Label | Description |
Show Advanced Settings / Hide Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
Create new Object | Use to configure any new settings objects that you need to use in this screen. |
Enable L2TP Over IPSec | Use this field to turn the Zyxel Device’s L2TP VPN function on or off. |
VPN Connection | Select the IPSec VPN connection the Zyxel Device uses for L2TP VPN. All of the configured VPN connections display here, but the one you use must meet the requirements listed in IPSec Configuration Required for L2TP VPN. ![]() |
IP Address Pool | Select the pool of IP addresses that the Zyxel Device uses to assign to the L2TP VPN clients. Use Create new Object if you need to configure a new pool of IP addresses. This should not conflict with any WAN, LAN, DMZ or WLAN subnet even if they are not in use. |
Authentication Method | Select how the Zyxel Device authenticates a remote user before allowing access to the L2TP VPN tunnel. The authentication method has the Zyxel Device check a user’s user name and password against the Zyxel Device’s local database, a remote LDAP, RADIUS, a Active Directory server, or more than one of these. |
Authentication Server Certificate | Select the certificate to use to identify the Zyxel Device for L2TP VPN connections. You must have certificates already configured in the My Certificates screen The certificate is used with the EAP, PEAP, and MSCHAPv2 authentication protocols. |
Allowed User | The remote user must log into the Zyxel Device to use the L2TP VPN tunnel. Select a user or user group that can use the L2TP VPN tunnel. Use Create new Object if you need to configure a new user account. Otherwise, select any to allow any user with a valid account and password on the Zyxel Device to log in. |
Keep Alive Timer | The Zyxel Device sends a Hello message after waiting this long without receiving any traffic from the remote user. The Zyxel Device disconnects the VPN tunnel if the remote user does not respond. |
First DNS Server, Second DNS Server | Specify the IP addresses of DNS servers to assign to the remote users. You can specify these IP addresses two ways. Custom Defined - enter a static IP address. From ISP - use the IP address of a DNS server that another interface received from its DHCP server. |
First WINS Server, Second WINS Server | The WINS (Windows Internet Naming Service) server keeps a mapping table of the computer names on your network and the IP addresses that they are currently using. Type the IP addresses of up to two WINS servers to assign to the remote users. You can specify these IP addresses two ways. |
Apply | Click Apply to save your changes in the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
