label | description |
File Path | Click Choose File or Browse to find the certificate file you want to upload. |
Password | Enter the certificate file’s password that was created when the PKCS #12 file was exported. The password consists of up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ] or [ , ]. |
Import | Click this button to save the certificate that you have enrolled from a certification authority from your computer to the Switch. |
Service | This field displays the service type that this certificate is for. |
Subject | This field displays identifying information about the certificate’s owner, such as CN (Common Name), OU (Organizational Unit or department), O (Organization or company) and C (Country). It is recommended that each certificate have unique subject information. |
Issuer | This field displays identifying information about the certificate’s issuing certification authority, such as a common name, organizational unit or department, organization or company and country. |
Valid From | This field displays the date that the certificate becomes applicable. |
Valid To | This field displays the date that the certificate expires. |
Select an entry’s checkbox to select a specific entry. | |
Delete | Click this button to delete the certificate (or certification request). You cannot delete a certificate that one or more features is configured to use. |
Maximum number of cluster members | 24 |
Cluster Member Models | Must be compatible with Zyxel cluster management implementation. |
Cluster Manager | The through which you manage the cluster member switches. |
Cluster Members | The switches being managed by the cluster manager Switch. |
label | Description |
Status | This field displays the role of this Switch within the cluster. Manager Member (you see this if you access this screen in the cluster member Switch directly and not through the cluster manager) None (neither a manager nor a member of a cluster) |
Manager | This field displays the cluster manager Switch’s hardware MAC address. |
The Number Of Member | This field displays the number of switches that make up this cluster. The following fields describe the cluster member switches. |
Index | You can manage cluster member switches through the cluster manager Switch. Each number in the Index column is a hyperlink leading to the cluster member Switch’s Web Configurator. |
MAC Address | This is the cluster member Switch’s hardware MAC address. |
Name | This is the cluster member Switch’s System Name. |
Model | This field displays the model name. |
Status | This field displays: Online (the cluster member Switch is accessible) Error (for example the cluster member Switch password was changed or the Switch was set as the manager and so left the member list, and so on) Offline (the Switch is disconnected – Offline shows approximately 1.5 minutes after the link between cluster member and manager goes down) |
Clustering Manager | The following fields relate to configuring the cluster manager. |
Active | Enable the switch button to have this Switch become the cluster manager switch. A cluster can only have one manager. Other (directly connected) switches that are set to be cluster managers will not be visible in the Clustering Candidates list. If a Switch that was previously a cluster member is later set to become a cluster manager, then its Status is displayed as Error in the Cluster Management Status screen and a warning icon appears in the member summary list below. |
Name | Type a name to identify the Clustering Manager. You may use up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ] or [ , ]. (spaces are allowed). |
VID | This is the VLAN ID and is only applicable if the Switch is set to 802.1Q VLAN. All switches must be directly connected and in the same VLAN group to belong to the same cluster. Switches that are not in the same VLAN group are not visible in the Clustering Candidates list. This field is ignored if the Clustering Manager is using Port-based VLAN. |
Apply | Click Apply to save your changes to the Switch’s run-time memory. The Switch loses these changes if it is turned off or loses power, so use the Save link on the top navigation panel to save your changes to the non-volatile memory when you are done configuring. |
Cancel | Click Cancel to begin configuring this screen afresh. |
Clustering Candidate | The next summary table shows the information for the clustering members configured. |
Add/Edit | Click this button to create or configure a clustering candidate. |
Delete | Click this button to remove the clustering candidate. |
Select an entry’s checkbox to select a specific entry. Otherwise, select the checkbox in the table heading row to select all entries. | |
Index | This is the index number of a cluster member switch. |
MAC Address | This is the cluster member switch’s hardware MAC address. |
Name | This is the cluster member switch’s System Name. |
Model | This is the cluster member switch’s model name. |
List | A list of suitable candidates found by auto-discovery is shown here. The switches must be directly connected. Directly connected switches that are set to be cluster managers will not be visible in the Clustering Candidate list. Switches that are not in the same management VLAN group will not be visible in the Clustering Candidate list. |
Password | Each cluster member’s password is its Web Configurator password. Select a member in the Clustering Candidate list and then enter its Web Configurator password. If that switch administrator changes the Web Configurator password afterwards, then it cannot be managed from the Cluster Manager. Its Status is displayed as Error in the Cluster Management Status screen. If multiple devices have the same password then hold [SHIFT] and click those switches to select them. Then enter their common Web Configurator password. You can enter up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ] or [ , ]. |
Clear | Click Clear to reset the fields to the factory defaults. |
Configure Clone | |
Source/Destination Port | Enter the source port under the Source label. This port’s attributes are copied. Enter the destination port or ports under the Destination label. These are the ports which are going to have the same attributes as the source port. You can enter individual ports separated by a comma or a range of ports by using a dash. Example: 2, 4, 6 indicates that ports 2, 4 and 6 are the destination ports. 2-6 indicates that ports 2 through 6 are the destination ports. |
Port Features | |
Select a feature’s checkbox to select a specific feature. Otherwise, select the checkbox in the table heading row to select all features for a category. | |
SYSTEM | Select the system feature (you configured in the SYSTEM menus) to be copied to the destination ports. Otherwise, select the SYSTEM checkbox in the table heading row to select all features for a category. |
PORT | Select which port features (you configured in the PORT menus) should be copied to the destination ports. Otherwise, select the PORT checkbox in the table heading row to select all features for a category. |
SWITCHING | Select which switching features (you configured in the SWITCHING menus) should be copied to the destination ports. Otherwise, select the SWITCHING checkbox in the table heading row to select all features for a category. |
NETWORKING | Select the networking feature (you configured in the NETWORKING menus) to be copied to the destination ports. Otherwise, select the NETWORKING checkbox in the table heading row to select all features for a category. |
SECURITY | Select which security features (you configured in the SECURITY menus) should be copied to the destination ports. Otherwise, select the SECURITY checkbox in the table heading row to select all features for a category. |
LABEL | DESCRIPTION |
Ping Test | |
IPv4 | Select this option if you want to ping an IPv4 address. Otherwise, select – to send ping requests to all VLANs on the Switch. |
IPv6 | Select this option if you want to ping an IPv6 address. You can also select vlan and specify the ID number of the VLAN to which the Switch is to send ping requests. Otherwise, select – to send ping requests to all VLANs on the Switch. |
IP Address/Host Name | Type the IP address or host name of a device that you want to ping in order to test a connection. Click Ping to have the Switch ping the IP address. |
Source IP Address | Type the source IP address that you want to ping in order to test a connection. Click Ping to have the Switch ping the IP address. |
Count | Enter the number of ICMP Echo Request (ping) messages the Switch continuously sends. |
Trace Route Test | |
IPv4 | Select this option if you want to trace the route packets taken to a device with an IPv4 address. Otherwise, select – to trace the path on any VLAN. ![]() |
IPv6 | Select this option if you want to trace the route packets taken to a device with an IPv6 address. |
IP Address/Host Name | Enter the IP address or host name of a device to which you want to perform a traceroute. Click Trace Route to have the Switch perform the traceroute function. This determines the path a packet takes to the specified device. |
TTL | Enter the Time To Live (TTL) value for the ICMP Echo Request packets. This is to set the maximum number of the hops (routers) a packet can travel through. Each router along the path will decrement the TTL value by one and forward the packets. When the TTL value becomes zero and the destination is not found, the router drops the packets and informs the sender. |
Wait Time | Specify how many seconds the Switch waits for a response to a probe before running another traceroute. |
Queries | Specify how many times the Switch performs the traceroute function. |
Ethernet Port Test | |
Port | Enter a port number and click Port Test to perform an internal loopback test. |
Cable Diagnostics | |
Port | Enter an Ethernet port number and click Diagnose to perform a physical wire-pair test of the Ethernet connections on the specified ports. The following fields display when you diagnose a port. |
Locator LED | |
Enter a time interval (in minutes) and click Blink to show the actual location of the Switch between several devices in a rack. The default time interval is 30 minutes. Click Stop to have the Switch terminate the blinking locater LED. |
Name | This is the name of the Switch that you are configuring. |
Version | The Switch has 2 firmware sets, Firmware 1 and Firmware 2, residing in flash. • Running shows the version number (and model code) and MM/DD/YYYY creation date of the firmware currently in use on the Switch (Firmware 1 or Firmware 2). The firmware information is also displayed at System Information in Basic Setting. • Firmware 1 shows its version number (and model code) and MM/DD/YYYY creation date. • Firmware 2 shows its version number (and model code) and MM/DD/YYYY creation date. |
Boot Image | |
Current Boot Image | This displays which firmware is currently in use on the Switch (Firmware 1 or Firmware 2). |
Config Boot Image | Select which firmware (Firmware 1 or Firmware 2) should load, click Apply and reboot the Switch to see changes, you will also see changes in the Current Boot Image field above as well. |
Firmware | Choose to upload the new firmware to (Firmware) 1 or (Firmware) 2. |
File Path | Click Choose File or Browse to locate the firmware file you wish to upload to the Switch. |
Upgrade | Click Upgrade to load the new firmware. Firmwares are only applied after a reboot. To reboot, go to MAINTENANCE > Reboot System and click Config 1, Config 2 or Factory Default (Config 1, Config 2, Factory Default, and Custom Default are the configuration files you want the Switch to use when it restarts). |
File Path | Click Choose File or Browse to find the authorized key file you want to upload. |
Import | Click this button to save the authorized key file you want to import from your computer to the Switch. |
Select an entry’s checkbox to select a specific key. | |
User | This field displays the user name of the authorized key file (up to 32 characters). |
Hostname | This field displays the hostname of the authorized key file (up to 32 characters only). |
Content | This field displays the actual encryption key’s text string (up to 64 characters). |
Delete | After selecting an entry’s checkbox, click this button to delete the authorized key file. |
RSA | At the time of writing, the Switch supports RSA encryption for the SSH host key. See SSH Authorized Keys for information about the RSA. |
Regenerate Key | Click this button to regenerate the Switch's default host key. ![]() |
Label | description |
CPU | Type a number ranging from 50 to 100 in the CPU threshold box, and type another number ranging from 5 to 60 in the seconds box then click Apply. For example, 80 for CPU threshold and 5 for seconds means a log will be created when CPU utilization reaches over 80% and lasts for 5 seconds. The log report holds 7 days of CPU log data and is stored in volatile memory (RAM). The data is lost if the Switch is turned off or in event of power outage. After 7 days, the logs wrap around and new ones and replace the earliest ones. The higher the CPU threshold number, the fewer logs will be created, and the less data technical support will have to analyze and vice versa. |
Mbuf | Type a number ranging from 50 to 100 in the Mbuf (Memory Buffer) threshold box. The Mbuf log report is stored in flash (permanent) memory. For example, Mbuf 50 means a log will be created when the Mbuf utilization is over 50%. The higher the Mbuf threshold number, the fewer logs will be created, and the less data technical support will have to analyze and vice versa. |
All | Click Download to see all the log report and system status. This log report is stored in flash memory. If the All log report is too large, you can download the log reports separately below. |
Crash | Click Download to see the crash log report. The log will include information of the last crash and is stored in flash memory. |
CPU | Click Download to see the CPU history log report. The 7-days log is stored in RAM and you will need to save it, otherwise it will be lost when the Switch is shutdown or during power outage. |
Memory | Click Download to see the memory section log report. This log report is stored in flash memory. |
Mbuf | Click Download to see the Mbuf (Memory Buffer) log report. This log report is stored in flash memory. |
ROM | Click Download to see the Read Only Memory (ROM) log report. This report is stored in flash memory. |
L3 | Click Download to see the layer-3 Switch log report. The log only applies to the layer-3 Switch models. This report is stored in flash memory. |
