BWM (Bandwidth Management)
Overview
Bandwidth management provides a convenient way to manage the use of various services on the network. It manages general protocols (for example, HTTP and FTP) and applies traffic prioritization to enhance the performance of delay-sensitive applications like voice and video.
Use the BWM screens to control bandwidth for services passing through the Zyxel Device, and to identify the conditions that define the bandwidth control.
What You Need to Know
When you allow a service, you can restrict the bandwidth it uses. It controls TCP and UDP traffic. Use policy routes to manage other types of traffic (like ICMP).
*Bandwidth management in policy routes has priority over TCP and UDP traffic policies.
If you want to use a service, make sure both the security policy allow the service’s packets to go through the Zyxel Device.
*The Zyxel Device checks security policies before it checks bandwidth management rules for traffic going through the Zyxel Device.
Bandwidth management examines every TCP and UDP connection passing through the Zyxel Device. Then, you can specify, by port, whether or not the Zyxel Device continues to route the connection.
Upload and Download Bandwidth Limits
You can limit an application’s upload or download bandwidth. This limit keeps the traffic from using up too much of the upload interface’s bandwidth. This way you can make sure there is bandwidth for other applications. When you apply a bandwidth limit to upload or download traffic, each member of the upload zone can send up to the limit. Take a LAN to WAN policy for example.
Upload traffic is limited to 200 kbps. The connection initiator is on the LAN1 so upload means the traffic traveling from the LAN1 to the WAN. Each of the WAN zone’s two interfaces can send the limit of 200 kbps of traffic.
Download traffic is limited to 500 kbps. The connection initiator is on the LAN so download means the traffic traveling from the WAN to the LAN.
Bandwidth Management Priority
The Zyxel Device gives bandwidth to higher-priority traffic first, until it reaches its configured bandwidth rate.
Then lower-priority traffic gets bandwidth.
The Zyxel Device uses a priority queueing scheduler to divide bandwidth among traffic flows with the same priority.
The Zyxel Device automatically treats traffic with bandwidth management disabled as priority 7 (the lowest priority).
Configured Rate Effect
In the following table the configured rates total less than the available bandwidth and maximize bandwidth usage is disabled, both servers get their configured rate.
Policy
Configured RAte
Max. bandwidth usage
priority
Actual rate
A
300 kbps
No
300 kbps
B
200 kbps
No
200 kbps
Priority and Over Allotment of Bandwidth Effect
Server A has a configured rate that equals the total amount of available bandwidth and a higher priority. You should regard extreme over allotment of traffic with different priorities (as shown here) as a configuration error. Even though the Zyxel Device still attempts to let all traffic get through and not be lost, regardless of its priority, server B gets almost no bandwidth with this configuration.
Policy
Configured RAte
priority
Actual rate
A
1000 kbps
Yes
999 kbps
B
1000 kbps
Yes
2
1 kbps
Limit the Bandwidth for a Specific VLAN
If you want to limit the bandwidth for a specific VLAN, set the VLAN as the incoming interface and VPN as the outgoing interface. Then, set the bandwidth limit for this BWM rule.
The Bandwidth Management Configuration
The Bandwidth management screens control the bandwidth allocation for TCP and UDP traffic. You can use incoming interface, outgoing interface, user, source, destination information, application, and service type as criteria to create a sequence of specific conditions, similar to the sequence of rules used by firewalls, to specify how the Zyxel Device allocates bandwidth for the matching packets.
This screen allows you to enable/disable bandwidth management and add, edit, and remove user-defined bandwidth management policies.The default bandwidth management policy is the one with the priority of “default”. It is the last policy the Zyxel Device checks if traffic does not match any other bandwidth management policies you have configured. You cannot remove, activate, deactivate or move the default bandwidth management policy.
Network > Bandwidth Management
Label
Description
Enable
Click to slide the switch to the right to activate bandwidth management on the Zyxel Device.
Add
Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Move to
To change an entry’s position in the numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed.
Status
The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. The status icon is not available for the default bandwidth management policy.
Pri (Priority)
This field displays a sequential value for each bandwidth management policy and it is not associated with a specific setting.
This field displays default for the default bandwidth management policy.
Name
This is the name of the BWM rule.
Description
This field displays additional information about this policy.
User
This is the type of user account to which the policy applies. If any displays, the policy applies to all user accounts.
Incoming Interface
This is the source interface of the traffic to which this policy applies.
Outgoing Interface
This is the destination interface of the traffic to which this policy applies.
Source
This is the source address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. If any displays, the policy is effective for every source.
Destination
This is the destination address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. If any displays, the policy is effective for every destination.
Service
App and the service name displays if you selected Application Object for the service type. An Application Object is a pre-defined service.
Obj and the service name displays if you selected Service Object for the service type. A Service Object is a customized pre-defined service or another service. Mouse over the service object name to view the corresponding IP protocol number.
BWM Download/Upload/Pri
This field shows the amount of bandwidth the traffic can use.
Download - This is how much inbound bandwidth, in megabits per second, this policy allows the matching traffic to use. Inbound refers to the traffic the Zyxel Device sends to a connection’s initiator. If 0 displays here, it means the download traffic has reached the maximum capacity the Zyxel Device can transmit.
Upload - This is how much outbound bandwidth, in megabits per second, this policy allows the matching traffic to use. Outbound refers to the traffic the Zyxel Device sends out from a connection’s initiator. If 0 displays here, it means the upload traffic has reached the maximum capacity the Zyxel Device can transmit.
Pri - This is the priority for the inbound or outbound traffic that matches this policy. The smaller the number, the higher the priority. Traffic with a higher priority is given bandwidth before traffic with a lower priority.
Apply
Cancel
Click Cancel to return the screen to its last-saved settings.
The Bandwidth Management Add/Edit Screen
The Network > BWM > Add/Edit screen allows you to create a new condition or edit an existing one.
The first BWM policy is the default and can only be edited.
Label
Description
Configuration
Enable
Select this check box to turn on this policy.
Name
Enter a name to identify the BWM rule. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
Description
Enter a description of this policy. It is not used elsewhere. You can use alphanumeric and ()+/:+?!*#@$_%- characters, and it can be up to 60 characters long.
BWM Type
The Shared BWM type is selected by default in a bandwidth management rule. All matched traffic shares the bandwidth configured in the rule.
If the BWM type is set to Per user in a rule, each user that matches the rule can use up to the configured bandwidth by his/her own. If you select this, the User field below cannot be any.
Select the Per-Source-IP type when you want to set the maximum bandwidth for traffic from an individual source IP address object. Only address objects with fewer than 1,024 IP addresses are available from the Source filed below. If you select this, the Source field below cannot be any.
Criteria
Use this section to configure the conditions of traffic to which this policy applies.
Incoming Interface
Select the source interface of the traffic to which this policy applies.
Outgoing Interface
Select the destination interface of the traffic to which this policy applies.
Source
Select a source address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Use Create new Object if you need to configure a new one. Select any if the policy is effective for every source.
Destination
Select a destination address or address group, including geographic address and FQDN (group) objects, for whom this policy applies. Use Create new Object if you need to configure a new one. Select any if the policy is effective for every destination.
Service Type
Select Service Object or Application Group if you want a specific service (defined in a service object) or application patrol service to which the policy applies.
Service Object
This field is available if you selected Service Object as the service type.
Select a service or service group to identify the type of traffic to which this policy applies. any means all services.
Application Group
This field is available if you selected Application Group as the service type.
Select an application to identify the specific traffic to which this policy applies.
If you select BitTorrent, it includes the services listed below at the time of writing:
BitTorrent
BitTorrent_FileTransfer
BitTorrent_Application
BitTorrent_Bundle
User
Select a user name or user group to which to apply the policy. Use Create new Object if you need to configure a new user account. Select any to apply the policy for every user.
Schedule
If you already created a One Time or Recurring schedule in Object > Schedule, then select a schedule that defines when the policy applies. Alternatively, select Create Object to configure a new schedule. Otherwise, select none to make the policy always effective.
Traffic Shaping
Configure these fields to set the amount of bandwidth the matching traffic can use.
Download Limit (Mbps)
Type how much inbound bandwidth, in megabits per second, this policy allows the traffic to use. Inbound refers to the traffic the Zyxel Device sends to a connection’s initiator.
Select Unlimited to apply bandwidth management for the matching traffic which is the maximum amount your Zyxel Device can transmit.
Select Limited to apply bandwidth management for matching traffic, and enter a number from 1 to 10,000 Mbps.
*Traffic matching a Limited policy may “borrow” all unused bandwidth on the inbound interface.
If the sum of the bandwidths for routes using the same next hop is higher than the actual transmission speed, lower priority traffic may not be sent if higher priority traffic uses all of the actual bandwidth.
Upload Limit (Mbps)
Type how much outbound bandwidth, in megabits per second, this policy allows the traffic to use. Outbound refers to the traffic the Zyxel Device sends out from a connection’s initiator.
*Traffic matching a Limited policy may “borrow” all unused bandwidth on the upload interface.
Priority
Choose a number between 0 and 7 to set the priority for traffic that matches this policy. The smaller the number, the higher the priority. 0 is for real-time traffic such as video, and 7 is for lowest priority traffic such as background traffic.
Traffic with a higher priority is given bandwidth before traffic with a lower priority. When traffic with higher priority has reached the full bandwidth, the traffic with lower priority can use the remaining bandwidth.
The Zyxel Device uses priority queueing scheduler to divide bandwidth between traffic flows with the same priority.
The number in this field is ignored if the download and upload limits are both set to Unlimited.
Related Setting
Log
Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) when any traffic matches this policy.
Apply
Cancel
Adding Objects for the BWM Policy
Objects are parameters to which the Policy rules are built upon. You can add/edit User and Address objects for the BWM policy.
User Objects
The following table describes the fields in the above screen.
Network > BWM > Create New Object > Add User
Label
Description
User Name
Type a user or user group object name of the rule.
User Type
Select a user type from the drop down menu. The user types are Admin, Limited admin, User, Guest, Ext-user, Ext-group-user.
Password
Type a password for the user object. The password can consist of alphanumeric characters, the underscore, and some punctuation marks (+-/*= :; .! @$&%#~ ‘ \ () ), and it can be up to eight characters long.
Retype
Retype the password to confirm.
Description
Save
Click Save to save the setting.
Cancel
User Group Objects
Network > BWM > Create New Object > Add User Group
Label
Description
Name
Type a user group name of the object.
Description
Member List
Select the users or user groups that will be in this user group.
Save
Cancel
Address Objects
Network > BWM > Create New Object > Add Address
Label
Description
Name
Enter a name for the Address object of the rule.
Address Type
Select an Address Type from the drop down menu on the right. The Address Types are Host, Range, Subnet, Interface IP, Interface Subnet, and Interface Gateway.
IP Address
Enter an IP address for the Address object.
Save
Cancel
Address Group Objects
Network > BWM > Create New Object > Add Address Group
Label
Description
Name
Type an address group name of the object.
Description
Enter a description of this object. It is not used elsewhere. You can use alphanumeric and ()+/:+?!*#@$_%- characters, and it can be up to 60 characters long.
Member List
Select the address objects that will be in this user group.
Save
Cancel
Example: Prioritize a Specific Application
You are a client on the Zyxel Device LAN. You use Teams to communicate with your colleagues and have video meetings often at work. You want to create a bandwidth management rule to prioritize traffic for Teams so that you can always use Teams without any delay.
This example uses the parameters given below.
BWM Example
description
service type
service object
guaranteed bandwidth
Teams
Application Group
Teams
Download 20 mbps/ Priority: 1
Upload: 20 mbps/ Priority: 1
1 Go to Network > BWM . Click Add to create a bandwidth management rule using the parameters given in BWM Example.
2 Select Teams under Application Group.
3 Click Apply to save your changes.
4 The traffic for Teams is now at the highest priority to use the Zyxel Device bandwidth.
