Characteristics | Ethernet | Ethernet | PPP | CELLULAR | VLAN | Bridge | Virtual |
Name* | wan1, wan2 | lan1, lan2, dmz | pppx | cellularx | vlanx | brx | ** |
Configurable Zone | No | No | Yes | Yes | Yes | Yes | No |
IP Address Assignment | |||||||
Static IP address | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
DHCP client | Yes | No | Yes | Yes | Yes | Yes | No |
Routing metric | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Interface Parameters | |||||||
Bandwidth restrictions | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Packet size (MTU) | Yes | Yes | Yes | Yes | Yes | Yes | No |
DHCP | |||||||
DHCP server | No | Yes | No | No | Yes | Yes | No |
DHCP relay | No | Yes | No | No | Yes | Yes | No |
Connectivity Check | Yes | No | Yes | Yes | Yes | Yes | No |
Interface | Required Port / Interface |
Ethernet interface | physical port |
VLAN interface | Ethernet interface |
bridge interface | Ethernet interface* VLAN interface* |
PPP interface | Ethernet interface* VLAN interface* bridge interface WAN1, WAN2, OPT* |
virtual interface (virtual Ethernet interface) (virtual VLAN interface) (virtual bridge interface) | Ethernet interface* VLAN interface* bridge interface |
trunk | Ethernet interface Cellular interface VLAN interface bridge interface PPP interface |
1111 1110 10 | 0 | Interface ID |
10 bits | 54 bits | 64 bits |
Label | Description |
Edit | Select an entry, and click this button to configure the speed and the duplex mode of the Ethernet connection on this port. |
Name | This field displays the name of the port. |
Interface | This field displays the interface for the port. |
Type | This field displays the cable type that is used on the port. |
Settings | Select the speed and the duplex mode of the Ethernet connection on this port. Choices are Auto Negotiate, 1000Mbps-Full Duplex, 100Mbps-Full Duplex, 100Mbps-Half Duplex, 10Mbps-Full Duplex, and 10Mbps-Half Duplex. Selecting Auto Negotiate allows one port to negotiate with a peer port automatically to obtain the connection speed (of up to 1000M) and duplex mode that both ends support. When auto-negotiation is turned on, a port on the Zyxel Device negotiates with the peer automatically to determine the connection speed and duplex mode. If the peer port does not support auto-negotiation or turns off this feature, the Zyxel Device determines the connection speed by detecting the signal on the cable and using half duplex mode. When the Zyxel Device’s auto-negotiation is turned off, a port uses the pre-configured speed and duplex mode when making a connection, thus requiring you to make sure that the settings of the peer port are the same in order to connect. |
Status | This field displays the speed and the duplex mode of the Ethernet connection on the port. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Configuration / IPv6 Configuration | Use the Configuration section for IPv4 network settings. Use the IPv6 Configuration section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove a virtual interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an interface, select it and click Activate. |
Inactivate | To turn off an interface, select it and click Inactivate. |
Create Virtual Interface | To open the screen where you can create a virtual Ethernet interface, select an Ethernet interface and click Create Virtual Interface. |
References | Select an entry and click References to open a screen that shows which settings use the entry. |
# | This field is a sequential value, and it is not associated with any interface. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Name | This field displays the name of the interface. |
Description | This field displays the description of the interface. |
IP Address | This field displays the current IP address of the interface. If the IP address is 0.0.0.0 (on the IPv4 network) or :: (on the IPv6 network), the interface does not have an IP address yet. On the IPv4 network, this screen also shows whether the IP address is a static IP address (STATIC) or dynamically assigned (DHCP). IP addresses are always static in virtual interfaces. On the IPv6 network, this screen also shows whether the IP address is a static IP address (STATIC), link-local IP address (LINK LOCAL), dynamically assigned (DHCP), or an IPv6 StateLess Address AutoConfiguration IP address (SLAAC). |
Mask | This field displays the interface’s subnet mask in dot decimal notation. |
IPv4/IPv6 View / IPv4 View / IPv6 View | Use this button to display both IPv4 and IPv6, IPv4-only, or IPv6-only configuration fields. |
Show Advanced Settings / Hide Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
Create New Object | Click this button to create a DHCPv6 lease or DHCPv6 request object that you may use for the DHCPv6 settings in this screen. |
General Settings | |
Enable Interface | Select this to enable this interface. Clear this to disable this interface. |
General IPv6 Setting | |
Enable IPv6 | Select this to enable IPv6 on this interface. Otherwise, clear this to disable it. |
Interface Properties | |
Interface Type | This field is configurable for the OPT interface only. Select to which type of network you will connect this interface. When you select internal or external the rest of the screen’s options automatically adjust to correspond. The Zyxel Device automatically adds default route and SNAT settings for traffic it routes from internal interfaces to external interfaces; for example LAN to WAN traffic. internal is for connecting to a local network. Other corresponding configuration options: DHCP server and DHCP relay. The Zyxel Device automatically adds default SNAT settings for traffic flowing from this interface to an external interface. external is for connecting to an external network (like the Internet). The Zyxel Device automatically adds this interface to the default WAN trunk. For general, the rest of the screen’s options do not automatically adjust and you must manually configure a policy route to add routing and SNAT settings for the interface. |
Interface Name | Specify a name for the interface. It can use alphanumeric characters, hyphens, and underscores, and it can be up to 11 characters long. |
Port | This is the name of the Ethernet interface’s physical port. |
Zone | Select the zone to which this interface is to belong. You use zones to apply security settings such as security policy, IDP, remote management, anti-malware, and application patrol. Make sure to select the correct zone as otherwise traffic may be blocked by a security policy. |
MAC Address | This field is read-only. This is the MAC address that the Ethernet interface uses. |
Description | Enter a description of this interface. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. Spaces are allowed, but the string can’t start with a space. |
IP Address Assignment | These IP address fields configure an IPv4 IP address on the interface itself. If you change this IP address on the interface, you may also need to change a related address object for the network connected to the interface. For example, if you use this screen to change the IP address of your LAN interface, you should also change the corresponding LAN subnet address object. |
Get Automatically | This option appears when Interface Type is external or general. Select this to make the interface a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server. You should not select this if the interface is assigned to a VRRP group. |
DHCP Option 60 | DHCP Option 60 is used by the Zyxel Device for identification to the DHCP server using the VCI (Vendor Class Identifier) on the DHCP server. The Zyxel Device adds it in the initial DHCP discovery message that a DHCP client broadcasts in search of an IP address. The DHCP server can assign different IP addresses or options to clients with the specific VCI or reject the request from clients without the specific VCI. Type a string using up to 63 of these characters [a-zA-Z0-9!\"#$%&\'()*+,-./:;<=>?@\[\\\]^_`{}] to identify this Zyxel Device to the DHCP server. For example, Zyxel-TW. |
Use Fixed IP Address | This option appears when Interface Type is external or general. Select this if you want to specify the IP address, subnet mask, and gateway manually. |
IP Address | Enter the IP address for this interface. |
Subnet Mask | Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network. |
Gateway | This option appears when Interface Type is external or general. Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface. |
Metric | This option appears when Interface Type is external or general. Enter the priority of the gateway (if any) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first. |
Enable IGMP Support | Select this to allow the Zyxel Device to act as an IGMP proxy for hosts connected on the IGMP downstream interface. |
IGMP Upstream | Enable IGMP Upstream on the interface which connects to a router running IGMP that is closer to the multicast server. |
IGMP Downstream | Enable IGMP Downstream on the interface which connects to the multicast hosts. |
IPv6 Address Assignment | These IP address fields configure an IPv6 IP address on the interface itself. |
Enable Stateless Address Auto-configuration (SLAAC) | Select this to enable IPv6 stateless auto-configuration on this interface. The interface will generate an IPv6 IP address itself from a prefix obtained from an IPv6 router on the network. |
Link-Local Address | This displays the IPv6 link-local address and the network prefix that the Zyxel Device generates itself for the interface. |
IPv6 Address/Prefix Length | Enter the IPv6 address and the prefix length for this interface if you want to use a static IP address. This field is optional. The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address. |
Gateway | Enter the IPv6 address of the default outgoing gateway using colon (:) hexadecimal notation. |
Metric | Enter the priority of the gateway (if any) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first. |
Address from DHCPv6 Prefix Delegation | Use this table to have the Zyxel Device obtain an IPv6 prefix from the ISP or a connected uplink router for an internal network, such as the LAN or DMZ. You have to also enter a suffix address which is appended to the delegated prefix to form an address for this interface. To use prefix delegation, you must: • Create at least one DHCPv6 request object before configuring this table. • The external interface must be a DHCPv6 client. You must configure the DHCPv6 request options using a DHCPv6 request object with the type of prefix-delegation. • Assign the prefix delegation to an internal interface and enable router advertisement on that interface. |
Add | Click this to create an entry. |
Edit | Select an entry and click this to change the settings. |
Remove | Select an entry and click this to delete it from this table. |
References | Select an entry and click References to check which settings use the entry. |
# | This field is a sequential value, and it is not associated with any entry. |
Delegated Prefix | Select the DHCPv6 request object to use from the drop-down list. |
Suffix Address | Enter the ending part of the IPv6 address, a slash (/), and the prefix length. The Zyxel Device will append it to the delegated prefix. For example, you got a delegated prefix of 2003:1234:5678/48. You want to configure an IP address of 2003:1234:5678:1111::1/128 for this interface, then enter ::1111:0:0:0:1/128 in this field. |
Address | This field displays the combined IPv6 IP address for this interface. ![]() |
DHCPv6 Setting | |
DHCPv6 | Select N/A to not use DHCPv6. Select Client to set this interface to act as a DHCPv6 client. Select Server to set this interface to act as a DHCPv6 server which assigns IP addresses and provides subnet mask, gateway, and DNS server information to clients. Select Relay to set this interface to route DHCPv6 requests to the DHCPv6 relay server you specify. The DHCPv6 server(s) may be on another network. |
DUID | This field displays the DHCP Unique IDentifier (DUID) of the interface, which is unique and used for identification purposes when the interface is exchanging DHCPv6 messages with others. |
DUID as MAC | Select this if you want the DUID is generated from the interface’s default MAC address. |
Customized DUID | If you want to use a customized DUID, enter it here for the interface. |
Enable Rapid Commit | Select this to shorten the DHCPv6 message exchange process from four to two steps. This function helps reduce heavy network traffic load. ![]() |
Information Refresh Time | Enter the number of seconds a DHCPv6 client should wait before refreshing information retrieved from DHCPv6. |
Request Address | This field is available if you set this interface to DHCPv6 Client. Select this to get an IPv6 IP address for this interface from the DHCP server. Clear this to not get any IP address information through DHCPv6. |
DHCPv6 Request Options / DHCPv6 Lease Options | If this interface is a DHCPv6 client, use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server. If the interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what additional information to offer to the DHCPv6 clients. |
Add | Click this to create an entry in this table. See Add/Edit DHCPv6 Request/Release Options for more information. |
Name | This field displays the name of the DHCPv6 request or lease object. |
Type | This field displays the type of the object. |
Value | This field displays the IPv6 prefix that the Zyxel Device obtained from an uplink router (Server is selected) or will advertise to its clients (Client is selected). |
Interface | When Relay is selected, select this check box and an interface from the drop-down list if you want to use it as the relay server. |
Relay Server | When Relay is selected, select this check box and enter the IP address of a DHCPv6 server as the relay server. |
IPv6 Router Advertisement Setting | |
Enable Router Advertisement | Select this to enable this interface to send router advertisement messages periodically. |
Advertised Hosts Get Network Configuration From DHCPv6 | Select this to have the Zyxel Device indicate to hosts to obtain network settings (such as prefix and DNS settings) through DHCPv6. Clear this to have the Zyxel Device indicate to hosts that DHCPv6 is not available and they should use the prefix in the router advertisement message. |
Advertised Hosts Get Other Configuration From DHCPv6 | Select this to have the Zyxel Device indicate to hosts to obtain DNS information through DHCPv6. Clear this to have the Zyxel Device indicate to hosts that DNS information is not available in this network. |
Router Preference | Select the router preference (Low, Medium or High) for the interface. The interface sends this preference in the router advertisements to tell hosts what preference they should use for the Zyxel Device. This helps hosts to choose their default router especially when there are multiple IPv6 router on the network. ![]() |
MTU | The Maximum Transmission Unit. Type the maximum size of each IPv6 data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device discards the packet and sends an error message to the sender to inform this. |
Hop Limit | Enter the maximum number of network segments that a packet can cross before reaching the destination. When forwarding an IPv6 packet, IPv6 routers are required to decrease the Hop Limit by 1 and to discard the IPv6 packet when the Hop Limit is 0. |
Advertised Prefix Table | Configure this table only if you want the Zyxel Device to advertise a fixed prefix to the network. |
Add | Click this to create an IPv6 prefix address. |
Edit | Select an entry in this table and click this to modify it. |
Remove | Select an entry in this table and click this to delete it. |
IPv6 Address/ Prefix Length | Enter the IPv6 network prefix address and the prefix length. The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address. |
Advertised Prefix from DHCPv6 Prefix Delegation | This table is available when the Interface Type is internal. Use this table to configure the network prefix if you want to use a delegated prefix as the beginning part of the network prefix. |
Add | Click this to create an entry in this table. |
Delegated Prefix | Select the DHCPv6 request object to use for generating the network prefix for the network. |
Suffix Address | Enter the ending part of the IPv6 network address plus a slash (/) and the prefix length. The Zyxel Device will append it to the selected delegated prefix. The combined address is the network prefix for the network. For example, you got a delegated prefix of 2003:1234:5678/48. You want to divide it into 2003:1234:5678:1111/64 for this interface and 2003:1234:5678:2222/64 for another interface. You can use ::1111/64 and ::2222/64 for the suffix address respectively. But if you do not want to divide the delegated prefix into subnetworks, enter ::0/48 here, which keeps the same prefix length (/48) as the delegated prefix. |
Address | This is the final network prefix combined by the delegated prefix and the suffix. ![]() |
Egress Bandwidth | Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can send through the interface to the network. Allowed values are 0 - 1048576. |
Ingress Bandwidth | This is reserved for future use. Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can receive from the network through the interface. Allowed values are 0 - 1048576. |
MTU | Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1500. Usually, this value is 1500. |
Connectivity Check | These fields appear when Interface Properties is External or General. The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check. |
Enable Connectivity Check | Select this to turn on the connection check. |
Check Method | Select the method that the gateway allows. Select icmp to have the Zyxel Device regularly ping the gateway you specify to make sure it is still available. Select tcp to have the Zyxel Device regularly perform a TCP handshake with the gateway you specify to make sure it is still available. |
Check Period | Enter the number of seconds between connection check attempts. |
Check Timeout | Enter the number of seconds to wait for a response before the attempt is a failure. |
Check Fail Tolerance | Enter the number of consecutive failures before the Zyxel Device stops routing through the gateway. |
Check Default Gateway | Select this to use the default gateway for the connectivity check. |
Check this address | Select this to specify a domain name or IP address for the connectivity check. Enter that domain name or IP address on the field next to it. |
Check Port | This field only displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check. |
Check these addresses | Type one or two domain names or IP addresses for the connectivity check. |
Probe Succeeds When | This field applies when you specify two domain names or IP addresses for the connectivity check. Select any one if you want the check to pass if at least one of the domain names or IP addresses responds. Select all if you want the check to pass only if both domain names or IP addresses respond. |
DHCP Setting | This section appears when Interface Type is internal or general. |
DHCP | Select what type of DHCP service the Zyxel Device provides to the network. Choices are: None - the Zyxel Device does not provide any DHCP services. There is already a DHCP server on the network. DHCP Relay - the Zyxel Device routes DHCP requests to one or more DHCP servers you specify. The DHCP server(s) may be on another network. DHCP Server - the Zyxel Device assigns IP addresses and provides subnet mask, gateway, and DNS server information to the network. The Zyxel Device is the DHCP server for the network. |
These fields appear if the Zyxel Device is a DHCP Relay. | |
Relay Server 1 | Enter the IP address of a DHCP server for the network. |
Relay Server 2 | This field is optional. Enter the IP address of another DHCP server for the network. |
These fields appear if the Zyxel Device is a DHCP Server. | |
IP Pool Start Address | Enter the IP address from which the Zyxel Device begins allocating IP addresses. If you want to assign a static IP address to a specific computer, use the Static DHCP Table. If this field is blank, the Pool Size must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address. |
Pool Size | Enter the number of IP addresses to allocate. This number must be at least one and is limited by the interface’s Subnet Mask. For example, if the Subnet Mask is 255.255.255.0 and IP Pool Start Address is 10.10.10.10, the Zyxel Device can allocate 10.10.10.10 to 10.10.10.254, or 245 IP addresses. If this field is blank, the IP Pool Start Address must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address. |
First DNS Server, Second DNS Server, Third DNS Server | Specify the IP addresses up to three DNS servers for the DHCP clients to use. Use one of the following ways to specify these IP addresses. Custom Defined - enter a static IP address. From ISP - select the DNS server that another interface received from its DHCP server. Zyxel Device - the DHCP clients use the IP address of this interface and the Zyxel Device works as a DNS relay. |
First WINS Server, Second WINS Server | Type the IP address of the WINS (Windows Internet Naming Service) server that you want to send to the DHCP clients. The WINS server keeps a mapping table of the computer names on your network and the IP addresses that they are currently using. |
Default Router | If you set this interface to DHCP Server, you can select to use either the interface’s IP address or another IP address as the default router. This default router will become the DHCP clients’ default gateway. To use another IP address as the default router, select Custom Defined and enter the IP address. |
Lease time | Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are: infinite - select this if IP addresses never expire. days, hours, and minutes - select this to enter how long IP addresses are valid. |
Extended Options | This table is available if you selected DHCP server. Configure this table if you want to send more information to DHCP clients through DHCP packets. |
Add | Click this to create an entry in this table. See Add/Edit DHCP Extended Options. |
Name | This is the name of the DHCP option. |
Code | This is the code number of the DHCP option. |
Type | This is the type of the set value for the DHCP option. |
Value | This is the value set for the DHCP option. |
PXE Server | PXE (Preboot eXecution Environment) allows a client computer to use the network to boot up and install an operating system via a PXE-capable Network Interface Card (NIC). PXE is available for computers on internal interfaces to allow them to boot up using boot software on a PXE server. The Zyxel Device acts as an intermediary between the PXE server and the computers that need boot software. The PXE server must have a public IPv4 address. You must enable DHCP Server on the Zyxel Device so that it can receive information from the PXE server. |
PXE Boot Loader File | A boot loader is a computer program that loads the operating system for the computer. Type the exact file name of the boot loader software file, including filename extension, that is on the PXE server. If the wrong filename is typed, then the client computers cannot boot. |
Enable IP/MAC Binding | Select this option to have this interface enforce links between specific IP addresses and specific MAC addresses. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses. |
Enable Logs for IP/MAC Binding Violation | Select this option to have the Zyxel Device generate a log if a device connected to this interface attempts to use an IP address that is bound to another device’s MAC address. |
Static DHCP Table | Configure a list of static IP addresses the Zyxel Device assigns to computers connected to the interface. Otherwise, the Zyxel Device assigns an IP address dynamically using the interface’s IP Pool Start Address and Pool Size. |
Add | Click this to create a new entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
# | This field is a sequential value, and it is not associated with a specific entry. |
IP Address | Enter the IP address to assign to a device with this entry’s MAC address. |
MAC | Enter the MAC address to which to assign this entry’s IP address. |
Description | Enter a description to help identify this static DHCP entry. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
RIP Setting | |
Enable RIP | Select this to enable RIP in this interface. |
Direction | This field is effective when RIP is enabled. Select the RIP direction from the drop-down list box. BiDir - This interface sends and receives routing information. In-Only - This interface receives routing information. Out-Only - This interface sends routing information. |
Send Version | This field is effective when RIP is enabled. Select the RIP version(s) used for sending RIP packets. Choices are 1, 2, and 1 and 2. |
Receive Version | This field is effective when RIP is enabled. Select the RIP version(s) used for receiving RIP packets. Choices are 1, 2, and 1 and 2. |
V2-Broadcast | This field is effective when RIP is enabled. Select this to send RIP-2 packets using subnet broadcasting; otherwise, the Zyxel Device uses multicasting. |
OSPF Setting | |
Area | Select the area in which this interface belongs. Select None to disable OSPF in this interface. |
Priority | Enter the priority (between 0 and 255) of this interface when the area is looking for a Designated Router (DR) or Backup Designated Router (BDR). The highest-priority interface identifies the DR, and the second-highest-priority interface identifies the BDR. Set the priority to zero if the interface can not be the DR or BDR. |
Link Cost | Enter the cost (between 1 and 65,535) to route packets through this interface. |
Passive Interface | Select this to stop forwarding OSPF routing information from the selected interface. As a result, this interface only receives routing information. |
Authentication | Select an authentication method, or disable authentication. To exchange OSPF routing information with peer border routers, you must use the same authentication method that they use. Choices are: Same-as-Area - use the default authentication method in the area None - disable authentication Text - authenticate OSPF routing information using a plain-text password MD5 - authenticate OSPF routing information using MD5 encryption |
Text Authentication Key | This field is available if the Authentication is Text. Type the password for text authentication. The key can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long. |
MD5 Authentication ID | This field is available if the Authentication is MD5. Type the ID for MD5 authentication. The ID can be between 1 and 255. |
MD5 Authentication Key | This field is available if the Authentication is MD5. Type the password for MD5 authentication. The password can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long. |
MAC Address Setting | This section appears when Interface Properties is External or General. Have the interface use either the factory assigned default MAC address, a manually specified MAC address, or clone the MAC address of another device or computer. |
Use Default MAC Address | Select this option to have the interface use the factory assigned default MAC address. By default, the Zyxel Device uses the factory assigned MAC address to identify itself. |
Overwrite Default MAC Address | Select this option to have the interface use a different MAC address. Either enter the MAC address in the fields or click Clone by host and enter the IP address of the device or computer whose MAC you are cloning. Once it is successfully configured, the address will be copied to the configuration file. It will not change unless you change the setting or upload a different configuration file. |
Proxy ARP | Proxy ARP is available for external or general interfaces on the Zyxel Device. See Proxy ARP for more information on Proxy ARP. |
Enable Proxy ARP | Select this to allow the Zyxel Device to answer external interface ARP requests on behalf of a device on its internal interface. Interfaces supported are: • Ethernet • VLAN • Bridge See Proxy ARP for more information. |
Add | Click Add to create an IPv4 Address, an IPv4 CIDR (for example, 192.168.1.1/24) or an IPv4 Range (for example, 192.168.1.2-192.168.1.100) as the target IP address. The Zyxel Device answers external ARP requests only if they match one of these inputted target IP addresses. For example, if the IPv4 Address is 192.168.1.5, then the Zyxel Device will answer ARP requests coming from the WAN only if it contains 192.168.1.5 as the target IP address. Select an existing entry and click Remove to delete that entry. |
Related Setting | |
Configure PPPoE/PPTP | Click PPPoE/PPTP if this interface’s Internet connection uses PPPoE or PPTP or L2TP. |
Configure VLAN | Click VLAN if you want to configure a VLAN interface for this Ethernet interface. |
Configure WAN TRUNK | Click WAN TRUNK to go to a screen where you can set this interface to be part of a WAN trunk for load balancing. |
Configure Policy Route | Click Policy Route to go to the policy route summary screen where you can manually associate traffic with this interface. You must manually configure a policy route to add routing and SNAT settings for an interface with the Interface Type set to general. You can also configure a policy route to override the default routing and SNAT behavior for an interface with an Interface Type of internal or external. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
Interface Name | This identifies the interface for which the configuration settings that use it are displayed. |
Address Type | Choose IPv4 Address, or IPv4 CIDR (for example, 192.168.1.1/24) or an IPv4 Range (for example, 192.168.1.2-192.168.1.100) and then enter the target IP address information. The Zyxel Device answers external ARP requests only if they match one of these inputted target IP addresses. For example, if the IPv4 Address is 192.168.1.5, then the Zyxel Device will answer ARP requests coming from the WAN only if it contains 192.168.1.5 as the target IP address. |
Interface Name | This field is read-only. It displays the name of the virtual interface, which is automatically derived from the underlying Ethernet interface, VLAN interface, or bridge interface. |
Description | Enter a description of this interface. It is not used elsewhere. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
Gateway | Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface. |
Name | This identifies the object for which the configuration settings that use it are displayed. Click the object’s name to display the object’s configuration screen in the main window. |
Service | This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window. |
Priority | If it is applicable, this field lists the referencing configuration item’s position in its list, otherwise N/A displays. |
Name | This field identifies the configuration item that references the object. |
Description | If the referencing configuration item has a description configured, it displays here. |
Refresh | Click this to update the information in this screen. |
Cancel | Click Cancel to close the screen. |
Option | Select which DHCP option that you want to add in the DHCP packets sent through the interface. See the next table for more information. |
Name | This field displays the name of the selected DHCP option. If you selected User Defined in the Option field, enter a descriptive name to identify the DHCP option. You can enter up to 16 characters (“a-z”, “A-Z, “0-9”, “-”, and “_”) with no spaces allowed. The first character must be alphabetical (a-z, A-Z). |
Code | This field displays the code number of the selected DHCP option. If you selected User Defined in the Option field, enter a number for the option. This field is mandatory. |
Type | This is the type of the selected DHCP option. If you selected User Defined in the Option field, select an appropriate type for the value that you will enter in the next field. Only advanced users should configure User Defined. Misconfiguration could result in interface lockout. |
Value | Enter the value for the selected DHCP option. For example, if you selected TFTP Server Name (66) and the type is TEXT, enter the DNS domain name of a TFTP server here. This field is mandatory. |
First IP Address, Second IP Address, Third IP Address | If you selected Time Server (4), NTP Server (41), SIP Server (120), CAPWAP AC (138), or TFTP Server (150), you have to enter at least one IP address of the corresponding servers in these fields. The servers should be listed in order of your preference. |
First Enterprise ID, Second Enterprise ID | If you selected VIVC (124) or VIVS (125), you have to enter at least one vendor’s 32-bit enterprise number in these fields. An enterprise number is a unique number that identifies a company. |
First Class, Second Class | If you selected VIVC (124), enter the details of the hardware configuration of the host on which the client is running, or of industry consortium compliance. |
First Information, Second Information | If you selected VIVS (125), enter additional information for the corresponding enterprise number in these fields. |
OK | Click this to close this screen and update the settings to the previous Edit screen. |
Option Name | Code | Description |
Time Offset | 2 | This option specifies the offset of the client's subnet in seconds from Coordinated Universal Time (UTC). |
Time Server | 4 | This option specifies a list of Time servers available to the client. |
NTP Server | 42 | This option specifies a list of the NTP servers available to the client by IP address. |
TFTP Server Name | 66 | This option is used to identify a TFTP server when the “sname” field in the DHCP header has been used for DHCP options. The minimum length of the value is 1. |
Bootfile | 67 | This option is used to identify a bootfile when the “file” field in the DHCP header has been used for DHCP options. The minimum length of the value is 1. |
SIP Server | 120 | This option carries either an IPv4 address or a DNS domain name to be used by the SIP client to locate a SIP server. |
VIVC | 124 | Vendor-Identifying Vendor Class option A DHCP client may use this option to unambiguously identify the vendor that manufactured the hardware on which the client is running, the software in use, or an industry consortium to which the vendor belongs. |
VIVS | 125 | Vendor-Identifying Vendor-Specific option DHCP clients and servers may use this option to exchange vendor-specific information. |
CAPWAP AC | 138 | CAPWAP Access Controller addresses option The Control And Provisioning of Wireless Access Points Protocol allows a Wireless Termination Point (WTP) to use DHCP to discover the Access Controllers to which it is to connect. This option carries a list of IPv4 addresses indicating one or more CAPWAP ACs available to the WTP. |
TFTP Server | 150 | The option contains one or more IPv4 addresses that the client may use. The current use of this option is for downloading configuration from a VoIP server via TFTP; however, the option may be used for purposes other than contacting a VoIP configuration server. |
User Configuration / System Default | The Zyxel Device comes with the (non-removable) System Default PPP interfaces pre-configured. You can create (and delete) User Configuration PPP interfaces. System Default PPP interfaces vary by model. |
Add | Click this to create a new user-configured PPP interface. |
Remove | To remove a user-configured PPP interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Connect | To connect an interface, select it and click Connect. You might use this in testing the interface or to manually establish the connection for a Dial-on-Demand PPPoE/PPTP interface. |
Disconnect | To disconnect an interface, select it and click Disconnect. You might use this in testing the interface. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. The connect icon is lit when the interface is connected and dimmed when it is disconnected. |
Base Interface | This field displays the interface on the top of which the PPPoE/PPTP/L2TP interface is. |
Account Profile | This field displays the ISP account used by this PPPoE/PPTP interface. |
Create New Object | Click this button to create an ISP Account or a DHCPv6 request object that you may use for the ISP or DHCPv6 settings in this screen. |
Base Interface | Select the interface upon which this PPP interface is built. ![]() |
Zone | Select the zone to which this PPP interface belongs. The zone determines the security settings the Zyxel Device uses for the interface. |
Connectivity | |
Nailed-Up | Select this if the PPPoE/PPTP/L2TP connection should always be up. Clear this to have the Zyxel Device establish the PPPoE/PPTP/L2TP connection only when there is traffic. You might use this option if a lot of traffic needs to go through the interface or it does not cost extra to keep the connection up all the time. |
Dial-on-Demand | Select this to have the Zyxel Device establish the PPPoE/PPTP/L2TP connection only when there is traffic. You might use this option if there is little traffic through the interface or if it costs money to keep the connection available. |
ISP Setting | |
Account Profile | Select the ISP account that this PPPoE/PPTP/L2TP interface uses. The drop-down box lists ISP accounts by name. Use Create new Object if you need to configure a new ISP account. |
Protocol | This field is read-only. It displays the protocol specified in the ISP account. |
User Name | This field is read-only. It displays the user name for the ISP account. |
Service Name | This field is read-only. It displays the PPPoE service name specified in the ISP account. This field is blank if the ISP account uses PPTP. |
IP Address Assignment | Click Show Advanced Settings to display more settings. Click Hide Advanced Settings to display fewer settings. |
Get Automatically | Select this if this interface is a DHCP client. In this case, the DHCP server configures the IP address automatically. The subnet mask and gateway are always defined automatically in PPPoE/PPTP/L2TP interfaces. |
Use Fixed IP Address | Select this if you want to specify the IP address manually. |
IP Address | This field is enabled if you select Use Fixed IP Address. Enter the IP address for this interface. |
Gateway | This field is enabled if you select Use Fixed IP Address. Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface. |
Metric | Enter the priority of the gateway (the ISP) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first. |
DHCPv6 Setting | |
DHCPv6 | Select Client to obtain an IP address and DNS information from the service provider for the interface. Otherwise, select N/A to disable the function. |
Request Address | Select this to get an IPv6 IP address for this interface from the DHCP server. Clear this to not get any IP address information through DHCPv6. |
DHCPv6 Request Options | Use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server. |
Name | This field displays the name of the DHCPv6 request object. |
Value | This field displays the IPv6 prefix that the Zyxel Device will advertise to its clients. |
MTU | Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1492. Usually, this value is 1492. |
Connectivity Check | The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check. |
Check this address | Select this to specify a domain name or IP address for the connectivity check. Enter that domain name or IP address in the field next to it. |
Related Setting | |
Configure WAN TRUNK | Click WAN TRUNK to go to a screen where you can configure the interface as part of a WAN trunk for load balancing. |
Policy Route | Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this interface. |
Add | Click this to create a new cellular interface. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Connect | To connect an interface, select it and click Connect. You might use this in testing the interface or to manually establish the connection. |
Extension Slot | This field displays where the entry’s cellular card is located. |
Connected Device | This field displays the name of the cellular card. |
ISP Settings | This field displays the profile of ISP settings that this cellular interface is set to use. |
Mobile Broadband Dongle Support | You should have registered your Zyxel Device at myZyxel. myZyxel hosts a list of supported mobile broadband dongle devices. You should have an Internet connection to access this website. |
Latest Version | This displays the latest supported mobile broadband dongle list version number. |
Current Version | This displays the currently supported (by the Zyxel Device) mobile broadband dongle list version number. |
Update Now | If the latest version number is greater than the current version number, then click this button to download the latest list of supported mobile broadband dongle devices to the Zyxel Device. |
Enable Interface | Select this option to turn on this interface. |
Interface Name | Select a name for the interface. |
Zone | Select the zone to which you want the cellular interface to belong. The zone determines the security settings the Zyxel Device uses for the interface. |
Extension Slot | This is the USB slot that you are configuring for use with a mobile broadband card. |
Connected Device | This displays the manufacturer and model name of your mobile broadband card if you inserted one in the Zyxel Device. Otherwise, it displays none. |
Connectivity | |
Nailed-Up | Select this if the connection should always be up. Clear this to have the Zyxel Device to establish the connection only when there is traffic. You might not nail up the connection if there is little traffic through the interface or if it costs money to keep the connection available. |
Idle timeout | This value specifies the time in seconds (0~360) that elapses before the Zyxel Device automatically disconnects from the ISP’s server. Zero disables the idle timeout. |
ISP Settings | |
Profile Selection | Select Device to use one of the mobile broadband device’s profiles of device settings. Then select the profile (use Profile 1 unless your ISP instructed you to do otherwise). Select Custom to configure your device settings yourself. |
APN | This field is read-only if you selected Device in the profile selection. Select Custom in the profile selection to be able to manually input the APN (Access Point Name) provided by your service provider. This field applies with a GSM or HSDPA mobile broadband card. Enter the APN from your service provider. Connections with different APNs may provide different services (such as Internet access or MMS (Multi-Media Messaging Service)) and charge method. You can enter up to 63 ASCII printable characters. Spaces are allowed. |
Dial String | Enter the dial string if your ISP provides a string, which would include the APN, to initialize the mobile broadband card. You can enter up to 63 ASCII printable characters. Spaces are allowed. This field is available only when you insert a GSM mobile broadband card. |
Authentication Type | The Zyxel Device supports PAP (Password Authentication Protocol) and CHAP (Challenge Handshake Authentication Protocol). CHAP is more secure than PAP; however, PAP is readily available on more platforms. Use the drop-down list box to select an authentication protocol for outgoing calls. Options are: None: No authentication for outgoing calls. CHAP - Your Zyxel Device accepts CHAP requests only. PAP - Your Zyxel Device accepts PAP requests only. |
User Name | This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection. If this field is configurable, enter the user name for this mobile broadband card exactly as the service provider gave it to you. You can use 1 ~ 64 alphanumeric and #:%-_@$./ characters. The first character must be alphanumeric or -_@$./. Spaces are not allowed. |
Password | This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection and the password is included in the mobile broadband card’s profile. If this field is configurable, enter the password for this SIM card exactly as the service provider gave it to you. You can use 0 ~ 63 alphanumeric and `~!@#$%^&*()_-+={}|;:'<,>./ characters. Spaces are not allowed. |
Retype to Confirm | This field displays when you select an authentication type other than None. This field is read-only if you selected Device in the profile selection and the password is included in the mobile broadband card’s profile. If this field is configurable, re-enter the password for this SIM card exactly as the service provider gave it to you. |
SIM Card Setting | |
PIN Code | This field displays with a GSM or HSDPA mobile broadband card. A PIN (Personal Identification Number) code is a key to a mobile broadband card. Without the PIN code, you cannot use the mobile broadband card. Enter the 4-digit PIN code (0000 for example) provided by your ISP. If you enter the PIN code incorrectly, the mobile broadband card may be blocked by your ISP and you cannot use the account to access the Internet. If your ISP disabled PIN code authentication, enter an arbitrary number. |
Retype to Confirm | Type the PIN code again to confirm it. |
Egress Bandwidth | Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can send through the interface to the network. Allowed values are 0 - 1048576. This setting is used in WAN load balancing and bandwidth management. |
Related Setting | |
Configure Policy Route | Click Policy Route to go to the policy route summary screen where you can configure a policy route to override the default routing and SNAT behavior for the interface. |
Get Automatically | Select this option If your ISP did not assign you a fixed IP address. This is the default selection. |
Use Fixed IP Address | Select this option If the ISP assigned a fixed IP address. |
IP Address Assignment | Enter the cellular interface’s WAN IP address in this field if you selected Use Fixed IP Address. |
Device Settings | |
Band Selection | This field appears if you selected a mobile broadband device that allows you to select the type of network to use. Select the type of mobile broadband service for your mobile broadband connection. If you are unsure what to select, check with your mobile broadband service provider to find the mobile broadband service available to you in your region. Select auto to have the card connect to an available network. Choose this option if you do not know what networks are available. You may want to manually specify the type of network to use if you are charged differently for different types of network or you only have one type of network available to you. Select GPRS / EDGE (GSM) only to have this interface only use a 2.5G or 2.75G network (respectively). If you only have a GSM network available to you, you may want to select this so the Zyxel Device does not spend time looking for a WCDMA network. Select UMTS / HSDPA (WCDMA) only to have this interface only use a 3G or 3.5G network (respectively). You may want to do this if you want to make sure the interface does not use the GSM network. Select LTE only to have this interface only use a 4G LTE network. This option only appears when a dongle for 4G technology is inserted. |
Network Selection | Home network is the network to which you are originally subscribed. Select Home to have the mobile broadband device connect only to the home network. If the home network is down, the Zyxel Device’s mobile broadband Internet connection is also unavailable. Select Auto (Default) to allow the mobile broadband device to connect to a network to which you are not subscribed when necessary, for example when the home network is down or another mobile broadband base station's signal is stronger. This is recommended if you need continuous Internet connectivity. If you select this, you may be charged using the rate of a different network. |
Budget Setup | |
Enable Budget Control | Select this to set a monthly limit for the user account of the installed mobile broadband card. You can set a limit on the total traffic and/or call time. The Zyxel Device takes the actions you specified when a limit is exceeded during the month. |
Time Budget | Select this and specify the amount of time (in hours) that the mobile broadband connection can be used within one month. If you change the value after you configure and enable budget control, the Zyxel Device resets the statistics. |
Data Budget | Select this and specify how much downstream and/or upstream data (in Mega bytes) can be transmitted via the mobile broadband connection within one month. Select Download to set a limit on the downstream traffic (from the ISP to the Zyxel Device). Select Upload to set a limit on the upstream traffic (from the Zyxel Device to the ISP). Select Download/Upload to set a limit on the total traffic in both directions. If you change the value after you configure and enable budget control, the Zyxel Device resets the statistics. |
Reset time and data budget counters on | Select the date on which the Zyxel Device resets the budget every month. If the date you selected is not available in a month, such as 30th or 31st, the Zyxel Device resets the budget on the last day of the month. |
Reset time and data budget counters | This button is available only when you enable budget control in this screen. Click this button to reset the time and data budgets immediately. The count starts over with the mobile broadband connection’s full configured monthly time and data budgets. This does not affect the normal monthly budget restart; so if you configured the time and data budget counters to reset on the second day of the month and you use this button on the first, the time and data budget counters will still reset on the second. |
Actions when over budget | Specify the actions the Zyxel Device takes when the time or data limit is exceeded. |
Log | Select None to not create a log, Log to create a log, or Log-alert to create an alert log. If you select Log or Log-alert you can also select recurring every to have the Zyxel Device send a log or alert for this event periodically. Specify how often (from 1 to 65535 minutes) to send the log or alert. |
New connection | Select Allow to permit new mobile broadband connections or Disallow to drop/block new mobile broadband connections. |
Current connection | Select Keep to maintain an existing mobile broadband connection or Drop to disconnect it. You cannot set New connection to Allow and Current connection to Drop at the same time. If you set New connection to Disallow and Current connection to Keep, the Zyxel Device allows you to transmit data using the current connection, but you cannot build a new connection if the existing connection is disconnected. |
Actions when over % of time budget or % of data budget | Specify the actions the Zyxel Device takes when the specified percentage of time budget or data limit is exceeded. Enter a number from 1 to 99 in the percentage fields. If you change the value after you configure and enable budget control, the Zyxel Device resets the statistics. |
Log | Select None to not create a log when the Zyxel Device takes this action, Log to create a log, or Log-alert to create an alert log. If you select Log or Log-alert you can also select recurring every to have the Zyxel Device send a log or alert for this event periodically. Specify how often (from 1 to 65535 minutes) to send the log or alert. |
Add | Click this to create a new GRE tunnel interface. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
IP Address | This is the IP address of the interface. If the interface is active (and connected), the Zyxel Device tunnels local traffic sent to this IP address to the Remote Gateway Address. |
Tunnel Mode | This is the tunnel mode of the interface (GRE, IPv6-in-IPv4 or 6to4). This field also displays the interface’s IPv4 IP address and subnet mask if it is a GRE tunnel. Otherwise, it displays the interface’s IPv6 IP address and prefix length. |
My Address | This is the interface or IP address uses to identify itself to the remote gateway. The Zyxel Device uses this as the source for the packets it tunnels to the remote gateway. |
Remote Gateway Address | This is the IP address or domain name of the remote gateway to which this interface tunnels traffic. |
Reset | Click Reset to begin configuring this screen afresh. |
Enable | Select this to enable this interface. Clear this to disable this interface. |
Interface Name | This field is read-only if you are editing an existing tunnel interface. Enter the name of the tunnel interface. The format is tunnelx, where x is 0 - 3. For example, tunnel0. |
Zone | Use this field to select the zone to which this interface belongs. This controls what security settings the Zyxel Device applies to this interface. |
Tunnel Mode | Select the tunneling protocol of the interface (GRE, IPv6-in-IPv4 or 6to4). |
IP Address Assignment | This section is available if you are configuring a GRE tunnel. |
IPv6 Address Assignment | This section is available if you are configuring an IPv6-in-IPv4 or a 6to4 tunnel. |
6to4 Tunnel Parameter | This section is available if you are configuring a 6to4 tunnel which encapsulates IPv6 to IPv4 packets. |
6to4 Prefix | Enter the IPv6 prefix of a destination network. The Zyxel Device forwards IPv6 packets to the hosts on the matched network. If you enter a prefix starting with 2002, the Zyxel Device will forward the matched packets to the IPv4 IP address converted from the packets’ destination address. The IPv4 IP address can be converted from the next 32 bits after the prefix you specified in this field. The Zyxel Device forwards the unmatched packets to the specified Relay Router. |
Relay Router | Enter the IPv4 address of a 6to4 relay router which helps forward packets between 6to4 networks and native IPv6 networks. |
Remote Gateway Prefix | Enter the IPv4 network address and network bits of a remote 6to4 gateway, for example, 14.15.0.0/16. This field works if you enter a 6to4 Prefix not starting with 2002 (2003 for example). The Zyxel Device forwards the matched packets to a remote gateway with the network address you specify here, and the bits converted after the 6to4 Prefix in the packets. For example, you configure the 6to4 prefix to 2003:A0B::/32 and the remote gateway prefix to 14.15.0.0/16. If a packet’s destination is 2003:A0B:1011:5::8, the Zyxel Device forwards the packet to 14.15.16.17, where the network address is 14.15.0.0 and the host address is the remain bits converted from 1011 after the packet’s 6to4 prefix (2003:A0B). |
Gateway Settings | |
My Address | Specify the interface or IP address to use as the source address for the packets this interface tunnels to the remote gateway. The remote gateway sends traffic to this interface or IP address. |
Remote Gateway Address | Enter the IP address or domain name of the remote gateway to which this interface tunnels traffic. Automatic displays in this field if you are configuring a 6to4 tunnel. It means the 6to4 tunnel will help forward packets to the corresponding remote gateway automatically by looking at the packet’s destination address. |
Connectivity Check | This section is available if you are configuring a GRE tunnel. The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check. |
Check Port | This field displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check. |
Related Setting | |
WAN TRUNK | Click this link to go to a screen where you can configure WAN trunk load balancing. |
Policy Route | Click this link to go to the screen where you can manually configure a policy route to associate traffic with this interface. |
Create Virtual Interface | To open the screen where you can create a virtual interface, select an interface and click Create Virtual Interface. |
Port/VID | For VLAN interfaces, this field displays • the Ethernet interface on which the VLAN interface is created • the VLAN ID For virtual interfaces, this field is blank. |
IP Address | This field displays the current IP address of the interface. If the IP address is 0.0.0.0, the interface does not have an IP address yet. This screen also shows whether the IP address is a static IP address (STATIC) or dynamically assigned (DHCP). IP addresses are always static in virtual interfaces. |
Label | Description |
Enable Interface | Select this to turn this interface on. Clear this to disable this interface. |
Interface Type | Select one of the following option depending on the type of network to which the Zyxel Device is connected or if you want to additionally manually configure some related settings. internal is for connecting to a local network. Other corresponding configuration options: DHCP server and DHCP relay. The Zyxel Device automatically adds default SNAT settings for traffic flowing from this interface to an external interface. external is for connecting to an external network (like the Internet). The Zyxel Device automatically adds this interface to the default WAN trunk. For general, the rest of the screen’s options do not automatically adjust and you must manually configure a policy route to add routing and SNAT settings for the interface. |
Interface Name | This field is read-only if you are editing an existing VLAN interface. Enter the number of the VLAN interface. You can use a number from 0~4094. For example, use vlan0, vlan8, and so on. The total number of VLANs you can configure on the Zyxel Device depends on the model. |
Zone | Select the zone to which the VLAN interface belongs. |
Base Port | Select the Ethernet interface on which the VLAN interface runs. |
VLAN ID | Enter the VLAN ID. This 12-bit number uniquely identifies each VLAN. Allowed values are 1 - 4094. (0 and 4095 are reserved.) |
Priority Code | This is a 3-bit field within a 802.1Q VLAN tag that’s used to prioritize associated outgoing VLAN traffic. . The setting configured in Configuration > BWM overwrites the priority setting here. |
IP Address Assignment | |
Get Automatically | Select this if this interface is a DHCP client. In this case, the DHCP server configures the IP address, subnet mask, and gateway automatically. You should not select this if the interface is assigned to a VRRP group. |
Use Fixed IP Address | Select this if you want to specify the IP address, subnet mask, and gateway manually. |
Subnet Mask | This field is enabled if you select Use Fixed IP Address. Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network. |
Link-Local address | This displays the IPv6 link-local address and the network prefix that the Zyxel Device generates itself for the interface. |
IPv6 Address/Prefix Length | Enter the IPv6 address and the prefix length for this interface if you want to configure a static IP address for this interface. This field is optional. The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address. |
References | Select an entry and click References to open a screen that shows which settings use the entry. |
DHCPv6 Setting | |
DUID as MAC | Select this to have the DUID generated from the interface’s default MAC address. |
DHCPv6 Request Options / DHCPv6 Lease Options | If this interface is a DHCPv6 client, use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server. If this interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what to offer to the DHCPv6 clients. |
Add | Click this to create an entry in this table. S |
MTU | The Maximum Transmission Unit. Type the maximum size of each IPv6 data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. |
Advertised Prefix from DHCPv6 Prefix Delegation | Use this table to configure the network prefix if you want to use a delegated prefix as the beginning part of the network prefix. |
Interface Parameters | |
Connectivity Check | The Zyxel Device can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often to check the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check. |
DHCP Setting | The DHCP settings are available for the OPT, LAN and DMZ interfaces. |
IP Pool Start Address | Enter the IP address from which the Zyxel Device begins allocating IP addresses. If you want to assign a static IP address to a specific computer, click Add Static DHCP. If this field is blank, the Pool Size must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address. |
First DNS Server Second DNS Server Third DNS Server | Specify the IP addresses up to three DNS servers for the DHCP clients to use. Use one of the following ways to specify these IP addresses. Custom Defined - enter a static IP address. From ISP - select the DNS server that another interface received from its DHCP server. Zyxel Device - the DHCP clients use the IP address of this interface and the Zyxel Device works as a DNS relay. |
Lease time | Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are: infinite - select this if IP addresses never expire days, hours, and minutes - select this to enter how long IP addresses are valid. The default is 2 days. |
Name | This is the option’s name. |
Code | This is the option’s code number. |
Type | This is the option’s type. |
Value | This is the option’s value. |
Enable IP/MAC Binding | Select this option to have the Zyxel Device enforce links between specific IP addresses and specific MAC addresses for this VLAN. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses. |
Enable Logs for IP/MAC Binding Violation | Select this option to have the Zyxel Device generate a log if a device connected to this VLAN attempts to use an IP address that is bound to another device’s MAC address. |
MAC Address | Enter the MAC address to which to assign this entry’s IP address. |
RIP Setting | |
Enable RIP | Select this to enable RIP on this interface. |
OSPF Setting | |
Overwrite Default MAC Address | Select this option to have the interface use a different MAC address. Either the MAC address in the field. Once it is successfully configured, the address will be copied to the configuration file. It will not change unless you change the setting or upload a different configuration file. |
Proxy ARP | Proxy ARP is available for external or general interfaces on the Zyxel Device. See These screen’s fields are described in the table below. for more information on Proxy ARP. |
Enable Proxy ARP | Select this to allow the to answer external interface ARP requests on behalf of a device on its internal interface. Interfaces supported are: • Ethernet • VLAN • Bridge See Proxy ARP for more information. |
Related Setting | |
Configure WAN TRUNK | Click WAN TRUNK to go to a screen where you can set this VLAN to be part of a WAN trunk for load balancing. |
Configure Policy Route | Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this VLAN. |
Configuration / IPv6 Configuration | Use the Configuration section for IPv4 network settings. Use the IPv6 Configuration section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
# | This field is a sequential value, and it is not associated with any interface. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Name | This field displays the name of the interface. |
Description | This field displays the description of the interface. |
Member | This field displays the Ethernet interfaces and VLAN interfaces in the bridge interface. It is blank for virtual interfaces. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
IPv4/IPv6 View / IPv4 View / IPv6 View | Use this button to display both IPv4 and IPv6, IPv4-only, or IPv6-only configuration fields. |
Show Advanced Settings / Hide Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
Create New Object | Click this button to create a DHCPv6 lease or DHCPv6 request object that you may use for the DHCPv6 settings in this screen. |
General Settings | |
Enable Interface | Select this to enable this interface. Clear this to disable this interface. |
General IPv6 Setting | |
Enable IPv6 | Select this to enable IPv6 on this interface. Otherwise, clear this to disable it. |
Interface Properties | |
Interface Name | This field is read-only if you are editing the interface. Enter the name of the bridge interface. The format is brx, where x is 0 - 11. For example, br0, br3, and so on. |
Zone | Select the zone to which the interface is to belong. You use zones to apply security settings such as security policy, IDP, remote management, anti-malware, and application patrol. |
Description | Enter a description of this interface. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. Spaces are allowed, but the string can’t start with a space. |
Member Configuration | |
Available | This field displays Ethernet interfaces and VLAN interfaces that can become part of the bridge interface. An interface is not available in the following situations: • There is a virtual interface on top of it • It is already used in a different bridge interface Select one, and click the >> arrow to add it to the bridge interface. Each bridge interface can only have one VLAN interface. |
Member | This field displays the interfaces that are part of the bridge interface. Select one, and click the << arrow to remove it from the bridge interface. |
Get Automatically | Select this if this interface is a DHCP client. In this case, the DHCP server configures the IP address, subnet mask, and gateway automatically. |
DHCP Option 60 | DHCP Option 60 is used by the Zyxel Device for identification to the DHCP server using the VCI (Vendor Class Identifier) on the DHCP server. The Zyxel Device adds it in the initial DHCP discovery message that a DHCP client broadcasts in search of an IP address. The DHCP server can assign different IP addresses or options to clients with the specific VCI or reject the request from clients without the specific VCI. Type a string using up to 63 of these characters [a-zA-Z0-9!\"#$%&\'()*+,-./:;<=>?@\[\\\]^_`{}] to identify this Zyxel Device to the DHCP server. For example, Zyxel-TW. |
Metric | Enter the priority of the gateway (if any) on this interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first. |
Enable IGMP Support | Select this to allow the Zyxel Device to act as an IGMP proxy for hosts connected on the IGMP downstream interface. |
IGMP Upstream | Enable IGMP Upstream on the interface which connects to a router running IGMP that is closer to the multicast server. |
IGMP Downstream | Enable IGMP Downstream on the interface which connects to the multicast hosts. |
IPv6 Address Assignment | These IP address fields configure an IPv6 IP address on the interface itself. |
Enable Stateless Address Auto-configuration (SLAAC) | Select this to enable IPv6 stateless auto-configuration on this interface. The interface will generate an IPv6 IP address itself from a prefix obtained from an IPv6 router on the network. |
IPv6 Address/Prefix Length | Enter the IPv6 address and the prefix length for this interface if you want to use a static IP address. This field is optional. The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address. |
Gateway | Enter the IPv6 address of the default outgoing gateway using colon (:) hexadecimal notation. |
Address from DHCPv6 Prefix Delegation | Use this table to have the Zyxel Device obtain an IPv6 prefix from the ISP or a connected uplink router for an internal network, such as the LAN or DMZ. You have to also enter a suffix address which is appended to the delegated prefix to form an address for this interface. To use prefix delegation, you must: • Create at least one DHCPv6 request object before configuring this table. • The external interface must be a DHCPv6 client. You must configure the DHCPv6 request options using a DHCPv6 request object with the type of prefix-delegation. • Assign the prefix delegation to an internal interface and enable router advertisement on that interface. |
Add | Click this to create an entry. |
Edit | Select an entry and click this to change the settings. |
Remove | Select an entry and click this to delete it from this table. |
# | This field is a sequential value, and it is not associated with any entry. |
Delegated Prefix | Select the DHCPv6 request object to use from the drop-down list. |
Suffix Address | Enter the ending part of the IPv6 address, a slash (/), and the prefix length. The Zyxel Device will append it to the delegated prefix. For example, you got a delegated prefix of 2003:1234:5678/48. You want to configure an IP address of 2003:1234:5678:1111:1/128 for this interface, then enter ::1111:0:0:0:1/128 in this field. |
Address | This field displays the combined IPv6 IP address for this interface. ![]() |
DHCPv6 Setting | |
DHCPv6 | Select N/A to not use DHCPv6. Select Client to set this interface to act as a DHCPv6 client. Select Server to set this interface to act as a DHCPv6 server which assigns IP addresses and provides subnet mask, gateway, and DNS server information to clients. Select Relay to set this interface to route DHCPv6 requests to the DHCPv6 relay server you specify. The DHCPv6 server(s) may be on another network. |
DUID | This field displays the DHCP Unique IDentifier (DUID) of the interface, which is unique and used for identification purposes when the interface is exchanging DHCPv6 messages with others. See DHCPv6 for more information. |
DUID as MAC | Select this if you want the DUID is generated from the interface’s default MAC address. |
Customized DUID | If you want to use a customized DUID, enter it here for the interface. |
Enable Rapid Commit | Select this to shorten the DHCPv6 message exchange process from four to two steps. This function helps reduce heavy network traffic load. ![]() |
Information Refresh Time | Enter the number of seconds a DHCPv6 client should wait before refreshing information retrieved from DHCPv6. |
Request Address | This field is available if you set this interface to DHCPv6 Client. Select this to get an IPv6 IP address for this interface from the DHCP server. Clear this to not get any IP address information through DHCPv6. |
DHCPv6 Request Options / DHCPv6 Lease Options | If this interface is a DHCPv6 client, use this section to configure DHCPv6 request settings that determine what additional information to get from the DHCPv6 server. If the interface is a DHCPv6 server, use this section to configure DHCPv6 lease settings that determine what to offer to the DHCPv6 clients. |
Add | Click this to create an entry in this table. See Add/Edit DHCPv6 Request/Release Options for more information. |
Name | This field displays the name of the DHCPv6 request or lease object. |
Type | This field displays the type of the object. |
Value | This field displays the IPv6 prefix that the Zyxel Device obtained from an uplink router (Server is selected) or will advertise to its clients (Client is selected). |
Interface | When Relay is selected, select this check box and an interface from the drop-down list if you want to use it as the relay server. |
Relay Server | When Relay is selected, select this check box and enter the IP address of a DHCPv6 server as the relay server. |
IPv6 Router Advertisement Setting | |
Enable Router Advertisement | Select this to enable this interface to send router advertisement messages periodically. |
Advertised Hosts Get Network Configuration From DHCPv6 | Select this to have the Zyxel Device indicate to hosts to obtain network settings (such as prefix and DNS settings) through DHCPv6. Clear this to have the Zyxel Device indicate to hosts that DHCPv6 is not available and they should use the prefix in the router advertisement message. |
Advertised Hosts Get Other Configuration From DHCPv6 | Select this to have the Zyxel Device indicate to hosts to obtain DNS information through DHCPv6. Clear this to have the Zyxel Device indicate to hosts that DNS information is not available in this network. |
Router Preference | Select the router preference (Low, Medium or High) for the interface. The interface sends this preference in the router advertisements to tell hosts what preference they should use for the Zyxel Device. This helps hosts to choose their default router especially when there are multiple IPv6 router on the network. ![]() |
Hop Limit | Enter the maximum number of network segments that a packet can cross before reaching the destination. When forwarding an IPv6 packet, IPv6 routers are required to decrease the Hop Limit by 1 and to discard the IPv6 packet when the Hop Limit is 0. |
Advertised Prefix Table | Configure this table only if you want the Zyxel Device to advertise a fixed prefix to the network. |
Add | Click this to create an IPv6 prefix address. |
Edit | Select an entry in this table and click this to modify it. |
Remove | Select an entry in this table and click this to delete it. |
IPv6 Address/ Prefix Length | Enter the IPv6 network prefix address and the prefix length. The prefix length indicates what the left-most part of the IP address is the same for all computers on the network, that is, the network address. |
Add | Click this to create an entry in this table. |
Delegated Prefix | Select the DHCPv6 request object to use for generating the network prefix for the network. |
Suffix Address | Enter the ending part of the IPv6 network address plus a slash (/) and the prefix length. The Zyxel Device will append it to the selected delegated prefix. The combined address is the network prefix for the network. For example, you got a delegated prefix of 2003:1234:5678/48. You want to divide it into 2003:1234:5678:1111/64 for this interface and 2003:1234:5678:2222/64 for another interface. You can use ::1111/64 and ::2222/64 for the suffix address respectively. But if you do not want to divide the delegated prefix into subnetworks, enter ::0/48 here, which keeps the same prefix length (/48) as the delegated prefix. |
Address | This is the final network prefix combined by the selected delegated prefix and the suffix. ![]() |
Egress Bandwidth | Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can send through the interface to the network. Allowed values are 0 - 1048576. |
Ingress Bandwidth | This is reserved for future use. Enter the maximum amount of traffic, in kilobits per second, the Zyxel Device can receive from the network through the interface. Allowed values are 0 - 1048576. |
MTU | Maximum Transmission Unit. Type the maximum size of each data packet, in bytes, that can move through this interface. If a larger packet arrives, the Zyxel Device divides it into smaller fragments. Allowed values are 576 - 1500. Usually, this value is 1500. |
DHCP Setting | |
DHCP | Select what type of DHCP service the Zyxel Device provides to the network. Choices are: None - the Zyxel Device does not provide any DHCP services. There is already a DHCP server on the network. DHCP Relay - the Zyxel Device routes DHCP requests to one or more DHCP servers you specify. The DHCP server(s) may be on another network. DHCP Server - the Zyxel Device assigns IP addresses and provides subnet mask, gateway, and DNS server information to the network. The Zyxel Device is the DHCP server for the network. |
These fields appear if the Zyxel Device is a DHCP Relay. | |
Relay Server 1 | Enter the IP address of a DHCP server for the network. |
Relay Server 2 | This field is optional. Enter the IP address of another DHCP server for the network. |
These fields appear if the Zyxel Device is a DHCP Server. | |
Lease time | Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are: infinite - select this if IP addresses never expire days, hours, and minutes - select this to enter how long IP addresses are valid. |
Enable Connectivity Check | Select this to turn on the connection check. |
Check Method | Select the method that the gateway allows. Select icmp to have the Zyxel Device regularly ping the gateway you specify to make sure it is still available. Select tcp to have the Zyxel Device regularly perform a TCP handshake with the gateway you specify to make sure it is still available. |
Check Period | Enter the number of seconds between connection check attempts. |
Check Timeout | Enter the number of seconds to wait for a response before the attempt is a failure. |
Check Fail Tolerance | Enter the number of consecutive failures before the Zyxel Device stops routing through the gateway. |
Check Default Gateway | Select this to use the default gateway for the connectivity check. |
Check Port | This field only displays when you set the Check Method to tcp. Specify the port number to use for a TCP connectivity check. |
Check these addresses | Type one or two domain names or IP addresses for the connectivity check. |
Probe Succeeds When | This field applies when you specify two domain names or IP addresses for the connectivity check. Select any one if you want the check to pass if at least one of the domain names or IP addresses responds. Select all if you want the check to pass only if both domain names or IP addresses respond. |
Related Setting | |
Configure Policy Route | Click Policy Route to go to the screen where you can manually configure a policy route to associate traffic with this bridge interface. |
Configuration | |
Name | This field displays the name of the LAG interface. |
Description | This field displays the description of the LAG interface. |
Mode | Mode refers to whether the LAG is acting as follows: • active-backup where only one slave in the LAG interface is active and another slave becomes active only if the active slave fails. • 802.3ad (IEEE 802.3ad Dynamic link aggregation) where Link Aggregation Control Protocol (LACP) negotiates automatic combining of links and balances the traffic load across the LAG link by sending LACP packets to the directly connected device that also implements LACP. The slaves must have the same speed and duplex settings. • balance-alb (adaptive load balancing) where traffic is distributed according to the current load on each slave by ARP negotiation. Incoming traffic is received by the current slave. If the receiving slave fails, another slave takes over the MAC address of the failed receiving slave. |
IP Address | This field displays the current IP address of the LAG interface. If the IP address is 0.0.0.0, the interface does not have an IP address yet. This screen also shows whether the IP address is a static IP address (STATIC) or dynamically assigned (DHCP). IP addresses are always static in virtual interfaces. |
Slaves | A slave is a physical Ethernet interface that is a member of a LAG. Slaves do not have an IP Address and in some cases share the same MAC address. This field displays the member Ethernet interfaces and VLAN interfaces in the LAG. |
Interface Name | This field is read-only if you are editing the interface. Enter the name of the LAG interface. The format is lagx, where x is 0 - 3. For example, lag0, lag1, and so on. |
Zone | Select the zone to which the interface is to belong. You use zones to apply security settings such as security policy, IDP, remote management, anti-virus, and application patrol. |
LAG Configuration | |
Mode | Select a Mode for this LAG interface. Choices are as follows: • active-backup where only one slave in the LAG interface is active and another slave becomes active only if the active slave fails. • 802.3ad (IEEE 802.3ad Dynamic link aggregation) where Link Aggregation Control Protocol (LACP) negotiates automatic combining of links and balances the traffic load across the LAG link by sending LACP packets to the directly connected device that also implements LACP. The slaves must have the same speed and duplex settings. • balance-alb (adaptive load balancing) where traffic is distributed according to the current load on each slave by ARP negotiation. Incoming traffic is received by the current slave. If the receiving slave fails, another slave takes over the MAC address of the failed receiving slave. |
Link Monitoring | Select from none, mii or arp. none means no link monitoring is done. mii monitoring monitors the state of the local interface; it can’t tell if the link can transmit or receive packets. arp monitoring sends ARP queries and uses the reply to know if the link is up and that traffic is flowing over the link. |
Miimom | This field displays for mii Link Monitoring. Set the link check interval in milliseconds that the system polls the Media Independent Interface (MII) to get status. |
Updelay | This field displays for mii Link Monitoring. Set the waiting time in milliseconds to confirm the slave interface status is up. |
Downdelay | This field displays for mii Link Monitoring. Set the waiting time in milliseconds to confirm the slave interface status is down. |
Xmit Hash Policy | This field displays in 802.3ad Mode. This field sets the algorithm for slave selection according to the selected TCP/IP layer. |
LACP Rate | This field displays in 802.3ad Mode. Select the preferred LACPDU packet transmission rate (slow/fast) to request from 802.3ad partner. |
ARP Interval | This field displays for arp Link Monitoring. Select the frequency of ARP requests sent to confirm a that slave interface is up. |
ARP IP Target | This field displays for arp Link Monitoring. Set the IP address of the link to send ARP queries. |
Available | This field displays Ethernet interfaces and VLAN interfaces that can become part of the LAG interface. Please see Available Interfaces for LAG for criteria on available interfaces. Select one, and click the >> arrow to add it to the LAG interface. ![]() ![]() |
Slaves | A slave is a physical Ethernet interface that is a member of a LAG. This field displays the interfaces that are part of the LAG interface. Select one, and click the << arrow to remove it from the LAG interface. |
Subnet Mask | This field is enabled if you select Use Fixed IP Address. Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers in the network. |
DHCPv6 Setting | |
DHCP Setting | |
Pool Size | Enter the number of IP addresses to allocate. This number must be at least one and is limited by the interface’s Subnet Mask. For example, if the Subnet Mask is 255.255.255.0 and IP Pool Start Address is 10.10.10.10, the Zyxel Device can allocate 10.10.10.10 to 10.10.10.254, or 245 IP addresses. If this field is blank, the IP Pool Start Address must also be blank. In this case, the Zyxel Device can assign every IP address allowed by the interface’s IP address and subnet mask, except for the first address (network address), last address (broadcast address) and the interface’s IP address. |
First WINS Server, Second WINS Server | Type the IP address of the WINS (Windows Internet Naming Service) server that you want to send to the DHCP clients. The WINS server keeps a mapping table of the computer names on your network and the IP addresses that they are currently using. |
Default Router | If you set this interface to DHCP Server, you can select to use either the interface’s IP address or another IP address as the default router. This default router will become the DHCP clients’ default gateway. To use another IP address as the default router, select Custom Defined and enter the IP address. |
Extended Options | This table is available if you selected DHCP server. Configure this table if you want to send more information to DHCP clients through DHCP packets. |
Enable IP/MAC Binding | Select this option to have this interface enforce links between specific IP addresses and specific MAC addresses. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses. |
Enable Logs for IP/MAC Binding Violation | Select this option to have the Zyxel Device generate a log if a device connected to this interface attempts to use an IP address that is bound to another device’s MAC address. |
Static DHCP Table | Configure a list of static IP addresses the Zyxel Device assigns to computers connected to the interface. Otherwise, the Zyxel Device assigns an IP address dynamically using the interface’s IP Pool Start Address and Pool Size. |
Add | Click this to create a new entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
# | This field is a sequential value, and it is not associated with a specific entry. |
IP Address | Enter the IP address to assign to a device with this entry’s MAC address. |
Description | Enter a description to help identify this static DHCP entry. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
Related Setting | |
Configuration | |
Name | This field displays the name of the VTI interface. |
IP Address | This field displays the current IP address of the virtual interface and subnet mask in bits. If the IP address is 0.0.0.0, the interface does not have an IP address yet. |
vpn-rule | This shows the name of the associated IPSec VPN rule with VPN Tunnel Interface application scenario. |
Enable | Select this to enable VTI. Clear this to disable it. |
Interface Name | This field is read-only if you are editing an existing VPN tunnel interface. For a new VPN tunnel interface, enter the name of the VPN tunnel interface in vtix format, where x is a number from 0 to the maximum number of VPN connections allowed for this model. For example, enter vti10. |
Zone | Select a zone. Make sure that the zone you select does not have traffic blocked by a security feature such as a security policy. |
vpn-rule | You should have created a VPN tunnel first for a VPN Tunnel Interface scenario. Select one of the VPN Tunnel Interface scenario rules that you created. |
IP Address | Enter the IP address for this interface. |
Subnet Mask | Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers on the network. |
Connectivity Check | These fields appear when you select a vpn-rule. The interface can regularly check the connection to the gateway you specified to make sure it is still available. You specify how often the interface checks the connection, how long to wait for a response before the attempt is a failure, and how many consecutive failures are required before the Zyxel Device stops routing to the gateway. The Zyxel Device resumes routing to the gateway the first time the gateway passes the connectivity check. |
RIP Setting | |
Enable RIP | Select this to enable RIP in this interface. |
Direction | This field is effective when RIP is enabled. Select the RIP direction from the drop-down list box. BiDir - This interface sends and receives routing information. In-Only - This interface receives routing information. Out-Only - This interface sends routing information. |
Send Version | This field is effective when RIP is enabled. Select the RIP version(s) used for sending RIP packets. Choices are 1, 2, and 1 and 2. |
Receive Version | This field is effective when RIP is enabled. Select the RIP version(s) used for receiving RIP packets. Choices are 1, 2, and 1 and 2. |
V2-Broadcast | This field is effective when RIP is enabled. Select this to send RIP-2 packets using subnet broadcasting; otherwise, the Zyxel Device uses multicasting. |
OSPF Setting | |
Area | Select the area in which this interface belongs. Select None to disable OSPF in this interface. |
Priority | Enter the priority (between 0 and 255) of this interface when the area is looking for a Designated Router (DR) or Backup Designated Router (BDR). The highest-priority interface identifies the DR, and the second-highest-priority interface identifies the BDR. Set the priority to zero if the interface can not be the DR or BDR. |
Link Cost | Enter the cost (between 1 and 65,535) to route packets through this interface. |
Passive Interface | Select this to stop forwarding OSPF routing information from the selected interface. As a result, this interface only receives routing information. |
Authentication | Select an authentication method, or disable authentication. To exchange OSPF routing information with peer border routers, you must use the same authentication method that they use. Choices are: Same-as-Area - use the default authentication method in the area None - disable authentication Text - authenticate OSPF routing information using a plain-text password MD5 - authenticate OSPF routing information using MD5 encryption |
Text Authentication Key | This field is available if the Authentication is Text. Type the password for text authentication. The key can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long. |
MD5 Authentication ID | This field is available if the Authentication is MD5. Type the ID for MD5 authentication. The ID can be between 1 and 255. |
MD5 Authentication Key | This field is available if the Authentication is MD5. Type the password for MD5 authentication. The password can consist of alphanumeric characters and the underscore, and it can be up to 16 characters long. |
Related Setting | |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
label | description |
Configuration | Configure what to do with existing passive mode interface connections when an interface set to active mode in the same trunk comes back up. |
Disconnect Connections Before Falling Back | Select this to terminate existing connections on an interface which is set to passive mode when any interface set to active mode in the same trunk comes back up. |
Enable Default SNAT | Select this to have the Zyxel Device use the IP address of the outgoing interface as the source IP address of the packets it sends out through its WAN trunks. The Zyxel Device automatically adds SNAT settings for traffic it routes from internal interfaces to external interfaces. |
Default Trunk Selection | Select whether the Zyxel Device is to use the default system WAN trunk or one of the user configured WAN trunks as the default trunk for routing traffic from internal interfaces to external interfaces. |
User Configuration / System Default | The Zyxel Device automatically adds all external interfaces into the pre-configured system default SYSTEM_DEFAULT_WAN_TRUNK. You cannot delete it. You can create your own User Configuration trunks and customize the algorithm, member interfaces and the active/passive mode. |
Add | Click this to create a new user-configured trunk. |
Remove | To remove a user-configured trunk, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Name | This field displays the label that you specified to identify the trunk. |
Algorithm | This field displays the load balancing method the trunk is set to use. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Name | This is read-only if you are editing an existing trunk. When adding a new trunk, enter a descriptive name for this trunk. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Load Balancing Algorithm | Select a load balancing method to use from the drop-down list box. Select Weighted Round Robin to balance the traffic load between interfaces based on their respective weights. An interface with a larger weight gets more chances to transmit traffic than an interface with a smaller weight. For example, if the weight ratio of wan1 and wan2 interfaces is 2:1, the Zyxel Device chooses wan1 for 2 sessions’ traffic and wan2 for 1 session’s traffic in each round of 3 new sessions. Select Least Load First to send new session traffic through the least utilized trunk member. Select Spillover to send network traffic through the first interface in the group member list until there is enough traffic that the second interface needs to be used (and so on). |
Load Balancing Index(es) | This field is available if you selected to use the Least Load First or Spillover method. Select Outbound, Inbound, or Outbound + Inbound to set the traffic to which the Zyxel Device applies the load balancing method. Outbound means the traffic traveling from an internal interface (ex. LAN) to an external interface (ex. WAN). Inbound means the opposite. |
The table lists the trunk’s member interfaces. You can add, edit, remove, or move entries for user configured trunks. | |
Add | Click this to add a member interface to the trunk. Select an interface and click Add to add a new member interface after the selected member interface. |
Edit | Select an entry and click Edit to modify the entry’s settings. |
Remove | To remove a member interface, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Move | To move an interface to a different number in the list, click the Move icon. In the field that appears, specify the number to which you want to move the interface. |
# | This column displays the priorities of the group’s interfaces. The order of the interfaces in the list is important since they are used in the order they are listed. |
Member | Click this table cell and select an interface to be a group member. If you select an interface that is part of another Ethernet interface, the Zyxel Device does not send traffic through the interface as part of the trunk. For example, if you have physical port 5 in the ge2 representative interface, you must select interface ge2 in order to send traffic through port 5 as part of the trunk. If you select interface ge5 as a member here, the Zyxel Device will not send traffic through port 5 as part of the trunk. |
Mode | Click this table cell and select Active to have the Zyxel Device always attempt to use this connection. Select Passive to have the Zyxel Device only use this connection when all of the connections set to active are down. You can only set one of a group’s interfaces to passive mode. |
Weight | This field displays with the weighted round robin load balancing algorithm. Specify the weight (1~10) for the interface. The weights of the different member interfaces form a ratio. This ratio determines how much traffic the Zyxel Device assigns to each member interface. The higher an interface’s weight is (relative to the weights of the interfaces), the more sessions that interface should handle. |
Ingress Bandwidth | This is reserved for future use. This field displays with the least load first load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to allow to come in through the interface per second. ![]() |
Egress Bandwidth | This field displays with the least load first or spillover load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to send out through the interface per second. ![]() |
Spillover | This field displays with the spillover load balancing algorithm. Specify the maximum bandwidth of traffic in kilobits per second (1~1048576) to send out through the interface before using another interface. When this spillover bandwidth limit is exceeded, the Zyxel Device sends new session traffic through the next interface. The traffic of existing sessions still goes through the interface on which they started. The Zyxel Device uses the group member interfaces in the order that they are listed. |
Name | This field displays the name of the selected system default trunk. |
Load Balancing Algorithm | Select the load balancing method to use for the trunk. Select Weighted Round Robin to balance the traffic load between interfaces based on their respective weights. An interface with a larger weight gets more chances to transmit traffic than an interface with a smaller weight. For example, if the weight ratio of wan1 and wan2 interfaces is 2:1, the Zyxel Device chooses wan1 for 2 sessions’ traffic and wan2 for 1 session’s traffic in each round of 3 new sessions. Select Least Load First to send new session traffic through the least utilized trunk member. Select Spillover to send network traffic through the first interface in the group member list until there is enough traffic that the second interface needs to be used (and so on). |
The table lists the trunk’s member interfaces. This table is read-only. | |
Member | This column displays the name of the member interfaces. |
Mode | This field displays Active if the Zyxel Device always attempt to use this connection. This field displays Passive if the Zyxel Device only use this connection when all of the connections set to active are down. Only one of a group’s interfaces can be set to passive mode. |
Weight | This field displays with the weighted round robin load balancing algorithm. Specify the weight (1~10) for the interface. The weights of the different member interfaces form a ratio. s |
Ingress Bandwidth | This is reserved for future use. This field displays with the least load first load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to allow to come in through the interface per second. |
Egress Bandwidth | This field displays with the least load first or spillover load balancing algorithm. It displays the maximum number of kilobits of data the Zyxel Device is to send out through the interface per second. |
