Label | Description |
General Settings | |
Action taken when mail sessions threshold is reached | An e-mail session is when an e-mail client and e-mail server (or two e-mail servers) connect through the Zyxel Device. Select how to handle concurrent e-mail sessions that exceed the maximum number of concurrent e-mail sessions that the anti-spam feature can handle. See the chapter of product specifications for the threshold. Select Forward Session to have the Zyxel Device allow the excess e-mail sessions without any spam filtering. Select Drop Session to have the Zyxel Device drop mail connections to stop the excess e-mail sessions. The e-mail client or server will have to re-attempt to send or receive e-mail later when the number of e-mail sessions is under the threshold. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
References | Select an entry and click References to open a screen that shows which settings use the entry.Click Refresh to update information in this screen. |
Priority | This is the index number of the anti-spam rule. Antis-spam rules are applied in turn. |
Name | The name identifies the anti-spam rule. |
Description | This is some optional extra information on the rule. |
Scan Options | This shows which types (protocols) of traffic to scan for spam. |
Reference | This shows how many objects are referenced in the rule. |
Service | |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. |
Service Type | This read-only field displays what kind of service registration you have for the anti-spam scanning. None displays if you have not successfully registered and activated the service. Standard displays if you have successfully registered the Zyxel Device and activated the service with your iCard’s PIN number. Trial displays if you have successfully registered the Zyxel Device and activated the trial service subscription. |
Expiration Date | This field displays the date your service license expires. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
label | description |
Name | Enter a descriptive name for this anti-spam rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Description | Enter a description for the anti-spam rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. This field is optional. |
Log | Select how the Zyxel Device is to log the event when the DNSBL times out or an e-mail matches the white list, black list, or DNSBL. no: Do not create a log. log: Create a log on the Zyxel Device. log alert: An alert is an e-mailed log for more serious events that may need more immediate attention. Select this option to have the Zyxel Device send an alert. |
Scan Options | |
Check White List | Select this check box to check e-mail against the white list. The Zyxel Device classifies e-mail that matches a white list entry as legitimate (not spam). |
Check Black List | Select this check box to check e-mail against the black list. The Zyxel Device classifies e-mail that matches a black list entry as spam. |
Check Mailicious Mail | |
Check DNSBL | Select this check box to check e-mail against the Zyxel Device’s configured DNSBL domains. The Zyxel Device classifies e-mail that matches a DNS black list as spam. |
Actions for Spam Mail | Use this section to set how the Zyxel Device is to handle spam mail. |
SMTP | Select how the Zyxel Device is to handle spam SMTP mail. Select drop to discard spam SMTP mail. Select forward to allow spam SMTP mail to go through. Select forward with tag to add a spam tag to an SMTP spam mail’s mail subject and send it on to the destination. |
POP3 | Select how the Zyxel Device is to handle spam POP3 mail. Select forward to allow spam POP3 mail to go through. Select forward with tag to add a spam tag to an POP3 spam mail’s mail subject and send it on to the destination. |
OK | Click OK to save your changes. |
Cancel | Click Cancel to exit this screen without saving your changes. |
Enable Malicious Mail Checking | |
Query Timeout Settings | |
SMTP | Select how the Zyxel Device is to handle SMTP mail query timeout. Select drop to discard SMTP mail. Select forward to allow SMTP mail to go through. Select forward with tag to add a tag to an SMTP query timeout mail’s mail subject and send it on to the destination. |
POP3 | Select how the Zyxel Device is to handle POP3 mail query timeout. Select forward to allow POP3 mail to go through. Select forward with tag to add a tag to an POP3 query timeout mail’s mail subject and send it on to the destination. |
Timeout Value | Set how long the Zyxel Device waits for a reply from the mail scan server. If there is no reply before this time period expires, the Zyxel Device takes the action defined in the relevant Actions when Query Timeout field. |
Timeout Tag | Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that the Zyxel Device forwards if queries to the mail scan servers time out. |
Timeout X-Header | Specify the name and value for the X-Header to be added when queries to the mail scan servers time out. |
Enable Black List Checking | Select this check box to have the Zyxel Device treat e-mail that matches (an active) black list entry as spam. |
Black List Spam Tag | Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that match the Zyxel Device’s spam black list. |
Black List X-Header | Specify the name and value for the X-Header to be added to e-mails that match the Zyxel Device’s spam black list. |
Rule Summary | |
Add | Click this to create a new entry. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
# | This is the entry’s index number in the list. |
Type | This field displays whether the entry is based on the e-mail’s subject, source or relay IP address, source e-mail address, or header. |
Content | This field displays the subject content, source or relay IP address, source e-mail address, or header value for which the entry checks. |
Enable Rule | Select this to have the Zyxel Device use this entry as part of the black or white list. To actually use the entry, you must also turn on the use of the list in the corresponding list screen, enable the anti-spam feature in the anti-spam general screen, and configure an anti-spam policy to use the list. |
Type | Use this field to base the entry on the e-mail’s subject, source or relay IP address, source e-mail address, or header. Select Subject to have the Zyxel Device check e-mail for specific content in the subject line. Select IP Address to have the Zyxel Device check e-mail for a specific source or relay IP address. Select IPv6 Address to have the Zyxel Device check e-mail for a specific source or relay IPv6 address. Select E-Mail Address to have the Zyxel Device check e-mail for a specific source e-mail address or domain name. Select Mail Header to have the Zyxel Device check e-mail for specific header fields and values. Configure black list header entries to check for e-mail from bulk mail programs or with content commonly used in spam. Configure white list header entries to allow certain header values that identify the e-mail as being from a trusted source. |
Mail Subject Keyword | This field displays when you select the Subject type. Enter up to 63 ASCII characters of text to check for in e-mail headers. Spaces are not allowed, although you could substitute a question mark (?). See Regular Expressions in Black or White List Entries for more details. |
Sender or Mail Relay IP Address | This field displays when you select the IP Address type. Enter an IP address in dotted decimal notation. |
Sender or Mail Relay IPv6 Address | This field displays when you select the IPv6 Address type. Enter an IPv6 address with prefix. |
Netmask | This field displays when you select the IP type. Enter the subnet mask here, if applicable. |
Sender E-Mail Address | This field displays when you select the E-Mail type. Enter a keyword (up to 63 ASCII characters). See Regular Expressions in Black or White List Entries for more details. |
Mail Header Field Name | This field displays when you select the Mail Header type. Type the name part of an e-mail header (the part that comes before the colon). Use up to 63 ASCII characters. For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter “Received” here. |
Field Value Keyword | This field displays when you select the Mail Header type. Type the value part of an e-mail header (the part that comes after the colon). Use up to 63 ASCII characters. For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter the mail server’s domain here. See Regular Expressions in Black or White List Entries for more details. |
Enable White List Checking | Select this check box to have the Zyxel Device forward e-mail that matches (an active) white list entry without doing any more anti-spam checking on that individual e-mail. |
White List X-Header | Specify the name and value for the X-Header to be added to e-mails that match the Zyxel Device’s spam white list. |
Rule Summary | |
Add | Click this to create a new entry. See Anti-Spam Black or White List Add/Edit for details. |
Edit | Select an entry and click this to be able to modify it. See Anti-Spam Black or White List Add/Edit for details. |
Type | This field displays whether the entry is based on the e-mail’s subject, source or relay IP address, source e-mail address, or a header. |
Show Advanced Settings / Hide Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
Enable DNS Black List (DNSBL) Checking | Select this to have the Zyxel Device check the sender and relay IP addresses in e-mail headers against the DNSBL servers maintained by the DNSBL domains listed in the Zyxel Device. |
DNSBL Spam Tag | Enter a message or label (up to 15 ASCII characters) to add to the beginning of the mail subject of e-mails that have a sender or relay IP address in the header that matches a black list maintained by one of the DNSBL domains listed in the Zyxel Device. This tag is only added if the anti-spam policy is configured to forward spam mail with a spam tag. |
Max. IPs Checking Per Mail | Set the maximum number of sender and relay server IP addresses in the mail header to check against the DNSBL domain servers. |
IP Selection Per Mail | Select first N IPs to have the Zyxel Device start checking from the first IP address in the mail header. This is the IP of the sender or the first server that forwarded the mail. Select last N IPs to have the Zyxel Device start checking from the last IP address in the mail header. This is the IP of the last server that forwarded the mail. |
Query Timeout Setting | |
SMTP | Select how the Zyxel Device is to handle SMTP mail (mail going to an e-mail server) if the queries to the DNSBL domains time out. Select drop to discard SMTP mail. Select forward to allow SMTP mail to go through. Select forward with tag to add a DNSBL timeout tag to the mail subject of an SMTP mail and send it. |
POP3 | Select how the Zyxel Device is to handle POP3 mail (mail coming to an e-mail client) if the queries to the DNSBL domains time out. Select forward to allow POP3 mail to go through. Select forward with tag to add a DNSBL timeout tag to the mail subject of an POP3 mail and send it. |
Timeout Value | Set how long the Zyxel Device waits for a reply from the DNSBL domains listed below. If there is no reply before this time period expires, the Zyxel Device takes the action defined in the relevant Actions when Query Timeout field. |
Timeout Tag | Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that the Zyxel Device forwards if queries to the DNSBL domains time out. |
Timeout X-Header | Specify the name and value for the X-Header to be added to e-mails that the Zyxel Device forwards if queries to the DNSBL domains time out. |
DNSBL Domain List | |
DNSBL Domain | This is the name of a domain that maintains DNSBL servers. Enter the domain that is maintaining a DNSBL. |
