label | description |
Pause/Resume Auto Refresh | Enter the number of seconds when the Summary screen details will be updated. Click the Pause or Play icon to stop or resume the screen update. |
Connect Ports | This chart displays the number of ports with connection (IP CAM + NVR + Others) over the total number of ports on this Switch. |
Power Usage(W) | This chart displays the used PoE Watts over the total number of Watts provided on this Switch. |
Port | This field displays the port of this Switch. |
Port Name | This field displays the port description of this Switch. |
PD Health | This field displays the status of auto PD recovery on this port. • Red: The Switch failed to get information from the PD connected to the port using LLDP, or the connected PD did not respond to the Switch’s ping requests. • Yellow: The Switch is restarting the connected PD by turning the power off and turning it on again. • Green: The Switch successfully discovered the connected PD using LLDP or ping. • –: Auto PD Recovery is not enabled on the Switch and the port, or the Switch does not supply power to the connected PD. |
Link Speed | This shows the speed (either 10M for 10 Mbps, 100M for 100 Mbps, or 1G for 1 Gbps) and the duplex (F for full duplex or H for half). This field displays Down if the port is not connected to any device. |
PoE Draw | This shows the consumption that the neighboring device connected to this port draws from the Switch. This allows you to plan and use within the power budget of the Switch. |
Bandwidth Tx/Rx (%) | This field displays the percentage of bandwidth usage on this port as a percentage of the Link Speed. |
CRC | This field displays the number of packets received with CRC (Cyclic Redundant Check) errors. |
Extended Range | This field shows whether PoE range is extended up to 250 meters for the port on this Switch. |
Device Type | This field displays the model name of this Switch. |
System Name | This field displays the name used to identify the Switch on any network. |
IP | This field displays the Switch’s current IPv4 address. |
Discovered Devices | This field displays the Neighbor Detail of the discovered device by clicking the link. |
Action | Click the Reset button to restart the neighbor device. A warning message “Are you sure you want to reboot the powered device?” appears prompting you to confirm the action. After confirming the action a count down button (from 5 to 0) starts. Click the Restore button to reset the neighbor device to its factory default settings. A warning message “Are you sure you want to reset the AP to factory default?” appears prompting you to confirm the action. |
Search Ports... | Enter the port number and click the magnify icon to view and manage the neighboring device connected to the port. |
Flush All | Click the Flush All button to remove information about neighbors learned on all the ports of the Switch. |
Port | This shows the port of the Switch, on which the neighboring device is discovered. |
Flush | Click the Flush button to remove information about neighbors learned on the selected ports. |
Port Name | This shows the port description of the Switch. |
PD Health | This shows the status of auto PD recovery on this port. • Red: The Switch failed to get information from the PD connected to the port using LLDP, or the connected PD did not respond to the Switch’s ping requests. • Yellow: The Switch is restarting the connected PD by turning the power off and turning it on again. • Green: The Switch successfully discovered the connected PD using LLDP or ping. • –: Auto PD Recovery is not enabled on the Switch and the port, or the Switch does not supply power to the connected PD. |
Link | This shows the speed (either 10M for 10 Mbps, 100M for 100 Mbps, or 1G for 1 Gbps) and the duplex (F for full duplex or H for half). This field displays Down if the port is not connected to any device. |
PoE Draw (W) | This shows the consumption that the neighboring device connected to this port draws from the Switch. This allows you to plan and use within the power budget of the Switch. |
Action | Click the Reset button to turn OFF the power of the neighbor device and turn it back ON again. |
CRC | This shows the number of packets received with CRC (Cyclic Redundant Check) errors. |
Extend Range | This shows whether PoE range is extended up to 250 meters for the port on this Switch. |
PD Failed Count | This shows the number of times the Switch attempts to restart the PD on the port. The PD Failed Count will reset after clicking the Flush button. |
System Name | This shows the system name of the neighbor device. |
Port | This shows the number of the neighbor device’s port which is connected to the Switch. |
Model | This shows the model name of the neighbor device. This field will show “--” for devices that do not support the ZON utility. |
IP | This shows the IPv4 or IPv6 address of the neighbor device. The IPv4 or IPv6 address is a hyper link that you can click to log into and manage the neighbor device through its Web Configurator. |
Action | Click the Restore button to reset the neighboring device to its factory default settings. A warning message “Are you sure you want to reset the AP to factory default?” appears prompting you to confirm the action. • The Switch must support power sourcing (PSE) or the network device is a powered device (PD). • If multiple neighbor devices use the same port, the Default button is not available. • You can only reset Zyxel powered devices that support the ZON utility. |
Location | This shows the geographic location of the neighbor device. This field will show “--” for devices that do not support the ZON utility. |
Desc. | This shows the description of the neighbor device’s port which is connected to the Switch. |
Firmware | This shows the firmware version of the neighbor device. This field will show “--” for devices that do not support the ZON utility. |
MAC | This shows the MAC address of the neighbor device. |
Device Type | This field displays the IP-based security products, for example IP camera or NVR (network video recorder), that is connected to this Switch. |
