Label | Description |
SSID Summary | |
Quick Setup | Click this to go to the Quick Setup Wireless Wizard to configure a wireless network. |
Add | Click this to configure a new wireless network. You can configure up to 4 SSID profiles. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Activate/Inactivate | To turn on an entry, select it and click Activate. To turn off an entry, select it and click Inactivate. |
# | This is the wireless network’s index number in this list. |
Status | This displays whether or not the wireless network is activated. |
SSID | This shows the name of the wireless network. |
Security Mode | This shows the security used for this wireless network. No security allows any wireless client to associate with this network without authentication. |
Band Mode | This shows the wireless band which this wireless network uses. 2.4 GHz is the frequency used by IEEE 802.11b/g/n/ax wireless clients. 5 GHz is the frequency used by IEEE 802.11ax/ac/a/n wireless clients. |
Outgoing Interface | This is the outgoing interface that the wireless network uses to transmit packets. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Activate | To turn on an entry, select Activate. To turn off an entry, select it and click Inactivate. |
SSID | Enter the SSID name for this profile. This is the name visible on the network to wireless clients. Enter up to 32 characters, spaces and underscores are allowed. |
QoS | Select a Quality of Service (QoS) access category to associate with this SSID. Access categories minimize the delay of data packets across a wireless network. Certain categories, such as video or voice, are given a higher priority due to the time sensitive nature of their data packets. QoS access categories are as follows: disable: Turns off QoS for this SSID. All data packets are treated equally and not tagged with access categories. WMM: Enables automatic tagging of data packets. The Zyxel Device assigns access categories to the SSID by examining data as it passes through it and making a best guess effort. If something looks like video traffic, for instance, it is tagged as such. WMM_VOICE: All wireless traffic to the SSID is tagged as voice data. This is recommended if an SSID is used for activities like placing and receiving VoIP phone calls. WMM_VIDEO: All wireless traffic to the SSID is tagged as video data. This is recommended for activities like video conferencing. WMM_BEST_EFFORT: All wireless traffic to the SSID is tagged as “best effort,” meaning the data travels the best route it can without displacing higher priority traffic. This is good for activities that do not require the best bandwidth throughput, such as surfing the Internet. WMM_BACKGROUND: All wireless traffic to the SSID is tagged as low priority or “background traffic”, meaning all other access categories take precedence over this one. If traffic from an SSID does not have strict throughput requirements, then this access category is recommended. For example, an SSID that only has network printers connected to it. |
Outgoing Interface | Select the outgoing interface that the wireless network uses to transmit packets. |
Authentication Settings | |
Security Mode | Select a security mode from the list: open, wep, wpa2, or wpa2-mix. |
802.1x | Select this to enable 802.1x secure authentication with a RADIUS server. |
Auth. Method | This field is available only when you select the RADIUS Server Type to Internal. Select an authentication method if you have created any on the Configuration > Object > Auth. Method screen. |
Reauthentication Timer | Enter the interval (in seconds) between authentication requests. Enter a 0 for unlimited requests. |
PSK | Select this option to use a Pre-Shared Key with WPA encryption. |
Pre-Shared Key | Enter a pre-shared key of between 8 and 63 case-sensitive ASCII characters (including spaces and symbols) or 64 hexadecimal characters. |
Cipher Type | Select an encryption cipher type from the list. • auto - This automatically chooses the best available cipher based on the cipher in use by the wireless client that is attempting to make a connection. • aes - This is the Advanced Encryption Standard encryption method. It is a more recent development over TKIP and considerably more robust. Not all wireless clients may support this. |
Idle Timeout | Enter the idle interval (in seconds) that a client can be idle before authentication is discontinued. |
Group Key Update Timer | Enter the interval (in seconds) at which the AP updates the group WPA encryption key. |
Pre-Authentication | This field is available only when you set Security Mode to wpa2 or wpa2-mix and enable 802.1x authentication. Enable or Disable pre-authentication to allow the AP to send authentication information to other APs on the network, allowing connected wireless clients to switch APs without having to re-authenticate their network connection. |
Management Frame Protection | This field is available only when you select wpa2 in the Security Mode field and set Cipher Type to aes. Data frames in 802.11 WLANs can be encrypted and authenticated with WEP, WPA or WPA2. But 802.11 management frames, such as beacon/probe response, association request, association response, de-authentication and disassociation are always unauthenticated and unencrypted. IEEE 802.11w Protected Management Frames allows APs to use the existing security mechanisms (encryption and authentication methods defined in IEEE 802.11i WPA/WPA2) to protect management frames. This helps prevent wireless DoS attacks. Select the check box to enable management frame protection (MFP) to add security to 802.11 management frames. Select Optional if you do not require the wireless clients to support MFP. Management frames will be encrypted if the clients support MFP. Select Required and wireless clients must support MFP in order to join the Zyxel Device’s wireless network. |
Hidden SSID | Select this if you want to “hide” your SSID from wireless clients. This tells any wireless clients in the vicinity of the AP using this SSID profile not to display its SSID name as a potential connection. Not all wireless clients respect this flag and display it anyway. When a SSID is “hidden” and a wireless client cannot see it, the only way you can connect to the SSID is by manually entering the SSID name in your wireless connection setup screen(s) (these vary by client, client connectivity software, and operating system). |
Enable Intra-BSS Traffic Blocking | Select this option to prevent crossover traffic from within the same SSID on the Zyxel Device. |
Enable U-APSD | Select this option to enable Unscheduled Automatic Power Save Delivery (U-APSD), which is also known as WMM-Power Save. This helps increase battery life for battery-powered wireless clients connected to the Zyxel Device using this SSID profile. |
Enable ARP Proxy | The Address Resolution Protocol (ARP) is a protocol for mapping an IP address to a MAC address. An ARP broadcast is sent to all devices on the same Ethernet network to request the MAC address of a target IP address. Select this option to allow the Zyxel Device to answer ARP requests for an IP address on behalf of a client associated with this SSID. This can reduce broadcast traffic and improve network performance. |
802.11k/v Assisted Roaming | Select this option to enable IEEE 802.11k/v assisted roaming on the Zyxel Device. When the connected clients request 802.11k neighbor lists, the Zyxel Device will response with a list of neighbor APs that can be candidates for roaming. |
Schedule SSID | Select this option and set whether the SSID is enabled or disabled on each day of the week. You also need to select the hour and minute (in 24-hour format) to specify the time period of each day during which the SSID is enabled/enabled. |
Radius Settings | |
Radius Server Type | Select Internal to use the Zyxel Device’s internal authentication database, or External to use an external RADIUS server for authentication. |
Proxy by controller directly | Select this to allow the Zyxel Device to answer authentication requests on behalf of an external RADIUS server. |
MAC Filter | |
Filter Action | Select allow to permit the wireless client with the MAC addresses in this profile to connect to the network through the associated SSID; select deny to block the wireless clients with the specified MAC addresses. |
Add | Click this to add a MAC address to the profile’s list. |
Edit | Click this to edit the selected MAC address in the profile’s list. |
Remove | Click this to remove the selected MAC address from the profile’s list. |
# | This field is a sequential value, and it is not associated with a specific user. |
MAC | This field specifies a MAC address associated with this profile. You can click the MAC address to make it editable. |
Description | This field displays a description for the MAC address associated with this profile. You can click the description to make it editable. Enter up to 60 characters, spaces and underscores allowed. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
Hide / Show Advanced Settings | Click this to hide or show the Advanced Settings in this window. |
2.4GHz General Settings | |
802.11 Band | Select how to let wireless clients connect to the AP. • 11b/g: allows either IEEE 802.11b or IEEE 802.11g compliant WLAN devices to associate with the AP. The AP adjusts the transmission rate automatically according to the wireless standard supported by the wireless devices. • 11b/g/n: allows IEEE802.11b, IEEE802.11g and IEEE802.11n compliant WLAN devices to associate with the AP. The transmission rate of your AP might be reduced. |
Channel Width | Select the wireless channel bandwidth you want the AP to use. A standard 20 MHz channel offers transfer speeds of up to 144Mbps (2.4GHz) or 217Mbps (5GHZ) whereas a 40MHz channel uses two standard channels and offers speeds of up to 300Mbps (2.4GHz) or 450Mbps (5GHZ). 40 MHz (channel bonding or dual channel) bonds two adjacent radio channels to increase throughput. Because not all devices support all channels, select 20/40MHz to allow the AP to adjust the channel bandwidth automatically. Select 20MHz if you want to lessen radio interference with other wireless devices in your neighborhood or the wireless clients do not support channel bonding. ![]() |
Channel Selection | Select the wireless channel which this radio profile should use. It is recommended that you choose the channel least in use by other APs in the region where this profile will be implemented. This will reduce the amount of interference between wireless clients and the AP to which this profile is assigned. Select DCS to have the AP automatically select the radio channel upon which it broadcasts by scanning the area around it and determining what channels are currently being used by other devices. ![]() Select Manual and specify the channels the AP uses. |
Output Power | Enter the maximum output power of the Zyxel Device. If there is a high density of APs in an area, decrease the output power of the Zyxel Device to reduce interference with other APs. Reducing the output power also reduces the Zyxel Device’s effective broadcast radius. |
Enable DCS Client Aware | This field is available when you set Channel Selection to DCS. Select this to have the AP wait until all connected clients have disconnected before switching channels. If you disable this then the AP switches channels immediately regardless of any client connections. In this instance, clients that are connected to the AP when it switches channels are dropped. |
2.4 GHz Channel Selection Method | This field is available when you set Channel Selection to DCS. Select auto to have the AP search for available channels automatically in the 2.4 GHz band. The available channels vary depending on what you select in the 2.4 GHz Channel Deployment field. Select manual and specify the channels the AP uses in the 2.4 GHz band. |
Channel ID | This field is available only when you set Channel Selection to DCS and set 2.4 GHz Channel Selection Method to manual. Select the check boxes of the channels that you want the AP to use. |
2.4 GHz Channel Deployment | This field is available only when you set Channel Selection to DCS and set 2.4 GHz Channel Selection Method to auto. Select Three-Channel Deployment to limit channel switching to channels 1,6, and 11, the three channels that are sufficiently attenuated to have almost no impact on one another. In other words, this allows you to minimize channel interference by limiting channel-hopping to these three “safe” channels. Select Four-Channel Deployment to limit channel switching to four channels. Depending on the country domain, if the only allowable channels are 1-11 then the Zyxel Device uses channels 1, 4, 7, 11 in this configuration; otherwise, the Zyxel Device uses channels 1, 5, 9, 13 in this configuration. Four channel deployment expands your pool of possible channels while keeping the channel interference to a minimum. |
Time Interval | Select this option to have the Zyxel Device survey the other APs within its broadcast radius at the end of the specified time interval. |
DCS Time Interval | This field is available when you set Channel Selection to DCS. Enter a number of minutes. This regulates how often the AP surveys the other APs within its broadcast radius. If the channel on which it is currently broadcasting suddenly comes into use by another AP, the AP will then dynamically select the next available clean channel or a channel with lower interference. |
Schedule | Select this option to have the Zyxel Device survey the other APs within its broadcast radius at a specific time on selected days of the week. |
Start Time | Specify the time of the day (in 24-hour format) to have the Zyxel Device use DCS to automatically scan and find a less-used channel. |
Week Days | Select each day of the week to have the Zyxel Device use DCS to automatically scan and find a less-used channel. |
Advanced Settings | |
Guard Interval | This field is available only when the channel width is 20/40MHz or 20/40/80MHz. Set the guard interval for this radio profile to either Short or Long. The guard interval is the gap introduced between data transmission from users in order to reduce interference. Reducing the interval increases data transfer rates but also increases interference. Increasing the interval reduces data transfer rates but also reduces interference. |
Enable A-MPDU Aggregation | Select this to enable A-MPDU aggregation. Message Protocol Data Unit (MPDU) aggregation collects Ethernet frames along with their 802.11n headers and wraps them in a 802.11n MAC header. This method is useful for increasing bandwidth throughput in environments that are prone to high error rates. |
A-MPDU Limit | Enter the maximum frame size to be aggregated. |
A-MPDU Subframe | Enter the maximum number of frames to be aggregated each time. |
Enable A-MSDU Aggregation | Select this to enable A-MSDU aggregation. Mac Service Data Unit (MSDU) aggregation collects Ethernet frames without any of their 802.11n headers and wraps the header-less payload in a single 802.11n MAC header. This method is useful for increasing bandwidth throughput. It is also more efficient than A-MPDU except in environments that are prone to high error rates. |
A-MSDU Limit | Enter the maximum frame size to be aggregated. |
RTS/CTS Threshold | Use RTS/CTS to reduce data collisions on the wireless network if you have wireless clients that are associated with the same AP but out of range of one another. When enabled, a wireless client sends an RTS (Request To Send) and then waits for a CTS (Clear To Send) before it transmits. This stops wireless clients from transmitting packets at the same time (and causing data collisions). A wireless client sends an RTS for all packets larger than the number (of bytes) that you enter here. Set the RTS/CTS equal to or higher than the fragmentation threshold to turn RTS/CTS off. |
Beacon Interval | When a wirelessly networked device sends a beacon, it includes with it a beacon interval. This specifies the time period before the device sends the beacon again. The interval tells receiving devices on the network how long they can wait in low-power mode before waking up to handle the beacon. A high value helps save current consumption of the access point. |
DTIM | Delivery Traffic Indication Message (DTIM) is the time period after which broadcast and multicast packets are transmitted to mobile clients in the Active Power Management mode. A high DTIM value can cause clients to lose connectivity with the network. This value can be set from 1 to 255. |
Enable Signal Threshold | Select the check box to use the signal threshold to ensure wireless clients receive good throughput. This allows only wireless clients with a strong signal to connect to the AP. Clear the check box to not require wireless clients to have a minimum signal strength to connect to the AP. |
Station Signal Threshold | Set a minimum client signal strength. A wireless client is allowed to connect to the AP only when its signal strength is stronger than the specified threshold. -20 dBm is the strongest signal you can require and -76 is the weakest. |
Disassociate Station Threshold | Set a minimum kick-off signal strength. When a wireless client’s signal strength is lower than the specified threshold, the Zyxel Device disconnects the wireless client from the AP. -20 dBm is the strongest signal you can require and -90 is the weakest. |
Allow Station Connection after Multiple Retries | Select this option to allow a wireless client to try to associate with the AP again after it is disconnected due to weak signal strength. |
Station Retry Count | Set the maximum number of times a wireless client can attempt to re-connect to the AP. |
Allow 802.11n/ac stations only | Only select this if you want to deny 802.11b/g/n clients access to the radio. |
Multicast Settings | Use this section to set a transmission mode and maximum rate for multicast traffic. |
Transmission Mode | Set how the AP handles multicast traffic. Select Multicast to Unicast to broadcast wireless multicast traffic to all of the wireless clients as unicast traffic. Unicast traffic dynamically changes the data rate based on the application’s bandwidth requirements. The retransmit mechanism of unicast traffic provides more reliable transmission of the multicast traffic, although it also produces duplicate packets. Select Fixed Multicast Rate to send wireless multicast traffic at a single data rate. You must know the multicast application’s bandwidth requirements and set it in the following field. |
Multicast Rate (Mbps) | If you set the multicast transmission mode to fixed multicast rate, set the data rate for multicast traffic here. For example, to deploy 4 Mbps video, select a fixed multicast rate higher than 4 Mbps. |
5GHz General Settings | |
802.11 Band | Select how to let wireless clients connect to the AP. • 11a: allows only IEEE 802.11a compliant WLAN devices to associate with the Zyxel Device. • 11a/n: allows both IEEE802.11n and IEEE802.11a compliant WLAN devices to associate with the Zyxel Device. • 11ac: allows IEEE802.11n, IEEE802.11a, and IEEE802.11ac compliant WLAN devices to associate with the Zyxel Device. If the WLAN device isn’t compatible with 802.11ac, the Zyxel Device will communicate with the WLAN device using 802.11n, and so on. |
Channel Width | Select the channel bandwidth you want to use for your wireless network. Select 20 MHz if you want to lessen radio interference with other wireless devices in your neighborhood. Select 20/40 MHz to allow the Zyxel Device to choose the channel bandwidth (20 or 40 MHz) that has least interference. Select 20/40/80 MHz to allow the Zyxel Device to choose the channel bandwidth (20 or 40 or 80 MHz) that has least interference. This option is available only when you select 11ac or 11ax in the 802.11 Mode field. ![]() |
Country Code | Select the country code of where the Zyxel Device is located/installed. The available channels vary depending on the country you selected. |
Registration Type | Select Manual to add each AP to the Zyxel Device for management, or Always Accept to automatically add APs to the Zyxel Device for management. If you select Manual, then go to Monitor > Wireless > AP Information > AP List, select an AP to be managed and then click Add to Mgnt AP List. That AP will then appear in Configuration > Wireless > Controller > Mgnt. AP List. ![]() APs must be connected to the Zyxel Device by a wired connection or network. |
Filter | Click Show Advanced Settings to reveal Filter fields where you can display managed APs by status, keyword or those managed by the Nebula portal. |
AP List | Select the type of APs you want to display. Select All to show all kinds of APs that are currently or used to be connected to the Zyxel Device. Select NebulaFlexPRO to show the APs that can work in Nebula cloud management mode. |
Status | Select the status of APs you want to display. |
Keyword | Enter a keyword to display the APs that include it in their AP information, such as model number, firmware version, MAC address and so on. This field is case-sensitive. |
Search | Click this to update the list of APs based on the search criteria. Your search criteria is retained when navigating between screens. |
Reset | Click this to return the search criteria to the factory defaults and display all currently or previously connected APs without a filter. |
Enable Column Freeze | Select this to lock the index columns in place while scrolling to the right. |
Edit the selected rule | Select an AP and click this to change the selected AP’s properties, such as its group, radio, VLAN and port settings. |
Add to Mgmt AP List | Select an AP and click this to add the selected AP to the managed AP list. |
Reboot device | Select one or multiple APs and click this button to force the AP(s) to restart. |
Remove the selected rule | Select one or multiple APs and click this button to remove the AP(s) from the manged AP list. ![]() |
DCS Now | Select one or multiple APs and click this button to use DCS (Dynamic Channel Selection) to allow the AP to automatically find a less-used channel in an environment where there are many APs and there may be interference. ![]() ![]() |
More Information | Select an AP and click this to view a daily station count about the selected AP. The count records station activity on the AP over a consecutive 24 hour period. |
Radio Information | Select an online AP and click this button to go to the Monitor > Wireless > AP Information > Radio List screen to view detailed information about the AP’s radios. |
Query Controller Log | Select one or multiple APs and click this button to go to the Monitor > Log > View Log screen to view the selected AP’s current log messages. |
Nebula | Select an AP and click this to open a screen where you can set whether the AP’s IP address and VLAN settings will be changed when it goes into Nebula cloud management mode. ![]() |
Upgrade Firmware Now | Select one or more APs and click this button to update the APs’ firmware version. |
Suppression On | Select an AP and click this button to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Suppression Off | Select an AP and click this button to disable the AP’s LED suppression mode. The AP LEDs stay lit after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Locator On | Select an AP and click this button to run the locator feature. The AP’s Locator LED will start to blink for 10 minutes by default. It will show the actual location of the AP between several devices on the network. |
# | This field is a sequential value, and it is not associated with any entry. |
Status | This field displays the status of AP. • Online All • Online • Conflict • Non Support • Updating • Offline All • Offline • Offline for Firmware Update • Update • Un-Mgmt |
Description | This field displays the AP’s description, which you can configure by selecting the AP’s entry and clicking the Edit button. |
CPU Usage | This field displays the CPU Usage of the AP. |
IP Address | This field displays the IP address of the AP. |
MAC Address | This field displays the MAC address of the AP. |
Station 2.4G | This field displays the number of 2.4G wireless clients connected to the AP. |
Station 5G | This field displays the number of 5G wireless clients connected to the AP. |
Recent Online Time | This displays the most recent time the AP came on-line. N/A displays if the AP has not come on-line since the Zyxel Device last started up. |
LED Status | This displays the AP LED status. N/A displays if the AP does not support LED suppression mode and/or have a locator LED to show the actual location of the AP. A gray LED icon signifies that the AP LED suppression mode is enabled. All the LEDs of the AP will turn off after the AP is ready. A green LED icon signifies that the AP LED suppression mode is disabled and the AP LEDs stay lit after the AP is ready. A sun icon signifies that the AP’s locator LED is blinking. A circle signifies that the AP’s locator LED is extinguished. |
Model | This field displays the AP’s hardware model information. It displays N/A (not applicable) only when the AP disconnects from the Zyxel Device and the information is unavailable as a result. |
Refresh | Click Refresh to update the AP list. |
Create new Object | Use this menu to create a new Radio Profile object to associate with this AP. |
AP Role | Select this to enable the remote AP feature. |
MAC | This displays the MAC address of the selected AP. |
S/N | This displays the serial number of the selected AP. |
Description | Enter a description for this AP. You can use up to 31 characters, spaces and underscores allowed. |
Group Setting | Select an AP group to which you want this AP to belong. |
System Name | Enter a name to identify the AP on a network. This is usually the AP’s fully qualified domain name. |
Location | Specify the name of the place where the AP is located. |
Roaming Group | Specify the name of the roaming group to which the AP belongs. You can use up to 31 alphanumeric and @# characters. Dashes and underscores are also allowed. The name should start with a letter or digit. The 802.11k neighbor list a client requests from the AP is generated according to the roaming group and RCPI (Received Channel Power Indicator) value of its neighbor APs. When a client wants to roam from the current AP to another, other APs in the same roaming group or not in a roaming group will be candidates for roaming. Neighbor APs in a different roaming group will be excluded from the 802.11k neighbor lists even when the neighbor AP has the best signal strength. If the AP’s roaming group is not configured, any neighbor APs can be candidates for roaming. |
Load Balancing Group 1/2 | Load balancing is only applied to APs within the same group. If a load balancing group is not assigned to an AP, it will belong to a default group. Each AP can belong to up to two groups. |
Radio 1/2 Setting | |
Override Group Radio Setting | Select this option to overwrite the AP radio settings with the settings you configure here. |
OP Mode | Select the operating mode for radio 1 or radio 2. AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). MON Mode means the AP monitors the broadcast area for other APs, then passes their information on to the Zyxel Device where it can be determined if those APs are friendly or rogue. If an AP is set to this mode it cannot receive connections from wireless clients. Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a ZyMesh to extend its wireless network. Repeater AP means the radio can establish a wireless connection with other APs (in either root AP or repeater mode). ![]() ![]() ![]() |
Override Group Output Power Setting | Select this option to overwrite the AP output power setting with the setting you configure here. |
Output Power | Set the output power of the AP. |
Override Group SSID Setting | Select this option to overwrite the AP SSID profile setting with the setting you configure here. This section allows you to associate an SSID profile with the radio. |
Radio 1/2 AP Profile | Select an AP profile from the list. If no profile exists, you can create a new one through the Create new Object menu. |
Radio 1/2 Profile | Select a monitor profile from the list. If no profile exists, you can create a new one through the Create new Object menu. |
Radio 1/2 ZyMesh Profile | This field is available only when the radio is in Root AP or Repeater AP mode. Select the ZyMesh profile the radio uses to connect to a root AP or repeater. |
Enable Wireless Bridging | This field is available only when the radio is in Repeater AP mode. Select this option to enable wireless bridging on the radio. The managed AP must support LAN provision and the radio should be in repeater mode. VLAN and bridge interfaces are created automatically according to the LAN port’s VLAN settings. When wireless bridging is enabled, the managed repeater AP can still transmit data through its Ethernet port(s) after the ZyMesh link is up. Be careful to avoid bridge loops. The managed APs in the same ZyMesh must use the same static VLAN ID. |
Edit | Select an SSID and click this button to reassign it. The selected SSID becomes editable immediately upon clicking. |
# | This is the index number of the SSID profile. You can associate up to eight SSID profiles with an AP radio. |
SSID Profile | Indicates which SSID profile is associated with this radio profile. |
IP Setting | |
Force Overwrite IP Setting | Select this to have the Zyxel Device change the AP’s IP address setting to match the configuration in this screen. |
Get Automatically | Select this to have the AP act as a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server. |
Use Fixed IP Address | Select this if you want to specify the IP address, subnet mask, gateway and DNS server address manually. |
IP Address | Enter the IP address for the AP. |
Subnet Mask | Enter the subnet mask of the AP in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all devices in the network. |
Gateway | Enter the IP address of the gateway. The AP sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the AP. |
DNS Server IP Address | Enter the IP address of the DNS server. |
VLAN Settings | |
Override Group VLAN Setting | Select this option to overwrite the AP VLAN setting with the setting you configure here. |
Force Overwrite VLAN Config | Select this to have the Zyxel Device change the AP’s management VLAN to match the configuration in this screen. |
Management VLAN ID | Enter a VLAN ID for this AP. |
As Native VLAN | Select this option to treat this VLAN ID as a VLAN created on the Zyxel Device and not one assigned to it from outside the network. |
Storm Control Setting | |
Broadcast Storm Control | Enabling this will drop ingress broadcast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide). Ethernet storm control prevents WiFi clients from receiving excessive broadcast traffic sent from wired clients in the same subnet. Wireless storm control prevents wired clients from receiving excessive broadcast traffic sent from WiFi clients in the same subnet. |
Multicast Storm Control | Enabling this will drop ingress multicast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide). Ethernet storm control prevents WiFi clients from receiving excessive multicast traffic sent from wired clients in the same subnet. Wireless storm control prevents wired clients from receiving excessive multicast traffic sent from WiFi clients in the same subnet. |
Rogue AP Detection Setting | |
Override Group Rogue AP Detection Setting | Select this option to overwrite the AP Rogue Detection Settings with the settings you configure here |
Enable Rogue AP Detection | Select this option to detect Rogue APs in the network. |
Antenna Setting | This section is available only when the AP has an antenna switch. The screen varies depending on whether the AP has a physical antenna switch or allows you to change antenna orientation settings on a per-radio basis or on a per-AP basis. |
Wall/ Ceiling | This allows you to adjust coverage depending on the antenna orientation of the AP’s radios for better coverage. Select Wall if you mount the AP to a wall. Select Ceiling if the AP is mounted on a ceiling. You can switch from Wall to Ceiling if there are still wireless dead zones, and vice versa. |
LED Suppression Mode Configuration | This section is available only when the AP supports LED suppression mode. |
Suppression On | Select this option to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. If the check box is unchecked, it means the LEDs will stay lit after the AP is ready. |
Power Setting | Enable Force override the power mode to full power if you are using a PoE injector that does not support PoE negotiation. Otherwise, the AP cannot draw full power from the power sourcing equipment. Enable this power mode to improve the AP’s performance in this situation. ![]() ![]() |
Locator LED Configuration | This section is available only when the AP has a locator LED. |
Turn On/ Turn Off | When the locator LED is off, click the Turn On button to activate the locator function. It will show the actual location of the AP between several devices in the network. If the locator LED is blinking, click the Turn Off button to stop the locator LED from blinking immediately. |
Automatically Extinguish After | Enter a time interval between 1 and 60 minutes to stop the locator LED from blinking. The locator LED will start to blink for the number of minutes set here. If you make changes to the time default setting, it will be stored as the default when the AP restarts. |
Reset AP Configuration | This section is available only when the AP is online. |
Apply Factory Default | Click the button to reset all of the AP settings to the factory defaults. |
Cancel | Click Cancel to close the window with changes unsaved. |
IP Setting | |
VLAN Settings | |
OP Mode | AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). |
Secure Tunnel SSID | Configure your AP using Secure Tunnel SSID profiles if you want to access the network behind the Zyxel Device or to access the Internet. |
# | This field is a sequential value, and it is not associated with a specific entry. |
SSID Profile | Click on the SSID profile to show the drop down list box. Select a pre-configured SSID profile you want to configure as the Secure Tunnel SSID. |
Interface | Click on the interface to show the drop-down list box. Select an interface you want the AP traffic to go through on the Zyxel Device. The interface you select here will override the interface configured in the SSID profile. |
Band Mode | Click on the band mode to show the drop-down list box. Select the frequency band you want the AP to use. |
Local Bridge SSID | |
# | This field is a sequential value, and it is not associated with a specific |
SSID Profile | Click on the SSID profile name to show the drop down list box. Select a pre-configured SSID profile you want to configure as the Local Bridge SSID. |
VID | Click on the interface to configure the VID number. The VID you set here will override the VID configured in the SSID profile. |
Broadcast Storm Control | Enabling this will drop ingress broadcast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide). Ethernet storm control prevents WiFi clients from receiving excessive broadcast traffic sent from wired clients in the same subnet. Wireless storm control prevents wired clients from receiving excessive broadcast traffic sent from WiFi clients in the same subnet. See Edit AP List for more information on storm control. |
Multicast Storm Control | Enabling this will drop ingress multicast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. The maximum traffic rate can be changed using the CLI (see CLI Reference Guide). Ethernet storm control prevents WiFi clients from receiving excessive multicast traffic sent from wired clients in the same subnet. Wireless storm control prevents wired clients from receiving excessive multicast traffic sent from WiFi clients in the same subnet. See Edit AP List for more information on storm control. |
Force Override AC IP Config on AP | Select this to have the Zyxel Device change the AP controller’s IP address on the managed AP(s) to match the configuration in this screen. |
Override Type | Select Auto to have the managed AP(s) automatically send broadcast packets to find any other available AP controllers. Select Manual to replace the AP controller’s IP address configured on the managed AP(s) with the one(s) you specified below. |
Primary Controller | Specify the IP address of the primary AP controller if you set Override Type to Manual. |
Secondary Controller | Specify the IP address of the secondary AP controller if you set Override Type to Manual. |
Fall back to Primary Controller when possible | Select this option to have the managed AP(s) change back to associate with the primary AP controller as soon as the primary AP controller is available. |
Fall Back Check Interval | Set how often the managed AP(s) check whether the primary AP controller is available. |
Group Setting | |
Default Group | Select a group that is used as the default group. Any AP that is not configured to associate with a specific AP group belongs to the default group automatically. |
Group Summary | |
Add | Click this button to create a new AP group. |
Edit | Select an entry and click this button to edit its properties. |
Remove | Select an entry and click this button to remove it from the list. ![]() |
DCS Now | Select one or multiple groups and click this button to use DCS (Dynamic Channel Selection) to allow the APs in the group(s) to automatically find a less-used channel in an environment where there are many APs and there may be interference. ![]() ![]() |
# | This is the index number of the group in the list. |
Group Name | This is the name of the group. |
Member Count | This is the total number of APs which belong to this group. |
Group Name | Enter a name for this group. You can use up to 31 alphanumeric characters. Dashes and underscores are also allowed. The name should start with a letter. |
Description | Enter a description for this group. You can use up to 31 characters, spaces and underscores allowed. |
Location | Specify the name of the place where the AP group is located. |
Output Power | Set the maximum output power of the AP. If there is a high density of APs in an area, decrease the output power of the managed AP to reduce interference with other APs. ![]() |
VLAN Settings | |
Port Settings | |
Model Specific Setting | Select the model of the managed AP to display the model-specific port and VLAN settings in the tables below. |
Port Setting | You can activate or deactivate a non-uplink port. |
# | This is the port’s index number in this list. |
Status | This displays whether or not the port is activated. |
Port | This shows the name of the physical Ethernet port on the managed AP. |
PVID | This shows the port’s PVID. A PVID (Port VLAN ID) is a tag that adds to incoming untagged frames received on a port so that the frames are forwarded to the VLAN group that the tag defines. |
VLAN Configuration | Use Add to create a new VLAN Configuration. Select a VLAN Configuration first to use the Edit, Remove, Activate and Inactivate buttons. |
# | This is the VLAN’s index number in this list. |
Status | This displays whether or not the VLAN is activated. |
Name | This shows the name of the VLAN. |
VID | This shows the VLAN ID number. |
Member | This field displays the Ethernet port(s) that is a member of this VLAN. |
Load Balancing Setting | |
Enable Load Balancing | Select this to enable load balancing on the Zyxel Device. Use this section to configure wireless network traffic load balancing between the managed APs in this group. ![]() |
Mode | Select a mode by which load balancing is carried out. Select By Station Number to balance network traffic based on the number of specified stations connected to an AP. Select By Traffic Level to balance network traffic based on the volume generated by the stations connected to an AP. Select By Smart Classroom to balance network traffic based on the number of specified stations connected to an AP. The AP ignores association request and authentication request packets from any new station when the maximum number of stations is reached. If you select By Station Number or By Traffic Level, once the threshold is crossed (either the maximum station numbers or with network traffic), the AP delays association request and authentication request packets from any new station that attempts to make a connection. This allows the station to automatically attempt to connect to another, less burdened AP if one is available. |
Radio 1/2 Max Station Number | Enter the threshold number of stations at which an AP begins load balancing its connections. |
Disassociate station when overloaded | This function is enabled by default and the disassociation priority is always Signal Strength when you set Mode to By Station Number. Select this option to disassociate wireless clients connected to the AP when it becomes overloaded. If you do not enable this option, then the AP simply delays the connection until it can afford the bandwidth it requires, or it transfers the connection to another AP within its broadcast radius. The disassociation priority is determined automatically by the Zyxel Device and is as follows: • Idle Timeout - Devices that have been idle the longest will be disassociated first. If none of the connected devices are idle, then the priority shifts to Signal Strength. • Signal Strength - Devices with the weakest signal strength will be disassociated first. ![]() |
Radio 1/2 Traffic Level | Select the threshold traffic level at which the AP begins load balancing its connections (Low, Medium, High). The maximum bandwidth allowed for each level is: • Low - 11 Mbps, • Medium - 23 Mbps • High - 35M bps |
AP List | |
Available | This lists the APs that do not belong to this group. Select the APs that you want to add to the group you are editing, and click the right arrow button to add them. |
Member | This lists the APs that belong to this group. Select any APs that you want to remove from the group, and click the left arrow button to remove them. |
AP List | |
Override Member AP Setting | Click this button to overwrite the settings of all managed APs in this group with the settings you configure here. All Override Group check boxes on the AP Management > Mgnt. AP List > Edit AP List screen for the APs in this group will be deselected. |
AP Firmware | |
Runtime Firmware | This displays the current AP firmware version on the Zyxel Device. The Zyxel Device must have the latest AP firmware to manage all supported APs. |
Available Firmware | This field displays if there is a later AP firmware version available on the firmware server. It displays N/A if the Zyxel Device cannot connect with the firmware server. Check that the Zyxel Device has Internet access if N/A displays and then click the Check button below. If a newer Zyxel Device AP firmware is available, its version number and a More Details icon displays here. |
Last Check Success | This displays the date and time the last check for new firmware was made and whether the check is in progress (checking), was successful (success), or has failed (fail). |
Check | Click this button to have the Zyxel Device display the latest AP firmware version available on the firmware server. |
Apply AP Firmware | Due to space limitations, the Zyxel Device only downloads and keeps AP firmware for APs it is currently managing. If you connect a new AP to the Zyxel Device, the Zyxel Device may need to download a new AP firmware. Please wait while downloading new firmware as the speed depends on your Internet connection speed. Make sure to maintain the Internet connection while downloading new firmware. |
Apply | Click this to download newer Available Firmware from the firmware server and update the Runtime Firmware version. |
# | This is an index number of a managed AP. |
Model | This displays the name of all manageable AP models. |
Runtime Firmware | This displays the firmware version that the managed AP must have in order to be managed by the Zyxel Device. Firmware for APs that the Zyxel Device already has displays in bold; firmware that the Zyxel Device doesn’t have or is still downloading is grayed out. Firmware that is in the download queue will show To be downloaded. |
Refresh | Click this to update the model firmware table. |
Suspected Rogue AP Classification Rule | Click the check boxes (Weak Security (Open, WEP, WPA-PSK), Un-managed AP, Hidden SSID, SSID Keyword) of the characteristics an AP should have for the Zyxel Device to rule it as a rogue AP. |
Add | Click this to add an SSID Keyword. |
Edit | Select an SSID Keyword and click this button to modify it. |
Remove | Select an existing SSID keyword and click this button to delete it. |
# | This is the SSID Keyword’s index number in this list. |
SSID Keyword | This field displays the SSID Keyword. |
Rogue/Friendly AP List | |
Add | Click this button to add an AP to the list and assign it either friendly or rogue status. |
Edit | Select an AP in the list to edit and reassign its status. |
Remove | Select an AP in the list to remove. |
Containment | Click this button to quarantine the selected AP. A quarantined AP cannot grant access to any network services. Any stations that attempt to connect to a quarantined AP are disconnected automatically. |
Dis-Containment | Click this button to take the selected AP out of quarantine. An unquarantined AP has normal access to the network. |
# | This field is a sequential value, and it is not associated with any interface. |
Containment | This field indicates the selected AP’s containment status. |
Role | This field indicates whether the selected AP is a rogue-ap or a friendly-ap. To change the AP’s role, click the Edit button. |
MAC Address | This field indicates the AP’s radio MAC address. |
Description | This field displays the AP’s description. You can modify this by clicking the Edit button. |
Rogue/Friendly AP List Importing/Exporting | These controls allow you to export the current list of rogue and friendly APs or import existing lists. |
File Path / Browse / Importing | Enter the file name and path of the list you want to import or click the Browse button to locate it. Once the File Path field has been populated, click Importing to bring the list into the Zyxel Device. |
Exporting | Click this button to export the current list of either rogue APs or friendly APS. |
Monitor Mode Settings | |
Enable Rogue AP Containment | Select this to enable rogue AP containment. |
MAC | Enter the MAC address of the AP you want to add to the list. A MAC address is a unique hardware identifier in the following hexadecimal format: xx:xx:xx:xx:xx:xx where xx is a hexadecimal number separated by colons. |
Description | Enter up to 60 characters for the AP’s description. Spaces and underscores are allowed. |
Role | Select either Rogue AP or Friendly AP for the AP’s role. |
2.4GHz Radio Auto Optimization | Select this to have the AP scan and choose a radio channel that has least interface. |
5GHz Radio Auto Optimization | Select this to have the AP change the channel bandwidth from 80MHz to 20 MHz to reduce the radio interference with other APs. |
Client Auto Optimization | Select this to have the AP try to steer the wireless clients in poor health to an AP or SSID with a strong signal every 30 minutes. |
Enable Auto Healing | Select this option to turn on the auto healing feature. |
Save Current State | Click this button to have all manged APs immediately scan their neighborhoods three times in a row and update their neighbor lists to the AP controller (Zyxel Device). |
Auto Healing Interval | Set the time interval (in minutes) at which the managed APs scan their neighborhoods and report the status of neighbor APs to the AP controller (Zyxel Device). An AP is considered “failed” if the AP controller obtains the same scan result that the AP is missing from the neighbor list of other APs three times. |
Power Threshold | Set the power level (in dBm) to which the neighbor APs of the failed AP increase their output power in order to extend their wireless service coverage areas. When the failed AP is working again, its neighbor APs return their output power to the original level. |
Port Number | Type | Description |
8548 | TCP | Ekahau T201 location update. |
8549 | UDP | Ekahau T201 location update. |
8550 | TCP | Ekahau T201 tag maintenance protocol and Ekahau RTLS Controller user interface. |
8552 | UDP | Ekahau Location Protocol |
8553 | UDP | Ekahau Maintenance Protocol |
8554 | UDP | Ekahau T301 firmware update. |
8560 | TCP | Ekahau Vision web interface |
8562 | UDP | Ekahau T301W firmware update. |
8569 | UDP | Ekahau TZSP Listener Port |
Enable | Select this to use Wi-Fi to track the location of Ekahau Wi-Fi tags. |
IP Address | Specify the IP address of the Ekahau RTLS Controller. |
Server Port | Specify the server port number of the Ekahau RTLS Controller. |
