policy in the global policy list (including all through-Zyxel Device and to-Zyxel Device policies). The ordering of your policies is important as policies are applied in sequence. Default displays for the default Security Policy behavior that the Zyxel Device performs on traffic that does not match any other Security Policy.
Status
This icon is lit when the entry is active and dimmed when the entry is inactive.
Name
This is the name of the Security policy.
From / To
This is the direction of travel of packets. Select from which zone the packets come and to which zone they go.
Security Policies are grouped based on the direction of travel of packets to which they apply. For example, from LAN to LAN means packets traveling from a computer or subnet on the LAN to either another computer or subnet on the LAN.
From any displays all the Security Policies for traffic going to the selected To Zone.
To any displays all the Security Policies for traffic coming from the selected From Zone.
From any to any displays all of the Security Policies.
To ZyWALL policies are for traffic that is destined for the Zyxel Device and control which computers can manage the Zyxel Device.
IPv4 / IPv6 Source
This displays the IPv4 / IPv6 source address object, including geographic address and FQDN (group) objects, to which this Security Policy applies.
This displays the IPv4 / IPv6 destination address object, including geographic address and FQDN (group) objects, to which this Security Policy applies.
Service
This displays the service object to which this Security Policy applies.
User
This is the user name or user group name to which this Security Policy applies.
Schedule
This field tells you the schedule object that the policy uses. none means the policy is active at all times if enabled.
Action
This field displays whether the Security Policy silently discards packets without notification (deny), permits the passage of packets (allow) or drops packets with notification (reject)
Log
Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or not (no) when the policy is matched to the criteria listed above.
Profile
This field shows you which Security Service profiles (application patrol, content filter, IDP, anti-malware, email security) apply to this Security policy. Click an applied Security Service profile icon to edit the profile directly.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving.
Content Filter Add Profile Category Service
Configuration > Security Service > Content Filter > Profile > Add > Category Service
Label
Description
Name
Enter a descriptive name for this content filtering profile name. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
Description
Enter a description for the content filtering profile rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
This field is optional.
Enable SafeSearch
SafeSearch is a search engine that can automatically filter sexually explicit videos and images from the search result without overloading the Zyxel Device. It does this by adding a parameter in the search URL:
https://www.google.com.tw/?gws_rd=ssl#q=porn&safe=active.
Supported search engines at the time of writing are:
Yahoo, Google, MSN Live Bing, Yandex
Enable Content Filter Category Service
Enable external database content filtering to have the Zyxel Device check an external database to find to which category a requested web page belongs. The Zyxel Device then blocks or forwards access to the web page depending on the configuration of the rest of this page.
Log all web pages
Select this to record attempts to access web pages when:
They match the other categories that you select below.
They are not categorized.
The external content filtering database is unavailable.
Action for Managed Web Pages
Select Pass to allow users to access web pages that match the other categories that you select below.
Select Block to prevent users from accessing web pages that match the other categories that you select below. When external database content filtering blocks access to a web page, it displays the denied access message that you configured in the Content Filter General screen along with the category of the blocked web page.
Select Log to record attempts to access web pages that match the other categories that you select below.
Action for Unrated Web Pages
Select Pass to allow users to access web pages that the external web filtering service has not categorized.
Select Block to prevent users from accessing web pages that the external web filtering service has not categorized. When the external database content filtering blocks access to a web page, it displays the denied access message that you configured in the Content Filter General screen along with the category of the blocked web page.
Select Warn to display a warning message before allowing users to access web pages that the external web filtering service has not categorized.
Select Log to record attempts to access web pages that are not categorized.
Action When Category Server Is Unavailable
Select Pass to allow users to access any requested web page if the external content filtering database is unavailable.
Select Block to block access to any requested web page if the external content filtering database is unavailable.
Select Warn to display a warning message before allowing users to access any requested web page if the external content filtering database is unavailable.
The following are possible causes for the external content filtering server not being available:
There is no response from the external content filtering server within the time period specified in the Content Filter Server Unavailable Timeout field.
The Zyxel Device is not able to resolve the domain name of the external content filtering database.
There is an error response from the external content filtering database. This can be caused by an expired content filtering registration (External content filtering’s license key is invalid”).
Select Log to record attempts to access web pages that occur when the external content filtering database is unavailable.
Select Categories
Select All Categories
Select this check box to restrict access to all site categories listed below.
Clear All Categories
Select this check box to clear the selected categories below.
Managed Categories
These are categories of web pages based on their content. Select categories in this section to control access to specific types of Internet content.
You must have the Category Service content filtering license to filter these categories. See the next table for category details.
Test Web Site Category
URL to test
You can check which category a web page belongs to. Enter a web site URL in the text box.
When the content filter is active, you should see the web page’s category. The query fails if the content filter is not active.
Content Filtering can query a category by full URL string (for example, http://www.google.com/picture/index.htm), but HTTPS Domain Filter can only query a category by domain name ('www.google.com'), so the category may be different in the query result. URL to test displays both results in the test.
If you think the category is incorrect
Click this link to see the category recorded in the Zyxel Device’s content filtering database for the web page you specified (if the database has an entry for it).
Test Against Content Filter Category Server
Click this button to see the category recorded in the external content filter server’s database for the web page you specified.
OK
Cancel
Click Cancel to exit this screen without saving your changes.
The following table describes the managed categories.
Managed Category Descriptions
Category
Description
Adult Topics
Web pages that contain content or themes that are generally considered unsuitable for children.
Alcohol
Web pages that mainly sell, promote, or advocate the use of alcohol, such as beer, wine, and liquor.
This category also includes cocktail recipes and home-brewing instructions.
Anonymizing Utilities
Web pages that result in anonymous web browsing without the explicit intent to provide such a service.
This category includes URL translators, web-page caching, and other utilities that might function as anonymizers, but without the express purpose of bypassing filtering software.
This category does not include text translation.
Art Culture Heritage
Web pages that contain virtual art galleries, artist sites (including sculpture and photography), museums, ethnic customs, and country customs.
This category does not include online photograph albums.
Auctions Classifieds
Web pages that provide online bidding and selling of items or services.
This category includes web pages that focus on bidding and sales.
This category does not include classified advertisements such as real estate postings, personal ads, or companies marketing their auctions.
Blogs/Wiki
Web pages containing dynamic content, which often changes because users can post or edit content at any time.
This category covers the risks with dynamic content that might range from harmless to offensive.
Business
Web pages that provide business-related information, such as corporate overviews or business planning and strategies.
This category also includes information, services, or products that help other businesses plan, manage, and market their enterprises, and multi-level marketing.
This category does not include personal pages and web-hosting web pages.
Chat
Web pages that provide web-based, real-time social messaging in public and private chat rooms. This category includes IRC.
This category does not include instant messaging.
Computing Internet
Web pages containing reviews, information, buyer's guides of computers, computer parts and accessories, computer software and internet companies, industry news and magazines, and pay-to-surf sites.
Consumer Protection
Websites that try to rob or cheat consumers.
Some examples of their activities include selling counterfeit products, selling products that were originally provided for free, or improperly using the brand of another company. This category also includes sites where many consumers reported being cheated or not receiving services.
This category does not include phishing, which tries to perpetrate fraud or theft by stealing account information.
Content Server
URLs for servers that host images, media files, or JavaScript for one or more sites and are intended to speed up content retrieval for existing web servers, such as Apache.
This category includes domain-level and sub-domain-level URLs that function as content servers.
This category does not include:
Web pages for businesses that provide the content servers
Web pages that allow users to browse photographs. See the Media Sharing category.
URLs for servers that serve only advertisements. See the Web Ads category.
Controversial Opinions
Web pages that contain opinions that are likely to offend political or social sensibilities and incite controversy. Much of this content is at the extremes of public opinion.
This category does not include opinion or language clearly intended to promote hate or discrimination.
Cult Occult
Sites relating to non-traditional religious practices considered to be false, unorthodox, extremist, or coercive.
Dating Personals
Web pages that provide networking for online dating, matchmaking, escort services, or introductions to potential spouses.
This category does not include sites that provide social networking that might include dating, but are not specific to dating.
Dating Social Networking
Web pages that focus on social interaction such as online dating, friendship, school reunions, pen-pals, escort services, or introductions to potential spouses.
This category does not include wedding-related content, dating tips, or related marketing.
Digital Postcards
Web pages that allow people to send and receive digital postcards and greeting cards via the Internet.
Discrimination
Web pages, which provide information that explicitly encourages the oppression or discrimination of a specific group of individuals.
This category does not include jokes and humor, unless the focus of the entire site is considered discriminatory.
Drugs
Websites that provide information on the purchase, manufacture, and use of illegal or recreational drugs.
This category does not include sites with exclusive health or political themes.
Education Reference
Web pages devoted to academic-related content such as academic subjects (mathematics, history), school or university web pages, and education administration pages (school boards, teacher curriculum).
Entertainment
Web pages that provide information about cinema, theater, music, television, infotainment, entertainment industry gossip-news, and sites about celebrities such as actors and musicians.
This category also includes sites where the content is devoted to providing entertainment on the web, such as horoscopes or fan clubs.
Extreme
Web pages that provide content considered gory, perverse, or horrific.
Fashion Beauty
Web pages that market clothing, cosmetics, jewelry, and other fashion-oriented products, accessories, or services.
This category also includes product reviews, comparisons, and general consumer information, and services such as hair salons, tanning salons, tattoo studios, and body-piercing studios.
This category does not include fashion-related content such as modeling or celebrity fashion unless the site focuses on marketing the product line.
Finance Banking
Web pages that provide financial information or access to online financial accounts.
This category includes stock information (but not stock trading), home finance, and government-related financial information.
For Kids
Web pages that are family-safe, specifically for children of approximate ages ten and under.
This category can also be used as an exception to allow web pages that do not pose a risk to children, or to access sites that have a primary educational or recreational focus for children, but are in other categories such as Games, Humor/Comics, Recreation/Hobbies, or Entertainment.
Forum Bulletin Boards
Web pages that provide access (http://) to Usenet newsgroups or hold discussions and post user-generated content, such as real-time message posting for an interest group. This category also includes archives of files uploaded to newsgroups.
This category does not include message forums with a business or technical support focus.
Gambling
Web pages that allow users to wager or place bets online, or provide gambling software that allows online betting, such as casino games, betting pools, sports betting, and lotteries.
This category does not include web pages related to gambling that do not allow betting online.
Gambling Related
Web pages that offer information about gambling, without providing the means to gamble.
This category includes casino-related web pages that do not offer online gambling, gambling links, tips, sports picks, lottery results, and horse, car, or boat racing.
Game Cartoon Violence
Web pages that provide fantasy or fictitious representations of violence within the context of games, comics, cartoons, or graphic novels.
This category includes images and textual descriptions of physical assaults or hand-to-hand combat, and grave injury and destruction caused by weapons or explosives.
Games
Web pages that offer online games and related information such as cheats, codes, demos, emulators, online contests or role-playing games, gaming clans, game manufacturer sites, fantasy or virtual sports leagues, and other gaming sites without chances of profit.
This category includes gaming consoles.
General News
Web pages that provide online news media, such as international or regional news broadcasting and publication.
This category includes portal sites that provide news content.
Government Military
Web pages that contain content maintained by governmental or military organizations, such as government branches or agencies, police departments, fire departments, civil defense, counter-terrorism organizations, or supranational organizations, such as the United Nations or the European Union.
This category includes military and veterans’ medical facilities.
Gruesome Content
Web pages with content that can be considered tasteless, gross, shocking, or gruesome.
This category does not include web pages with content pertaining to physical assault.
Health
Web pages that cover all health-related information and health care services.
This category does not include cosmetic surgery, marketing/selling pharmaceuticals, or animal-related medical services.
Historical Revisionism
Web pages that denounce, or offer different interpretations of, significant historical facts, such as holocaust denial.
This category does not include all re-examination of historical facts, only historical events that are highly sensitive.
History
Web pages that provide content about historical facts.
This category includes content suitable for higher education, but the Education category includes content for primary education. For example, a site with Holocaust photographs might be offensive, but have academic value.
Humor Comics
Web pages that provide comical or funny content.
This category includes sites with jokes, sketches, comics, and satire pages. This category might also include graphic novel content, which is often associated with comics.
Illegal UK
Web pages that contain child sexual abuse content hosted anywhere in the world, and criminally obscene and incitement to racial hatred content hosted in the UK.
Incidental Nudity
Web pages that contain non-pornographic images of the bare human body like those in classic sculpture and paintings, or medical images.
This category enables you to allow or block sites in order to address cultural or geographic differences in opinion about nudity. For example, you can use this category to block access to nudity, but allow access when nudity is not the primary focus of a site, such as news sites or major portals.
Information Security
Web pages that legitimately provide information about data protection. This category includes detailed information for safeguarding business or personal data, intellectual property, privacy, and infrastructure on the Internet, private networks, or in other bandwidth services such as telecommunications.
Legitimate information security companies and security software providers, such as virus protection companies.
Sites that intend to exploit security or teach how to bypass security.
Information Security New
Instant Messaging
Web pages that provide software for real-time communication over a network exclusively for users who joined a member’s contact list or an instant-messaging session.
Most instant-messaging software includes features such as file transfer, PC-to-PC phone calls, and can track when other people log on and off.
Interactive Web Applications
Web pages that provide access to live or interactive web applications, such as browser-based office suites and groupware. This category includes sites with business, academic, or individual focus.
This category does not include sites providing access to interactive web applications that do not take critical user data or offer security risks, such as Google Maps.
Internet Radio TV
Web pages that provide software or access to continuous audio or video broadcasting, such as Internet radio, TV programming, or podcasting.
Quick downloads and shorter streams that consume less bandwidth are in the Streaming Media or Media Downloads categories.
Internet Services
Web pages that provide services for publication and maintenance of Internet sites such as web design, domain registration, Internet Service Providers, and broadband and telecommunications companies that provide web services.
This category includes web utilities such as statistics and access logs, and web graphics like clip art.
Job Search
Web pages related to a job search including sites concerned with resume writing, interviewing, changing careers, classified advertising, and large job databases. This category also includes corporate web pages that list job openings, salary comparison sites, temporary employment, and company job-posting sites.
This category does not include make-money-at-home sites.
Major Global Religions
Web pages with content about religious topics and information related to major religions. This category includes sites that cover religious content such as discussion, beliefs, non-controversial commentary, articles, and information for local congregations such as a church or synagogue homepage.
The religions in this category are Baha'i, Buddhism, Chinese Traditional, Christianity, Hinduism, Islam, Jainism, Judaism, Shinto, Sikhism, Tenrikyo, Zoroastrianism.
Marketing Merchandising
Web pages that promote individual or business products or services on the web, but do not sell their products or services online.
This category includes websites that are generally a company overview, describing services or products that cannot be purchased directly from these sites. Examples include automobile manufacturer sites, wedding photography services, or graphic design services.
Other categories that imply marketing such as Alcohol, Auctions/Classifieds, Drugs, Finance/Banking, Mobile Phone, Online Shopping, Real Estate, School Cheating Information, Software/Hardware, Stock Trading, Tobacco, Travel, and Weapons.
Sites that market their services only to other businesses. See the Business category.
Sites that rob or cheat consumers. See the Consumer Protection category.
Media Downloads
Web pages that provide audio or video files for download such as MP3, WAV, AVI, and MPEG formats. The files are saved to, and played from, the user’s computer.
This category does not include audio or video files that are played directly through a browser window. See the Streaming Media category.
Media Sharing
Web pages that allow users to upload, search for, and share media files and photographs, such as online photograph albums.
Messaging
Examples include text messaging to mobile phones, PDAs, fax machines, and internal website user-to-user messaging or site-to-site messaging.
This category does not include real-time chat or instant messaging, or message posts that can be viewed by anyone but the intended recipient.
Mobile Phone
Web pages that sell media, software, or utilities for mobile phones that can be downloaded and delivered to mobile phones.
Examples include ringtones, logos/skins, games, screen-savers, text-based tunes, and software for SMS, MMS, WAP, and other mobile phone protocols.
Moderated
Bulletin boards, chat rooms, search engines, or web mail sites that are monitored by an individual or group who has the authority to block messages or content considered inappropriate.
This category does not include sites with posted rules against offensive content. See the Forum/Bulletin Boards category.
Motor Vehicles
Websites for manufacturers and dealerships of consumer transportation vehicles, such as cars, vans, trucks, SUVs, motorcycles, and scooters. This category also includes sites that provide product marketing, reviews, comparisons, pricing information, auto fairs, auto expos, and general consumer information about motor vehicles.
This category does not include automotive accessories, mechanics, auto-body shops, and recreational hobby pages. This category does not include sites that provide business-to-business-only content regarding motor vehicles.
Non Profit Advocacy NGO
Web pages from charitable or educational groups that fulfill a stated mission, benefiting the larger community, such as clubs, lobbies, communities, non-profit organizations, labor unions, and advocacy groups.
Examples are Masons, Elks, Boy and Girl Scouts, or Big Brothers.
Nudity
Web pages that have non-pornographic images of the bare human body. This category includes classic sculpture and paintings, artistic nude photographs, some naturism pictures, and detailed medical illustrations.
This category does not include high-profile sites where nudity is not a concern for visitors. See the Incidental Nudity category.
Online Shopping
Web pages that sell products or services online.
Web pages selling a broad range of products might pose a risk to users by offering access to items that are normally in other categories such as Pornography, Weapons, Nudity, or Violence. Web pages selling such content exclusively are in their respective categories.
P2P File Sharing
Web pages that allow the exchange of files between computers and users for business or personal use, such as downloadable music.
P2P clients allow users to search for and exchange files from a peer-user network. They often include spyware or real-time chat capabilities. This category includes BitTorrent web pages.
Parked Domain
Web pages that once served content, but their domains have been sold or abandoned and are no longer registered.
Parked domains do not host their own content, but usually redirect users to a generic page that states the domain name is for sale, or redirect users to a generic search engine and portal page, some of which provide valid search engine results.
Personal Network Storage
Web pages that allow users to upload folders and files to an online network server in order to backup, share, edit, or retrieve files or folders from any web browser.
Personal Pages
Personal home pages that share a common domain such as those hosted by ISPs, university/education servers, or free web page hosts.
This category also includes unique domains that contain personal information, such as a personal home page. This category does not include home pages of public figures.
Pharmacy
Web pages that provide reviews, descriptions, and market or sell prescription-based drugs, over-the-counter drugs, birth control, or dietary supplements.
Politics Opinion
Web pages covering political parties, individuals in political life, and opinion on various topics.
This category might also cover laws and political opinion about drugs. This category includes URLs for political parties, political campaigning, and opinions on various topics, including political debates.
Pornography
Web pages that contain materials intended to be sexually arousing or erotic.
This category includes fetish pages, animation, cartoons, stories, and illegal pornography.
Portal Sites
Web pages that serve as major gateways or directories to content on the web.
Many portal sites also provide a variety of internal site features or services such as search engines, email, news, and entertainment. Mailing list sites with a variety of content are in this category.
This category does not include sites with topic-specific content.
Potential Criminal Activities
Web pages that provide instructions to commit illegal or criminal activities.
Instructions include committing murder or suicide, sabotage, bomb-making, lock-picking, service theft, evading law enforcement, or spoofing drug tests. This category might also include information on how to distribute illegal content, perpetrate fraud, or consumer scams.
This category does not include computer-related fraud.
Potential Hacking Computer Crime
Web pages that provide instructions, or otherwise enable, fraud, crime, or malicious activity that is computer-oriented.
This category includes web pages related to computer crime include malicious hacking information or tools that help individuals gain unauthorized access to computers and networks (root kits, kiddy scripts). This category also includes other areas of electronic fraud such as dialer scams and illegal manipulation of electronic devices.
This category does not include illegal software.
Potential Illegal Software
Web pages, which the filter believes offer information to potentially ‘pirated’ or illegally distribute software or electronic media, such as copyrighted music or film, distribution of illegal license key generators, software cracks, and serial numbers.
This category does not include peer-to-peer web pages.
Private IP Addresses
Sites that are private IP addresses as defined in RFC 1918, that is, hosts that do not require access to hosts in other enterprises (or require just limited access) and whose IP address may be ambiguous between enterprises but are well defined within a certain enterprise.
Profanity
Web pages that contain crude, vulgar, or obscene language or gestures.
Professional Networking
Web pages that provide social networking exclusively for professional or business purposes.
This category includes sites that provide personal or group profiles, and enable their members to interact through real-time communication, message posting, public bulletins, and media sharing. This category also contains alumni sites that have a networking function.
This category does not include social networking sites where the focus might vary, but include friendship, dating, or professional focuses.
Provocative Attire
Web pages with pictures that include alluring or revealing attire, lingerie and swimsuits, or supermodel or celebrity photograph collections, but do not involve nudity.
This category does not include sites with swimwear or similar attire that is not intended to be provocative. For example, Olympic swimming sites are not in this category.
Public Information
Web pages that provide general reference information such as public service providers, regional information, transportation schedules, maps, or weather reports.
PUPs
Web pages that contain Potentially Unwanted Programs (PUPs).
PUPs are often made for a beneficial purpose but they alter the security of a computer or the computer user’s privacy. Computer users who are concerned about security or privacy might want to be informed about this software, and in some cases, they might want to remove this software from their computers.
Real Estate
Web pages that provide commercial or residential real estate services and information.
Service and information includes sales and rental of living space or retail space and guides for apartments, housing, and property, and information on appraisal and brokerage. This category includes sites that allow you to browse model homes.
This category does not include content related to personal finance, such as credit applications.
Recreation Hobbies
Web pages for recreational organizations and facilities that include content devoted to recreational activities and hobbies.
This category includes information about public swimming pools, zoos, fairs, festivals, amusement parks, recreation guides, hiking, fishing, bird watching, or stamp collecting.
This category does not include activities that need no active participation, such as watching a movie or reading celebrity gossip.
Religion Ideology
Web pages with content related to religious topics and beliefs in human spirituality that are not within the major religions.
This category includes religious discussion, beliefs, articles, and information for local congregations or groups such as a church homepage, unless the site is already in the Major Global Religions category. This category also includes comparative religion, or sites that include religions and ideologies.
This category does not include astrology and horoscope sites
Remote Access
Web pages that provide remote access to a program, online service, or an entire computer system.
Although remote access is often used legitimately to run a computer from a remote location, it creates a security risk, such as backdoor access. Backdoor access, written by the original programmer, allows the system to be controlled by another party without the user's knowledge.
Reserved
This category is reserved for future use.
Residential IP Addresses
IP addresses (and any domains associated with them) that access the Internet by DSL modems or cable modems.
Because this content is not generally intended for Internet access via HTTP, access to the Internet through these IP addresses can indicate suspicious behavior. This behavior might be related to malware located on the home computer or homegrown gateways set up to allow anonymous Internet access.
Resource Sharing
Web pages that harness idle or unused computer resources to focus on a common task.
The task can be on a company or an international basis. Well known examples are the SETI program and the Human Genome Project, which use the idle time of thousands of volunteered computers to analyze data.
Restaurants
Web pages that provide information about restaurants, bars, catering, take-out and delivery, including online ordering.
This category includes sites that provide information about location, hours, prices, menus and related dietary information. This category also includes restaurant guides and reviews, and cafes and coffee shops.
This category does not include groceries, wholesale food, non-profit and charitable food organizations, or bars that do not focus on serving food.
Web pages that promote plagiarism or cheating by providing free or fee-based term papers, written essays, or exam answers.
This category does not include sites that offer student help, discuss literature, films, or books, or other content that is often the subject of research papers.
Search Engines
Web pages that provide search results that enable users to find information on the Internet based on key words.
This category does not include site-specific search engines.
Sexual Materials
Web pages that describe or depict sexual acts, but are not intended to be arousing or erotic.
Examples of sexual materials include sex education, sexual innuendo, humor, or sex related merchandise.
This category does not include web pages with content intended to arouse.
Shareware Freeware
Web pages that are repositories of downloadable copies of shareware and freeware.
This category does not include subscription-based software.
Social Networking
Web pages that enable social networking for a variety of purposes, such as friendship, dating, professional, or topics of interest.
These sites provide personal or group profiles and enable interaction among their members through real-time communication, message posting, public bulletins, and media sharing.
This category does not include sites that are exclusive to dating, matchmaking, or a specific professional networking focus.
Software Hardware
Web pages related to computing software and hardware, including vendors, product marketing and reviews, deployment and maintenance of software and hardware, and software updates and add-ons such as scripts, plug-ins, or drivers. Hardware includes computer parts, accessories, and electronic equipment used with computers and networks.
This category includes the marketing of software and hardware, and magazines focused on software or hardware product reviews or industry trends.
Sports
Web pages related to professional or organized recreational sports.
This category includes sporting news, events, and information such as playing tips, strategies, game scores, or player trades.
This category does not include fantasy leagues, sports centers, athletic clubs, fitness or martial arts clubs, and non-league billiards, darts, or other such activities.
Stock Trading
Web pages that offer purchasing, selling, or trading of shares online.
This category also includes ticker-tape information that enables viewing of real-time stock prices and financial spread betting in the stock market. Other betting is in the Gambling category.
This category does not include sites that offer information about stocks, but do not offer purchasing, selling, or trading of shares.
Streaming Media
Web pages that provide streaming media, or contain software plug-ins for displaying audio and visual data before the entire file has been transmitted.
This category does not include audio or video files that are downloaded to a user’s computer before being played.
Technical Business Forums
Web pages with a technical or business focus that provide online message posting or real-time chatting, such as technical support or interactive business communication.
Although users can post any type of content, these forums tend to present less risk of containing offensive content.
Sites that offer a variety of forums with themes, including technical and business content, are only in the categories of Forum/Bulletin Boards or Chat.
Technical Information
Web pages that provide computing information with an educational focus in areas such as Information Technology, computer programming, and certification.
Examples include Linux user groups, UNIX commands, software tutorials, or dictionaries of technical terms. Most sites in this category might be subdirectories of larger domains. For example, a software site with a tutorial page is in this category only at the tutorial page URL.
This category does not include content about information security.
Text Spoken Only
Content that is text or audio only, and does not contain pictures.
This category can be used as an exception to allow explicit text and recorded material to be accessed when you want pictures blocked using the Pornography, Violence, or Sexual Materials categories. Libraries or universities can use this category to prevent the display of offensive graphics in their public facilities.
Text Translators
Web pages that allow users to type phrases or a block of text to translate it from one language into another.
This category also includes language identifier web pages. URL translation is in the Anonymizing Utilities category.
Tobacco
Web pages that sell, promote, or advocate the use of tobacco products, tobacco paraphernalia, including cigarettes, cigars, pipes, snuff and chewing tobacco.
Travel
Web pages that promote personal or business travel, such as hotels, resorts, airlines, ground transportation, car rentals, travel agencies, and general tourist and travel information.
This category also includes sites for buying tickets or accommodation.
This category does not include personal vacation photographs.
Usenet News
Web pages that provide access (http://) to Usenet newsgroups and archives of files uploaded to newsgroups.
This category also includes online groups that offer similar community-oriented content posting.
Violence
Web pages that contain real or lifelike images or text that portray, describe, or advocate physical assaults against people, animals, or institutions, such as depictions of war, suicide, mutilation, or dismemberment.
Visual Search Engine
Web pages that provide image-specific search results such as thumbnail pictures.
This category does not include sites that offer site-specific visual search engines.
Weapons
Web pages that provide information about buying, making, modifying, or using weapons, such as guns, knives, swords, paintball guns, and ammunition, explosives, and weapon accessories.
This category also includes sites that contain content for: weapons for personal or military use, homemade weapons, non-lethal weapons such as mace, pepper spray, or Taser guns, weapons facilities, such as shooting ranges, and government or military oriented weapons.
This category does not include political action groups, such as the NRA.
Web Ads
Web pages that provide advertisement-hosting or programs that create advertisements.
Examples include links, source code or applets for banners, popups, and other kinds of static or dynamically generated advertisements that appear on web pages. This category is intended to block advertisements on web pages, not the companies that provide the advertisements or advertising services.
This category does not include aggressive advertising adware. See the Spyware/Adware category.
Web Mail
Web pages that enable users to send or receive email through the Internet.
Web Meetings
Web pages that host live meetings, video conferences, and interactive presentations mainly for businesses.
Web meetings generally include streaming audio and video, and allow data transfer or office-oriented application sharing, such as online presentations.
Web Phone
Web pages that enable users to make telephone calls via the Internet or obtain information or software for this purpose.
Web Phone service is also called Internet Telephony, or VoIP. Web phone service includes PC-to-PC, PC-to-phone, and phone-to-phone services connecting via TCP/IP networks.
Content Filter Add Filter Profile Custom Service
You can create a list of good (allowed) web site addresses and a list of bad (blocked) web site addresses. You can also block web sites based on whether the web site’s address contains a keyword. Use this screen to add or remove specific sites or keywords from the filter list.
Configuration > Security Service > Content Filter > Profile > Custom Service
Label
Description
Name
Description
Enable Custom Service
Select this check box to allow trusted web sites and block forbidden web sites. Content filter list customization may be enabled and disabled without re-entering these site names.
Allow Web traffic for trusted web sites only
When this box is selected, the Zyxel Device blocks Web access to sites that are not on the Trusted Web Sites list. If they are chosen carefully, this is the most effective way to block objectionable material.
Check Common Trusted/Forbidden List
Select this check box to check the common trusted and forbidden web sites lists. See Content Filter Trusted Web Sites and Content Filter Forbidden Web Sites for information on configuring these lists.
Restricted Web Features
Select the check box(es) to restrict a feature. Select the check box(es) to restrict a feature.
When you download a page containing ActiveX or Java, that part of the web page will be blocked with an X.
When you download a page coming from a Web Proxy, the whole web page will be blocked.
When you download a page containing cookies, the cookies will be removed, but the page will not be blocked.
Block
ActiveX
ActiveX is a tool for building dynamic and active web pages and distributed object applications. When you visit an ActiveX web site, ActiveX controls are downloaded to your browser, where they remain in case you visit the site again.
Java
Java is a programming language and development environment for building downloadable Web components or Internet and intranet business applications of all kinds.
Cookies
Cookies are files stored on a computer’s hard drive. Some web servers use them to track usage and provide service based on ID.
Web Proxy
A server that acts as an intermediary between a user and the Internet to provide security, administrative control, and caching service. When a proxy server is located on the WAN it is possible for LAN users to circumvent content filtering by pointing to this proxy server.
Allow Java/ActiveX/Cookies/Web proxy to trusted web sites
When this box is selected, the Zyxel Device will permit Java, ActiveX and Cookies from sites on the Trusted Web Sites list to the LAN. In certain cases, it may be desirable to allow Java, ActiveX or Cookies from sites that are known and trusted.
Trusted Web Sites
These are sites that you want to allow access to, regardless of their content rating, can be allowed by adding them to this list.
Add
Click this to create a new entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
This displays the index number of the trusted web sites.
Trusted Web Site
This column displays the trusted web sites already added.
Enter host names such as www.good-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All subdomains are allowed. For example, entering “*zyxel.com” also allows “www.zyxel.com”, “partner.zyxel.com”, “press.zyxel.com”, and so on. You can also enter just a top level domain. For example, enter “*.com” to allow all .com domains.
Use up to 127 characters (0-9a-z-). The casing does not matter. “*” can be used as a wildcard to match any string. The entry must contain at least one “.” or it will be invalid.
Add
Edit
Remove
This displays the index number of the forbidden web sites.
Forbidden Web Sites
This list displays the forbidden web sites already added.
Enter host names such as www.bad-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All subdomains are also blocked. For example, entering “*bad-site.com” also blocks “www.bad-site.com”, “partner.bad-site.com”, “press.bad-site.com”, and do on. You can also enter just a top level domain. For example, enter “*.com” to block all .com domains.
Blocked URL Keywords
This section allows you to block Web sites with URLs that contain certain keywords in the domain name or IP address.
Add
Edit
Remove
This displays the index number of the blocked URL keywords.
This list displays the keywords already added.
Enter a keyword or a numerical IP address to block. You can also enter a numerical IP address.
Use up to 127 case-insensitive characters (0-9a-zA-Z;/?:@&=+$\.-_!~*()%). “*” can be used as a wildcard to match any string. Use “|*” to indicate a single wildcard character.
For example enter *Bad_Site* to block access to any web page that includes the exact phrase Bad_Site. This does not block access to web pages that only include part of the phrase (such as Bad for example).
OK
Cancel
You can create a common list of good (allowed) web site addresses. When you configure Filter Profiles, you can select the option to check the Common Trusted Web Sites list. Use this screen to add or remove specific sites from the filter list.
Configuration > Security Service > Content Filter > Trusted Web Sites
Label
Description
Add
Edit
Remove
Trusted Web Site
Enter host names such as www.good-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All subdomains are allowed. For example, entering “zyxel.com” also allows “www.zyxel.com”, “partner.zyxel.com”, “press.zyxel.com”, and so on. You can also enter just a top level domain. For example, enter .com to allow all .com domains.
Apply
Reset
You can create a common list of bad (blocked) web site addresses. When you configure Filter Profiles, you can select the option to check the Common Forbidden Web Sites list. Use this screen to add or remove specific sites from the filter list.
Configuration > Security Service > Content Filter > Forbidden Web Sites
Label
Description
Forbidden Web Site List
Sites that you want to block access to, regardless of their content rating, can be allowed by adding them to this list.
Add
Edit
Remove
Forbidden Web Sites
Enter host names such as www.bad-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All subdomains are also blocked. For example, entering “bad-site.com” also blocks “www.bad-site.com”, “partner.bad-site.com”, “press.bad-site.com”, and do on. You can also enter just a top level domain. For example, enter .com to block all .com domains.
Apply
Cancel
