type | description |
File Infector | This is a small program that embeds itself in a legitimate program. A file infector is able to copy and attach itself to other programs that are executed on an infected computer. |
Boot Sector Virus | This type of virus infects the area of a hard drive that a computer reads and executes during startup. The virus causes computer crashes and to some extend renders the infected computer inoperable. |
Macro Virus | Macro viruses or Macros are small programs that are created to perform repetitive actions. Macros run automatically when a file to which they are attached is opened. Macros spread more rapidly than other types of viruses as data files are often shared on a network. |
Email Virus | Email viruses are malicious programs that spread through email. |
Polymorphic Virus | A polymorphic virus (also known as a mutation virus) tries to evade detection by changing a portion of its code structure after each execution or self replication. This makes it harder for an anti-malware scanner to detect or intercept it. A polymorphic virus can also belong to any of the virus types discussed above. |
• 7z Archive (7z) | • AVI Video (avi) | • BMP Image (bmp) | • BZ2 Archive (bz2) |
• Executables (exe) | • Macromedia Flash Data (swf) | • GIF Image (gif) | • GZ Archive (gz) |
• JPG Image (jpg) | • MOV Video (mov) | • MP3 Audio (mp3) | • MPG Video (mpg) |
• MS Office Document (doc...) | • PDF Document (pdf) | • PNG Image (png) | • RAR Archive (rar) |
• RM Video (rm) | • RTF Document (rtf) | • TIFF Image (tif) | • WAV Audio (wav) |
• ZIP Archive (zip) |
label | description |
General Setting | |
Enable | Click to activate the anti-malware feature to protect your connected network from infection and the installation of malicious software. |
Collect Statistics | Click to have the Zyxel Device collect anti-malware statistics. All of the statistics are erased if you restart the Zyxel Device or click Flush Data in Security Statistics > Anti-Malware. |
Scan and detect EICAR test virus | Click to have the Zyxel Device check for an EICAR test file and treat it in the same way as a real malware file. The EICAR test file is a standardized test file for signature based anti-malware scanners. When the scanner detects the EICAR file, it responds in the same way as if it found real malware. The EICAR file can also be compressed to test whether the anti-malware software can detect it in a compressed file. |
File size limit | Set the limit of the file size the Zyxel Device anti-malware will scan. A file that exceeds the file size you set here will pass without been scanned by the Zyxel Device anti-malware. |
Destroy infected file | When you select this check box, if a malware signature is matched, the Zyxel Device overwrites the infected portion of the file with zeros before being forwarded to the user. The uninfected portion of the file will pass through unmodified. |
Log | These are the log options: • no: Do not create a log when a packet matches a signature. • log: Create a log on the Zyxel Device when a packet matches a signature. • log alert: An alert is an emailed log for more serious events that may need more immediate attention. Select this option to have the Zyxel Device send an alert when a packet matches a signature(s). |
File Type for Scan | File types that can be checked by the Zyxel Device are listed here. Note that the files on this list are currently bypassed. To use this feature on a specific file type, click this file type and then click the right arrow button. See available file types in File Scanning Cloud Query Supported File Types. |
Search | Type an item in the search box, then click this to display all file types in the table below according to the item you typed. |
Select All | Select this to select all file types in the table. |
Apply | Click Apply to save your changes. |
Cancel | Click Cancel to return the screen to its last-saved settings. |
LABEL | Description |
Enable Allow List | Select this to bypass checking by this feature (if enabled) and automatically allow incoming files with names or hash value (MD5 Hash) that match the white list patterns. |
Log | These are the log options: • no: Do not create a log when a packet matches a signature. • log: Create a log on the Zyxel Device when a packet matches a signature. |
MD5 Hash | Configure the settings to automatically allow incoming files with MD5 Hash value that match the patterns you set. An MD5 hash can consist of 32 alpha-numerical characters. |
Add | Click this to create a new entry. |
Remove | Select an entry and click this to delete it. |
Active | To turn on an entry, select it and click Active. |
Inactive | To turn off an entry, select it and click Inactive. |
Column ( ![]() | Click the column icon to select the fields you want to show in the table. Uncheck the checkbox if you want to hide a field in the table. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
Value | This field displays the hash pattern of the entry. Enter the hash pattern for this entry. Specify a pattern to identify the names of files that the Zyxel Device should not scan for viruses. |
Edit | Select an entry and click this icon to modify it. ![]() |
Remove | Select an entry and click this icon to delete it. ![]() |
Save Changes | Click this icon to save the changes in this row. ![]() |
Cancel Changes | Click this icon to cancel the changes in this row. ![]() |
File Name Pattern | Configure the settings to automatically allow incoming files with names that match the patterns you set. |
Name | This field displays the file pattern of the entry. Enter the file pattern for this entry. Specify a pattern to identify the names of files that the Zyxel Device should not scan for viruses. • Use up to 80 characters. Alphanumeric characters, underscores (_), dashes (-), question marks (?) and asterisks (*) are allowed. • A question mark (?) lets a single character in the file name vary. For example, use “a?.zip” (without the quotation marks) to specify aa.zip, ab.zip and so on. • Wildcards (*) let multiple files match the pattern. For example, use “*a.zip” (without the quotation marks) to specify any file that ends with “a.zip”. A file named “testa.zip would match. There could be any number (of any type) of characters in front of the “a.zip” at the end and the file name would still match. A file named “test.zipa” for example would not match. • A * in the middle of a pattern has the Zyxel Device check the beginning and end of the file name and ignore the middle. For example, with “abc*.zip”, any file starting with “abc” and ending in “.zip” matches, no matter how many characters are in between. • The whole file name has to match if you do not use a question mark or asterisk. • If you do not use a wildcard, the Zyxel Device checks up to the first 80 characters of a file name. |
Enable Block List | Select this to bypass checking by this feature (if enabled) and automatically block incoming files with names or hash value (MD5 Hash) that match the block list patterns. |
MD5 Hash | Configure the settings to automatically block incoming files with MD5 Hash value that match the patterns you set. An MD5 hash can consist of 32 alpha-numerical characters. |
Column ( ![]() | Click the column icon to select the fields you want to show in the table. Clear the check box if you want to hide a field in the table. |
File Name Pattern | Configure the settings to automatically block incoming files with names that match the patterns you set. |
Value | This field displays the file pattern of the entry. Enter the file pattern for this entry. Specify a pattern to identify the names of files that the Zyxel Device should not scan for viruses. • Use up to 80 characters. Alphanumeric characters, underscores (_), dashes (-), question marks (?) and asterisks (*) are allowed. • A question mark (?) lets a single character in the file name vary. For example, use “a?.zip” (without the quotation marks) to specify aa.zip, ab.zip and so on. • Wildcards (*) let multiple files match the pattern. For example, use “*a.zip” (without the quotation marks) to specify any file that ends with “a.zip”. A file named “testa.zip would match. There could be any number (of any type) of characters in front of the “a.zip” at the end and the file name would still match. A file named “test.zipa” for example would not match. • A * in the middle of a pattern has the Zyxel Device check the beginning and end of the file name and ignore the middle. For example, with “abc*.zip”, any file starting with “abc” and ending in “.zip” matches, no matter how many characters are in between. • The whole file name has to match if you do not use a question mark or asterisk. • If you do not use a wildcard, the Zyxel Device checks up to the first 80 characters of a file name. |
