label | Description |
Profile Management | |
Add | Click Add to create a new profile. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
References | Select an entry and click References to open a screen that shows which settings use the entry.Click Refresh to update information on this screen. |
# | This is the entry’s index number in the list. |
Name | This displays the name of the profile. |
Description | This displays the description of the profile. |
CA Certificate | This displays the CA certificate being used in this profile. |
Reference | This displays the number of times an object reference is used in a profile. |
LABEL | Description |
Name | This is the name of the profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names: • MyProfile • mYProfile • Mymy12_3-4 These are invalid profile names: • 1mYProfile • My Profile • MyProfile? • Whatalongprofilename123456789012 |
Description | Enter additional information about this SSL Inspection entry. You can enter up to 60 characters ("0-9", "a-z", "A-Z", "-" and "_"). |
CA Certificate | This contains the default certificate and the certificates created in Object > Certificate > My Certificates. Choose the certificate for this profile. |
Severity Level | Select a severity level and these use the icons to enable/disable and configure logs and actions for all signatures of that level. |
Action for connection with SSL v2 | SSL Inspection supports SSLv3 and TLS1.0. Select to pass or block SSLv2 traffic that matches traffic bound to this policy here. |
Log | These are the log options for SSLv2 traffic that matches traffic bound to this policy: • no: Select this option to have the Zyxel Device create no log for SSLv2 traffic that matches traffic bound to this policy. • log: Select this option to have the Zyxel Device create a log for SSLv2 traffic that matches traffic bound to this policy. • log alert: An alert is an e-mailed log for more serious events that may need more immediate attention. They also appear in red in the Monitor > Log screen. Select this option to have the Zyxel Device send an alert for SSLv2 traffic that matches traffic bound to this policy. |
Action for Connection with unsupported suit | SSL Inspection supports these cipher suites: • DES • 3DES • AES Select to pass or block unsupported traffic (such as other cipher suites, compressed traffic, client authentication requests, and so on) that matches traffic bound to this policy here. |
Log | These are the log options for unsupported traffic that matches traffic bound to this policy: • no: Select this option to have the Zyxel Device create no log for unsupported traffic that matches traffic bound to this policy. • log: Select this option to have the Zyxel Device create a log for unsupported traffic that matches traffic bound to this policy • log alert: An alert is an e-mailed log for more serious events that may need more immediate attention. They also appear in red in the Monitor > Log screen. Select this option to have the Zyxel Device send an alert for unsupported traffic that matches traffic bound to this policy. |
Excepted Signatures | Use the icons to enable/disable and configure logs and actions for individual signatures that are different to the general settings configured for the severity level to which the signatures belong. Signatures configured in Query View will appear in Group View. |
Add | Click this to configure settings to a signature that are different to the severity level to which it belongs. |
Remove | Select an existing signature exception and then click this to delete the exception. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Log | To edit an item’s log option, select it and use the Log icon. These are the log options: no: Select this option on an individual signature or a complete service group to have the Zyxel Device create no log when a packet matches a signature(s). log: Select this option on an individual signature or a complete service group to have the Zyxel Device create a log when a packet matches a signature(s). log alert: An alert is an e-mailed log for more serious events that may need more immediate attention. Select this option to have the Zyxel Device send an alert when a packet matches a signature(s). |
Action | To edit what action the Zyxel Device takes when a packet matches a signature, select the signature and use the Action icon. none: Select this action on an individual signature or a complete service group to have the Zyxel Device take no action when a packet matches the signature(s). drop: Select this action on an individual signature or a complete service group to have the Zyxel Device silently drop a packet that matches the signature(s). Neither sender nor receiver are notified. reject-sender: Select this action on an individual signature or a complete service group to have the Zyxel Device send a reset to the sender when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with a ‘RST’ flag. If it is an ICMP or UDP attack packet, the Zyxel Device will send an ICMP unreachable packet. reject-receiver: Select this action on an individual signature or a complete service group to have the Zyxel Device send a reset to the receiver when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with an a ‘RST’ flag. If it is an ICMP or UDP attack packet, the Zyxel Device will do nothing. reject-both: Select this action on an individual signature or a complete service group to have the Zyxel Device send a reset to both the sender and receiver when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with a ‘RST’ flag to the receiver and sender. If it is an ICMP or UDP attack packet, the Zyxel Device will send an ICMP unreachable packet. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
SID | Type the exact signature ID (identification) number that uniquely identifies a Zyxel Device IDP signature. |
Log | These are the log options. To edit this, select an item and use the Log icon. |
Action | This is the action the Zyxel Device should take when a packet matches a signature here. To edit this, select an item and use the Action icon. |
OK | Click OK to save your settings to the Zyxel Device, and return to the profile summary page. |
Cancel | Click Cancel to return to the profile summary page without saving any changes. |
General Settings | |
Enable Logs for Exclude List | Click this to create a log for traffic that bypasses SSL Inspection. |
Exclude List Settings | Use this part of the screen to create, edit, or delete items in the SSL Inspection exclusion list. |
Add | Click this to create a new entry. |
Exclude List of Certificate Identity | SSL traffic to a server to be excluded from SSL Inspection is identified by its certificate. Identify the certificate in one of the following ways: • The Common Name (CN) of the certificate. The common name of the certificate can be created in the Object > Certificate > My Certificates screen. • Type an IPv4 or IPv6 address. For example, type 192.168.1.35, or 2001:7300:3500::1 • Type an IPv4/IPv6 in CIDR notation. For example, type 192.168.1.1/24, or 2001:7300:3500::1/64 • Type an IPv4/IPv6 address range. For example, type 192.168.1.1-192.168.1.35, or 2001:7300:3500::1-2001:7300:3500::35 • Type an email address. For example, type abc@zyxel.com.tw • Type a DNS name or a common name (wildcard char: '*', escape char: '\'). Use up to 127 case-insensitive characters (0-9a-zA-Z`~!@#$%^&*()-_=+[]{}\|;:',.<>/?). ‘*’ can be used as a wildcard to match any string. Use ‘\*’ to indicate a single wildcard character. Alternatively, to automatically add an entry for existing SSL traffic to a destination server, go to Monitor > UTM Statistics > SSL Inspection > Certificate Cache List, select an item and then click Add to Exclude List. The item will then appear here. |
Apply | Click Apply to save your settings to the Zyxel Device. |
Reset | Click Reset to return to the profile summary page without saving any changes. |
Certificate Information | |
Current Version | This displays the current certificate set version. |
Certificate Update | You should have Internet access and have activated SSL Inspection on the Zyxel Device at myZyxel. |
Update Now | Click this button to download the latest certificate set (Windows, MAC OS X, and Android) from the myZyxel and update it on the Zyxel Device. |
Auto Update | Select this to automatically have the Zyxel Device update the certificate set when a new one becomes available on myZyxel. |
