zywall | zywall usg |
ZyWALL 110 | USG40 |
ZyWALL 310 | USG40W |
ZyWALL 1100 | USG60 |
USG60W | |
USG110 | |
USG210 | |
USG310 | |
USG1100 | |
USG1900 | |
USG2200 |
Feature | ZyWALL | USG | |||||||||||
110 | 310 | 1100 | 40 | 60 | 40W | 60W | 110 | 210 | 310 | 1100 | 1900 | 2200 | |
Amazon VPC (on Web Configurator) | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only | CLI Only |
Anomaly Detection & Prevention | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
Anti-Spam | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
Anti-Virus | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
AP Controller | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
App Patrol | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
Content Filtering | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
Device HA Pro | YES | YES | YES | NO | NO | NO | NO | YES | YES | YES | YES | YES | YES |
Easy Mode | YES | NO | NO | YES | YES | YES | YES | YES | NO | NO | NO | NO | NO |
Hotspot Management | YES | YES | YES | NO | YES | NO | YES | YES | YES | YES | YES | YES | YES |
IDP | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
IP Exception | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
LAG | NO | YES | YES | NO | NO | NO | NO | NO | NO | YES | YES | YES | YES |
Microsoft Azure | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
Port Role | NO | YES | YES | NO | NO | NO | NO | NO | NO | YES | YES | YES | YES |
Port Group | YES | NO | NO | YES | YES | YES | YES | YES | YES | NO | NO | NO | NO |
Reputation Filter (IP and DNS) | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
Sandboxing | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
SD-WAN mode | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
SecuReporter | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
SSL Application | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES | YES |
SSL Encrypted Traffic Inspection | YES | YES | YES | NO | NO | NO | NO | YES | YES | YES | YES | YES | YES |
URL Threat Filter | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
UTM feature License-need to buy | YES | YES | YES | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr | after 1yr |
Built-in AP | NO | NO | NO | NO | NO | YES | YES | NO | NO | NO | NO | NO | NO |
• Application Patrol (AP) | • Intrusion Detection & Prevention (IDP) |
• Anomaly Detection & Prevention (ADP) | • Content Filtering (CF) |
• Anti-Virus (AV) | • Anti-Spam (AS) |
• Secure Socket Layer (SSL) encrypted traffic Inspection |
• ZyWALL 110 | • ZyWALL 310 | • ZyWALL 1100 |
• USG110 | • USG210 | • USG310 |
• USG1100 | • USG1900 | • USG2200 |
Setting | Value |
Speed | 115200 bps |
Data Bits | 8 |
Parity | None |
Stop Bit | 1 |
Flow Control | Off |
remote management | ssl vpn | ipsec vpn provisioning | two-factor vpn access authentication |
8800 | 8080 | 443 (default) | 8008 |
Label | Description |
Allow secure remote management from WAN | Select this to allow access to the Zyxel Device remotely only from specified IP addresses or Fully Qualified Domain Names (FQDNs), such as 1.1.1.1 or www.zyxel.com. See Secure SSL Access from the Internet to the Zyxel Device for more information. |
Port | Configure a new port between 1024 to 65535 to use it to access the web configurator. Do not use a port number that has been used. For example, use https://1.1.1.1:8800 if you changed the default HTTPS port to 8800. |
Trusted Host 1-3 | Configure the IP addresses or FQDNs that are allowed to access the Zyxel Device. |
Allow SSL VPN access from WAN | Select this to allow SSL VPN clients to access the Zyxel Device only from specified regions. See Secure SSL VPN Access from the Internet to the Network Behind the Zyxel Device for more information. |
Port | Configure a new port between 1024 to 65535 to use it to access the web configurator using SSL VPN. Do not use a port number that has been used. The port you configure here must be the same as the port you use in SecuExtender. See Secure SSL VPN Access from the Internet to the Network Behind the Zyxel Device for more information on SecuExtender. |
Trusted Geolocation 1-3 | Select the regions that are allowed to access the Zyxel Device from the drop-down list box. |
Change Two-Factor Authentication Port | Select this to change the port VPN clients use to access the Zyxel Device LAN with two-factor authentication. See Change the Default Port for Two-Factor VPN Access Authentication for more information. Configure a new port between 1024 to 65535. Do not use a port number that has been used. |
Change Zyxel IPSec VPN Client Provisioning Port | Select this to change the port IPSec VPN clients use to retrieve VPN rule settings from the Zyxel Device. See Change the Default IPSec VPN Provisioning Port for more information. Configure a new port between 1024 to 65535. Do not use a port number that has been used. The port you configure here must be the same as the port you use when logging in as a Zyxel IPSec VPN client. |
Please remind me | Select how often to display the screen from the drop-down list box. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
Web Console | Click this to open one or multiple console windows from which you can run command line interface (CLI) commands. You will be prompted to enter your user name and password. See the Command Reference Guide for information about the commands. Logging in to the Zyxel Device with HTTPS, so you can open one or multiple console windows. |
CLI | Click this to open a popup window that displays the CLI commands sent by the Web Configurator to the Zyxel Device. |
Reference | Click this to check which configuration items reference an object. |
Site Map | Click this to see an overview of links to the Web Configurator screens. |
Community | Go to https://businessforum.zyxel.com/categories/security for security product discussions. |
Help | Click this to open the help page for the current screen. |
About | Click this to display basic information about the Zyxel Device. |
Easy Mode | Click this to go to a mode that contains wizards that help you configure the Zyxel Device, and links to portals. Not all models have this mode. |
Logout | Click this to log out of the Web Configurator. |
Type | Select the type of reference from the drop-down list box. |
Name | Select the specific reference for the type selected. The settings then display in the table below. |
# | This field is a sequential value, and it is not associated with any entry. |
Service | This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window. |
Priority | If it is applicable, this field lists the referencing configuration item’s position in its list, otherwise N/A displays. |
Name | This field identifies the configuration item that references the object. |
Description | If the referencing configuration item has a description configured, it displays here. |
Refresh | Click this to update the information in this screen. |
Cancel | Click Cancel to close the screen. |
Folder or Link | Tab | Function |
System Status | ||
Port Statistics | Port Statistics | Displays packet statistics for each physical port. |
Interface Status | Interface Summary | Displays general interface information and packet statistics. |
Traffic Statistics | Traffic Statistics | Collect and display traffic statistics. |
Session Monitor | Session Monitor | Displays the status of all current sessions. |
IGMP Statistics | IGMP Statistics | Collect and display IGMP statistics. |
DDNS Status | DDNS Status | Displays the status of the Zyxel Device’s DDNS domain names. |
IP/MAC Binding | IP/MAC Binding | Lists the devices that have received an IP address from Zyxel Device interfaces using IP/MAC binding. |
Login Users | Login Users | Lists the users currently logged into the Zyxel Device. |
Dynamic Guest | Dynamic Guest | List the dynamic guest accounts in the Zyxel Device’s local database. |
Cellular Status | Cellular Status | Displays details about the Zyxel Device’s mobile broadband connection status. |
UPnP Port Status | Port Statistics | Displays details about UPnP connections going through the Zyxel Device. |
USB Storage | Storage Information | Displays details about USB device connected to the Zyxel Device. |
Ethernet Neighbor | Ethernet Neighbor | View and manage the Zyxel Device’s neighboring devices via Smart Connect (Layer Link Discovery Protocol (LLDP)). Use the Zyxel One Network (ZON) utility to view and manage the Zyxel Device’s neighboring devices via the Zyxel Discovery Protocol (ZDP). |
FQDN Object | FQDN Object | Displays FQDN (Fully Qualified Domain Name) object cache lists used in DNS queries. |
Wireless | ||
AP Information | AP List | Lists APs managed by the Zyxel Device. |
Radio List | Lists wireless details of APs managed by the Zyxel Device. | |
Top N APs | Lists managed APs with the most wireless traffic usage and most associated wireless stations. | |
Single AP | Lists APs wireless traffic usage and associated wireless stations for a managed AP. | |
ZyMesh | ZyMesh Link Info | Display statistics about ZyMesh wireless connections between managed APs. |
SSID Info | SSID Info | Display information about the SSID’s wireless clients. |
Station Info | Station List | Lists wireless clients associated with the APs managed by the Zyxel Device. |
Top N Stations | Lists wireless stations with the most wireless traffic usage. | |
Single Station | Lists wireless traffic usage for an associated wireless station. | |
Detected Device | Detected Device | Display information about suspected rogue APs. |
Printer Status | Printer Status | Display information about the connected statement printers. |
VPN Monitor | ||
IPSec | IPSec | Displays and manages the active IPSec SAs. |
SSL | SSL | Lists users currently logged into the VPN SSL client portal. You can also log out individual users and delete related session information. |
L2TP over IPSec | L2TP over IPSec | Displays details about current L2TP sessions. |
UTM Statistics | ||
App Patrol | Summary | Displays application patrol statistics. |
Content Filter | Summary | Collect and display content filter statistics |
IDP | Summary | Collect and display statistics on the intrusions that the Zyxel Device has detected. |
Anti-Virus | Summary | Collect and display statistics on the viruses that the Zyxel Device has detected. |
Anti-Spam | Summary | Collect and display spam statistics. |
Status | Displays how many mail sessions the ZyWALL is currently checking and DNSBL (Domain Name Service-based spam Black List) statistics. | |
SSL Inspection | Summary | Collect and display SSL Inspection statistics. |
Certificate Cache List | Displays traffic to destination servers using certificates. | |
Log | View Log | Lists log entries. |
View AP Log | Lists AP log entries. | |
Dynamic Users Log | Display the Zyxel Device’s dynamic guest account log messages. | |
Quick Setup | Quickly configure WAN interfaces or VPN connections. | |
Licensing | ||
Registration | Registration | Register the device and activate trial services. |
Service | View the licensed service status and upgrade licensed services. | |
Signature Update | Anti-Virus | Update anti-virus signatures immediately or by a schedule. |
IDP/AppPatrol | Update IDP signatures immediately or by a schedule. | |
Wireless | ||
Controller | Configuration | Configure manual or automatic controller registration. |
AP Management | Mgnt AP List | Edit or remove entries in the lists of APs managed by the Zyxel Device. |
AP Policy | Configure the AP controller’s IP address on the managed APs and determine the action the managed APs take if the current AP controller fails. | |
AP Group | Create groups of APs, define their radio, VLAN, port and load balancing settings. | |
Firmware | Update the firmware on APs connected to your Zyxel Device. | |
Rogue AP | Rogue/Friendly AP List | Configure how the Zyxel Device monitors rogue APs. |
Load Balancing | Load Balancing | Configure load balancing for traffic moving to and from wireless clients. |
DCS | DCS | Configure dynamic wireless channel selection. |
Auto Healing | Auto Healing | Enable auto healing to extend the wireless service coverage area of the managed APs when one of the APs fails. |
RTLS | Real Time Location System | Use the managed APs as part of an Ekahau RTLS to track the location of Ekahau WiFi tags. |
Network | ||
Interface | Port Port Role/Port Configuration | Use the Port Role screen to set the Zyxel Device’s flexible ports such as LAN, OPT, WLAN, or DMZ. Use the Port Configuration screen to configure settings for individual Zyxel Device ports. |
Ethernet | Manage Ethernet interfaces and virtual Ethernet interfaces. | |
PPP | Create and manage PPPoE and PPTP interfaces. | |
Cellular | Configure a cellular Internet connection for an installed mobile broadband card. | |
Tunnel | Configure tunneling between IPv4 and IPv6 networks. | |
VLAN | Create and manage VLAN interfaces and virtual VLAN interfaces. | |
Bridge | Create and manage bridges and virtual bridge interfaces. | |
VTI | Configure IP address assignment and interface parameters for VTI (Virtual Tunnel Interface). | |
Trunk | Create and manage trunks (groups of interfaces) for load balancing. | |
Routing | Policy Route | Create and manage routing policies. |
Static Route | Create and manage IP static routing information. | |
RIP | Configure device-level RIP settings. | |
OSPF | Configure device-level OSPF settings, including areas and virtual links. | |
BGP | Configure exchange of Border Gateway Protocol (BGP) information over an IPSec tunnel. | |
DDNS | DDNS | Define and manage the Zyxel Device’s DDNS domain names. |
NAT | NAT | Set up and manage port forwarding rules. |
Redirect Service | Redirect Service | Set up and manage HTTP and SMTP redirection rules. |
ALG | ALG | Configure SIP, H.323, and FTP pass-through settings. |
UPnP | UPnP | Configure interfaces that allow UPnP and NAT-PMP connections. |
IP/MAC Binding | Summary | Configure IP to MAC address bindings for devices connected to each supported interface. |
Exempt List | Configure ranges of IP addresses to which the Zyxel Device does not apply IP/MAC binding. | |
Layer 2 Isolation | General | Enable layer-2 isolation on the Zyxel Device and the internal interface(s). |
White List | Enable and configure the white list. | |
DNS Inbound LB | DNS Load Balancing | Configure DNS Load Balancing. |
Web Authentication | Web Authentication General/Authentication Type/Custom Web Portal File/Custom User Agreement File/Facebook Wi-Fi | Define a web portal and exempt services from authentication. |
SSO | Configure the Zyxel Device to work with a Single Sign On agent. | |
Hotspot | ||
Billing | General | Configure the general billing settings, such as the accounting method. |
Billing Profile | Configure the billing profiles for the web-based account generator and each button on the connected statement printer. | |
Discount | Configure discount price plans. | |
Payment Service | Enable online payment service and configure the service pages. | |
Printer Manager | General | Configure the printer list, enable printer management and customize the account printout. |
Printout Configuration | Detect the connected statement printers, change their IP addresses and/or add them to the managed printer list. | |
Free Time | Free Time | Allow users to get a free account for Internet surfing during the specified time period. |
IPnP | IPnP | Enable IPnP on the Zyxel Device and the internal interface(s). |
Walled Garden | Walled Garden General/URL Base/Domain/IP Base | Create walled garden links that display in the login screen. |
Advertisement | Advertisement | Enable and set advertisement links. |
Security Policy | ||
Policy Control | Policy | Create and manage level-3 traffic rules and apply UTM profiles. |
ADP | General | Display and manage ADP bindings. |
Profile | Create and manage ADP profiles. | |
Session Control | Session Control | Limit the number of concurrent client NAT/security policy sessions. |
Cloud CNM | SecuManager | Enable and configure management of the Zyxel Device by a Central Network Management system. |
SecuReporter | Enable SecuReporter logging and access the SecuReporter security analytics portal that collects and analyzes logs from your Zyxel Device in order to identify anomalies, alert on potential internal / external threats, and report on network usage. | |
VPN | ||
IPSec VPN | VPN Connection | Configure IPSec tunnels. |
VPN Gateway | Configure IKE tunnels. | |
Concentrator | Combine IPSec VPN connections into a single secure network | |
Configuration Provisioning | Set who can retrieve VPN rule settings from the Zyxel Device using the Zyxel Device IPSec VPN Client. | |
SSL VPN | Access Privilege | Configure SSL VPN access rights for users and groups. |
Global Setting | Configure the Zyxel Device’s SSL VPN settings that apply to all connections. | |
L2TP VPN | L2TP VPN | Configure L2TP over IPSec tunnels. |
BWM | BWM | Enable and configure bandwidth management rules. |
UTM Profile | ||
AppPatrol | Profile | Manage different types of traffic in this screen. Create App Patrol template(s) of settings to apply to a traffic flow using a security policy. |
Content Filter | Profile | Create and manage the detailed filtering rules for content filtering profiles and then apply to a traffic flow using a security policy. |
Trusted Web Sites | Create a list of allowed web sites that bypass content filtering policies. | |
Forbidden Web Sites | Create a list of web sites to block regardless of content filtering policies. | |
IDP | Profile | Create IDP template(s) of settings to apply to a traffic flow using a security policy. |
Custom Signatures | Create, import, or export custom signatures. | |
Anti-Virus | Profile | Create anti-virus template(s) of settings to apply to a traffic flow using a security policy. |
Black/White List | Set up a black list to identify files with virus file patterns and a white list to identify files that should not be checked for AV. | |
Signature | Search for signatures by signature name or attributes and configure how the Zyxel Device uses them. | |
Anti-Spam | Profile | Turn anti-spam on or off and manage anti-spam policies. Create anti-spam template(s) of settings to apply to a traffic flow using a security policy. |
Mail Scan | Configure e-mail scanning details. | |
Black/White List | Set up a black list to identify spam and a white list to identify legitimate e-mail. | |
DNSBL | Have the ZyWALL check e-mail against DNS Black Lists. | |
SSL Inspection | Profile | Decrypt HTTPS traffic for UTM inspection. Create SSL Inspection template(s) of settings to apply to a traffic flow using a security policy. |
Exclude List | Configure services to be excluded from SSL Inspection. | |
Certificate Update | Use this screen to update the latest certificates of servers using SSL connections to the Zyxel Device network. | |
Device HA | General | Configure Device HA global settings, and see the status of each interface monitored by Device HA. View Device HA Pro license information. |
Device HA Pro | Configure Device HA Pro global, monitored interfaces and synchronization settings. | |
Device HA | Configure active-passive mode Device HA. See Device HA Pro logs. | |
Object | ||
Zone | Zone | Configure zone template(s) used to define various policies. |
User/Group | User | Create and manage users. |
Group | Create and manage groups of users. | |
Setting | Manage default settings for all users, general settings for user sessions, and rules to force user authentication. | |
MAC Address | Configure the MAC addresses of wireless clients for MAC authentication using the local user database. | |
AP Profile | Radio | Create template(s) of radio settings to apply to policies as an object. |
SSID SSID List/Security List/MAC Filter List | Create template(s) of wireless settings to apply to radio profiles or policies as an object. | |
MON Profile | MON Profile | Create and manage rogue AP monitoring files that can be associated with different APs. |
ZyMesh Profile | ZyMesh Profile | Create and manage ZyMesh files that can be associated with different APs. |
Application | Application | Create template(s) of services to apply to policies as an object. |
Application Group | Create and manage groups of applications to apply to policies as a single object. | |
Address/Geo IP | Address | Create and manage host, range, and network (subnet) addresses. |
Address Group | Create and manage groups of addresses to apply to policies as a single objects. | |
Geo IP | Update the database of country-to-IP address mappings and manually configure country-to-IP address mappings for geographic address objects that can be used in security policies. | |
Service | Service | Create and manage TCP and UDP services. |
Service Group | Create and manage groups of services to apply to policies as a single object. | |
Schedule | Schedule | Create one-time and recurring schedules. |
Schedule Group | Create and manage groups of schedules to apply to policies as a single object. | |
AAA Server | Active Directory | Configure the Active Directory settings. |
LDAP | Configure the LDAP settings. | |
RADIUS | Configure the RADIUS settings. | |
Auth. Method | Authentication Method | Create and manage ways of authenticating users. |
Two-factor Authentication | Configure SMS/email authentication to access a secured network behind the Zyxel Device via a VPN tunnel. | |
Certificate | My Certificates | Create and manage the Zyxel Device’s certificates. |
Trusted Certificates | Import and manage certificates from trusted sources. | |
ISP Account | ISP Account | Create and manage ISP account information for PPPoE/PPTP interfaces. |
SSL Application | SSL Application | Create SSL web application or file sharing objects to apply to policies. |
System | ||
Host Name | Host Name | Configure the system and domain name for the Zyxel Device. |
USB Storage | Settings | Configure the settings for the connected USB devices. |
Date/Time | Date/Time | Configure the current date, time, and time zone in the Zyxel Device. |
Console Speed | Console Speed | Set the console speed. |
DNS | DNS | Configure the DNS server and address records for the Zyxel Device. |
WWW | Service Control | Configure HTTP, HTTPS, and general authentication. |
Login Page Desktop View/Mobile View | Configure how the login and access user screens look. | |
SSH | SSH | Configure SSH server and SSH service settings. |
TELNET | TELNET | Configure telnet server settings for the Zyxel Device. |
FTP | FTP | Configure FTP server settings. |
SNMP | SNMP | Configure SNMP communities and services. |
Auth. Server | Auth. Server | Configure the Zyxel Device to act as a RADIUS server. |
Notification | Mail Server | Configure a mail server with authentication to send reports and password expiration notification emails. |
SMS | Enable the SMS service to send dynamic guest account information in text messages and authorization for VPN tunnel access to a secured network. | |
Language | Language | Select the Web Configurator language. |
IPv6 | IPv6 | Enable IPv6 globally on the Zyxel Device here. |
ZON | ZON | Use the Zyxel One Network (ZON) utility to view and manage the Zyxel Device’s neighboring devices via the Zyxel Discovery Protocol (ZDP). |
Log & Report | ||
Email Daily Report | Email Daily Report | Configure where and how to send daily reports and what reports to send. |
Log Settings | Log Settings | Configure the system log, e-mail logs, and remote syslog servers. |
File Manager | Configuration File | Manage and upload configuration files for the Zyxel Device. |
Firmware Management | View the current firmware version and upload firmware. Reboot with your choice of firmware. | |
Shell Script | Manage and run shell script files for the Zyxel Device. | |
Diagnostics | Diagnostics Collect Collect on AP Files | Collect diagnostic information. |
Packet Capture Capture/Capture on AP/Files | Capture packets for analysis. | |
CPU/Memory Status | View CPU and memory usage statistics. | |
System Log | Connect a USB device to the Zyxel Device and archive the Zyxel Device system logs to it here. | |
Network Tool | Identify problems with the connections. You can use Ping or Traceroute to help you identify problems. | |
Routing Traces | Configure traceroute to identify where packets are dropped for troubleshooting. | |
Packet Flow Explore | Routing Status | Check how the Zyxel Device determines where to route a packet. |
SNAT Status | View a clear picture on how the Zyxel Device converts a packet’s source IP address and check the related settings. | |
Shutdown | Shutdown | Turn off the Zyxel Device. |
Add | Click this to create a new entry. For features where the entry’s position in the numbered list is important (features where the Zyxel Device applies the table’s entries in order like the security policy for example), you can select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Connect | To connect an entry, select it and click Connect. |
Disconnect | To disconnect an entry, select it and click Disconnect. |
References | Select an entry and click References to check which settings use the entry. |
Move | To change an entry’s position in a numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed. For example, if you type 6, the entry you are moving becomes number 6 and the previous entry 6 (if there is one) gets pushed up (or down) one. |
