Label | Description |
System Name | Enter a descriptive name to identify your Zyxel Device device. This name can be up to 64 alphanumeric characters long. Spaces are not allowed, but dashes (-) underscores (_) and periods (.) are accepted. |
Domain Name | Enter the domain name (if you know it) here. This name is propagated to DHCP clients connected to interfaces with the DHCP server enabled. This name can be up to 254 alphanumeric characters long. Spaces are not allowed, but dashes “-” are accepted. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Activate USB storage service | Select this if you want to use the connected USB device(s). |
Disk full warning when remaining space is less than | Set a number and select a unit (MB or %) to have the Zyxel Device send a warning message when the remaining USB storage space is less than the value you set here. |
Current Time and Date | |
Current Time | This field displays the present time of your Zyxel Device. |
Current Date | This field displays the present date of your Zyxel Device. |
Time and Date Setup | |
Manual | Select this radio button to enter the time and date manually. If you configure a new time and date, time zone and daylight saving at the same time, the time zone and daylight saving will affect the new time and date you entered. When you enter the time settings manually, the Zyxel Device uses the new setting once you click Apply. |
New Time (hh-mm-ss) | This field displays the last updated time from the time server or the last time configured manually. When you set Time and Date Setup to Manual, enter the new time in this field and then click Apply. |
New Date (yyyy-mm-dd) | This field displays the last updated date from the time server or the last date configured manually. When you set Time and Date Setup to Manual, enter the new date in this field and then click Apply. |
Get from Time Server | Select this radio button to have the Zyxel Device get the time and date from the time server you specify below. The Zyxel Device requests time and date settings from the time server under the following circumstances. • When the Zyxel Device starts up. • When you click Apply or Synchronize Now in this screen. • 24-hour intervals after starting up. |
Time Server Address | Enter the IP address or URL of your time server. Check with your ISP/network administrator if you are unsure of this information. |
Sync. Now | Click this button to have the Zyxel Device get the time and date from a time server (see the Time Server Address field). This also saves your changes (except the daylight saving settings). |
Time Zone Setup | |
Time Zone | Choose the time zone of your location. This will set the time difference between your time zone and Greenwich Mean Time (GMT). |
Automatically Sync Time Zone | Select this for the Zyxel Device to automatically get its time zone. |
Daylight Saving | |
Enable Daylight Savings | Daylight savings is a period from late spring to early fall when many countries set their clocks ahead of normal local time by one hour to give more daytime light in the evening. Select this option if you use Daylight Saving Time. |
Automatically adjust clock for Daylight Saving Time | Select this for the Zyxel Device to automatically adjust the time if daylight savings is implemented in its time zone. |
Start Date | Configure the day and time when Daylight Saving Time starts if you selected Enable Daylight Saving. The at field uses the 24 hour format. Here are a couple of examples: Daylight Saving Time starts in most parts of the United States on the second Sunday of March. Each time zone in the United States starts using Daylight Saving Time at 2 A.M. local time. So in the United States you would select Second, Sunday, March and type 2 in the at field. Daylight Saving Time starts in the European Union on the last Sunday of March. All of the time zones in the European Union start using Daylight Saving Time at the same moment (1 A.M. GMT or UTC). So in the European Union you would select Last, Sunday, March. The time you type in the at field depends on your time zone. In Germany for instance, you would type 2 because Germany's time zone is one hour ahead of GMT or UTC (GMT+1). |
End Date | Configure the day and time when Daylight Saving Time ends if you selected Enable Daylight Saving. The at field uses the 24 hour format. Here are a couple of examples: Daylight Saving Time ends in the United States on the first Sunday of November. Each time zone in the United States stops using Daylight Saving Time at 2 A.M. local time. So in the United States you would select First, Sunday, November and type 2 in the at field. Daylight Saving Time ends in the European Union on the last Sunday of October. All of the time zones in the European Union stop using Daylight Saving Time at the same moment (1 A.M. GMT or UTC). So in the European Union you would select Last, Sunday, October. The time you type in the at field depends on your time zone. In Germany for instance, you would type 2 because Germany's time zone is one hour ahead of GMT or UTC (GMT+1). |
Offset | Specify how much the clock changes when daylight saving begins and ends. Enter a number from 1 to 5.5 (by 0.5 increments). For example, if you set this field to 3.5, a log occurred at 6 P.M. in local official time will appear as if it had occurred at 10:30 P.M. |
0.pool.ntp.org |
1.pool.ntp.org |
2.pool.ntp.org |
Console Port Speed | Use the drop-down list box to change the speed of the console port. Your Zyxel Device supports 9600, 19200, 38400, 57600, and 115200 bps (default) for the console port. The Console Port Speed applies to a console port connection using terminal emulation software and NOT the Console in the Zyxel Device Web Configurator Status screen. |
Address/PTR Record | This record specifies the mapping of a Fully-Qualified Domain Name (FQDN) to an IP address. An FQDN consists of a host and domain name. For example, www.zyxel.com.tw is a fully qualified domain name, where “www” is the host, “zyxel” is the third-level domain, “com” is the second-level domain, and “tw” is the top level domain. |
Add | Click this to create a new entry. |
Edit | Double-click an entry or select it and click Edit to be able to modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. Note that subsequent entries move up by one when you take this action. |
# | This is the index number of the address/PTR record. |
FQDN | This is a host’s fully qualified domain name. |
IP Address | This is the IP address of a host. |
CNAME Record | This record specifies an alias for a FQDN. Use this record to bind all subdomains with the same IP address as the FQDN without having to update each one individually, which increases chance for errors. See CNAME Record (
CNAME Record) for more details. |
# | This is the index number of the domain zone forwarder record. The ordering of your rules is important as rules are applied in sequence. A hyphen (-) displays for the default domain zone forwarder record. The default record is not configurable. The Zyxel Device uses this default record if the domain zone that needs to be resolved does not match any of the other domain zone forwarder records. |
Alias Name | Enter an Alias name. Use “*.” as prefix for a wildcard domain name. For example, *.example.com. |
FQDN | Enter the Fully Qualified Domain Name (FQDN). |
Domain Zone Forwarder | This specifies a DNS server’s IP address. The Zyxel Device can query the DNS server to resolve domain zones for features like VPN, DDNS and the time server. When the Zyxel Device needs to resolve a domain zone, it checks it against the domain zone forwarder entries in the order that they appear in this list. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Move | To change an entry’s position in the numbered list, select the method and click Move to display a field to type a number for where you want to put it and press [ENTER] to move the rule to the number that you typed. |
Domain Zone | A domain zone is a fully qualified domain name without the host. For example, zyxel.com.tw is the domain zone for the www.zyxel.com.tw fully qualified domain name. A “*” means all domain zones. |
Type | This displays whether the DNS server IP address is assigned by the ISP dynamically through a specified interface or configured manually (User-Defined). |
DNS Server | This is the IP address of a DNS server. This field displays N/A if you have the Zyxel Device get a DNS server IP address from the ISP dynamically but the specified interface is not active. |
Query Via | This is the interface through which the Zyxel Device sends DNS queries to the entry’s DNS server. If the Zyxel Device connects through a VPN tunnel, tunnel displays. |
MX Record (for My FQDN) | A MX (Mail eXchange) record identifies a mail server that handles the mail for a particular domain. |
# | This is the index number of the MX record. |
Domain Name | This is the domain name where the mail is destined for. |
IP/FQDN | This is the IP address or Fully-Qualified Domain Name (FQDN) of a mail server that handles the mail for the domain specified in the field above. |
Security Option Control | Click Show Advanced Settings to display this part of the screen. There are two control policies: Default and Customize. |
Edit | Click either control policy and then click this button to change allow or deny actions for Query Recursion and Additional Info from Cache. |
Priority | The Customize control policy is checked first and if an address object match is not found, the Default control policy is checked. |
Name | You may change the name of the Customize control policy. |
Address | These are the object addresses used in the control policy. RFC1918 refers to private IP address ranges. It can be modified in Object > Address. |
Additional Info from Cache | This displays if the Zyxel Device is allowed or denied to cache Resource Records (RR) obtained from previous DNS queries. |
Query Recursion | This displays if the Zyxel Device is allowed or denied to forward DNS client requests to DNS servers for resolution. |
Service Control | This specifies from which computers and zones you can send DNS queries to the Zyxel Device. |
# | This the index number of the service control rule. The ordering of your rules is important as rules are applied in sequence. The entry with a hyphen (-) instead of a number is the Zyxel Device’s (non-configurable) default policy. The Zyxel Device applies this to traffic that does not match any other configured rule. It is not an editable rule. To apply other behavior, configure a rule that traffic will match so the Zyxel Device will not have to use the default policy. |
Zone | This is the zone on the Zyxel Device the user is allowed or denied to access. |
Address | This is the object name of the IP address(es) with which the computer is allowed or denied to send DNS queries. |
Action | This displays whether the Zyxel Device accepts DNS queries from the computer with the IP address specified above through the specified zone (Accept) or discards them (Deny). |
FQDN | Type a Fully-Qualified Domain Name (FQDN) of a server. An FQDN starts with a host name and continues all the way up to the top-level domain name. For example, www.zyxel.com.tw is a fully qualified domain name, where “www” is the host, “zyxel” is the third-level domain, “com” is the second-level domain, and “tw” is the top level domain. Underscores are not allowed. Use "*." as a prefix in the FQDN for a wildcard domain name (for example, *.example.com). |
IP Address | Enter the IP address of the host in dotted decimal notation. |
OK | Click OK to save your customized settings and exit this screen. |
Cancel | Click Cancel to exit this screen without saving |
label | description |
Alias name | Enter an Alias Name. Use "*." as a prefix in the Alias name for a wildcard domain name (for example, *.example.com). |
Cancel | Click Cancel to exit this screen without saving. |
Domain Zone | A domain zone is a fully qualified domain name without the host. For example, zyxel.com.tw is the domain zone for the www.zyxel.com.tw fully qualified domain name. For example, whenever the Zyxel Device receives needs to resolve a zyxel.com.tw domain name, it can send a query to the recorded name server IP address. Enter * if all domain zones are served by the specified DNS server(s). |
DNS Server | Select DNS Server(s) from ISP if your ISP dynamically assigns DNS server information. You also need to select an interface through which the ISP provides the DNS server IP address(es). The interface should be activated and set to be a DHCP client. The fields below display the (read-only) DNS server IP address(es) that the ISP assigns. N/A displays for any DNS server IP address fields for which the ISP does not assign an IP address. Select Public DNS Server if you have the IP address of a DNS server. Enter the DNS server's IP address in the field to the right. The Zyxel Device must be able to connect to the DNS server without using a VPN tunnel. The DNS server could be on the Internet or one of the Zyxel Device’s local networks. You cannot use 0.0.0.0. Use the Query via field to select the interface through which the Zyxel Device sends DNS queries to a DNS server. Select Private DNS Server if you have the IP address of a DNS server to which the Zyxel Device connects through a VPN tunnel. Enter the DNS server's IP address in the field to the right. You cannot use 0.0.0.0. |
Domain Name | Enter the domain name where the mail is destined for. |
IP Address/FQDN | Enter the IP address or Fully-Qualified Domain Name (FQDN) of a mail server that handles the mail for the domain specified in the field above. |
Name | You may change the name for the customized security option control policy. The customized security option control policy is checked first and if an address object match is not found, the Default control policy is checked |
Query Recursion | Choose if the ZyWALL/USG is allowed or denied to forward DNS client requests to DNS servers for resolution. This can apply to specific open DNS servers using the address objects in a customized rule. |
Additional Info from Cache | Choose if the ZyWALL/USG is allowed or denied to cache Resource Records (RR) obtained from previous DNS queries. |
Address List | Specifying address objects is not available in the default policy as all addresses are included. |
Available | This box displays address objects created in Object > Address. Select one (or more), and click the > arrow to have it (them) join the Member list of address objects that will apply to this rule. For example, you could specify an open DNS server suspect of sending compromised resource records by adding an address object for that server to the member list. |
Member | This box displays address objects that will apply to this rule. |
Create new Object | Use this to configure any new settings objects that you need to use in this screen. |
Address Object | Select ALL to allow or deny any computer to send DNS queries to the Zyxel Device. Select a predefined address object to just allow or deny the computer with the IP address that you specified to send DNS queries to the Zyxel Device. |
Zone | Select ALL to allow or prevent DNS queries through any zones. Select a predefined zone on which a DNS query to the Zyxel Device is allowed or denied. |
Action | Select Accept to have the Zyxel Device allow the DNS queries from the specified computer. Select Deny to have the Zyxel Device reject the DNS queries from the specified computer. |
HTTPS | |
Enable | Select the check box to allow or disallow the computer with the IP address that matches the IP address(es) in the Service Control table to access the Zyxel Device Web Configurator using secure HTTPs connections. |
Server Port | The HTTPS server listens on port 443 by default. If you change the HTTPS server port to a different number on the Zyxel Device, for example 8443, then you must notify people who need to access the Zyxel Device Web Configurator to use “https://Zyxel Device IP Address:8443” as the URL. |
Authenticate Client Certificates | Select Authenticate Client Certificates (optional) to require the SSL client to authenticate itself to the Zyxel Device by sending the Zyxel Device a certificate. To do that the SSL client must have a CA-signed certificate from a CA that has been imported as a trusted CA on the Zyxel Device . |
Server Certificate | Select a certificate the HTTPS server (the Zyxel Device) uses to authenticate itself to the HTTPS client. You must have certificates already configured in the My Certificates screen. |
Redirect HTTP to HTTPS | To allow only secure Web Configurator access, select this to redirect all HTTP connection requests to the HTTPS server. |
Admin/User Service Control | Admin Service Control specifies from which zones an administrator can use HTTPS to manage the Zyxel Device (using the Web Configurator). You can also specify the IP addresses from which the administrators can manage the Zyxel Device. User Service Control specifies from which zones a user can use HTTPS to log into the Zyxel Device (to log into SSL VPN for example). You can also specify the IP addresses from which the users can access the Zyxel Device. |
# | This is the index number of the service control rule. The entry with a hyphen (-) instead of a number is the Zyxel Device’s (non-configurable) default policy. The Zyxel Device applies this to traffic that does not match any other configured rule. It is not an editable rule. To apply other behavior, configure a rule that traffic will match so the Zyxel Device will not have to use the default policy. |
Address | This is the object name of the IP address(es) with which the computer is allowed or denied to access. |
Action | This displays whether the computer with the IP address specified above can access the Zyxel Device zone(s) configured in the Zone field (Accept) or not (Deny). |
HTTP | |
Enable | Select the check box to allow or disallow the computer with the IP address that matches the IP address(es) in the Service Control table to access the Zyxel Device Web Configurator using HTTP connections. |
Server Port | You may change the server port number for a service if needed, however you must use the same port number in order to use that service to access the Zyxel Device. |
Admin/User Service Control | Admin Service Control specifies from which zones an administrator can use HTTP to manage the Zyxel Device (using the Web Configurator). You can also specify the IP addresses from which the administrators can manage the Zyxel Device. User Service Control specifies from which zones a user can use HTTP to log into the Zyxel Device (to log into SSL VPN for example). You can also specify the IP addresses from which the users can access the Zyxel Device. |
Authentication | |
Client Authentication Method | Select a method the HTTPS or HTTP server uses to authenticate a client. You must have configured the authentication methods in the Auth. method screen. |
Other | When HTTPS Domain Filter blocks a page, the connection is redirected to a local web server to display the blocking message. HSTS (HTTP Strict Transport Security) may be activated in some browsers as the browser cached certificate is different to the one displayed by the local server. In this case, you cannot see a blocking warning message. Accessing a web page may require multiple connections to different sites to get all the information in the web page. When there is a connection to a HTTPS website that belongs to a blocked category, it is filtered, but you don't receive a warning page with the option to continue. For example, you want to block www.google.com and issue a Warn action. When you connect to www.google.com another connection to pic.google.com is created to get the pictures on the Google page. www.google.com can display a warning page in your browser (and you can click ‘Continue’ to forward the connection) but the connection to pic.google.com cannot display a ‘Continue’ dialog, so parts of the Google page will appear blank and will not display the related picture content. |
Enable Content Filter HTTPS Domain Filter Block/Warn Page | Use this field to have the Zyxel Device display a warning page instead of a blank page when an HTPPS connection is redirected. |
Block/Warn Page Port | Use the default port number as displayed for the warning page. If you change it, the new port number should be unique. |
Address Object | Select ALL to allow or deny any computer to communicate with the Zyxel Device using this service. Select a predefined address object to just allow or deny the computer with the IP address that you specified to access the Zyxel Device using this service. |
Zone | Select ALL to allow or prevent any Zyxel Device zones from being accessed using this service. Select a predefined Zyxel Device zone on which a incoming service is allowed or denied. |
Action | Select Accept to allow the user to access the Zyxel Device from the specified computers. Select Deny to block the user’s access to the Zyxel Device from the specified computers. |
Select Type | Select whether the Web Configurator uses the default login screen or one that you customize in the rest of this screen. |
Logo File | You can upload a graphic logo to be displayed on the upper left corner of the Web Configurator login screen and access page. Specify the location and file name of the logo graphic or click Browse to locate it. Click Upload to transfer the specified graphic file from your computer to the Zyxel Device. |
Customized Login Page | Use this section to set how the Web Configurator login screen looks. |
Title | Enter the title for the top of the screen. Use up to 64 printable ASCII characters. Spaces are allowed. |
Title Color | Specify the color of the screen’s title text. |
Message Color | Specify the color of the screen’s text. |
Note Message | Enter a note to display at the bottom of the screen. Use up to 64 printable ASCII characters. Spaces are allowed. |
Background | Set how the screen background looks. To use a graphic, select Picture and upload a graphic. Specify the location and file name of the logo graphic or click Browse to locate it. The picture’s size cannot be over 438 x 337 pixels. To use a color, select Color and specify the color. |
Customized Access Page | Use this section to customize the page that displays after an access user logs into the Web Configurator to access network services like the Internet. |
Note Message | Enter a note to display below the title. Use up to 64 printable ASCII characters. Spaces are allowed. |
Background | Set how the window’s background looks. To use a graphic, select Picture and upload a graphic. Specify the location and file name of the logo graphic or click Browse to locate it. The picture’s size cannot be over 438 x 337 pixels. To use a color, select Color and specify the color. |
Enable | Select the check box to allow or disallow the computer with the IP address that matches the IP address(es) in the Service Control table to access the Zyxel Device CLI using this service. |
Version 1 | Select the check box to have the Zyxel Device use both SSH version 1 and version 2 protocols. If you clear the check box, the Zyxel Device uses only SSH version 2 protocol. |
Server Port | You may change the server port number for a service if needed, however you must use the same port number in order to use that service for remote management. |
Server Certificate | Select the certificate whose corresponding private key is to be used to identify the Zyxel Device for SSH connections. You must have certificates already configured in the My Certificates screen. |
Service Control | This specifies from which computers you can access which Zyxel Device zones. |
# | This the index number of the service control rule. |
# | This the index number of the service control rule. The entry with a hyphen (-) instead of a number is the Zyxel Device’s (non-configurable) default policy. The Zyxel Device applies this to traffic that does not match any other configured rule. It is not an editable rule. To apply other behavior, configure a rule that traffic will match so the Zyxel Device will not have to use the default policy. |
Enable | Select the check box to allow or disallow the computer with the IP address that matches the IP address(es) in the Service Control table to access the Zyxel Device using this service. |
TLS required | Select the check box to use FTP over TLS (Transport Layer Security) to encrypt communication. This implements TLS as a security mechanism to secure FTP clients and/or servers. |
Server Certificate | Select the certificate whose corresponding private key is to be used to identify the Zyxel Device for FTP connections. You must have certificates already configured in the My Certificates screen. |
OBJECT LABEL | OBJECT ID | description |
Cold Start | 1.3.6.1.6.3.1.1.5.1 | This trap is sent when the Zyxel Device is turned on or an agent restarts. |
linkDown | 1.3.6.1.6.3.1.1.5.3 | This trap is sent when the Ethernet link is down. |
linkUp | 1.3.6.1.6.3.1.1.5.4 | This trap is sent when the Ethernet link is up. |
authenticationFailure | 1.3.6.1.6.3.1.1.5.5 | This trap is sent when an SNMP request comes from non-authenticated hosts. |
vpnTunnelDisconnected | 1.3.6.1.4.1.890.1.6.22.2.3 | This trap is sent when an IPSec VPN tunnel is disconnected. |
vpnTunnelName | 1.3.6.1.4.1.890.1.6.22.2.2.1.1 | This trap is sent along with the vpnTunnelDisconnected trap. This trap carries the disconnected tunnel’s IPSec SA name. |
vpnIKEName | 1.3.6.1.4.1.890.1.6.22.2.2.1.2 | This trap is sent along with the vpnTunnelDisconnected trap. This trap carries the disconnected tunnel’s IKE SA name. |
vpnTunnelSPI | 1.3.6.1.4.1.890.1.6.22.2.2.1.3 | This trap is sent along with the vpnTunnelDisconnected trap. This trap carries the security parameter index (SPI) of the disconnected VPN tunnel. |
Trap | |
Community | Type the trap community, which is the password sent with each trap to the SNMP manager. The default is public and allows all requests. |
Destination | Type the IP address of the station to send your SNMP traps to. |
SNMPv2c | Select the SNMP version for the Zyxel Device. The SNMP version on the Zyxel Device must match the version on the SNMP manager. |
Get Community | Enter the Get Community, which is the password for the incoming Get and GetNext requests from the management station. The default is public and allows all requests. |
Set Community | Enter the Set community, which is the password for incoming Set requests from the management station. The default is private and allows all requests. |
SNMPv3 | Select the SNMP version for the Zyxel Device. The SNMP version on the Zyxel Device must match the version on the SNMP manager. SNMPv3 (RFCs 3413 to 3415) provides secure access by authenticating and encrypting data packets over the network. The Zyxel Device uses your login password as the SNMPv3 authentication and encryption passphrase. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry |
# | This is the index number of the entry. |
User | This displays the name of the user object to be sent to the SNMP manager along with the SNMP v3 trap. |
Authentication | This displays the authentication algorithm used for this entry. MD5 (Message Digest 5) and SHA (Secure Hash Algorithm) are hash algorithms used to authenticate SNMP data. SHA authentication is generally considered stronger than MD5, but is slower. |
Privacy | This displays the encryption method for SNMP communication from this user. Methods available are: • DES - Data Encryption Standard is a widely used (but breakable) method of data encryption. It applies a 56-bit key to each 64-bit block of data. • AES - Advanced Encryption Standard is another method for data encryption that also uses a secret key. AES applies a 128-bit key to 128-bit blocks of data. |
Privilege | This displays the access rights to MIBs. • Read-Write - The associated user can create and edit the MIBs on the Zyxel Device, except the user account. • Read-Only - The associated user can only collect information from the Zyxel Device MIBs. |
LABEL | Description |
User | Specify the username of a login account on the Zyxel Device. The associated password is used in authentication algorithms and encryption methods. |
Authentication | Select an authentication algorithm. MD5 (Message Digest 5) and SHA (Secure Hash Algorithm) are hash algorithms used to authenticate SNMP data. SHA authentication is generally considered stronger than MD5, but is slower. |
Privacy | Specify the encryption method for SNMP communication from this user. You can choose one of the following: • DES - Data Encryption Standard is a widely used (but breakable) method of data encryption. It applies a 56-bit key to each 64-bit block of data. • AES - Advanced Encryption Standard is another method for data encryption that also uses a secret key. AES applies a 128-bit key to 128-bit blocks of data. |
Privilege | Select the access rights to MIBs. • Read-Write - The associated user can create and edit the MIBs on the Zyxel Device, except the user account. • Read-Only - The associated user can only collect information from the Zyxel Device MIBs. |
OK | Click OK to save the changes. |
Cancel | Click Cancel to begin configuring this screen afresh. |
Enable Authentication Server | Select the check box to have the Zyxel Device act as a RADIUS server. |
Authentication Server Certificate | Select the certificate whose corresponding private key is to be used to identify the Zyxel Device to the RADIUS client. You must have certificates already configured in the My Certificates screen |
Authentication Method | Select an authentication method if you have created any in the Configuration > Object > Auth. Method screen. |
Trusted Client | Use this section to configure trusted clients in the Zyxel Device RADIUS server database. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Profile Name | This field indicates the name assigned to the profile. |
IP Address | This is the IP address of the RADIUS client that is allowed to exchange messages with the Zyxel Device. |
Mask | This is the subnet mask of the RADIUS client. |
Description | This is the description of the RADIUS client. |
Activate | Select this check box to make this profile active. |
Profile Name | Enter a descriptive name (up to 31 alphanumerical characters) for identification purposes. |
IP Address | Enter the IP address of the RADIUS client that is allowed to exchange messages with the Zyxel Device. |
Netmask | Enter the subnet mask of the RADIUS client. |
Secret | Enter a password (up to 64 alphanumeric characters) as the key to be shared between the Zyxel Device and the RADIUS client. The key is not sent over the network. This key must be the same on the external authentication server and the Zyxel Device. |
Description | Enter the description of each server, if any. You can use up to 60 printable ASCII characters. |
Cancel | Click Cancel to discard the changes. |
Mail Server | Type the name or IP address of the outgoing SMTP server. |
Mail Subject | Go to to type a subject line for outgoing e-mail from the Zyxel Device. |
Append system name | Select Append system name to add the Zyxel Device’s system name to the subject. |
Append date time | Select Append date time to add the Zyxel Device’s system date and time to the subject. |
Mail Server Port | Enter the same port number here as is on the mail server for mail traffic. |
TLS Security | Select this option if the mail server uses Transport Layer Security (TLS) for encrypted communications between the mail server and the Zyxel Device. |
STARTTLS | Select this option if the mail server uses SSL or TLS for encrypted communications between the mail server and the Zyxel Device. |
Authenticate Server | Select this if the Zyxel Device authenticates the mail server in the TLS handshake. |
Mail From | Type the e-mail address from which the outgoing e-mail is delivered. This address is used in replies. |
SMTP Authentication | Select this check box if it is necessary to provide a user name and password to the SMTP server. |
User Name | This box is effective when you select the SMTP Authentication check box. Type the user name to provide to the SMTP server when the log is e-mailed. |
Password | This box is effective when you select the SMTP Authentication check box. Type the password to provide to the SMTP server when the log is e-mailed. |
Retype to Confirm | Type the password again to make sure that you have entered is correctly. |
Time for sending report | Select the time of day (hours and minutes) when the log is e-mailed. Use 24-hour notation. |
General Settings | |
Enable SMS | Select the check box to turn on the SMS service. |
Default country code for phone number | Enter the default country code for the mobile phone number to which you want to send SMS messages. |
ViaNett Configuration | |
User Name | Enter the user name for your ViaNett account. |
Password | Type the Password associated with the user name. |
Retype to Confirm | Type your password again for confirmation. |
Hotspot Service Status | |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. You must subscribe to the SMS service before you can use the service to send a text message. |
Service Type | This shows whether you have a trial or standard license or none (Trial, Standard, None). |
Expiration Date | This shows when your hotspot license will expire. |
Register Now | Click the link to go to myZyxel where you can register your Zyxel Device and activate the service. This link is available only when the service is not activated yet. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Label | DESCRIPTION |
Language Setting | Select a display language for the Zyxel Device’s Web Configurator screens. You also need to open a new browser session to display the screens in the new language. |
Enable IPv6 | Select this to have the Zyxel Device support IPv6 and make IPv6 settings be available on the screens that the functions support, such as the Configuration > Network > Interface > Ethernet, VLAN, and Bridge screens. The Zyxel Device discards all IPv6 packets if you clear this check box. |
icon | DESCRIPTION |
1 IP configuration | Change the selected device’s IP address. |
2 Renew IP Address | Update a DHCP-assigned dynamic IP address. |
3 Reboot Device | Use this icon to restart the selected device(s). This may be useful when troubleshooting or upgrading new firmware. |
4 Reset Configuration to Default | If you forget your password or cannot access the Web Configurator, you can use this icon to reload the factory-default configuration file. This means that you will lose all configurations that you had previously. |
5 Locator LED | Use this icon to locate the selected device by causing its Locator LED to blink. |
6 Web GUI | Use this to access the selected device web configurator from your browser. You will need a username and password to log in. |
7 Firmware Upgrade | Use this icon to upgrade new firmware to selected device(s) of the same model. Make sure you have downloaded the firmware from the Zyxel website to your computer and unzipped it in advance. |
8 Change Password | Use this icon to change the admin password of the selected device. You must know the current admin password before changing to a new one. |
9 Configure NCC Discovery | You must have Internet access to use this feature. Use this icon to enable or disable Nebula Control Center (NCC) discovery on the selected device. If it’s enabled, the selected device will try to connect to the NCC. Once the selected device is connected to and has registered in the NCC, it’ll go into the cloud management mode. |
10 ZAC | Use this icon to run the Zyxel AP Configurator of the selected AP. |
11 Clear and Rescan | Use this icon to clear the list and discover all devices on the connected network again. |
12 Save Configuration | Use this icon to save configuration changes to permanent memory on a selected device. |
13 Settings | Use this icon to select a network adaptor for the computer on which the ZON utility is installed, and the utility language. |
Type | This field displays an icon of the kind of device discovered. |
Model | This field displays the model name of the discovered device. |
Firmware Version | This field displays the firmware version of the discovered device. |
MAC Address | This field displays the MAC address of the discovered device. |
IP Address | This field displays the IP address of an internal interface on the discovered device that first received an ZDP discovery request from the ZON utility. |
System Name | This field displays the system name of the discovered device. |
Location | This field displays where the discovered device is. |
Status | This field displays whether changes to the discovered device have been done successfully. As the Zyxel Device does not support IP Configuration, Renew IP address and Flash Locator LED, this field displays “Update failed”, “Not support Renew IP address” and “Not support Flash Locator LED” respectively. |
NCC Discovery | This field displays if the discovered device supports the Nebula Control Center (NCC) discovery feature. If it’s enabled, the selected device will try to connect to the NCC. Once the selected device is connected to and has registered in the NCC, it’ll go into the cloud management mode. |
Serial Number | Enter the admin password of the discovered device to display its serial number. |
Hardware Version | This field displays the hardware version of the discovered device. |
ZDP | Zyxel Discovery Protocol (ZDP) is the protocol that the Zyxel One Network (ZON) utility uses for discovering and configuring ZDP-aware Zyxel devices in the same broadcast domain as the computer on which ZON is installed. |
Enable | Select to activate ZDP discovery on the Zyxel Device. |
Smart Connect | Smart Connect uses Link Layer Discovery Protocol (LLDP) for discovering and configuring LLDP-aware devices in the same broadcast domain as the Zyxel Device that you’re logged into using the web configurator. |
Enable | Select to activate LLDP discovery on the Zyxel Device. See also Monitor > System Status > Ethernet Discovery. |
