Wireless
Use the Wireless screens to configure how the Zyxel Device manages supported Access Points (APs). Supported APs should be in managed mode. See the product page Licenses tab for a list of supported APs.
Built-in AP
If your Zyxel Device has a built-in AP, then use this function to allow WiFi clients to access your Zyxel Device wirelessly to connect to the network. If your Zyxel Device is in AP Controller Mode, go to Configuration > Wireless > Built-in AP_ General and click Switch to Built-in AP Mode.
To go to AP Controller Mode from Built-in AP Mode, go to Configuration > Controller and click Switch to AP Controller Mode.
The Configuration > Wireless > Built-in AP displays showing AP information in Built-in AP Mode.
Each field is described in the following table.
Configuration> Wireless> General
Label
Description
SSID Summary
Quick Setup
Click this to go to the Quick Setup Wireless Wizard to configure a wireless network.
Add
Click this to configure a new wireless network.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings.
Activate/Inactivate
To turn on an entry, select it and click Activate. To turn off an entry, select it and click Inactivate.
This is the wireless network’s index number in this list.
Status
This displays whether or not the wireless network is activated.
SSID
This shows the name of the wireless network.
Security Mode
This shows the security used for this wireless network. No security allows any wireless client to associate with this network without authentication.
Band Mode
This shows the wireless band which this wireless network uses. 2.4 GHz is the frequency used by IEEE 802.11b/g/n/ax wireless clients. 5 GHz is the frequency used by IEEE 802.11ax/ac/a/n wireless clients.
Outgoing Interface
This is the outgoing interface that the wireless network uses to transmit packets.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Wireless > Built-in AP > General >Add/Edit SSID
An SSID, or Service Set IDentifier, is the name of the wireless network to which a wireless client can connect.
Configuration > Object > AP Profile > SSID > SSID List > Add/Edit SSID Profile
Label
Description
Activate
To turn on an entry, select Activate. To turn off an entry, select it and click Inactivate.
SSID
Enter the SSID name for this profile. This is the name visible on the network to wireless clients. Enter up to 32 characters, spaces and underscores are allowed.
Band Mode
QoS
Select a Quality of Service (QoS) access category to associate with this SSID. Access categories minimize the delay of data packets across a wireless network. Certain categories, such as video or voice, are given a higher priority due to the time sensitive nature of their data packets.
QoS access categories are as follows:
disable: Turns off QoS for this SSID. All data packets are treated equally and not tagged with access categories.
WMM: Enables automatic tagging of data packets. The Zyxel Device assigns access categories to the SSID by examining data as it passes through it and making a best guess effort. If something looks like video traffic, for instance, it is tagged as such.
WMM_VOICE: All wireless traffic to the SSID is tagged as voice data. This is recommended if an SSID is used for activities like placing and receiving VoIP phone calls.
WMM_VIDEO: All wireless traffic to the SSID is tagged as video data. This is recommended for activities like video conferencing.
WMM_BEST_EFFORT: All wireless traffic to the SSID is tagged as “best effort,” meaning the data travels the best route it can without displacing higher priority traffic. This is good for activities that do not require the best bandwidth throughput, such as surfing the Internet.
WMM_BACKGROUND: All wireless traffic to the SSID is tagged as low priority or “background traffic”, meaning all other access categories take precedence over this one. If traffic from an SSID does not have strict throughput requirements, then this access category is recommended. For example, an SSID that only has network printers connected to it.
Outgoing Interface
Select the outgoing interface that the wireless network uses to transmit packets.
Authentication Settings
Security Mode
Select a security mode from the list: open, wep, wpa2, or wpa2-mix.
802.1x
Select this to enable 802.1x secure authentication with a RADIUS server.
Auth. Method
This field is available only when you select the RADIUS Server Type to Internal.
Select an authentication method if you have created any on the Configuration > Object > Auth. Method screen.
Reauthentication Timer
Enter the interval (in seconds) between authentication requests. Enter a 0 for unlimited requests.
PSK
Select this option to use a Pre-Shared Key with WPA encryption.
Pre-Shared Key
Enter a pre-shared key of between 8 and 63 case-sensitive ASCII characters (including spaces and symbols) or 64 hexadecimal characters.
Cipher Type
Select an encryption cipher type from the list.
auto - This automatically chooses the best available cipher based on the cipher in use by the wireless client that is attempting to make a connection.
aes - This is the Advanced Encryption Standard encryption method. It is a more recent development over TKIP and considerably more robust. Not all wireless clients may support this.
Idle Timeout
Enter the idle interval (in seconds) that a client can be idle before authentication is discontinued.
Group Key Update Timer
Enter the interval (in seconds) at which the AP updates the group WPA encryption key.
Pre-Authentication
This field is available only when you set Security Mode to wpa2 or wpa2-mix and enable 802.1x authentication.
Enable or Disable pre-authentication to allow the AP to send authentication information to other APs on the network, allowing connected wireless clients to switch APs without having to re-authenticate their network connection.
Management Frame Protection
This field is available only when you select wpa2 in the Security Mode field and set Cipher Type to aes.
Data frames in 802.11 WLANs can be encrypted and authenticated with WEP, WPA or WPA2. But 802.11 management frames, such as beacon/probe response, association request, association response, de-authentication and disassociation are always unauthenticated and unencrypted. IEEE 802.11w Protected Management Frames allows APs to use the existing security mechanisms (encryption and authentication methods defined in IEEE 802.11i WPA/WPA2) to protect management frames. This helps prevent wireless DoS attacks.
Select the check box to enable management frame protection (MFP) to add security to 802.11 management frames.
Select Optional if you do not require the wireless clients to support MFP. Management frames will be encrypted if the clients support MFP.
Select Required and wireless clients must support MFP in order to join the Zyxel Device’s wireless network.
Hidden SSID
Select this if you want to “hide” your SSID from wireless clients. This tells any wireless clients in the vicinity of the AP using this SSID profile not to display its SSID name as a potential connection. Not all wireless clients respect this flag and display it anyway.
When a SSID is “hidden” and a wireless client cannot see it, the only way you can connect to the SSID is by manually entering the SSID name in your wireless connection setup screen(s) (these vary by client, client connectivity software, and operating system).
Enable Intra-BSS Traffic Blocking
Select this option to prevent crossover traffic from within the same SSID on the Zyxel Device.
Enable U-APSD
Select this option to enable Unscheduled Automatic Power Save Delivery (U-APSD), which is also known as WMM-Power Save. This helps increase battery life for battery-powered wireless clients connected to the Zyxel Device using this SSID profile.
Enable ARP Proxy
The Address Resolution Protocol (ARP) is a protocol for mapping an IP address to a MAC address. An ARP broadcast is sent to all devices on the same Ethernet network to request the MAC address of a target IP address.
Select this option to allow the Zyxel Device to answer ARP requests for an IP address on behalf of a client associated with this SSID. This can reduce broadcast traffic and improve network performance.
802.11k/v Assisted Roaming
Select this option to enable IEEE 802.11k/v assisted roaming on the Zyxel Device. When the connected clients request 802.11k neighbor lists, the Zyxel Device will response with a list of neighbor APs that can be candidates for roaming.
Schedule SSID
Select this option and set whether the SSID is enabled or disabled on each day of the week. You also need to select the hour and minute (in 24-hour format) to specify the time period of each day during which the SSID is enabled/enabled.
Radius Settings
Radius Server Type
Select Internal to use the Zyxel Device’s internal authentication database, or External to use an external RADIUS server for authentication.
Proxy by controller directly
Select this to allow the Zyxel Device to answer authentication requests on behalf of an external RADIUS server.
MAC Filter
Filter Action
Select allow to permit the wireless client with the MAC addresses in this profile to connect to the network through the associated SSID; select deny to block the wireless clients with the specified MAC addresses.
Add
Click this to add a MAC address to the profile’s list.
Edit
Click this to edit the selected MAC address in the profile’s list.
Remove
Click this to remove the selected MAC address from the profile’s list.
This field is a sequential value, and it is not associated with a specific user.
MAC
This field specifies a MAC address associated with this profile. You can click the MAC address to make it editable.
Description
This field displays a description for the MAC address associated with this profile. You can click the description to make it editable. Enter up to 60 characters, spaces and underscores allowed.
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving your changes.
Wireless > Built-in AP > Radio
This screen allows you to create radio profiles for the Zyxel Device. A radio profile is a list of settings that a Zyxel Device can use to configure its radio transmitter(s).
Configuration > Object > AP Profile > Add/Edit Radio Profile
Label
Description
Hide / Show Advanced Settings
Click this to hide or show the Advanced Settings in this window.
2.4GHz General Settings
802.11 Band
Select how to let wireless clients connect to the AP.
11b/g: allows either IEEE 802.11b or IEEE 802.11g compliant WLAN devices to associate with the AP. The AP adjusts the transmission rate automatically according to the wireless standard supported by the wireless devices.
11b/g/n: allows IEEE802.11b, IEEE802.11g and IEEE802.11n compliant WLAN devices to associate with the AP. The transmission rate of your AP might be reduced.
Channel Width
Select the wireless channel bandwidth you want the AP to use.
A standard 20 MHz channel offers transfer speeds of up to 144Mbps (2.4GHz) or 217Mbps (5GHZ) whereas a 40MHz channel uses two standard channels and offers speeds of up to 300Mbps (2.4GHz) or 450Mbps (5GHZ).
40 MHz (channel bonding or dual channel) bonds two adjacent radio channels to increase throughput. Because not all devices support all channels, select 20/40MHz to allow the AP to adjust the channel bandwidth automatically.
Select 20MHz if you want to lessen radio interference with other wireless devices in your neighborhood or the wireless clients do not support channel bonding.
*If the environment has poor signal-to-noise (SNR), the Zyxel Device will switch to a lower bandwidth.
Channel Selection
Select the wireless channel which this radio profile should use.
It is recommended that you choose the channel least in use by other APs in the region where this profile will be implemented. This will reduce the amount of interference between wireless clients and the AP to which this profile is assigned.
Select DCS to have the AP automatically select the radio channel upon which it broadcasts by scanning the area around it and determining what channels are currently being used by other devices.
*If you change the country code later, Channel Selection is set to Manual automatically.
Select Manual and specify the channels the AP uses.
Output Power
Enter the maximum output power of the Zyxel Device. If there is a high density of APs in an area, decrease the output power of the Zyxel Device to reduce interference with other APs. Reducing the output power also reduces the Zyxel Device’s effective broadcast radius.
Enable DCS Client Aware
This field is available when you set Channel Selection to DCS.
Select this to have the AP wait until all connected clients have disconnected before switching channels.
If you disable this then the AP switches channels immediately regardless of any client connections. In this instance, clients that are connected to the AP when it switches channels are dropped.
2.4 GHz Channel Selection Method
Select auto to have the AP search for available channels automatically in the 2.4 GHz band. The available channels vary depending on what you select in the 2.4 GHz Channel Deployment field.
Select manual and specify the channels the AP uses in the 2.4 GHz band.
Channel ID
This field is available only when you set Channel Selection to DCS and set 2.4 GHz Channel Selection Method to manual.
Select the check boxes of the channels that you want the AP to use.
This field is available only when you set Channel Selection to DCS and set 2.4 GHz Channel Selection Method to auto.
Select Three-Channel Deployment to limit channel switching to channels 1,6, and 11, the three channels that are sufficiently attenuated to have almost no impact on one another. In other words, this allows you to minimize channel interference by limiting channel-hopping to these three “safe” channels.
Select Four-Channel Deployment to limit channel switching to four channels. Depending on the country domain, if the only allowable channels are 1-11 then the Zyxel Device uses channels 1, 4, 7, 11 in this configuration; otherwise, the Zyxel Device uses channels 1, 5, 9, 13 in this configuration. Four channel deployment expands your pool of possible channels while keeping the channel interference to a minimum.
Time Interval
Select this option to have the Zyxel Device survey the other APs within its broadcast radius at the end of the specified time interval.
DCS Time Interval
Enter a number of minutes. This regulates how often the AP surveys the other APs within its broadcast radius. If the channel on which it is currently broadcasting suddenly comes into use by another AP, the AP will then dynamically select the next available clean channel or a channel with lower interference.
Schedule
Select this option to have the Zyxel Device survey the other APs within its broadcast radius at a specific time on selected days of the week.
Start Time
Specify the time of the day (in 24-hour format) to have the Zyxel Device use DCS to automatically scan and find a less-used channel.
Week Days
Select each day of the week to have the Zyxel Device use DCS to automatically scan and find a less-used channel.
Advanced Settings
Guard Interval
This field is available only when the channel width is 20/40MHz or 20/40/80MHz.
Set the guard interval for this radio profile to either Short or Long.
The guard interval is the gap introduced between data transmission from users in order to reduce interference. Reducing the interval increases data transfer rates but also increases interference. Increasing the interval reduces data transfer rates but also reduces interference.
Enable A-MPDU Aggregation
Select this to enable A-MPDU aggregation.
Message Protocol Data Unit (MPDU) aggregation collects Ethernet frames along with their 802.11n headers and wraps them in a 802.11n MAC header. This method is useful for increasing bandwidth throughput in environments that are prone to high error rates.
A-MPDU Limit
Enter the maximum frame size to be aggregated.
A-MPDU Subframe
Enter the maximum number of frames to be aggregated each time.
Enable A-MSDU Aggregation
Select this to enable A-MSDU aggregation.
Mac Service Data Unit (MSDU) aggregation collects Ethernet frames without any of their 802.11n headers and wraps the header-less payload in a single 802.11n MAC header. This method is useful for increasing bandwidth throughput. It is also more efficient than A-MPDU except in environments that are prone to high error rates.
A-MSDU Limit
RTS/CTS Threshold
Use RTS/CTS to reduce data collisions on the wireless network if you have wireless clients that are associated with the same AP but out of range of one another. When enabled, a wireless client sends an RTS (Request To Send) and then waits for a CTS (Clear To Send) before it transmits. This stops wireless clients from transmitting packets at the same time (and causing data collisions).
A wireless client sends an RTS for all packets larger than the number (of bytes) that you enter here. Set the RTS/CTS equal to or higher than the fragmentation threshold to turn RTS/CTS off.
Beacon Interval
When a wirelessly networked device sends a beacon, it includes with it a beacon interval. This specifies the time period before the device sends the beacon again. The interval tells receiving devices on the network how long they can wait in low-power mode before waking up to handle the beacon. A high value helps save current consumption of the access point.
DTIM
Delivery Traffic Indication Message (DTIM) is the time period after which broadcast and multicast packets are transmitted to mobile clients in the Active Power Management mode. A high DTIM value can cause clients to lose connectivity with the network. This value can be set from 1 to 255.
Enable Signal Threshold
Select the check box to use the signal threshold to ensure wireless clients receive good throughput. This allows only wireless clients with a strong signal to connect to the AP.
Clear the check box to not require wireless clients to have a minimum signal strength to connect to the AP.
Station Signal Threshold
Set a minimum client signal strength. A wireless client is allowed to connect to the AP only when its signal strength is stronger than the specified threshold.
-20 dBm is the strongest signal you can require and -76 is the weakest.
Disassociate Station Threshold
Set a minimum kick-off signal strength. When a wireless client’s signal strength is lower than the specified threshold, the Zyxel Device disconnects the wireless client from the AP.
-20 dBm is the strongest signal you can require and -90 is the weakest.
Allow Station Connection after Multiple Retries
Select this option to allow a wireless client to try to associate with the AP again after it is disconnected due to weak signal strength.
Station Retry Count
Set the maximum number of times a wireless client can attempt to re-connect to the AP.
Allow 802.11n/ac stations only
Only select this if you want to deny 802.11b/g/n clients access to the radio.
Multicast Settings
Use this section to set a transmission mode and maximum rate for multicast traffic.
Transmission Mode
Set how the AP handles multicast traffic.
Select Multicast to Unicast to broadcast wireless multicast traffic to all of the wireless clients as unicast traffic. Unicast traffic dynamically changes the data rate based on the application’s bandwidth requirements. The retransmit mechanism of unicast traffic provides more reliable transmission of the multicast traffic, although it also produces duplicate packets.
Select Fixed Multicast Rate to send wireless multicast traffic at a single data rate. You must know the multicast application’s bandwidth requirements and set it in the following field.
Multicast Rate (Mbps)
If you set the multicast transmission mode to fixed multicast rate, set the data rate for multicast traffic here. For example, to deploy 4 Mbps video, select a fixed multicast rate higher than 4 Mbps.
5GHz General Settings
802.11 Band
11a: allows only IEEE 802.11a compliant WLAN devices to associate with the Zyxel Device.
11a/n: allows both IEEE802.11n and IEEE802.11a compliant WLAN devices to associate with the Zyxel Device.
11ac: allows IEEE802.11n, IEEE802.11a, and IEEE802.11ac compliant WLAN devices to associate with the Zyxel Device. If the WLAN device isn’t compatible with 802.11ac, the Zyxel Device will communicate with the WLAN device using 802.11n, and so on.
Channel Width
Select the channel bandwidth you want to use for your wireless network.
Select 20 MHz if you want to lessen radio interference with other wireless devices in your neighborhood.
Select 20/40 MHz to allow the Zyxel Device to choose the channel bandwidth (20 or 40 MHz) that has least interference.
Select 20/40/80 MHz to allow the Zyxel Device to choose the channel bandwidth (20 or 40 or 80 MHz) that has least interference. This option is available only when you select 11ac or 11ax in the 802.11 Mode field.
*If the environment has poor signal-to-noise ratio (SNR), the Zyxel Device will switch to a lower bandwidth.
Channel Selection
Output Power
OK
Cancel
Controller Screen
Use this screen to set how the Zyxel Device allows new APs to connect to the network.
Configuration > Wireless > Controller
Label
Description
Country Code
Select the country code of where the Zyxel Device is located/installed. The available channels vary depending on the country you selected.
Registration Type
Select Manual to add each AP to the Zyxel Device for management, or Always Accept to automatically add APs to the Zyxel Device for management.
If you select Manual, then go to Monitor > Wireless > AP Information > AP List, select an AP to be managed and then click Add to Mgnt AP List. That AP will then appear in Configuration > Wireless > Controller > Mgnt. AP List.
*Select the Manual option for managing a specific set of APs. This is recommended as the registration mechanism cannot automatically differentiate between friendly and rogue APs.
APs must be connected to the Zyxel Device by a wired connection or network.
Apply
Reset
Connecting an AP to the Zyxel Device
You can connect an AP directly to one of the Ethernet ports on the Zyxel Device. You can also connect an AP indirectly to the Zyxel Device through the local network.
If an AP and the Zyxel Device are on the same subnet, the AP will automatically detect and connect to the Zyxel Device.
If an AP and the Zyxel Device are on different subnets, then you can must configure the AP to connect to the Zyxel Device. You can do this manually or by configuring DHCP Option 138 on the AP’s DHCP server.
After an AP has successfully connected to the Zyxel Device, the AP appears in the AP List on MONITOR > Wireless > AP Information.
Connecting an AP to the Zyxel Device Manually
1 Ensure that the Zyxel Device has a static IP address.
2 Connect to and log on to the AP using a web browser.
3 On the AP, go to CONFIGURATION > Network > AC Discovery.
4 Under Discovery Setting, select Manual.
5 Under Primary static AC IP, enter the IP address of the Zyxel Device.
6 Click Apply.
The Zyxel Device can now manage the AP.
Connecting an AP to the Zyxel Device Using DHCP Option 138
2 Log on to the DHCP server and configure settings for the network in which the AP is located.
3 Add a new DHCP option with the following values:
Code: 138
Type: IP Address
Value: <Zyxel Device IP address>
4 Restart the AP.
The AP picks up a new DCHP-assigned IP address. The Zyxel Device can now manage the AP.
Use the AP Management screens to manage all of the APs connected to the Zyxel Device.
AP Management Screens
Use these screens to manage all of the APs connected to the Zyxel Device. Click on the icon to go to the OneSecurity website where there is guidance on configuration walkthroughs and other information.
Mgnt. AP List
Configuration > Wireless > AP Management > Mgnt. AP List
Label
Description
Filter
Click Show Advanced Settings to reveal Filter fields where you can display managed APs by status, keyword or those managed by the Nebula portal.
AP List
Select the type of APs you want to display.
Select All to show all kinds of APs that are currently or used to be connected to the Zyxel Device.
Select NebulaFlexPRO to show the APs that can work in Nebula cloud management mode.
Status
Select the status of APs you want to display.
Keyword
Enter a keyword to display the APs that include it in their AP information, such as model number, firmware version, MAC address and so on. This field is case-sensitive.
Search
Click this to update the list of APs based on the search criteria.
Your search criteria is retained when navigating between screens.
Reset
Click this to return the search criteria to the factory defaults and display all currently or previously connected APs without a filter.
Enable Column Freeze
Select this to lock the index columns in place while scrolling to the right.
Edit the selected rule
Select an AP and click this to change the selected AP’s properties, such as its group, radio, VLAN and port settings.
Add to Mgmt AP List
Select an AP and click this to add the selected AP to the managed AP list.
Reboot device
Select one or multiple APs and click this button to force the AP(s) to restart.
Remove the selected rule
Select one or multiple APs and click this button to remove the AP(s) from the manged AP list.
*If on the Configuration > Wireless > Controller screen you set the Registration Type to Always Accept, then as soon as you remove an AP from this list it reconnects.
DCS Now
Select one or multiple APs and click this button to use DCS (Dynamic Channel Selection) to allow the AP to automatically find a less-used channel in an environment where there are many APs and there may be interference.
*You should have enabled DCS in the applied AP radio profile before the APs can use DCS.
*DCS is not supported on the radio which is working in repeater AP mode.
More Information
Select an AP and click this to view a daily station count about the selected AP. The count records station activity on the AP over a consecutive 24 hour period.
Radio Information
Select an online AP and click this button to go to the Monitor > Wireless > AP Information > Radio List screen to view detailed information about the AP’s radios.
Query Controller Log
Select one or multiple APs and click this button to go to the Monitor > Log > View Log screen to view the selected AP’s current log messages.
Nebula
Select an AP and click this to open a screen where you can set whether the AP’s IP address and VLAN settings will be changed when it goes into Nebula cloud management mode.
*The AP will be set to Nebula cloud management mode and removed from the managed AP list right after you click OK.
Upgrade Firmware Now
Select one or more APs and click this button to update the APs’ firmware version.
Suppression On
Select an AP and click this button to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode.
Suppression Off
Select an AP and click this button to disable the AP’s LED suppression mode. The AP LEDs stay lit after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode.
Locator On
Select an AP and click this button to run the locator feature. The AP’s Locator LED will start to blink for 10 minutes by default. It will show the actual location of the AP between several devices on the network.
This field is a sequential value, and it is not associated with any entry.
Status
This field displays the status of AP.
Online All
Online
Conflict
Non Support
Updating
Offline All
Offline
Offline for Firmware Update
Update
Un-Mgmt
Description
This field displays the AP’s description, which you can configure by selecting the AP’s entry and clicking the Edit button.
CPU Usage
This field displays the CPU Usage of the AP.
IP Address
This field displays the IP address of the AP.
MAC Address
This field displays the MAC address of the AP.
Station 2.4G
This field displays the number of 2.4G wireless clients connected to the AP.
Station 5G
This field displays the number of 5G wireless clients connected to the AP.
Recent Online Time
This displays the most recent time the AP came on-line. N/A displays if the AP has not come on-line since the Zyxel Device last started up.
LED Status
This displays the AP LED status.
N/A displays if the AP does not support LED suppression mode and/or have a locator LED to show the actual location of the AP.
A gray LED icon signifies that the AP LED suppression mode is enabled. All the LEDs of the AP will turn off after the AP is ready.
A green LED icon signifies that the AP LED suppression mode is disabled and the AP LEDs stay lit after the AP is ready.
A sun icon signifies that the AP’s locator LED is blinking.
A circle signifies that the AP’s locator LED is extinguished.
Model
This field displays the AP’s hardware model information. It displays N/A (not applicable) only when the AP disconnects from the Zyxel Device and the information is unavailable as a result.
Apply
Refresh
Click Refresh to update the AP list.
Edit AP List
Select an AP and click the Edit button in the Configuration > Wireless > AP Management table to display this screen.
Note: The settings in the screen will change when you select the Remote AP check box. See Edit AP List (Remote AP Mode) for more information.
Storm Control
Storm control prevents broadcast/multicast storms on AP interfaces. A broadcast/multicast storm occurs when broadcast/multicast packets flood devices in the same subnet, creating excessive traffic and degrading network performance.
When storm control is enabled on the Zyxel Device, the AP monitors packets received on the its interface and determines whether the packets are broadcast or multicast. The AP monitors the number of broadcast packets received within a one-second time interval. When the interface maximum packets per second threshold is met, incoming data traffic on the AP interface is dropped until the maximum packets per second falls below the threshold.
Ethernet storm control is enabled when you enable storm control on a supported AP. At the time of writing, the following APs support Ethernet storm control:
NWA1123AC-HD
NWA5123AC-HD
WAC6303D-S
WAC5302-Sv2
WAX650S
WAX610D
WAX510D
WAC500H
WAC500
NWA210AX
NWA110AX
NWA1123ACv3
Wireless storm control is enabled automatically when you enable Remote AP on a supported AP that has firmware version 6.20 or later. At the time of writing, the following APs support wireless storm control:
WAX650S
WAX610D
WAX510D
WAC500
WAC500H
Configuration > Wireless > AP Management > Mgnt. AP List > Edit AP List
Label
Description
Create new Object
Use this menu to create a new Radio Profile object to associate with this AP.
AP Role
Select this to enable the remote AP feature.
MAC
This displays the MAC address of the selected AP.
Model
S/N
This displays the serial number of the selected AP.
Description
Enter a description for this AP. You can use up to 31 characters, spaces and underscores allowed.
Group Setting
Select an AP group to which you want this AP to belong.
System Name
Enter a name to identify the AP on a network. This is usually the AP’s fully qualified domain name.
Location
Specify the name of the place where the AP is located.
Roaming Group
Specify the name of the roaming group to which the AP belongs. You can use up to 31 alphanumeric and @# characters. Dashes and underscores are also allowed. The name should start with a letter or digit.
The 802.11k neighbor list a client requests from the AP is generated according to the roaming group and RCPI (Received Channel Power Indicator) value of its neighbor APs.
When a client wants to roam from the current AP to another, other APs in the same roaming group or not in a roaming group will be candidates for roaming. Neighbor APs in a different roaming group will be excluded from the 802.11k neighbor lists even when the neighbor AP has the best signal strength.
If the AP’s roaming group is not configured, any neighbor APs can be candidates for roaming.
Load Balancing Group 1/2
Load balancing is only applied to APs within the same group. If a load balancing group is not assigned to an AP, it will belong to a default group.
Each AP can belong to up to two groups.
Radio 1/2 Setting
Override Group Radio Setting
Select this option to overwrite the AP radio settings with the settings you configure here.
OP Mode
Select the operating mode for radio 1 or radio 2.
AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing).
MON Mode means the AP monitors the broadcast area for other APs, then passes their information on to the Zyxel Device where it can be determined if those APs are friendly or rogue. If an AP is set to this mode it cannot receive connections from wireless clients.
Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a ZyMesh to extend its wireless network.
Repeater AP means the radio can establish a wireless connection with other APs (in either root AP or repeater mode).
*To prevent bridge loops, do NOT set both radios on a managed AP to Repeater AP mode.
*The root AP and repeater AP(s) in a ZyMesh must use the same country code and AP radio profile settings in order to communicate with each other.
*Ensure you restart the managed AP after you change its operating mode.
Override Group Output Power Setting
Select this option to overwrite the AP output power setting with the setting you configure here.
Output Power
Set the output power of the AP.
Override Group SSID Setting
Select this option to overwrite the AP SSID profile setting with the setting you configure here.
This section allows you to associate an SSID profile with the radio.
Radio 1/2 AP Profile
Select an AP profile from the list. If no profile exists, you can create a new one through the Create new Object menu.
Radio 1/2 Profile
Select a monitor profile from the list. If no profile exists, you can create a new one through the Create new Object menu.
Radio 1/2 ZyMesh Profile
This field is available only when the radio is in Root AP or Repeater AP mode.
Select the ZyMesh profile the radio uses to connect to a root AP or repeater.
Enable Wireless Bridging
This field is available only when the radio is in Repeater AP mode.
Select this option to enable wireless bridging on the radio.
The managed AP must support LAN provision and the radio should be in repeater mode. VLAN and bridge interfaces are created automatically according to the LAN port’s VLAN settings. When wireless bridging is enabled, the managed repeater AP can still transmit data through its Ethernet port(s) after the ZyMesh link is up. Be careful to avoid bridge loops.
The managed APs in the same ZyMesh must use the same static VLAN ID.
Edit
Select an SSID and click this button to reassign it. The selected SSID becomes editable immediately upon clicking.
This is the index number of the SSID profile. You can associate up to eight SSID profiles with an AP radio.
SSID Profile
Indicates which SSID profile is associated with this radio profile.
IP Setting
Force Overwrite IP Setting
Select this to have the Zyxel Device change the AP’s IP address setting to match the configuration in this screen.
Get Automatically
Select this to have the AP act as a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server.
Use Fixed IP Address
Select this if you want to specify the IP address, subnet mask, gateway and DNS server address manually.
IP Address
Enter the IP address for the AP.
Subnet Mask
Enter the subnet mask of the AP in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all devices in the network.
Gateway
Enter the IP address of the gateway. The AP sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the AP.
DNS Server IP Address
Enter the IP address of the DNS server.
VLAN Settings
Override Group VLAN Setting
Select this option to overwrite the AP VLAN setting with the setting you configure here.
Force Overwrite VLAN Config
Select this to have the Zyxel Device change the AP’s management VLAN to match the configuration in this screen.
Management VLAN ID
Enter a VLAN ID for this AP.
As Native VLAN
Select this option to treat this VLAN ID as a VLAN created on the Zyxel Device and not one assigned to it from outside the network.
Storm Control Setting
Broadcast Storm Control
Enabling this will drop ingress broadcast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide).
Ethernet storm control prevents WiFi clients from receiving excessive broadcast traffic sent from wired clients in the same subnet.
Wireless storm control prevents wired clients from receiving excessive broadcast traffic sent from WiFi clients in the same subnet.
Multicast Storm Control
Enabling this will drop ingress multicast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide).
Ethernet storm control prevents WiFi clients from receiving excessive multicast traffic sent from wired clients in the same subnet.
Wireless storm control prevents wired clients from receiving excessive multicast traffic sent from WiFi clients in the same subnet.
Rogue AP Detection Setting
Override Group Rogue AP Detection Setting
Select this option to overwrite the AP Rogue Detection Settings with the settings you configure here
Enable Rogue AP Detection
Select this option to detect Rogue APs in the network.
Antenna Setting
This section is available only when the AP has an antenna switch. The screen varies depending on whether the AP has a physical antenna switch or allows you to change antenna orientation settings on a per-radio basis or on a per-AP basis.
Wall/ Ceiling
This allows you to adjust coverage depending on the antenna orientation of the AP’s radios for better coverage.
Select Wall if you mount the AP to a wall. Select Ceiling if the AP is mounted on a ceiling. You can switch from Wall to Ceiling if there are still wireless dead zones, and vice versa.
LED Suppression Mode Configuration
This section is available only when the AP supports LED suppression mode.
Suppression On
Select this option to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready.
If the check box is unchecked, it means the LEDs will stay lit after the AP is ready.
Power Setting
Enable Force override the power mode to full power if you are using a PoE injector that does not support PoE negotiation. Otherwise, the AP cannot draw full power from the power sourcing equipment. Enable this power mode to improve the AP’s performance in this situation.
*Ensure that the power sourcing equipment can supply enough power to the AP to avoid abnormal system reboots.
*Only enable this if you are using a passive PoE injector that is not IEEE 802.3at/bt compliant but can still provide full power.
Locator LED Configuration
This section is available only when the AP has a locator LED.
Turn On/ Turn Off
When the locator LED is off, click the Turn On button to activate the locator function. It will show the actual location of the AP between several devices in the network.
If the locator LED is blinking, click the Turn Off button to stop the locator LED from blinking immediately.
Automatically Extinguish After
Enter a time interval between 1 and 60 minutes to stop the locator LED from blinking. The locator LED will start to blink for the number of minutes set here.
If you make changes to the time default setting, it will be stored as the default when the AP restarts.
Reset AP Configuration
This section is available only when the AP is online.
Apply Factory Default
Click the button to reset all of the AP settings to the factory defaults.
OK
Cancel
Click Cancel to close the window with changes unsaved.
Select an AP and click the Edit button in the Configuration > Wireless > AP Management table, Select the Remote AP check box to display this screen.
Remote AP
Remote AP enables the Zyxel Device to connect to an Access Point (AP) through a secure VPN tunnel. This allows you to set up a VPN-enabled WiFi access points in remote locations, such as in a branch office or at home, which remote WiFi clients can connect to in order to access your network.
You can associate up to four Secure Tunnel SSID profiles and two Local Bridge SSID profiles with a remote AP radio.
Configure your AP using Secure Tunnel SSID profiles if you want to access the network behind the Zyxel Device or to access the Internet. Network traffic from clients connected to these SSIDs is sent through the RAP tunnel to the Zyxel Device. The Zyxel Device then sends the traffic out through the interface defined in the SSID profile.
Configure your AP using Local Bridge SSID profiles if you only want to access the Internet. Network traffic from clients connected to these SSIDs is sent directly to the network through the AP’s local gateway.
To enable the Remote AP role, the Zyxel Device needs 5.00 or later firmware and the managed AP needs 6.20 or later firmware. Go to AP Management> Firmware to check if the AP has the correct firmware.
To enable the Remote AP role, you need to have the Secure WiFi license. See Licensing for more information.
Configuration > Wireless > AP Management > Mgnt. AP List > Edit AP List (Remote AP Mode)
Label
Description
Create new Object
AP Role
MAC
Model
S/N
Description
Group Setting
System Name
Location
IP Setting
Get Automatically
IP Address
Subnet Mask
Gateway
VLAN Settings
Management VLAN ID
As Native VLAN
Radio 1/2 Setting
OP Mode
Output Power
Secure Tunnel SSID
This field is a sequential value, and it is not associated with a specific entry.
SSID Profile
Click on the SSID profile to show the drop down list box. Select a pre-configured SSID profile you want to configure as the Secure Tunnel SSID.
Interface
Click on the interface to show the drop-down list box. Select an interface you want the AP traffic to go through on the Zyxel Device. The interface you select here will override the interface configured in the SSID profile.
Band Mode
Click on the band mode to show the drop-down list box. Select the frequency band you want the AP to use.
Local Bridge SSID
SSID Profile
Click on the SSID profile name to show the drop down list box. Select a pre-configured SSID profile you want to configure as the Local Bridge SSID.
VID
Click on the interface to configure the VID number. The VID you set here will override the VID configured in the SSID profile.
Band Mode
See Edit AP List for more information on storm control.
Antenna Setting
Wall/ Ceiling
Suppression On
Power Setting
Turn On/ Turn Off
OK
Cancel
AP Policy
Use this screen to configure the AP controller’s IP address on the managed APs and determine the action the managed APs take if the current AP controller fails.
Configuration > Wireless > AP Management > AP Policy
Label
Description
Force Override AC IP Config on AP
Select this to have the Zyxel Device change the AP controller’s IP address on the managed AP(s) to match the configuration in this screen.
Override Type
Select Auto to have the managed AP(s) automatically send broadcast packets to find any other available AP controllers.
Select Manual to replace the AP controller’s IP address configured on the managed AP(s) with the one(s) you specified below.
Primary Controller
Specify the IP address of the primary AP controller if you set Override Type to Manual.
Secondary Controller
Specify the IP address of the secondary AP controller if you set Override Type to Manual.
Fall back to Primary Controller when possible
Select this option to have the managed AP(s) change back to associate with the primary AP controller as soon as the primary AP controller is available.
Fall Back Check Interval
Set how often the managed AP(s) check whether the primary AP controller is available.
Firmware Updating
Updating Mode
Specify how you want to upgrade firmware to managed APs (in the Run state) from the Zyxel Device (the AP Controller). In AP management > Firmware, click Check to make sure that the Zyxel Device has the latest AP firmware.
Select Auto to have the Zyxel Device check if the managed APs have the latest AP firmware, and if not, use CAPWAP (Control and Provisioning of Wireless Access Points protocol) or Cloud to automatically update firmware to the managed APs.
Select Manual to have the Zyxel Device admin manually check if the managed APs have the latest firmware. Go to Wireless > AP Management > Mgnt. AP List and check if there are any APs that display Compatible AP under Status. This means that this AP’s firmware is not the same as the AP firmware on the Zyxel Device. Check that Zyxel Device has the latest AP firmware in AP management > Firmware. If yes, go back to Wireless > AP Management > Mgnt. AP List, select the AP again and click the Upgrade Firmware Now to manually update firmware to that managed AP.
Apply
Reset
AP Group
Use this screen to configure AP groups, which define the radio, port, VLAN and load balancing settings and apply the settings to all APs in the group. An AP can belong to one AP group at a time.
Configuration > Wireless > AP Management > AP Group
Label
Description
Group Setting
Default Group
Select a group that is used as the default group.
Any AP that is not configured to associate with a specific AP group belongs to the default group automatically.
Group Summary
Add
Click this button to create a new AP group.
Edit
Select an entry and click this button to edit its properties.
Remove
Select an entry and click this button to remove it from the list.
*You cannot remove a group with which an AP is associated.
DCS Now
Select one or multiple groups and click this button to use DCS (Dynamic Channel Selection) to allow the APs in the group(s) to automatically find a less-used channel in an environment where there are many APs and there may be interference.
This is the index number of the group in the list.
Group Name
This is the name of the group.
Member Count
This is the total number of APs which belong to this group.
Apply
Reset
Add/Edit AP Group
Click Add or select an AP group and click the Edit button in the Configuration > Wireless > AP Management > AP Group table to display this screen.
Configuration > Wireless > AP Management > AP Group > Add/Edit
Label
Description
General Settings
Group Name
Enter a name for this group. You can use up to 31 alphanumeric characters. Dashes and underscores are also allowed. The name should start with a letter.
Description
Enter a description for this group. You can use up to 31 characters, spaces and underscores allowed.
Location
Specify the name of the place where the AP group is located.
Radio 1/2 Setting
OP Mode
Radio 1/2 Profile
Output Power
Set the maximum output power of the AP.
If there is a high density of APs in an area, decrease the output power of the managed AP to reduce interference with other APs.
*Reducing the output power also reduces the Zyxel Device’s effective broadcast radius.
Edit
SSID Profile
VLAN Settings
Management VLAN ID
As Native VLAN
Port Settings
Model Specific Setting
Select the model of the managed AP to display the model-specific port and VLAN settings in the tables below.
Port Setting
You can activate or deactivate a non-uplink port.
Edit
Activate/Inactivate
This is the port’s index number in this list.
Status
This displays whether or not the port is activated.
Port
This shows the name of the physical Ethernet port on the managed AP.
PVID
This shows the port’s PVID.
A PVID (Port VLAN ID) is a tag that adds to incoming untagged frames received on a port so that the frames are forwarded to the VLAN group that the tag defines.
VLAN Configuration
Use Add to create a new VLAN Configuration. Select a VLAN Configuration first to use the Edit, Remove, Activate and Inactivate buttons.
This is the VLAN’s index number in this list.
Status
This displays whether or not the VLAN is activated.
Name
This shows the name of the VLAN.
VID
This shows the VLAN ID number.
Member
This field displays the Ethernet port(s) that is a member of this VLAN.
Load Balancing Setting
Enable Load Balancing
Select this to enable load balancing on the Zyxel Device.
Use this section to configure wireless network traffic load balancing between the managed APs in this group.
*Load balancing is not supported on the radio which is working in root AP or repeater AP mode.
Mode
Select a mode by which load balancing is carried out.
Select By Station Number to balance network traffic based on the number of specified stations connected to an AP.
Select By Traffic Level to balance network traffic based on the volume generated by the stations connected to an AP.
Select By Smart Classroom to balance network traffic based on the number of specified stations connected to an AP. The AP ignores association request and authentication request packets from any new station when the maximum number of stations is reached.
If you select By Station Number or By Traffic Level, once the threshold is crossed (either the maximum station numbers or with network traffic), the AP delays association request and authentication request packets from any new station that attempts to make a connection. This allows the station to automatically attempt to connect to another, less burdened AP if one is available.
Radio 1/2 Max Station Number
Enter the threshold number of stations at which an AP begins load balancing its connections.
Disassociate station when overloaded
This function is enabled by default and the disassociation priority is always Signal Strength when you set Mode to By Station Number.
Select this option to disassociate wireless clients connected to the AP when it becomes overloaded. If you do not enable this option, then the AP simply delays the connection until it can afford the bandwidth it requires, or it transfers the connection to another AP within its broadcast radius.
The disassociation priority is determined automatically by the Zyxel Device and is as follows:
Idle Timeout - Devices that have been idle the longest will be disassociated first. If none of the connected devices are idle, then the priority shifts to Signal Strength.
Signal Strength - Devices with the weakest signal strength will be disassociated first.
*If you enable this function, you should ensure that there are multiple APs within the broadcast radius that can accept any rejected or kicked wireless clients; otherwise, a wireless client attempting to connect to an overloaded AP will be kicked continuously and never be allowed to connect.
Radio 1/2 Traffic Level
Select the threshold traffic level at which the AP begins load balancing its connections (Low, Medium, High).
The maximum bandwidth allowed for each level is:
Low - 11 Mbps,
Medium - 23 Mbps
High - 35M bps
AP List
Available
This lists the APs that do not belong to this group. Select the APs that you want to add to the group you are editing, and click the right arrow button to add them.
Member
This lists the APs that belong to this group. Select any APs that you want to remove from the group, and click the left arrow button to remove them.
AP List
Available
Member
OK
Cancel
Override Member AP Setting
Click this button to overwrite the settings of all managed APs in this group with the settings you configure here. All Override Group check boxes on the AP Management > Mgnt. AP List > Edit AP List screen for the APs in this group will be deselected.
Firmware
The Zyxel Device stores an AP firmware in order to manage supported APs. This screen allows the Zyxel Device to check for and download new AP firmware when it becomes available on the firmware server. All APs managed by the Zyxel Device must have the same firmware version as the AP firmware on the Zyxel Device.
When an AP connects to the Zyxel Device wireless controller, the Zyxel Device will check if the AP has the same firmware version as the AP firmware on the Zyxel Device. If yes, then the Zyxel Device can manage it. If no, then the AP must upgrade (or downgrade) its firmware to be the same version as the AP firmware on the Zyxel Device (and reboot).
The Zyxel Device should always have the latest AP firmware so that:
APs don’t have to downgrade firmware in order to be managed
All new APs are supported.
Use Check to see if the Zyxel Device has the latest AP firmware. Use Apply to have the Zyxel Device download the latest AP firmware (see More Details for more information on the firmware) from the firmware server. If the Zyxel Device does not have enough space for the latest AP firmware, then the Zyxel Device will delete an existing firmware that no AP is using before downloading the new AP firmware.
Configuration > Wireless > AP Management > Firmware
Label
Description
AP Firmware
Runtime Firmware
This displays the current AP firmware version on the Zyxel Device. The Zyxel Device must have the latest AP firmware to manage all supported APs.
Available Firmware
This field displays if there is a later AP firmware version available on the firmware server. It displays N/A if the Zyxel Device cannot connect with the firmware server. Check that the Zyxel Device has Internet access if N/A displays and then click the Check button below.
If a newer Zyxel Device AP firmware is available, its version number and a More Details icon displays here.
Last Check Success
This displays the date and time the last check for new firmware was made and whether the check is in progress (checking), was successful (success), or has failed (fail).
Check
Click this button to have the Zyxel Device display the latest AP firmware version available on the firmware server.
Apply AP Firmware
Due to space limitations, the Zyxel Device only downloads and keeps AP firmware for APs it is currently managing. If you connect a new AP to the Zyxel Device, the Zyxel Device may need to download a new AP firmware. Please wait while downloading new firmware as the speed depends on your Internet connection speed. Make sure to maintain the Internet connection while downloading new firmware.
Apply
Click this to download newer Available Firmware from the firmware server and update the Runtime Firmware version.
This is an index number of a managed AP.
Model
This displays the name of all manageable AP models.
Runtime Firmware
This displays the firmware version that the managed AP must have in order to be managed by the Zyxel Device. Firmware for APs that the Zyxel Device already has displays in bold; firmware that the Zyxel Device doesn’t have or is still downloading is grayed out. Firmware that is in the download queue will show To be downloaded.
Refresh
Click this to update the model firmware table.
Rogue AP
Use this screen to assign APs either to the rogue AP list or the friendly AP list. A rogue AP is a wireless access point operating in a network’s coverage area that is not under the control of the network administrator, and which can potentially open up holes in a network’s security.
Configuration > Wireless > Rogue AP
Label
Description
Suspected Rogue AP Classification Rule
Click the check boxes (Weak Security (Open, WEP, WPA-PSK), Un-managed AP, Hidden SSID, SSID Keyword) of the characteristics an AP should have for the Zyxel Device to rule it as a rogue AP.
Add
Click this to add an SSID Keyword.
Edit
Select an SSID Keyword and click this button to modify it.
Remove
Select an existing SSID keyword and click this button to delete it.
This is the SSID Keyword’s index number in this list.
SSID Keyword
This field displays the SSID Keyword.
Rogue/Friendly AP List
Add
Click this button to add an AP to the list and assign it either friendly or rogue status.
Edit
Select an AP in the list to edit and reassign its status.
Remove
Select an AP in the list to remove.
Containment
Click this button to quarantine the selected AP.
A quarantined AP cannot grant access to any network services. Any stations that attempt to connect to a quarantined AP are disconnected automatically.
Dis-Containment
Click this button to take the selected AP out of quarantine.
An unquarantined AP has normal access to the network.
This field is a sequential value, and it is not associated with any interface.
Containment
This field indicates the selected AP’s containment status.
Role
This field indicates whether the selected AP is a rogue-ap or a friendly-ap. To change the AP’s role, click the Edit button.
MAC Address
This field indicates the AP’s radio MAC address.
Description
This field displays the AP’s description. You can modify this by clicking the Edit button.
Rogue/Friendly AP List Importing/Exporting
These controls allow you to export the current list of rogue and friendly APs or import existing lists.
File Path / Browse / Importing
Enter the file name and path of the list you want to import or click the Browse button to locate it. Once the File Path field has been populated, click Importing to bring the list into the Zyxel Device.
Exporting
Click this button to export the current list of either rogue APs or friendly APS.
Monitor Mode Settings
Enable Rogue AP Containment
Select this to enable rogue AP containment.
Apply
Reset
Add/Edit Rogue/Friendly List
Select an AP and click the Edit button in the Configuration > Wireless > Rogue AP table to display this screen.
Configuration > Wireless > Rogue AP > Add/Edit Rogue/Friendly
Label
Description
MAC
Enter the MAC address of the AP you want to add to the list. A MAC address is a unique hardware identifier in the following hexadecimal format: xx:xx:xx:xx:xx:xx where xx is a hexadecimal number separated by colons.
Description
Enter up to 60 characters for the AP’s description. Spaces and underscores are allowed.
Role
Select either Rogue AP or Friendly AP for the AP’s role.
OK
Cancel
Auto Healing
Use this screen to enable auto healing, which allows you to extend the wireless service coverage area of the managed APs when one of the APs fails.
Configuration > Wireless > Auto Healing
Label
Description
Enable Auto Healing
Select this option to turn on the auto healing feature.
Save Current State
Click this button to have all manged APs immediately scan their neighborhoods three times in a row and update their neighbor lists to the AP controller (Zyxel Device).
Auto Healing Interval
Set the time interval (in minutes) at which the managed APs scan their neighborhoods and report the status of neighbor APs to the AP controller (Zyxel Device).
An AP is considered “failed” if the AP controller obtains the same scan result that the AP is missing from the neighbor list of other APs three times.
Power Threshold
Set the power level (in dBm) to which the neighbor APs of the failed AP increase their output power in order to extend their wireless service coverage areas.
When the failed AP is working again, its neighbor APs return their output power to the original level.
Apply
Reset
RTLS Overview
Ekahau RTLS (Real Time Location Service) tracks battery-powered Wi-Fi tags attached to APs managed by the Zyxel Device to create maps, alerts, and reports.
The Ekahau RTLS Controller is the centerpiece of the RTLS system. This server software runs on a Windows computer to track and locate Ekahau tags from Wi-Fi signal strength measurements. Use the Zyxel Device with the Ekahau RTLS system to take signal strength measurements at the APs (Integrated Approach / Blink Mode).
Before You Begin
You need:
At least three APs managed by the Zyxel Device (the more APs the better since it increases the amount of information the Ekahau RTLS Controller has for calculating the location of the tags)
IP addresses for the Ekahau Wi-Fi tags
A dedicated RTLS SSID is recommended
Ekahau RTLS Controller in blink mode with TZSP Updater enabled
Security policies to allow RTLS traffic if the Zyxel Device security policy control is enabled or the Ekahau RTLS Controller is behind a firewall.
For example, if the Ekahau RTLS Controller is behind a firewall, open ports 8550, 8553, and 8569 to allow traffic the APs send to reach the Ekahau RTLS Controller.
The following table lists default port numbers and types of packets RTLS uses.
RTLS Traffic Port Numbers
Port Number
Type
Description
8548
TCP
Ekahau T201 location update.
8549
UDP
8550
TCP
Ekahau T201 tag maintenance protocol and Ekahau RTLS Controller user interface.
8552
UDP
Ekahau Location Protocol
8553
UDP
Ekahau Maintenance Protocol
8554
UDP
Ekahau T301 firmware update.
8560
TCP
Ekahau Vision web interface
8562
UDP
Ekahau T301W firmware update.
8569
UDP
Ekahau TZSP Listener Port
Configuring RTLS
Use this screen to turn RTLS (Real Time Location System) on or off and specify the IP address and server port of the Ekahau RTLS Controller.
Configuration > Wireless > RTLS
Label
Description
Enable
Select this to use Wi-Fi to track the location of Ekahau Wi-Fi tags.
IP Address
Specify the IP address of the Ekahau RTLS Controller.
Server Port
Specify the server port number of the Ekahau RTLS Controller.
Apply
Reset
