Label | Description |
Collect Statistics | |
Enable | Enable to have the Zyxel Device collect app patrol statistics. All of the statistics are erased if you restart the Zyxel Device or click Flush Data in Security Statistics > App Patrol. |
Analyze All Traffic | Enable to have the Zyxel Device collect app patrol statistics from all Zyxel Device traffic. Disable to have the Zyxel Device only collect app patrol statistics from the traffic that matches the policy control rules with app patrol profiles applied. For example, if you create an app patrol profile and apply it to the policy control rule LAN_Outgoing, the Zyxel Device will only collect app patrol statistics from the traffic that matches the policy control rule LAN_Outgoing. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Select an entry and click Edit to open a screen where you can modify the entry’s settings. |
Remove | Select an entry and click Remove to delete the selected entry. |
Reference | Select an entry and click Reference to check which settings use the entry. |
Name | This displays the name of the profile created. |
Description | This displays the description of the App Patrol Profile. |
Reference | This displays the number of times an object reference is used in a profile. |
Action | Click this icon to apply the entry to a policy control rule. Go to the Security Policy > Policy Control screen to check the result. |
Signature Information | The following fields display information on the current signature set that the Zyxel Device is using. |
Current Version | This field displays the App Patrol signature set version number. |
Released Date | This field displays the date and time the set was released. |
Update Signatures | Click this link to go to the screen you can use to download signatures from the update server. |
General Settings | |
Name | Type the name of the profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names: • MyProfile • mYProfile • Mymy12_3-4 These are invalid profile names: • 1mYProfile • My Profile • MyProfile? • Whatalongprofilename123456789012 |
Description | Type a description for the profile rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. This field is optional. |
Allow only selected apps (with allowed actions) | Enable this to have the Zyxel Device drop packets from applications that are not included in this profile and send a TCP RST or ICMP host unreachable message to both the sender and receiver. |
Rejected unrecognized apps | Enable this to have the Zyxel Device drop packets from applications that are not recognized and send a TCP RST or ICMP host unreachable message to both the sender and receiver. |
Log rejected apps | Enable this to have the Zyxel Device generate a log when it rejects applications that are not included in this profile or are unrecognized. |
Application Management | |
Add | Click Add to create a new profile. |
Remove | To remove a profile, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Active | To turn on an entry, select it and click Active. The Status light changes accordingly. |
Inactive | To turn off an entry, select it and click Inactive. The Status light changes accordingly. |
Edit | Select an entry and click this icon to modify it. ![]() |
Remove | Select an entry and click this icon to delete it. ![]() |
Save Changes | Click this icon to save the changes in this row. ![]() |
Cancel Changes | Click this icon to cancel the changes in this row. ![]() |
Log | Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) by default when traffic matches a signature in this category. |
Action | Select the default action for all signatures in this category. forward - the Zyxel Device routes packets that matches these signatures. drop - the Zyxel Device silently drops packets that matches these signatures without sending a TCP RST or ICMP host unreachable message to both the sender and receiver. reject - the Zyxel Device drops packets that matches these signatures and sends a TCP RST or ICMP host unreachable message to both the sender and receiver. |
Priority | This field is a sequential value showing the number of the profile. The ordering of your profiles is important as profiles are applied in sequence. |
Status | |
Category | This field displays the category type of the application. |
Application | This field displays the application name or numbers of applications included in the policy. |
Action | Select the default action for all signatures in this category. forward - the Zyxel Device routes packets that matches these signatures. drop - the Zyxel Device silently drops packets that matches these signatures without notification. reject - the Zyxel Device drops packets that matches these signatures and sends notification. |
Apply | Click Apply to save your settings to the Zyxel Device. |
Cancel | Click Cancel to return to the profile summary page without saving any changes. |
profile name | application | action | log |
BlockMedia | TikTok | Reject | Log Alert |
to | from | log | app patrol profile |
WAN | LAN | By Profile | BlockMedia |
