label | description |
System Name | This field displays the descriptive name of the Switch for identification purposes. |
Product Model | This field displays the product model of the Switch. Use this information when searching for firmware upgrade or looking for other support information in the website. |
ZyNOS F/W Version | This field displays the version number of the Switch 's current firmware including the date created. |
Ethernet Address | This field refers to the Ethernet MAC (Media Access Control) address of the Switch. |
CPU Utilization Current (%) | CPU utilization quantifies how busy the system is. Current (%) displays the current percentage of CPU utilization. |
Memory Utilization | Memory utilization shows how much DRAM memory is available and in use. It also displays the current percentage of memory utilization. |
Name | This field displays the name of memory pool. |
Total (byte) | This field displays the total number of bytes in this memory pool. |
Used (byte) | This field displays the number of bytes being used in this memory pool. |
Utilization (%) | This field displays the percentage (%) of memory being used in this memory pool. |
Hardware Monitor | |
Temperature Unit | The Switch has temperature sensors that are capable of detecting and reporting if the temperature rises above the threshold. You may choose the temperature unit (Centigrade or Fahrenheit) in this field. |
Temperature (C) | CPU/MAC refers to the location of the temperature sensor on the Switch printed circuit board. |
Status | This field displays Normal for temperatures below the threshold and Error for those above. |
Current | This shows the current temperature at this sensor. |
MAX | This field displays the maximum temperature measured at this sensor. |
MIN | This field displays the minimum temperature measured at this sensor. |
Threshold | This field displays the upper temperature limit at this sensor. |
