Network
Overview
This describes how you can configure the management IP address and VLAN settings of your Zyxel Device.
IP Setup
IP Setting
Use this screen to configure the IP address for your Zyxel Device.
Configuration > Network > IP Setting
Label
Description
IP Address Assignment
Get Automatically
Select this to make the interface a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server.
Use Fixed IP Address
Select this if you want to specify the IP address, subnet mask, and gateway manually.
IP Address
Enter the IP address for this interface.
Subnet Mask
Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers in the network.
Gateway
Enter the IP address of the gateway. The Zyxel Device sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the interface.
DNS Server IP Address
Enter the IP address of the DNS server.
IPv6 Address Assignment
Enable Stateless Address Auto-configuration (SLAAC)
Select this to enable IPv6 stateless auto-configuration on the Zyxel Device. The Zyxel Device will generate an IPv6 address itself from a prefix obtained from an IPv6 router in the network.
Link-Local Address
This displays the IPv6 link-local address and the network prefix that the Zyxel Device generates itself for the LAN interface.
IPv6 Address/Prefix Length
Enter the IPv6 address and the prefix length for the LAN interface if you want to use a static IP address. This field is optional.
The prefix length indicates what the left-most part of the IP address is the same for all computers in the network, that is, the network address.
Gateway
Enter the IPv6 address of the default outgoing gateway using colon (:) hexadecimal notation.
Metric
Enter the priority of the gateway (if any) on the LAN interface. The Zyxel Device decides which gateway to use based on this priority. The lower the number, the higher the priority. If two or more gateways have the same priority, the Zyxel Device uses the one that was configured first. Enter zero to set the metric to 1024 for IPv6.
DHCPv6 Client
Select this option to set the Zyxel Device to act as a DHCPv6 client.
DUID
This field displays the DHCP Unique IDentifier (DUID) of the Zyxel Device, which is unique and used for identification purposes when the Zyxel Device is exchanging DHCPv6 messages with others.
Request Address
Select this option to get an IPv6 address from the DHCPv6 server.
DHCPv6 Request Options
Select this option to determine what additional information to get from the DHCPv6 server.
DNS Server
Select this option to obtain the IP address of the DNS server.
NTP Server
Select this option to obtain the IP address of the NTP server.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
VLAN
Note: Mis-configuring the management VLAN settings in your Zyxel Device can make it inaccessible. If this happens, you will have to reset the Zyxel Device.
A Virtual Local Area Network (VLAN) allows a physical network to be partitioned into multiple logical networks. Devices on a logical network belong to one group. A device can belong to more than one group. With VLAN, a device cannot directly talk to or hear from devices that are not in the same group(s); the traffic must first go through a router.
Wireless Bridge VLAN ID
Wireless bridge VLAN allows you to have clients in different WiFi networks appear to be in the same virtual network using VLAN IDs. VLAN IDs are sent across the wireless bridge so that only clients with the same VLAN ID receive that network traffic. See Zyxel Device Roles for more information on the wireless bridge.
In the figure below, a client (C2) in the branch office wants to connect to the main office (Y). The branch office client (C2) can connect to the main office network using the VLAN ID 10. However, the branch office client (C2) cannot connect to the to the main office network using the VLAN ID 20 because that VLAN ID does not exist in the main office network. To bridge the branch office network and the main office network, the VLAN IDs you set on the Zyxel Device (X) should be the same as the VLAN IDs you set on the root AP (Y).
Wireless Bridge VLAN ID Example
Use this screen to configure the VLAN settings for your Zyxel Device.
Configuration > Network > VLAN
Label
Description
VLAN Settings
Management VLAN ID
Enter a VLAN ID for the Zyxel Device.
As Native VLAN
Select this option to treat this VLAN ID as a VLAN created on the Zyxel Device and not one assigned to it from outside the network.
Wireless Bridge Vlan Setting
Add
Click this to add an entry in the table.
Remove
Select an entry and click this to remove the selected entry.
This field is a sequential value. It is not associated with any VLAN ID.
Wireless Bridge Vlan ID (1-4094)
Enter a VLAN ID for the wireless bridge. Duplicate VLAN IDs are not allowed.
The VLAN IDs you set on your root AP should be the same as the VLAN IDs you set here. See Zyxel Device Roles for more information on wireless bridge.
Apply
Reset
NCC Discovery
You can manage the Zyxel Device through the Zyxel Nebula Control Center (NCC). Use this screen to configure the proxy server settings if the Zyxel Device is behind a proxy server.
Configuration > Network > NCC Discovery
label
description
Nebula Control Center Status
Internet
This field displays whether the Zyxel Device can connect to the Internet.
Nebula Connectivity
This field displays whether the Zyxel Device can connect to the Zyxel Nebula Control Center (NCC).
Nebula Control Center Discovery Setting
Enable
Select this option to turn on NCC discovery on the Zyxel Device. The Zyxel Device will try to discover the NCC and go into NCC management mode when it is connected to the Internet and has been registered in the NCC.
If NCC discovery is disabled, the Zyxel Device will not discover the NCC and remain in standalone operation.
Use Proxy to Access NCC
If the Zyxel Device is behind a proxy server, you need to select this option and configure the proxy server settings so that the Zyxel Device can access the NCC through the proxy server.
Proxy Server
Enter the IP address of the proxy server.
Proxy Port
Enter the service port number used by the proxy server.
Authentication
Select this option if the proxy server requires authentication before it grants access to the NCC.
User Name
Enter your proxy user name.
Password
Enter your proxy password.
Apply
Reset
