Link Speed | Recommended value | Recommended range | Allowed Range | |
Path Cost | 4 Mbps | 250 | 100 to 1000 | 1 to 65535 |
Path Cost | 10 Mbps | 100 | 50 to 600 | 1 to 65535 |
Path Cost | 16 Mbps | 62 | 40 to 400 | 1 to 65535 |
Path Cost | 100 Mbps | 19 | 10 to 60 | 1 to 65535 |
Path Cost | 1 Gbps | 4 | 3 to 10 | 1 to 65535 |
Path Cost | 10 Gbps | 2 | 1 to 5 | 1 to 65535 |
Port State | Description |
Disabled | STP is disabled (default). |
Blocking | Only configuration and management BPDUs are received and processed. |
Listening | All BPDUs are received and processed. |
Learning | All BPDUs are received and processed. Information frames are submitted to the learning process but not forwarded. |
Forwarding | All BPDUs are received and processed. All information frames are received and forwarded. |
label | description |
Spanning Tree Mode | You can activate one of the STP modes on the Switch. Select Rapid Spanning Tree (RSTP), Multiple Rapid Spanning Tree (MRSTP) or Multiple Spanning Tree (MSTP). |
Auto Path-cost Mode Auto Path-cost Mode allows you to have the Switch automatically set the path cost for each port according to their link speed. The Switch uses the path costs to determine the best path to the root bridge in a spanning tree. There are three Auto Path-cost Modes that supports different path cost lengths: • Short (16-bit) • Long (32-bit) • User-defined (32-bit). The auto path cost values of each mode are described in Spanning Tree Setup. To use the auto path-cost feature, select the Auto Path-cost mode (Short, Long, User-defined), set a port’s Path Cost (in the SWITCHING > Spanning Tree Protocol > RSTP, MRSTP, and MSTP screens) to “0”. The Switch will automatically set the port’s path cost to the auto path cost value defined by the Auto Path-cost Mode you select. | |
Short | Select this mode if you want to use the 16-bit auto path cost values the Switch defines. |
Long | Select this mode if you want to use the 32-bit auto path cost values the Switch defines. |
User-defined | Select this mode to manually set the auto path costs for each link speed. Enter the path cost value for each link speed. The range is from 1 – 200000000. It is recommended to assign this value according to link speeds. The slower the speed, the higher the cost. |
Apply | Click Apply to save your changes to the Switch’s run-time memory. The Switch loses these changes if it is turned off or loses power, so use the Save link on the top navigation panel to save your changes to the non-volatile memory when you are done configuring. |
Cancel | Click Cancel to begin configuring this screen afresh. |
LABEL | DESCRIPTION |
Spanning Tree Protocol: RSTP | |
Bridge | Root Bridge refers to the base of the spanning tree (the root bridge). Our Bridge is this Switch. This Switch may also be the root bridge. |
Bridge ID | This is the unique identifier for this bridge, consisting of bridge priority plus MAC address. This ID is the same for Root Bridge and Our Bridge if the Switch is the root switch. |
Hello Time (seconds) | This is the time interval (in seconds) at which the root switch transmits a configuration message. The root bridge determines Hello Time, Max Age and Forwarding Delay. |
Max Age (seconds) | This is the maximum time (in seconds) the Switch can wait without receiving a configuration message before attempting to reconfigure. |
Forwarding Delay (seconds) | This is the time (in seconds) the root switch will wait before changing states (that is, listening to learning to forwarding). |
Cost to Bridge | This is the path cost from the root port on this Switch to the root switch. |
Port ID | This is the priority and number of the port on the Switch through which this Switch must communicate with the root of the Spanning Tree. |
Topology Changed Times | This is the number of times the spanning tree has been reconfigured. |
Time Since Last Change | This is the time since the spanning tree was last reconfigured. |
Port | This field displays the number of the port on the Switch. |
Port State | This field displays the port state in STP. • DISCARDING – The port does not forward or process received frames or learn MAC addresses, but still listens for BPDUs. • LEARNING – The port learns MAC addresses and processes BPDUs, but does NOT forward frames yet. • FORWARDING – The port is operating normally. It learns MAC addresses, processes BPDUs and forwards received frames. |
Port Role | This field displays the role of the port in STP. • Root – A forwarding port on a non-root bridge, which has the lowest path cost and is the best port from the non-root bridge to the root bridge. A root bridge does NOT have a root port. • Designated – A forwarding port on the designated bridge for each connected LAN segment. A designated bridge has the lowest path cost to the root bridge among the bridges connected to the LAN segment. All the ports on a root bridge (root switch) are designated ports. • Alternate – A blocked port, which has a best alternate path to the root bridge. This path is different from using the root port. The port moves to the forwarding state when the designated port for the LAN segment fails. • Backup – A blocked port, which has a backup or redundant path to a LAN segment where a designated port is already connected when a switch has two links to the same LAN segment. • Disabled – Not strictly part of STP. The port can be disabled manually. |
Designated Bridge ID | This field displays the identifier of the designated bridge to which this port belongs when the port is a designated port. Otherwise, it displays the identifier of the designated bridge for the LAN segment to which this port is connected. |
Designated Port ID | This field displays the priority and number of the bridge port (on the designated bridge), through which the designated bridge transmits the stored configuration messages. |
Designated Cost | This field displays the path cost to the LAN segment to which the port is connected when the port is a designated port. Otherwise, it displays the path cost to the root bridge from the designated port for the LAN segment to which this port is connected. |
Active | Enable the switch button to activate RSTP. Disable the switch to disable RSTP. |
Bridge Priority | Bridge priority is used in determining the root switch, root port and designated port. The Switch with the highest priority (lowest numeric value) becomes the STP root switch. If all Switches have the same priority, the Switch with the lowest MAC address will then become the root switch. Select a value from the drop-down list box. The lower the numeric value you assign, the higher the priority for this bridge. Bridge Priority determines the root bridge, which in turn determines Hello Time, Max Age and Forwarding Delay. |
Hello Time | This is the time interval in seconds between BPDU (Bridge Protocol Data Units) configuration message generations by the root switch. The allowed range is 1 to 10 seconds. |
Max Age | This is the maximum time (in seconds) the Switch can wait without receiving a BPDU before attempting to reconfigure. All Switch ports (except for designated ports) should receive BPDUs at regular intervals. Any port that ages out STP information (provided in the last BPDU) becomes the designated port for the attached LAN. If it is a root port, a new root port is selected from among the Switch ports attached to the network. The allowed range is 6 to 40 seconds. |
Forwarding Delay | This is the maximum time (in seconds) the Switch will wait before changing states. This delay is required because every Switch must receive information about topology changes before it starts to forward frames. In addition, each port needs time to listen for conflicting information that would make it return to a blocking state; otherwise, temporary data loops might result. The allowed range is 4 to 30 seconds. As a general rule: 2 * (Forward Delay – 1) >= Max Age >= 2 * (Hello Time + 1) |
Port | This field displays the port number. |
* | Settings in this row apply to all ports. Use this row only if you want to make some settings the same for all ports. Use this row first to set the common settings and then make adjustments on a port-by-port basis. |
Active | Select this checkbox to activate RSTP on this port. |
Edge | Select this checkbox to configure a port as an edge port when it is directly attached to a computer. An edge port changes its initial STP port state from blocking state to forwarding state immediately without going through listening and learning states right after the port is configured as an edge port or when its link status changes. |
Priority | Configure the priority for each port here. Priority decides which port should be disabled when more than one port forms a loop in a switch. Ports with a higher priority numeric value are disabled first. The allowed range is between 0 and 255 and the default value is 128. |
Path Cost | Path cost is the cost of transmitting a frame on to a LAN through that port. It is recommended to assign this value according to the speed of the bridge. The slower the media, the higher the cost. |
Tree | Select which STP tree configuration you want to view. |
Bridge | Root Bridge refers to the base of the spanning tree (the root bridge). Our Bridge is this switch. This Switch may also be the root bridge. |
Port State | This field displays the port state in STP. • DISCARDING – The port does not forward or process received frames or learn MAC addresses, but still listens for BPDUs. • LEARNING – The port learns MAC addresses and processes BPDUs, but does not forward frames yet. • FORWARDING – The port is operating normally. It learns MAC addresses, processes BPDUs and forwards received frames. |
Port Role | This field displays the role of the port in STP. • Root – A forwarding port on a non-root bridge, which has the lowest path cost and is the best port from the non-root bridge to the root bridge. A root bridge does not have a root port. • Designated – A forwarding port on the designated bridge for each connected LAN segment. A designated bridge has the lowest path cost to the root bridge among the bridges connected to the LAN segment. All the ports on a root bridge (root switch) are designated ports. • Alternate – A blocked port, which has a best alternate path to the root bridge. This path is different from using the root port. The port moves to the forwarding state when the designated port for the LAN segment fails. • Backup – A blocked port, which has a backup or redundant path to a LAN segment where a designated port is already connected when a switch has two links to the same LAN segment. • Disabled – Not strictly part of STP. The port can be disabled manually. |
Tree | This is the index number of the STP trees. |
Active | Select this checkbox to activate an STP tree. Clear this checkbox to disable an STP tree. |
Bridge Priority | Bridge priority is used in determining the root switch, root port and designated port. The switch with the highest priority (lowest numeric value) becomes the STP root switch. If all switches have the same priority, the switch with the lowest MAC address will then become the root switch. Select a value from the drop-down list box. The lower the numeric value you assign, the higher the priority for this bridge. Bridge Priority determines the root bridge, which in turn determines Hello Time, Max Age and Forwarding Delay. |
Forwarding Delay | This is the maximum time (in seconds) the Switch will wait before changing states. This delay is required because every switch must receive information about topology changes before it starts to forward frames. In addition, each port needs time to listen for conflicting information that would make it return to a blocking state; otherwise, temporary data loops might result. The allowed range is 4 to 30 seconds. As a general rule: 2 * (Forward Delay – 1) >= Max Age >= 2 * (Hello Time + 1) |
Active | Select this checkbox to activate STP on this port. |
Tree | Select which STP tree configuration this port should participate in. |
CST This section describes the Common Spanning Tree settings. | |
Configuration Name | This field displays the configuration name for this MST region. |
Revision Number | This field displays the revision number for this MST region. |
Configuration Digest | A configuration digest is generated from the VLAN-MSTI mapping information. This field displays the 16-octet signature that is included in an MSTP BPDU. This field displays the digest when MSTP is activated on the system. |
Instance | These fields display the MSTI to VLAN mapping. In other words, which VLANs run on each spanning tree instance. |
Instance | This field displays the MSTI ID. |
VLAN | This field displays which VLANs are mapped to an MSTI. |
MSTI | |
MSTI | Select the MST instance settings you want to view. |
Regional Root refers to the base of the MST instance. Our Bridge is this switch. This Switch may also be the root bridge. | |
Bridge ID | This is the unique identifier for this bridge, consisting of bridge priority plus MAC address. This ID is the same for Regional Root and Our Bridge if the Switch is the root switch. |
Internal Cost | This is the path cost from the root port in this MST instance to the regional root switch. |
Port ID | This is the priority and number of the port on the Switch through which this Switch must communicate with the root of the MST instance. |
Bridge | |
Active | Enable the switch button to activate MSTP on the Switch. Disable the switch to disable MSTP on the Switch. |
Max Age | This is the maximum time (in seconds) a switch can wait without receiving a BPDU before attempting to reconfigure. All switch ports (except for designated ports) should receive BPDUs at regular intervals. Any port that ages out STP information (provided in the last BPDU) becomes the designated port for the attached LAN. If it is a root port, a new root port is selected from among the Switch ports attached to the network. The allowed range is 6 to 40 seconds. |
Forwarding Delay | This is the maximum time (in seconds) a switch will wait before changing states. This delay is required because every switch must receive information about topology changes before it starts to forward frames. In addition, each port needs time to listen for conflicting information that would make it return to a blocking state; otherwise, temporary data loops might result. The allowed range is 4 to 30 seconds. As a general rule: |
Maximum hops | Enter the number of hops (between 1 and 255) in an MSTP region before the BPDU is discarded and the port information is aged. |
Configuration Name | Enter a descriptive name (up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ], or [ , ]) of an MST region. |
Revision Number | Enter a number to identify a region’s configuration. Devices must have the same revision number to belong to the same region. |
Instance Use this section to configure MSTI (Multiple Spanning Tree Instance) settings. | |
Instance | This field displays the ID of an MST instance. |
VLAN | This field displays the VID (or VID ranges) to which the MST instance is mapped. |
Active Port | This field display the ports configured to participate in the MST instance. |
Select an entry’s checkbox to select a specific entry. Otherwise, select the checkbox in the table heading row to select all entries. | |
Add/Edit | Click Add/Edit to add a new instance or edit a selected one. |
Delete | Click Delete to remove the selected instances. |
Instance | Enter the number you want to use to identify this MST instance on the Switch. The Switch supports instance numbers 0 – 16. |
Bridge Priority | Set the priority of the Switch for the specific spanning tree instance. The lower the number, the more likely the Switch will be chosen as the root bridge within the spanning tree instance. Enter priority values between 0 and 61440 in increments of 4096 (thus valid values are 4096, 8192, 12288, 16384, 20480, 24576, 28672, 32768, 36864, 40960, 45056, 49152, 53248, 57344 and 61440). |
VLAN List | Enter the VLAN ID range. You can specify multiple VLAN ID range separated by (no space) comma (,) or hyphen (“-”) for a range. For example, enter “1,3,5-7” for VLANs 1, 3, 5, 6, and 7. |
Port | This field displays the port number. * means all ports. |
Active | Select this checkbox to add this port to the MST instance. |
Priority | Configure the priority for each port here. Priority decides which port should be disabled when more than one port forms a loop in the Switch. Ports with a higher priority numeric value are disabled first. The allowed range is between 0 and 255 and the default value is 128. |
Clear | Click Clear to clear the fields to the factory defaults. |
Cancel | Click Cancel to not save the configuration you make and return to the last screen. |
Index | This field displays the index number of the rule. |
Active | This field displays whether the rule is activated or not. |
Name | This field displays the descriptive name for this rule. This is for identification purpose only. |
MAC Address | This field displays the source or destination MAC address with the VLAN identification number to which the MAC address belongs. |
VID | This field displays the VLAN group identification number. |
Action | This field displays Discard source, Discard destination, or Discard both depending on what you configured above. |
Add/Edit | Click Add/Edit to add a new entry or edit a selected one. |
Delete | Click Delete to remove the selected entries. |
Active | Enable the switch button to activate your rule. You may temporarily deactivate a rule without deleting it by de-selecting this checkbox. |
Name | Enter a descriptive name (up to 32 printable ASCII characters excluding [ ? ], [ | ], [ ' ], [ " ], or [ , ]) for this rule. This is for identification only. |
Action | Select Discard source to drop the frames from the source MAC address (specified in the MAC field). The Switch can still send frames to the MAC address. Select Discard destination to drop the frames to the destination MAC address (specified in the MAC address). The Switch can still receive frames originating from the MAC address. Select Discard source and Discard destination to block traffic to or from the MAC address specified in the MAC field. |
MAC | Enter a MAC address in valid MAC address format, that is, six hexadecimal character pairs. |
VID | Enter the VLAN group identification number. |
Index | This is the index number of a static MAC address rule. |
Active | This field displays whether this static MAC address forwarding rule is active. You may temporarily deactivate a rule without deleting it. |
Name | This field displays the descriptive name for identification purposes for this static MAC address-forwarding rule. |
MAC Address | This field displays the MAC address that will be forwarded and the VLAN identification number to which the MAC address belongs. |
VID | This field displays the ID number of the VLAN group. |
Port | This field displays the port where the MAC address shown in the next field will be forwarded. |
Add/Edit | Click Add/Edit to add a new rule or edit a selected one. |
Delete | Click Delete to remove the selected rules. |
Active | Enable the switch button to activate your rule. You may temporarily deactivate a rule without deleting it by disabling the switch. |
Name | Enter a descriptive name for identification purposes for this static MAC address forwarding rule. You can enter up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ], or [ , ]. |
MAC Address | Enter the MAC address in valid MAC address format, that is, six hexadecimal character pairs. |
VID | Enter the VLAN identification number. |
Port | Enter the port where the MAC address entered in the previous field will be automatically forwarded. |
