Label | Description |
Interface Summary IPv6 Interface Summary | Use the Interface Summary section for IPv4 network settings. Use the IPv6 Interface Summary section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below. |
Name | This field displays the name of the physical Ethernet port on the Zyxel Device. |
Status | This field displays the current status of each physical port on the Zyxel Device. Down - The port is not connected. Speed / Duplex - The port is connected. This field displays the port speed and duplex setting (Full or Half). |
VID | This field displays the VLAN ID to which the port belongs. |
IP Addr/Netmask IP Address | This field displays the current IP address (and subnet mask) of the interface. If the IP address is 0.0.0.0 (in the IPv4 network) or :: (in the IPv6 network), the interface does not have an IP address yet. |
IP Assignment | This field displays how the interface gets its IPv4 address. Static - This interface has a static IPv4 address. DHCP Client - This interface gets its IPv4 address from a DHCP server. |
Action | Use this field to get or to update the IP address for the interface. Click Renew to send a new DHCP request to a DHCP server. If the interface cannot use one of these ways to get or to update its IP address, this field displays n/a. |
Port Statistics Table | |
Poll Interval | Enter how often you want this window to be updated automatically, and click Set Interval. |
Set Interval | Click this to set the Poll Interval the screen uses. |
Stop | Click this to stop the window from updating automatically. You can start it again by setting the Poll Interval and clicking Set Interval. |
Switch to Graphic View | Click this to display the port statistics as a line graph. |
Name | This field displays the name of the interface. |
Status | This field displays the current status of the physical port. Down - The physical port is not connected. Speed / Duplex - The physical port is connected. This field displays the port speed and duplex setting (Full or Half). |
TxPkts | This field displays the number of packets transmitted from the Zyxel Device on the physical port since it was last connected. |
RxPkts | This field displays the number of packets received by the Zyxel Device on the physical port since it was last connected. |
Tx Bcast | This field displays the number of broadcast packets transmitted from the Zyxel Device on the physical port since it was last connected. |
Rx Bcast | This field displays the number of broadcast packets received by the Zyxel Device on the physical port since it was last connected. |
Collisions | This field displays the number of collisions on the physical port since it was last connected. |
Tx | This field displays the transmission speed, in bytes per second, on the physical port in the one-second interval before the screen updated. |
Rx | This field displays the reception speed, in bytes per second, on the physical port in the one-second interval before the screen updated. |
Up Time | This field displays how long the physical port has been connected. |
System Up Time | This field displays how long the Zyxel Device has been running since it last restarted or was turned on. |
Refresh Interval | Enter how often you want this window to be automatically updated. |
Refresh Now | Click this to update the information in the window right away. |
Port Selection | Select the Ethernet port for which you want to view the packet statistics. |
Switch to Grid View | Click this to display the port statistics as a table. |
Kbps/Mbps | The y-axis represents the speed of transmission or reception. |
Time | The x-axis shows the time period over which the transmission or reception occurred. |
TX | This line represents traffic transmitted from the Zyxel Device on the physical port since it was last connected. |
RX | This line represents the traffic received by the Zyxel Device on the physical port since it was last connected. |
Last Update | This field displays the date and time the information in the window was last updated. |
More Information | Click this to view additional information about the selected radio’s wireless traffic and station count. Information spans a 24 hour period. |
Status | This displays whether or not the radio is enabled. |
MAC Address | This displays the MAC address of the radio. |
Radio | This indicates the radio number on the Zyxel Device to which it belongs. |
OP Mode | This indicates the radio’s operating mode. Operating modes are AP (MBSSID), Root AP or Repeater. |
AP/WDS Profile | This indicates the AP profile name and WDS profile name to which the radio belongs. This field is available only on the Zyxel Device that supports WDS. |
Profile | This indicates the AP profile name to which the radio belongs. This field is available only on the Zyxel Device that does not support WDS. |
Frequency Band | This indicates the wireless frequency band currently being used by the radio. |
Channel | This indicates the radio’s channel ID. |
Transmit Power | This displays the output power of the radio. |
Station | This displays the number of wireless clients connected to this radio on the Zyxel Device. |
Upload | This displays the total number of packets received by the radio. |
Download | This displays the total number of packets transmitted by the radio. |
Channel Utilization | This indicates how much IEEE 802.11 traffic the radio can receive on the channel. It displays what percentage of the radio’s channel is currently being used. |
SSID Detail | This list shows information about all the wireless clients that have connected to the specified radio over the preceding 24 hours. |
# | This is the items sequential number in the list. It has no bearing on the actual data in this list. |
SSID Name | This displays an SSID associated with this radio. There can be up to eight maximum. |
BSSID | This displays a BSSID associated with this radio. The BSSID is tied to the SSID. |
Security Mode | This displays the security mode in which the SSID is operating. |
VLAN | This displays the VLAN ID associated with the SSID. |
Traffic Statistics | This graph displays the overall traffic information of the radio over the preceding 24 hours. |
Kbps/Mbps | This y-axis represents the amount of data moved across this radio in megabytes per second. |
Time | This x-axis represents the amount of time over which the data moved across this radio. |
Station Count | This graph displays the connected station information of the radio over the preceding 24 hours |
Stations | The y-axis represents the number of connected stations. |
Time | The x-axis shows the time period over which a station was connected. |
OK | Click this to close this window. |
Cancel | Click this to close this window. |
# | This is the station’s index number in this list. |
IP Address | This is the station’s IP address. |
MAC Address | This is the station’s MAC address. |
Radio | This is the radio number on the Zyxel Device to which the station is connected. |
Capability | This displays the supported standard currently being used by the station or the standards supported by the station. |
802.11 Features | This displays whether the station supports IEEE802.11r, IEEE 802.11k, IEEE 802.11v or none of the above (N/A). |
SSID Name | This indicates the name of the wireless network to which the station is connected. A single AP can have multiple SSIDs or networks. |
Security Mode | This indicates which secure encryption methods is being used by the station to connect to the network. |
Signal Strength | This is the RSSI (Received Signal Strength Indicator) of the station’s wireless connection. |
Tx Rate | This is the maximum transmission rate of the station. |
Rx Rate | This is the maximum reception rate of the station. |
Association Time | This displays the time the station first associated with the Zyxel Device’s wireless network. |
Refresh | Click this to refresh the items displayed on this page. |
WDS Uplink Info WDS Downlink Info | Uplink refers to the WDS link from the repeaters to the root AP. Downlink refers to the WDS link from the root AP to the repeaters. When the Zyxel Device is in root AP mode and connected to a repeater, only the downlink information is displayed. When the Zyxel Device is in repeater mode and connected to a root AP directly or via another repeater, the uplink information is displayed. When the Zyxel Device is in repeater mode and connected to a root AP and other repeater(s), both the uplink and downlink information would be displayed. |
# | This is the index number of the root AP or repeater in this list. |
MAC Address | This is the MAC address of the root AP or repeater to which the Zyxel Device is connected using WDS. |
Radio | This is the radio number on the root AP or repeater to which the Zyxel Device is connected using WDS. |
SSID Name | This indicates the name of the wireless network to which the Zyxel Device is connected using WDS. |
Security Mode | This indicates which secure encryption methods is being used by the Zyxel Device to connect to the root AP or repeater using WDS. |
Signal Strength | This is the RSSI (Received Signal Strength Indicator) of the wireless connection in WDS. |
Tx Rate | This is the maximum transmission rate of the root AP or repeater to which the Zyxel Device is connected using WDS. |
Rx Rate | This is the maximum reception rate of the root AP or repeater to which the Zyxel Device is connected using WDS. |
Association Time | This displays the time the Zyxel Device first associated with the wireless network using WDS. |
Discovered APs | |
Rogue AP | This shows how many devices are detected as rogue APs. |
Suspected rogue AP | This shows how many devices are detected as possible rogue APs based on the classification rule(s) in Rogue AP. |
Friendly AP | This shows how many devices are detected as friendly APs. |
Un-classified AP | This shows how many devices are detected, but have not been classified as either Rogue or Friendly by the Zyxel Device. |
Detect Now | Click this button for the Zyxel Device to scan for APs in the network. |
Detected Device | |
Mark as Rogue AP | Click this button to mark the selected AP as a rogue AP. For more on managing rogue APs, see the Configuration > Wireless > Rogue AP screen. |
Mark as Friendly AP | Click this button to mark the selected AP as a friendly AP. For more on managing friendly APs, see the Configuration > Wireless > Rogue AP screen. |
# | This is the detected device’s index number in this list. |
Status | This indicates the detected device’s status. |
Device | This indicates the type of device detected. |
Role | This indicates the detected device’s role (such as friendly or rogue). |
Classified by | This indicates the detected device’s classification rule. |
MAC Address | This indicates the detected device’s MAC address. |
SSID Name | This indicates the detected device’s SSID. |
Channel ID | This indicates the detected device’s channel ID. |
802.11 Mode | This indicates the 802.11 mode (a/b/g/n/ac/ax) transmitted by the detected device. |
Security | This indicates the encryption method (if any) used by the detected device. |
Description | This displays the detected device’s description. For more on managing friendly and rogue APs, see the Configuration > Wireless > Rogue APscreen. |
Last Seen | This indicates the last time the device was detected by the Zyxel Device. |
Show Filter / Hide Filter | Click this button to show or hide the filter settings. If the filter settings are hidden, the Display, Email Log Now, Refresh, and Clear Log fields are available. If the filter settings are shown, the Display, Priority, Source Address, Destination Address, Source Interface, Destination Interface, Protocol, Keyword, and Search fields are available. |
Display | Select the category of log message(s) you want to view. You can also view All Logs at one time, or you can view the Debug Log. |
Priority | This displays when you show the filter. Select the priority of log messages to display. The log displays the log messages with this priority or higher. Choices are: any, emerg, alert, crit, error, warn, notice, and info, from highest priority to lowest priority. This field is read-only if the Category is Debug Log. |
Source Address | This displays when you show the filter. Type the source IP address of the incoming packet that generated the log message. Do not include the port in this filter. |
Destination Address | This displays when you show the filter. Type the IP address of the destination of the incoming packet when the log message was generated. Do not include the port in this filter. |
Source Interface | This displays when you show the filter. Select the source interface of the packet that generated the log message. |
Destination Interface | This displays when you show the filter. Select the destination interface of the packet that generated the log message. |
Protocol | This displays when you show the filter. Select a service protocol whose log messages you would like to see. |
Keyword | This displays when you show the filter. Type a keyword to look for in the Message, Source, Destination and Note fields. If a match is found in any field, the log message is displayed. You can use up to 63 alphanumeric characters and the underscore, as well as punctuation marks ()’ ,:;?! +-*/= #$% @ ; the period, double quotes, and brackets are not allowed. |
Search | This displays when you show the filter. Click this button to update the log using the current filter settings. |
Email Log Now | Click this button to send log messages to the Active e-mail addresses specified in the Send Log To field on the Configuration > Log & Report > Log Settings screen. |
Refresh | Click this to update the list of logs. |
Clear Log | Click this button to clear the whole log, regardless of what is currently displayed on the screen. |
# | This field is a sequential value, and it is not associated with a specific log message. |
Time | This field displays the time the log message was recorded. |
Priority | This field displays the priority of the log message. It has the same range of values as the Priority field above. |
Category | This field displays the log that generated the log message. It is the same value used in the Display and (other) Category fields. |
Message | This field displays the reason the log message was generated. The text “[count=x]”, where x is a number, appears at the end of the Message field if log consolidation is turned on and multiple entries were aggregated to generate into this one. |
Source | This field displays the source IP address and the port number in the event that generated the log message. |
Source Interface | This field displays the source interface of the packet that generated the log message. |
Destination | This field displays the destination IP address and the port number of the event that generated the log message. |
Destination Interface | This field displays the destination interface of the packet that generated the log message. |
Protocol | This field displays the service protocol in the event that generated the log message. |
Note | This field displays any additional information about the log message. |
